LogicPDTIAM3517MCU应用产品开发方案(上)
最新更新时间:2012-04-26来源: OFweek 关键字:3D  Android™  白色家电 手机看文章 扫描二维码
随时随地手机看文章
TI公司的AM3517/05是工作频率高达600MHz的高性能ARM Cortex-A8微处理器,提供3D图像加速和支持包括DDR2, CAN, EMAC以及USB OTG PHY等多种外设,并支持 Linux®, Windows® CE和Android™操作系统,主要应用工业控制,单板机,工业和家庭自动化, 智能白色家电,DTV,PMP,数字摄像机,游戏机和交通等. Logic PD公司的基于TI公司AM3517的可用于生产的软件和硬件平台Zoom AM3517 EVM,包括Logic PD的系统模块(SOM-M2), AM3517应用开发板以及Zoom AM3517 eXperimenter基板.本文介绍了AM3517/05主要特性, 功能方框图以及Zoom™ AM3517 EVM开发套件主要特性,框图,电路图,材料清单和PCB元件布局图.
AM3517/05 is a high-performance ARM Cortex-A8 microprocessor with speeds up to 600 MHz. The device offers 3D graphics acceleration while also supporting numerous peripherals, including DDR2, CAN, EMAC, and USB OTG PHY that are well suited for industrial apllications.
The processor can support other applications, including:
• Single Board Computers
• Home and Industrial automation
• Human Machine Interface
The device supports high-level operating systems (OSs), such as:
• Linux®
• Windows® CE
• Android™
The following subsystems are part of the device:
• Microprocessor unit (MPU) subsystem based on the ARM Cortex-A8 microprocessor.
• PowerVR SGX™ Graphics Accelerator (AM3517 device only) Subsystem for 3D graphics acceleration to support display and gaming effects.
• Display subsystem with several features for multiple concurrent image manipulation, and a programmable interface supporting a wide variety of displays. The display subsystem also supports NTSC/PAL video out.
• High performance interconnects provide high-bandwidth data transfers for multiple initiators to the internal and external memory controllers and to on-chip peripherals. The device also offers a comprehensive clock-management scheme.
AM3517/05 devices are available in a 491-pin BGA package and a 484-pin PBGA package.
This AM3517/05 data manual presents the electrical and mechanical specifications for the AM3517/05 Sitara ARM Microprocessor.
AM3517/05主要特性:
AM3517/05应用:
• Transportation
• Industrial and Home Automation
• Navigation
• Digital Signage
• Smart White Goods
• Point of Service
• Digital TV
• Portable Media Player
• Digital Video Camera
• Portable Industrial
• Gaming
图1.AM3517/05功能方框图
Logic PD’s product-ready software and hardware platforms fast forward your product development while reducing risk and controlling costs. The Zoom AM3517 EVM Development Kit is a high-performance application development kit for evaluating the functionality of Texas Instruments’ Sitara AM3517 microprocessor and Logic PD’s System on Module (SOM).
Application development is performed right on the product-ready AM3517 SOM-M2 and software Board Support Packages (BSPs) included with the kit, which enables you to seamlessly transfer your application code and hardware into production. The included SOM provides easy evaluation of the AM3517 processor.
The AM3517 SOM-M2 is ideal for applications that require high-performance graphics, including applications that require OpenVG and OpenGLES1.1 & 2.0 acceleration. The AM3517 includes an SGX530 graphics accelerator and multiple communication ports including wireless 802.11 b/g/n and wired 10/100 Ethernet peripherals. For commercial signage, medical imaging, avionics, and industrial displays, the AM3517 SOM2 allows for powerful versatility, long-life, and greener products.
The Zoom AM3517 EVM Development Kit includes the AM3517 SOM-M2, baseboard, application board, accessories, and software required to immediately begin development work.
图2. AM3517 EVM系统模块(SOM)外形图
AM3517 EVM开发套件包括:
Includes AM3517 SOM-M2
256 MB DDR2 SDRAM
512 MB NAND flash
Wireless 802.11b/g/n
Bluetooth 2.1 + EDR interface
Software and Tools
Android demo and development kiton SD card
Linux demo and SDKon SD card
Windows Embedded CE demo and SDKon SD card
U-Boot (bootloader/monitor)
CodeSourcery G++ Lite and Commercial Tools - Evaluation DVD
Ubuntu 10.04 LTS Desktop Edition CD
Windows Embedded CE 6.0 180-day Evaluation Kit
Board Support Library (BSL) sample programs
Timesys Linux BSP
Supports QNX Neutrino RTOS
Baseboard Features
Display
Integrated LCD, touch, and backlight connector for optional Zoom Display Kits
4.3" WQVGA LCD panel with 4-wire resistive touchscreen
HDMI 24 bpp video-out interface (video only)
Network/USB/Serial Connectors
One RJ45 Ethernet jack connector
One USB 2.0 high-speed On-the-Go mini AB connector
One USB 2.0 full-speed host Type A connector
115.2kbps RS-232 debug serial port
One USB/UART debug serial port
PC Card Expansion
One MMC/SD card slot
Debug
Connectors for JTAG interface
Application Board Features
Audio
Two stereo-out mini-headphone jacks
One stereo-in mini-headphone jack
Two powered mic inputs
Video
S-Video in connector (TVP5146)
Component video in connector (TVP5146)
Composite RGB video in connectors (TVP5146)
Parallel camera interface
Keypad
Keypad with function-specific keys
5-way jog-knob dial
Network/ Connectors
Dual RJ45 Ethernet jacks connected via hub
One USB 2.0 high-speed host Type A connector
PC Card Expansion
One SD/MMC card slot
Cables
USB SD card reader
Null-modem serial cable
Ethernet crossover cable
USB A to mini-B cable
USB A to B cable
U.FL to RP-SMA 80 mm RF cable and 2.4 GHz, 2 dBi whip antenna
5 volt power supply and cord
Power converter
Mechanical Specs
RoHS compliant
图3. AM3517 SOM方框图
图4. AM3517 SOM电路图(1)
图5. AM3517 SOM电路图(2)
图6. AM3517 SOM电路图(3)
图7. AM3517 SOM电路图(4)
图8. AM3517 SOM电路图(5)
图9. AM3517 SOM电路图(6)
图10. AM3517 SOM电路图(7)
图11. AM3517 SOM电路图(8)
图12. AM3517 SOM电路图(9)
图13. AM3517 SOM电路图(10)
AM3517 SOM材料清单:
图14. AM3517 SOM PCB元件布局图:顶层
图15. AM3517 SOM PCB元件布局图:底层
图16. 4.3” WQVGA LCD适配器板电路图(1)
图17. 4.3” WQVGA LCD适配器板电路图(2)
图18. 4.3” WQVGA LCD适配器板电路图(3)
4.3” WQVGA LCD适配器板材料清单:
关键字:3D  Android™  白色家电 编辑:探路者 引用地址:LogicPDTIAM3517MCU应用产品开发方案(上)
上一篇:便携产品EMI滤波解决方案
下一篇:桥式起重机无线遥控电气系统的设计
推荐阅读最新更新时间:2023-10-18 16:41
摩托罗拉edge 30 Pro曝光:搭载骁龙8 Gen 1,装Android12
摩托罗拉 moto edge X30 于 12 月 9 日发布,搭载全新一代骁龙 8 Gen 1 处理器,首发价 2999 元起,据传它将在国际市场上以 Edge 30 Ultra 的名称推出。   现有网友发现,一款显示为 Moto Edge 30 Pro 的机型出现在了 Geekbench 基准测试平台上,透露了该设备的一些关键细节。让我们一起来看看。   摩托罗拉 Edge 30 Pro 规格   摩托罗拉 Edge 30 Pro 搭载的依然是高通最新的骁龙 8 Gen 1 SoC,主频为 3.0GHz 的 1+3+4 集群,具有三个主频为 2.5GHz 的性能内核和四个主频为 1.79GHz 的效率内核。   此
[手机便携]
摩托罗拉edge 30 Pro曝光:搭载骁龙8 Gen 1,装<font color='red'>Android</font>12
Android下一代 大小通吃
       Google Android全球合作伙伴关系总监John Lagerling表示,Android操作系统新版本Ice Cream Sandwich(冰淇淋三明治)将于下半年问世。他认为台湾的宏碁、华硕及中国联想等计算机品牌业者的优势为低成本结构及强有力的通路,今的圣诞节旺季,他相当看好亚洲计算机制造商的表现。      Google的开放式操作系统Android目前已经推出6个版本,前5个版本都是以智能型手机为主,包括宏达电、宏碁、华硕、Moto、LG、三星等都是Google的合作伙伴。而今年推出了的Android 3.0、代号为Honeycomb操作系统,适用于平板计算机产品。      John Lagerling
[手机便携]
5月28日Google I/O 传Android M即将登台
   本月底Google I/O开发者大会将要拉开帷幕,据说Android M也将在Google I/O中简要亮相。目前我们还并不清楚关于Android M的任何细节,只知道Android M可以将“Android的能力运用到各种工作场合中”。 5月28日Google I/O 传Android M即将登台     在Google I/O中发布新的Android版本,应该说是意料之中的,毕竟过去几年我们都是这么过来的。在去年,Google先在Google I/O中以“Android L”的形式让我们预览了Android 5.0的特性,不知道今年的Android M又会有怎样的惊喜。   不过不得不说,一个新版本的迭代必
[手机便携]
基于Android平台的即时通信系统客户端设计
引言   Android 是Google 推出的一个基于Linux 操作系统, 包含底层框架, 中间件和开发环境的一套平台系统。它支持流行的组件式程序设计, 具有针对性移动设备的Dalvik 虚拟机。浏览器核心是基于开源的WebKit 引擎, 对基于HTML 的各种语言具有良好的支持。图像引擎使用基于openGLES1. 0 的三维图形库。本文的研究目的就是基于Android 平台, 提出一种能为多种移动客户端提供即时通信服务系统的客户端解决方案。   1 系统开发环境   Android 的应用开发使用Java 语言环境下Android 应用开发工具和API 接口,包括支持各种分辨率的设备模拟器、调试工具
[工业控制]
基于<font color='red'>Android</font>平台的即时通信系统客户端设计
官方宣布锤子T1无缘安卓5.1升级
    刚刚过去的一周,锤子科技凭借全新的Smartisan T2可谓刷爆了屏,而有幸在第一时间获得系统更新的坚果手机,也在系统响应方面有了比较明显的提升。就在所有的T1用户期待系统更新的时候,锤子科技关于Smartisan T1(以下简称锤子T1)无法升级Android 5.1平台的消息再度引发热议,这也意味着锤子T1只能继续运行比较老旧的Android 4.4平台了。   按照锤子科技官方的说法,锤子T1将继续沿用Android 4.4内核,不会得到系统平台升级,直到2017年5月19日结束维护。据了解,不升级的原因是“安卓5.1内核对Smartisan T1这类的高配置芯片手机的优化效果不明显”,而对“芯片相对低端的坚
[手机便携]
Android Wear销量不佳 前景堪忧
   Android Wear装置当中最受欢迎的就是采用圆形萤幕的Moto 360。(图/新浪科技) 想跟上流行、下手购买智慧手表吗?或者看完以下的报告,会让你有不同的想法! 根据市场研究公司Canalys所公布的报告,2014年Google的Android Wear设备,仅占智慧可穿戴装置市场的15.6%,6款搭载Android Wear的出货量仅72万只,而这类设备的出货总量则是460万只。 Canalys分析师Chris Jones指出“Android Wear设备的市场表现,将会低于Google的预期。因为Android Wear设备过于强化接收通知的功能,导致耗电量大幅上升。为了加强Android
[手机便携]
Onyx Connect将成为非洲首家Android手机制造公司
集微网消息,据海外媒体报道,南非约翰尼斯堡新创公司Onyx Connect将成为首家在非洲制造智能型手机的公司。该公司将利用当地的低成本和不断成长的需求打造Android手机、平板电脑和其他装置。 根据彭博(Bloomberg)报导,Onyx已筹得1.5亿兰德(约1,080万美元)资金,预计将在2017年第1季开始生产Android手机。该公司已获Google授权,可在自有品牌产品或为其他公司代工的产品上加载Android、Chrome等Google软体。 Onyx销售主管Andre Van der Merwe表明,Onyx正在与Google、Vodacom和Vodafone南非分公司讨论制造手机、笔记型电脑和Android机上盒
[手机便携]
Android平台:人机界面开发的四个要点
  Android现已开始供货。它现在是什么样子?通过专注于用户界面(UI)的开发,如何最大化用户的体验?下面是四条重要的诀窍。 开源和人机界面的一致性   从多方面来看,Android是一种革命性的开源平台,作为开发商在创造更新以及创新服务和应用上有着许多的自由度。为了把G1 Android UI做的尽可能一致,人们已经付出了大量的努力。然而,当在一个开源的环境中工作时,要维持界面和用户体验上高水平的一致性是棘手的。开发商可以(并且应该)自由地选择各种应用软件,让它们看起来应该如何以及如何表现。从产品的观点来看,要保持每一个应用软件的设计与外表、以及对基本操作平台的感觉的紧密关系是至关重要的。用户界面需要一致且可预测
[焦点新闻]
小广播
最新电源管理文章
换一换 更多 相关热搜器件
