STSTEVAL-ISV002V23kW光伏电压转换解决方案
最新更新时间:2012-05-09来源: 21IC关键字:电源管理  太阳能  DC/DC 手机看文章 扫描二维码
随时随地手机看文章
ST公司的 STEVAL-ISV002V2 是能连接到电网的3kW光伏电压转换器开发板,包括高频绝缘输入功率部分(实现DC/DC转换)和逆变器部分(提供50Hz正弦波电流到电网),输入电压范围从200V到400V,系统输出通过LCL滤波器以230Vrms 50Hz连到电网,正常输出功率3kW.本文介绍了STEVAL-ISV002V2 主要特性,硬件方框图,控制方框图和MPPT算法方框图,以及系统指标,完整电路图和材料清单.
Interest in photovoltaic (PV) applications has grown exponentially in recent years. As PV systems require an electronic interface to be connected to the grid or standalone loads, the PV market is increasingly appealing for many power electronics manufacturers.
The STEVAL-ISV002V2 demonstration board implements a conversion system for PV applications with the aim of achieving high efficiency and significant reduction in production costs. It consists of a high-frequency isolated input power section which performs the DC-DC conversion, and an inverter section capable of delivering sinusoidal current at 50 Hz to the grid.
The system operates with input voltages in the range of 200 V to 400 V, and is tied to the grid at 230 Vrms, 50 Hz, through an LCL filter.
Other unique characteristics of the proposed converter are integration level, decoupled active and reactive power control and flexibility towards the source.
A fully digital control algorithm, including power management for grid-connected operation and MPPT (maximum power point tracking) algorithm, has been implemented on a dedicated control board, equipped with a latest-generation 32-bit (STM32) microcontroller.
STEVAL-ISV002V2 主要特性:
■ DC-DC input voltage: 200 V to 400 V
■ DC-DC output voltage: 450 V
■ DC-AC output voltage: 230 Vac
■ Nominal output power: 3 kW
■ DC-AC switching frequency: 17 kHz
■ DC-DC switching frequency: 35 kHz
■ Transformer turns ratio: 1.2
■ Grid voltage: 230 Vrms +/-20%
■ Grid frequency: 50 Hz
■ Power factor: above 10%; rated power > 0.9
■ THD @ full load: < 5%
■ RoHS compliant
图1.STEVAL-ISV002V2外形图
图2.STEVAL-ISV002V2硬件方框图
图3.STEVAL-ISV002V2控制方框图
图4.STEVAL-ISV002V2 MPPT算法方框图
STEVAL-ISV002V2包括:
It consists of 5 PCBs electrically connected by means of suitable connectors. The 5 PCBs are listed below and are hereafter referred to with the following nomenclature:
● Main power board
● Multi-output power supply board
● Control and signal conditioning board
● Output sensing and relay board
● Input current sensing board
STEVAL-ISV002V2系统指标:
图5.STEVAL-ISV002V2电路图:功率级
图6.STEVAL-ISV002V2电路图:输出检测和继电器板
图7.STEVAL-ISV002V2电路图:AC电压测量
图8.STEVAL-ISV002V2电路图:线电流调理电路
图9.STEVAL-ISV002V2电路图:STM32 MCU电路
图10.STEVAL-ISV002V2电路图:DC/DC转换器驱动电路
图11.STEVAL-ISV002V2电路图:DC/AC转换器驱动电路
图12.STEVAL-ISV002V2电路图:5V 1A反馈转换器和VIPER17HN电路
图13.STEVAL-ISV002V2电路图:多输出反馈转换器和VIPER27HN电路
STEVAL-ISV002V2材料清单:
详情请见:
http://www.st.com/internet/com/TECHNICAL_RESOURCES/TECHNICAL_LITERATURE/USER_MANUAL/CD00288488.pdf
http://www.st.com/internet/com/TECHNICAL_RESOURCES/TECHNICAL_DIAGRAM/SCHEMATICPACK/steval-isv002v2_schematic.pdf
以及
http://www.st.com/internet/com/TECHNICAL_RESOURCES/TECHNICAL_SPECIFICATION/BILL_OF_MATERIALS/steval-isv002v2_bom.pdf
http://www.st.com/internet/com/TECHNICAL_RESOURCES/TECHNICAL_LITERATURE/APPLICATION_NOTE/CD00253868.pdf
关键字:电源管理  太阳能  DC/DC 编辑:探路者 引用地址:STSTEVAL-ISV002V23kW光伏电压转换解决方案
上一篇:大电流变流装置过电压智能保护模块设计
下一篇:采用 6.25mm x 11.25mm BGA 封装的LTM8029
推荐阅读最新更新时间:2023-10-18 16:44
罗姆宣布推出适合22nm Atom平台电源管理芯片
日前,罗姆半导体宣布为Intel 22nm Atom平台开发一款新的电源管理平台Bay Trail,罗姆表示该PMIC适合超薄平板电脑或其他可携带设备。 上月,Dialog半导体宣布推出过类似PMIC。 “我们的PMIC产品不仅是一款设计成功的IC,同时也是协助英特尔进军高端平板电脑领域的重要产品,我们的芯片不但可以使电池寿命更长,同时提高了芯片组的集成度。”罗姆半导体表示。 英特尔平板电脑平台开发总监表示:“英特尔非常欢迎罗姆作为我们生态系统供应商的一部分,为下一代英特尔Atom平台提供具有竞争力的电源管理解决方案。”
[手机便携]
DAS的废气处理理念
中国上海—3月10 日讯 — 持续改善太阳能电池效率是环保节能的关键所在,对中国光伏行业制造商也不例外,他们大多数拥有自己的研发设施,并与工艺主设备供应商合作,寻找最佳的工艺方式。 成品整体性能的关键成功因素取决于防反射涂层与太阳能晶圆钝化,但这一工艺步骤也会产生一些关键的废气。DAS Environmental Expert公司与太阳能行业的客户密切合作,为客户在批量生产前及时提供DAS最优的尾气处理概念来对新工艺进行配套支持。 该领域的一项最新成果是DAS尾气处理系统STYRAX——一项专为光伏行业高要求的工艺流程而优化的燃烧/湿洗解决方案。该设备已在中国太
[半导体设计/制造]
DAS的废气处理理念
反击美日,中国拟限制稀土元素、太阳能技术出口
目前,中国正在制定一项禁令,将停止出口用于电动车(EV)高效能磁铁生产的稀土元素,太阳能面板相关生产技术也包括在内。 据日经新闻(Nikkei)、路透(Reuters)等报导,我国在2008年公布的禁止出口名单中,已列入稀土的加工、合金等技术。2020年曾修订过一次。 到了2022年底,商务部、科学技术部公布新的禁止与限制出口的技术名单,有43个追加与修正项目,其中就包含稀土的精炼与加工等细项。 以稀土元素来生产的高效能磁铁之中,必须使用某一种合金,此一合金的生产技术,在这次的修订案中,列入禁止与限制出口的项目。 这项新的禁止与限制出口名单,已走完专家会议意见讨论的阶段,最快将在2023年内完成手续并开始实施。
[汽车电子]
浅谈太阳能发电系统控制板的设计
0 引言   近年来,随着人们对环境问题的关注,地球对于清洁能源的要求也越来越高。本公司一直致力于研发太阳能发电的功率调节系统(PCS)。   结合太阳能发电系统控制板的研发案例,针对并联多个太阳能电池板的系统进行调整的问题,本文就降低成本和增设并联个数的方法进行介绍。   1 系统概要   图1为大规模太阳能发电系统的原理框图。      该系统的特点是,太阳能电池板和单元逆变器分组与系统相连(AC连接),将系统保护等信息汇总后作为信号发送到主控制器,并由此控制器控制各单元逆变器(通过RS485通信连接到菊花链连接)。   每个单元逆变器的控制部分如图2所示。      通过使用
[电源管理]
浅谈<font color='red'>太阳能</font>发电系统控制板的设计
反激式PWM DC/DC转换器
  反激式PWM转换器《单端隔离式PWM DC/DC转换器》如图(b)所示。实际上就是隔离式(有双绕组的)Buck Boost转换器。反激式转换器的电路特点是 电路简单,所用元器件的数量最少,一般多用于小功率(如100W)和多路输出的场合。   反激式转换器的工作原理是:当主开关管导通时变压器次级侧的二极管关断,变压器储能;在主开关管关断时,变压器次级侧二极管导通, 变压器的储能向负载释放。它与正激式转换器不同之处是,正激式转换器的变压器励磁电流储能一般很小,各绕组瞬时功率的代数和为零,变 压器只起隔离、变压的作用。而反激式转换器的变压器比较特殊,它兼有储能电感的作用,是一种储能式变压器(或电感式变压器)。为了防
[电源管理]
反激式PWM <font color='red'>DC</font>/<font color='red'>DC</font>转换器
电源管理芯片厂商芯龙半导体宣布全线产品涨价了!
5月6日,上海芯龙半导体技术股份有限公司(以下简称“芯龙半导体”)发布产品价格调整通知称,由于产品的上游原材料等成本持续上涨,且产能紧张、投产周期延长,导致我司产品成本多次大幅上升。为了更好的服务客户,确保产品的持续供应,缓解采购成本多次上升带来的压力,经过谨慎评估考虑,根据上游供应商价格上调的实际情况,本着共同发展,合作共赢的原则,我司决定对全线产品价格进行调整。 资料显示,上海芯龙半导体技术股份有限公司是一家专业从事电源管理类模拟集成电路开发的设计公司;芯龙的核心研发和管理团队由一批来自业界半导体设计公司的资深专家组成;芯龙将业界先进的设计技术与亚太地区的本土优势产业链相结合,服务全球市场,为客户提供快速、高效、高性价比的
[手机便携]
<font color='red'>电源管理</font>芯片厂商芯龙半导体宣布全线产品涨价了!
电源管理要过节能降耗关
待机能耗问题目前已成为国际社会普遍关注的热门话题,降低家用电器待机能耗不仅意味着为消费者节省用电开支,对缓解日趋紧张的能源压力有积极作用,更直接的是减少了能源浪费和环保压力。由中国电子商会电源专业委员会、北京电源行业协会联合主办的2006第五届中国国际电源产业展览会暨2006中国北京国际节电技术及设备展览会日前在北京举行。根据家用电器的特点,探索降低家用电器待机功耗的电源管理技术,提供切实可行的解决方案,将是全球相关行业面临的机遇和挑战。    市场政策双驱动   现在提高用电效率,降低待机功耗已成为全世界节能和应对能源危机的必由之路,很多国家都在终端电子产品上强制推行高效节能标准,如美国的“能源之星”、德国的“
[电源管理]
使用STM32ADC看门狗测量出待测信号
我们在做ADC应用时,有些场合需要精确测量出待测信号的数据,有时可能并不关心ADC结果多准确,只要满足某个范围即可,这时我们就可以考虑使用STM32ADC看门狗功能了。 STM32 ADC基本上都支持模拟看门狗功能,即ADC模块对被检测的模拟通道的转换结果基于硬件对其合法性、安全性进行监测。我们可以设置被监测通道的转换结果合法性检查的上下阈值,若结果处于阈值之外则视为异常,并可以触发中断。 尤其有些场合,我们可能使用到数个ADC通道,8个、10个甚至更多,同时程序还需要基于各通道的转换结果进行合法性或安全性监测,此时使用ADC模拟看门狗功能就很方便。我们可以先让模拟看门狗做第一步把关,只有出现异常数据时才去进一步检查确认。
[单片机]
使用STM32A<font color='red'>DC</font>看门狗测量出待测信号
小广播
最新电源管理文章
