ADIADP1046300W数字电源解决方案
最新更新时间:2012-05-10来源: 21IC关键字:DC/DC转换器  开关电源 手机看文章 扫描二维码
随时随地手机看文章
ADI公司的ADP1046是用于隔离电源应用的数字控制器,它和ADP1043A引脚兼容,性能上增加了电压正馈,提高了回路响应,可编死区时间控制以最大化效率. 集成了所有典型的PWM控制器功能,有七个PWM控制信号,主要用于AC/DC转换器,冗余电源系统,服务器,存储器,网络和通信等基础设备.本文介绍了ADP1046主要特性,方框图,典型应用电路以及300W ADP1046评估板技术指标,电路图,材料清单和PCB元件布局图.
The ADP1046 is a flexible, digital secondary side controller designed for ac-to-dc and isolated dc-to-dc secondary side applications. The ADP1046 is pin-compatible with the ADP1043A and offers several enhancements and new features, including voltage feedforward, improved loop response, and programmable dead time control to maximize efficiency. The ADP1046 is optimized for minimal component count, maximum flexibility, and minimum design time. Features include local and remote voltage sense, primary and secondary side current sense, digital pulse-width modulation (PWM) generation, current sharing, and redundant OrFET control. The control loop digital filter and compensation terms are integrated and can be programmed over the I2C interface. Programmable protection features include overcurrent protection (OCP), over- voltage protection (OVP), undervoltage lockout (UVLO), and overtemperature protection (OTP). The built-in EEPROM provides extensive programming of the integrated loop filter, PWM signal timing, inrush current, and soft start timing and sequencing. Reliability is improved through a built-in checksum and programmable protection circuits. A comprehensive GUI is provided for easy design of loop filter characteristics and programming of the safety features. The industry-standard I2C bus provides access to the many monitoring and system test functions. The ADP1046 is available in a 32-lead LFCSP and operates from a single 3.3 V supply.
ADP1046主要特性:
Integrates all typical PWM controller functions
7 PWM control signals
Digital control loop
Integrated programmable loop filters
Programmable voltage line feedforward
Dedicated soft start filter
Programmable dead time for improved efficiency
Remote and local voltage sense
Primary and secondary side current sense
Synchronous rectifier control
Current sharing
OrFET control I2C interface
Extensive fault detection and protection
Extensive programming and telemetry
Fast digital calibration
User accessible EEPROM
ADP1046应用:
AC-to-DC power supplies Isolated dc-to-dc power supplies
Redundant power supply systems
Server, storage, network, and communications infrastructure
图1.ADP1046 简化框图
图2.ADP1046典型应用电路图
ADP1046评估板
This evaluation board features the ADP1046 in a switching power supply application. With the evaluation board and software, the ADP1046 can be interfaced to any PC running Windows® 2000, Windows NT, or Windows XP via the computer’s USB port. The evaluation board allows all the input and output functions of the ADP1046 to be exercised without the need for external components. The software allows control and monitor-ing of the ADP1046 internal registers. The board is set up for the ADP1046 to act as an isolated switching power supply with a rated load of 12 V/25 A from an input voltage ranging from 350 V dc to 400 V dc.
ADP1046评估板主要特性:
Interleaved 2-switch forward switching power supply
12 V/25 A regulated output from 400 V dc input
Voltage feedback loop
Dynamic phase shedding
Integrated current balance between phases
I2C serial interface to PC
Software graphic user interface (GUI)
Programmable digital filters
7 PWM outputs including auxiliary PWM (for fan control)
Digital trimming
OrFET control for hot swap and redundancy
Current, voltage, and temperature sense through GUI
Digital current sharing
图3.ADP1046评估板和子板外形图
ADP1046评估板技术指标:
图4.交错式两个开关正馈转换器拓扑图
主板电路图:
图5.ADP1046评估板主板电路图:功率级
图6.ADP1046评估板主板电路图:接口
图7.ADP1046评估板子板电路图
图8.ADP1046评估板主板元件布局图:顶层, 6.5 in × 5 in
图9.ADP1046评估板子板元件布局图:顶层,1.5 in × 1.08 in
主板材料清单:
子板材料清单:
变压器指标:
图10.变压器电路图
输出电感指标:
详情请见:
http://www.analog.com/static/imported-files/user_guides/UG-320.pdf
关键字:DC/DC转换器  开关电源 编辑:探路者 引用地址:ADIADP1046300W数字电源解决方案
上一篇:采用数字技术降低继电器功耗
下一篇:SoC之数字显示系统设计
推荐阅读最新更新时间:2023-10-18 16:44
高频开关电源自动换向开关
将电镀整流器在生产现场安置到位后,连接整流器和换向开关的铜排,换向开关需要用地脚螺丝固定,连接换向开关和镀槽电极的铜排,将控制盒安置在观察操作方便的位置。连接整流器电源(380V三相三线),连接换向 开关电源 (380V三相四线)。并接好水管。   换向开关在第一次使用前和每次重新连接换向开关的电源线后,必须先检查确认电机转向。   将控制盒上的“手动/自动”开关打到“手动”,合上给换向开关供电的开关,按动控制盒上的正向按钮或反向按钮,看换向开关的马达的转动方向与标示的方向是否一致,(如不一致,要立即停止。否则会对机件造成严重损坏。)如果不一致,应调换换向开关输入电源线的任意两条相线,再按上面的方法进行检查。确认转动方向与
[电源管理]
高频<font color='red'>开关电源</font>自动换向开关
饱和电感及在开关电源中的应用
引言 饱和电感是一种磁滞回线矩形比高,起始磁导率高,矫顽力小,具有明显磁饱和点的电感,在电子电路中常被当作可控延时开关元件来使用。由于其独特的物理特性,使之在高频开关电源的开关噪声抑制,大电流输出辅路稳压,移相全桥变换器,谐振变换器及逆变电源等方面得到了日益广泛的应用。 1饱和电感的分类及其物理特性 1.1饱和电感的分类 饱和电感可分为自饱和和可控饱和二类。 1.1.1自饱和电感(Saturableinductor) 其电感量随通过的电流大小可变。若铁心磁特性是理想的(例如呈矩形),如图1(a)所示,则饱和电感工作时,类似于一个“开关”,即绕组中的电流小时,铁心不饱和,绕组电感很大
[电源管理]
高压开关电源设计方案
针对精密 电子 设备中所要求的高电压、低电流的小功率电源系统,设计制作了一种高压开关电源。并对高压电源的响应特性进行了测试。制作出的电源系统具有体积小、稳定性好、响应速度快等特点。 1、引 言 在复印设备、医学仪器等精密电子系统中,广泛使用高电压、低电流的小功率电源 。同时要求电源系统具有重量轻、响应速度快、稳定性好、可靠性高等特点。为了上述满足精密电子系统的要求,设计制作了一种新型高压开关电源。该电源具有稳定性好、响应速度快等优点,能广泛应用于复印设备、医学仪器等精密电子系统中。 2、 电路 原理 系统原理框图如图1所示。高压电源的输入信号来自220V的交流市电,经整流滤波后与PWM脉冲调制
[电源管理]
高压<font color='red'>开关电源</font>设计方案
一款2KW高频开关电源电路的设计方案
与此同时,大量集成电路、超大规模集成电路等电子通信设备日益增多,要求电源的发展趋势是小型化、轻量化。本文主要针对滤波电感、电容和变压器的体积和重量比较大,因此提出了一款2KW高频开关电源电路的设计方案,通过方案中的电源电路的设计方法,达到了以减少它们的体积来实现小型化、轻量化。 0 引言 我们可以通过减少变压器的绕组匝数和金减小铁心尺寸来提高工作频率,但在提高开关频率的同时,开关损耗会随之增加,电路效率会严重下降。针对这些问题出现了软开关技术,它利用以谐振为主的辅助换流手段,解决了电路中的开关损耗和开关噪声问题,使开关电源能高频高效地运行,从20世纪70年代以来国内外就开始不断研究高频软开关技术,目前已比较成熟,下面以方案中2KW
[电源管理]
一款2KW高频<font color='red'>开关电源</font>电路的设计方案
基于开关电源的模块的设计
随着我国科技生产水平的不断提高,各行各业对供电质量的要求越来越高,而智能高频开关电源作为一种继电保护装置和控制回路装置,为生活和生产中的供电的可靠性提供了有力的保障。当市电供电中断时还可以作为后备电源,所以说智能高频开关电源是对供电质量保证的重要组成部分之一。它具有高度灵活组合、自主监控的特点,另外可靠性强、稳定性好且具有体积小、噪声低、节能高效、维护方便等也是它的一大优点。 可以说智能高频开关电源是一种集计算机技术、控制技术、通信技术于一体的高科技产品,可实现系统的自动诊断、自动测试和自动控制。本文主要阐述的是智能高频开关电源的整流模块的设计方案。 1 系统总体结构介绍 智能高频开关电源系统的总体结构主要由主监控单元、配电模块、
[电源管理]
基于<font color='red'>开关电源</font>的模块的设计
开关电源设计软件PI Expert 学习笔记
社区搞活动,也借机会学习一下电源的设计工具PI Expert ,先下了软件,默认是英文版的,不过汉化很容易,在菜单设置里改成中文菜单就行了,很方便。下面的图都是汉化这后的结果。   上图是新建设计后出现的第一个窗口,从内容看是专为PI产品而开发的,包含所有PI产品的系列和产品选单,点选相应的产品就可能进行设计了,可能由于后面的设计文件里有PCB布局的内容,所以在这里有封闭形式和外壳形式的选择。根据实际应用选完后点下一个按钮这个汉化的就有点那个了。建议改进一下。     PI Expert 这款软件的分类很详细,可根据实际情况选择输入电源。如果不是通用可点用户自定义设计输入电压范围。
[电源管理]
<font color='red'>开关电源</font>设计软件PI Expert 学习笔记
技术文章—开关电源EMC基本概念
电磁干扰的产生与传输 电磁干扰传输有两种方式:一种是传导传输方式,另一种则是辐射传输方式。传导传输是在干扰源和敏感设备之间有完整的电路连接,干扰信号沿着连接电路传递到接收器而发生电磁干扰现象。 辐射传输是干扰信号通过介质以电磁波的形式向外传播的干扰形式。常见的辐射耦合有三种:1)一个天线发射的电磁波被另一个天线意外地接收,称为天线对天线的耦合;2)空间电磁场经导线感应而耦合,称为场对线的耦合。3)两根平等导线之间的高频信号相互感应而形成的耦合,称为线对线的感应耦合。 电磁干扰的产生机理 从被干扰的敏感设备角度来说,干扰耦合又可分为传导耦合和辐射耦合两类。 ● 传导耦合模型传导耦合按其原理可分为电阻性耦合、电容
[电源管理]
泰科的DC/DC转换器适用于IBA应用
泰科电子(Tyco Electronics)公司近日推出EUK240系列DC/DC转换器EUK240,输出功率达240W,采用1/8砖封装。该产品支持5:1固定比例输出的中间总线架构应用。 EUK240电源模块是隔离的DC/DC转换器,输入电压范围在36Vdc至60Vdc之间,提供单一固定比例的输出电压。最大输出电流达34A,在全部输入范围内均可输出240W的功率。该模块的输入与输出间完全隔离,允许多极性配置和接地连接,其内置的滤波器可减少外围元件数量。 EUK240可在55℃、1m/s的输入电压范围内输出240W功率,9.6V时效率高达96%,是采用负载点转换器IBA应用的理想解决方案。此外该模块还具有远程开/关逻辑
[新品]
小广播
最新电源管理文章
