TIbq5101x无线电源传输接收解决方案
最新更新时间:2012-05-16来源: 21IC关键字:电源管理  无线电源传输  AC/DC转换器 手机看文章 扫描二维码
随时随地手机看文章
TI 公司的bq5101x是用于手提设备的无线电源传输的接收器,提供AC/DC电源转换,同时集成了和Qi v1.0通信协议兼容的数字控制,和bq500210发送器控制器一起,能组成完整的无接触电源传输系统,AC/DC的效率93%,最大输入电压20V,主要用于WPC兼容的接收器,手机和智能手机,数码相机,手持媒体播放器和手持设备.本文介绍了bq5101x主要特性,简化框图,无线电源(WPC或Qi)的电感电源系统框图,应用电路以及bq51013AEVM-764无线电源接收器评估板主要特性和性能指标,电路图,材料清单和PCB元件布局图.
The bq5101x is an advanced, integrated, receiver IC for wireless power transfer in portable applications. The device provides the AC/DC power conversion while integrating the digital control required to comply with the Qi v1.0 communication protocol. Together with the bq500210 transmitter controller, the bq5101x enables a complete contact-less power transfer system for a wireless power supply solution. By using near-field inductive power transfer, the receiver coil embedded in the portable device receives the power transmitted by the transmitter coil via mutually coupled inductors. The AC signal from the receiver coil is then rectified and regulated to be used as a power supply for down-system electronics. Global feedback is established from the secondary to the transmitter in order to stabilize the power transfer process via back-scatter modulation.
bq5101x主要特性:
Integrated Wireless Power Receiver Solution with a 5V Regulated Supply
93% Overall Peak AC-DC Efficiency
Full Synchronous Rectifier
WPC v1.0 Compliant Communication Control
Output Voltage Conditioning
Only IC Required Between RX coil and 5V DC Output Voltage
Dynamic Rectifier Controlfor Improved Load Transient Response
Dynamic Efficiency Scalingfor Optimized Performance Over any
Range of Output Power
Adaptive Communication Limitfor Robust Communication During
High Levels of Load Current Noise
Supports 20-V Maximum Input
Low-power Dissipative Rectifier Overvoltage Clamp (VOVP = 15V)
Thermal Shutdown
Multifunction NTC and Control Pin for Temperature Monitoring,
Done Charging and Fault Host Control
Stand-alone Digital Controller
Programmable Termination Pin for Charge Status 100% (CS100) Support
1.9 x 3mm DSBG or 4.5 x 3.5mm QFN Package
bq5101x 应用:
WPC Compliant Receivers
Cell Phones, Smart Phones
Headsets
Digital Cameras
Portable Media Players
Hand-held Devices
图1.无线电源(WPC或Qi)的电感电源系统框图
图2.bq5101x简化框图
图3.bq5101x用作无线电源接收器和给系统负载供电的电路图
图4.带适配器电源通路复接器的bq5101x用作无线电源接收器和给系统负载供电的电路图
The bq51013AEVM-764 wireless power receiver evaluation kit from Texas Instruments is a highperformance, easy-to-use development kit for the design of wireless power solutions. Consisting of a 5-V power supply receiver and associated magnetics, the kit enables designers to speed the development of their end-applications.
bq51013AEVM-764无线电源接收器评估板应用:
The bq51013AEVM-764 evaluation module (EVM) demonstrates the receiver portion of the bqTESLA™ wireless power system. This receiver EVM is a complete receiver-side solution that produces 5 V out at up to 1 A when coupled with the bqTESLA™ transmitter. The bq51013AEVM-764 device shown on this EVM along with external components that support the device for a complete solution.
• The bqTESLA™ receiver can be used in any number of low-power battery portable devices as a power source for charging. With contact-free charging capability, no connections to the device are needed.
• Output voltage of 5 V up to 1 A
• External adapter switchover and control circuit
• Low-profile, external pick-up coil
• Frame is configured to provide correct receiver to transmitter spacing.
• Room above coil for testing with battery, key for tuning
• Adjustable resistor R16 can be used to set max output current bq51013AEVM-764
bq51013AEVM-764无线电源接收器评估板电性能指标:
图5.无线电源接收器评估板的建立
图6.HPA764AEVM电路图
HPA764AEVM材料清单:
图7.bq51013AEVM-764无线电源接收器评估板元件布局图:顶层
详情请见:
http://www.ti.com/lit/ds/symlink/bq51013a.pdf
http://www.ti.com/lit/ug/sluu910/sluu910.pdf
关键字:电源管理  无线电源传输  AC/DC转换器 编辑:探路者 引用地址:TIbq5101x无线电源传输接收解决方案
上一篇:700mA串连型稳压电源电路
下一篇:LinkSwitch-TN节能型开关电源电路设计
推荐阅读最新更新时间:2023-10-18 16:45
RZ/G1C MPU简化制造,降低BOM成本
2017年5月10日,中国北京讯——领先的半导体解决方案供应商瑞萨电子中国扩展了其高性能RZ微处理器(MPU)系列,以应对人机界面(HMI)和嵌入式视觉系统应用不断增长的市场需求,同时支持从入门级到高度复杂嵌入式应用程序的扩展。瑞萨电子RZ/G系列的新型RZ/G1C微处理器能够快速开发高性能HMI应用,并支持和3D图形及全高清(FHD)视频。RZ/G1C针对基于Linux的应用程序开发进行了特别优化。 瑞萨电子RZ/G能够让系统制造商选择适合的处理器,以支持其当前和下一代连接设备,包括带触摸式显示的家用电器及集成嵌入式视觉HMI的工业设备,可以实现图像识别和人工智能。 关于RZ/G1C MPU RZ/G1C基于最佳能效的A
[嵌入式]
介绍几个模块电源中常用的MOSFET驱动电路
MOSFET因导通内阻低、开关速度快等优点被广泛应用于开关电源中。MOSFET的驱动常根据电源IC和MOSFET的参数选择合适的电路。下面一起探讨MOSFET用于开关电源的驱动电路。 在使用MOSFET设计开关电源时,大部分人都会考虑MOSFET的导通电阻、最大电压、最大电流。但很多时候也仅仅考虑了这些因素,这样的电路也许可以正常工作,但并不是一个好的设计方案。更细致的,MOSFET还应考虑本身寄生的参数。对一个确定的MOSFET,其驱动电路,驱动脚输出的峰值电流,上升速率等,都会影响MOSFET的开关性能。 当电源IC与MOS管选定之后,选择合适的驱动电路来连接电源IC与MOS管就显得尤其重要了。 一个好的MOSFE
[电源管理]
ACPI(高级配置与电源接口)的PC电源管理
ACPI(Advanced Configuration and Power Interface),即高级配置与电源接口。这种新的能源管理可以通过诸如软件控制"开关"系统,亦可以用Modem信号唤醒和关闭系统。   ACPI在运行中有以下几种模式:   S0 正常。   S1 CPU停止工作。唤醒时间:0秒。   S2 CPU关闭。唤醒时间:0.1秒。   S3 除了内存外的部件都停止工作。唤醒时间:0.5秒。   S4 内存信息写入硬盘,所有部件停止工作。唤醒时间:30秒。(冬眠状态)   S5 关闭。 S1 = Standby。即指說系統處於低電源供應狀態,在 windows or BIOS 中可設定螢幕訊號輸出
[电源管理]
更省钱,Silicon Mitus全新Open-Cell LCD电视面板电源管理芯片问市
近期,电源管理集成电路 (PMIC) 技术专家 Silicon Mitus宣布推出采用Open-Cell方式的电源管理芯片 “SM4810”, 适用于LCD电视面板。 所谓的Open-cell是指以半成品的方式,在组装过程中,省略了模块制程。Open-cell LCD电视将传统的LCD电视模块中时序控制器 (T-con) 和电源管理 (PMIC) 功能集合于电视主板。Silicon Mitus公司代表许炎表示,与传统的方式相比,采用Open-cell方式能够更有效降低制造成本,因此,不断得到诸多电视厂商的广泛普及且备受青睐。 令人瞩目的是,传统的LCD面板电源管理芯片只能适用于特定的面板上,然而Silicon Mitus本
[嵌入式]
更省钱,Silicon Mitus全新Open-Cell LCD电视面板<font color='red'>电源管理</font>芯片问市
新一代PCI背板的电源管理需求
高速总线提高电源设计难度   随着许多高速处理器、大容量硬盘和磁盘阵列、显示卡、以太网络和光纤数据通讯、以及内存数组等设备通讯速度不断加快,使用更快速总线接口来符合其应用需求成为必要。   现代半导体技术能制造出比以前更快逻辑电路,但仅靠提高逻辑电路速度并不足以加快总线速度。总线架构工程师必须处理总线电容、因为讯号线长度不同所造成讯号歪斜现象、难以预测总线负载变化、以及系统零组件误差。总线速度越快,电压就必须越精确。而这些问题都与俗称为I/O电源或VIO.总线收发器电源供应习习相关,因此现代总线必须小心设计其电源才能有效发挥最大效能。   新旧PCI可相容   回溯兼容性是PCI总线最大优势。PCI特别工作小组已发展出一套方法让
[电源管理]
TI推出单芯片电源管理IC TPS6507x系列
    日前,德州仪器 (TI) 面向便携式电子产品宣布推出 TPS6507x 系列单芯片电源管理集成电路。最新电源管理单元 (PMU) 实施全部排序与默认选项,可为包括 TI OMAP 与数字信号处理器在内的当前领先处理器提供电源。     TPS65070 与 TPS65073 产品高度集成了 3 个高效率 2.25 MHz、1.5 A DC/DC 降压转换器(支持内核处理器、存储器以及 I/O 电压)、两个通用 200 mA LDO、白光 LED 背景照明(可支持达 5 英寸的 LED 显示屏)、I2C 通信接口、10 位模数转换器、触摸屏接口以及集成 1.5 A 线性电池充电器,与分立设计相比,可将 DC/DC 实施方
[电源管理]
Linux2.6内核中的最新电源管理技术综述
  前言   本系列文章将结合近年来不断在各种硬件(包括 CPU、芯片组、PCI Express 等各种最新总线标准以及外设)上新增的节能技术。   从 Linux® 2.6内核及整个 software stack (包括 kernel、middleware 以及各种用户态 utility)如何添加对这些创新的节能技术的支持这一角度,为读者介绍 Linux 操作系统近几年来在电源管理方面所取得的长足进步以及未来的发展方向。   作为本系列文章的开篇之作,首先要向大家介绍的是 cpufreq,它是 Linux 2.6内核为了更好的支持近年来在各款主流CPU 处理器中出现的变频技术而新增的一个内核子系统。    Cpufreq 的由
[电源管理]
Linux2.6内核中的最新<font color='red'>电源管理</font>技术综述
2009上半年中国电源管理芯片市场回顾
中国电源管理芯片市场首次出现大幅下滑,09年上半年同比下降13.7% 根据CSIA的初步统计,2009年上半年中国电源管理芯片销售额为139.2亿元,与2008年同期的161.3亿元销售额相比下滑13.7%,中国电 源管理芯片市场首次出现大幅下滑,在经历2008年金融危机和行业不景气的双重影响之后,2009年上半年中国电源管理芯片市场遭受了更为直接的上游整机 产品产量大幅下滑的打击。2009年,金融危机的持续影响以及全球电子产业向中国转移的规模的继续大幅缩减,使得中国电子信息制造业遭受沉重打击,如果说 前几年中国电源管理芯片市场只是受到下游电子制造业整机产品产量增速下降的影响的话,那么2009年上半年
[电源管理]
2009上半年中国<font color='red'>电源管理</font>芯片市场回顾
小广播
最新电源管理文章
