TIUCD3138三路数字电源控制解决方案
最新更新时间:2012-07-23来源: chinaaet关键字:TIUCD3138  三路数字电源  控制解决方案 手机看文章 扫描二维码
随时随地手机看文章
TI公司的UCD3138是高度集成的数字电源控制器, 能数字控制三路单独的反馈回路,专有的基于PID硬件,2极点/2零点配置,非线性控制,高达16MHz误差模数转换器(EADC),可配置分辨率到1mV/LSB,自动分辨率选择,高达8x过取样,14位有效DAC,主要用于电源和通信整流器,功率因速修正和隔离的DC/DC模块.本文介绍了UCD3138主要特性,方框图,以及评估板UCD3138PFCEVM-026主要特性,电路图,材料清单和PCB元件布局图.
The UCD3138 is a digital power supply controller from Texas Instruments offering superior levels of integration and performance in a single chip solution. The flexible nature of the UCD3138 makes it suitable for a wide variety of power conversion applications. In addition, multiple peripherals inside the device have been specifically optimized to enhance the performance of ac/dc and isolated dc/dc applications and reduce the solution component count in the IT and network infrastructure space.
The UCD3138 is a fully programmable solution offering customers complete control of their application, along with ample ability to differentiate their solution. At the same time, TI is committed to simplifying our customer’s development effort through offering best in class development tools, including application firmware, Code Composer Studio. software development environment, and TI’s Fusion Power Development GUI which enables customers to configure and monitor key system parameters.
At the core of the UCD3138 controller are the digital control loop peripherals, also known as Fusion Digital Power Peripherals (FDPP). Each FDPP implements a high speed digital control loop consisting of a dedicated Error Analog to Digital Converter (EADC), a PID based 2 pole–2 zero digital compensator and DPWM outputs with 250 ps pulse width resolution. The device also contains a 12-bit, 265ksps general purpose ADC with up to 14 channels, timers, interrupt control, JTAG debug and PMBus and UART communications ports. The device is based on a 32-bit ARM7TDMI-S RISC microcontroller that performs
real-time monitoring, configures peripherals and manages communications. The ARM microcontroller executes its program out of programmable flash memory as well as on-chip RAM and ROM.
In addition to the FDPP, specific power management peripherals have been added to enable high efficiency across the entire operating range, high integration for increased power density, reliability, and lowest overall system cost and high flexibility with support for the widest number of control schemes and topologies. Such peripherals include: light load burst mode, synchronous rectification, LLC and phase shifted full bridge mode switching, input voltage feed forward, copper trace current sense, ideal diode emulation, constant current constant power control, synchronous rectification soft on and off, peak current mode control, flux balancing, secondary side input voltage sensing, high resolution current sharing, hardware configurable soft start with pre bias, as well as several other features. Topology support has been optimized for voltage mode and peak current mode controlled phase shifted full bridge, single and dual phase PFC, bridgeless PFC, hard switched full bridge and half bridge, and LLC half bridge and full bridge.
UCD3138主要特性:
Digital Control of up to 3 Independent Feedback Loops
Dedicated PID based hardware
2-pole/2-zero configurable
Non-Linear Control
Up to 16MHz Error Analog to Digital Converter (EADC)
Configurable Resolution as Small as 1mV/LSB
Automatic Resolution Selection
Up to 8x Oversampling
Hardware Based Averaging (up to 8x)
14 bit Effective DAC
Up to 8 High Resolution Digital Pulse Width Modulated (DPWM) Outputs
250ps Pulse Width Resolution
4ns Frequency Resolution
4ns Phase Resolution
Adjustable Phase Shift Between Outputs
Adjustable Dead-band Between Pairs
Up to 2MHz Switching Frequency
Configurable PWM Edge Movement
Trailing Modulation
Leading Modulation
Dual Edge Modulation
Configurable Feedback Control
Voltage Mode
Average Current Mode
Peak Current Mode Control
Constant Current
Constant Power
Configurable Modulation Methods
Frequency Modulation
Phase Shift Modulation
Pulse Width Modulation
Fast, Automatic and Smooth Mode Switching
Frequency Modulation and PWM
Phase Shift Modulation and PWM
High Efficiency and Light Load Management
Burst Mode
Ideal Diode Emulation
Synchronous Rectifier Soft On/Off
Low IC Standby Power
Soft Start / Stop with and without Pre-bias
Fast Input Voltage Feed Forward Hardware
Primary Side Voltage Sensing
Copper Trace Current Sensing
Flux and Phase Current Balancing for Non-Peak Current
Mode Control Applications
Current Share Bus Support
Analog Average
Master/Slave
Feature Rich Fault Protection Options
7 High Speed Analog Comparators
Cycle-by-Cycle Current Limiting
Programmable Fault Counting
External Fault Inputs
4–10 Digital Comparators
Programmable blanking time
Synchronization of DPWM waveforms between multiple UCD313x devices
14 channel, 12 bit, 265 ksps General Purpose ADC with integrated
Programmable averaging filters
Dual sample and hold
Internal Temperature Sensor
Fully Programmable High-Performance 31.25MHz, 32-bit ARM7TDMI-S Processor
32 kByte (kB) Program Flash
2 kB Data Flash with ECC
4 kB Data RAM
4 kB Boot ROM Enables Firmware Boot-Load in the Field via
I2C or UART
Communication Peripherals
I2C/PMBus
2 UARTs
JTAG Debug Port
Timer capture with selectable input pins
Up to 5 Additional General Purpose Timers
Built In Watchdog: BOD and POR
64-pin QFN and 40-pin QFN packages
Operating Temperature: –40°C to 125°C
Fusion Digital Power GUI Support
UCD3138应用:
Power Supplies and Telecom Rectifiers
Power Factor Correction
Isolated dc-dc Modules
图1.UCD3138方框图
This EVM is to help evaluate the UCD3138 64-pin digital control device in off-line power converter application and then to aid its design. The EVM is a standalone Power Factor Correction (PFC) preregulator of single-phase AC input. The EVM UCD3138PFCEVM-026 is used together with its control card, UCD3138CC64EVM-030, also an EVM on which is placed UCD3138RGC.
The EVM of UCD3138PFCEVM-026 together with UCD3138CC64EVM-030 can be used as they are delivered without additional work, from either hardware or firmware, to evaluate PFC. The UCD3138PFCEVM-026 together with the UCD3138CC64EVM-030 can also be re-tuned on its design parameters through the operation of GUI, called Texas Instruments Fusion Digital Power Designer, or reloaded up with custom firmware with user’s definition and development.
The EVM system is in topology of single-phase boost converter at its delivery on both hardware and firmware, but can be re-configured into two other PFC topologies: dual-phase interleaved, and bridgeless, then corresponding operation can be made by reloading with that associated firmware. All necessity of hardware and firmware for the two additional topologies are already developed and delivered with the shipment. Please contact Texas Instruments to obtain the instructions how to make re-configuration.
In the package delivered, three EVMs are included UCD3138PFCEVM-026, UCD3138CC64EVM-030, and USB-TO-GPIO. In the same package, also included is a hard copy of Evaluation Module Electrical Safety Guideline.
This user’s guide provides basic evaluation instruction from a viewpoint of system operation in standalone PFC in its boost configuration.
UCD3138PFCEVM-026 together with UCD3138CC64EVM-030 is an EVM of PFC pre-regulator with digital control using UCD3138 device in boost converter topology and in the application of single-phase AC input.
UCD3138 device is located on the board of UCD3138CC64EVM-030. UCD3138CC64EVM-030 is a daughter card and serves all PFC required control functions with preloaded single-phase boost PFC firmware. UCD3138PFCEVM-026 accepts universal AC line input from 90 VAC to 264 VAC, and outputs nominal 390 VDC with full load output power 360 W, or full output current 0.92 A.
图2.评估板UCD3138PFCEVM-026外形图(UCD3138PFCEVM-030插在其上)
评估板UCD3138PFCEVM-026主要特性:
• Digitally Controlled PFC Pre-Regulator
• Universal AC Line Input from 90 VAC to 264 VAC with AC Line Frequency 47 Hz to 63 Hz
• Regulated Output 390 VDC with Output from No-Load to Full-Load
• Full-Load Power 360 W, or full-Load Current 0.92 A
• High Power Factor Close to 0.999 and Low THD Below 5% in Most Operation Conditions
• High Efficiency
• Protection:
– Over Voltage
– Over Current
– Brownout
– Power-On Inrush Current
• Test Points to Facilitate Device and Topology Evaluation
• Re-Configurable to Dual-Phase Interleaved PFC or Bridgeless PFC (please contact TI for detail)
评估板UCD3138PFCEVM-026应用:
• Single-Phase Universal AC Line Power Factor Correction Pre-Regulator
• Servers
• Telecommunication Systems
评估板UCD3138PFCEVM-026电性能指标:
图3.评估板UCD3138PFCEVM-026电路图(1)
图4.评估板UCD3138PFCEVM-026电路图(2)
评估板UCD3138PFCEVM-026材料清单:
图5.评估板UCD3138PFCEVM-026顶层PCB元件布局图
详情请见:
http://www.ti.com/lit/ds/symlink/ucd3138.pdf
http://www.ti.com/lit/ug/sluu885a/sluu885a.pdf
关键字:TIUCD3138  三路数字电源  控制解决方案 编辑:探路者 引用地址:TIUCD3138三路数字电源控制解决方案
上一篇:电源系统通信支持数字电源发展
下一篇:如何利用数字电源优化基站系统
推荐阅读最新更新时间:2023-10-17 14:58
士兰微电子推出多款家电及工具类电机控制解决方案
士兰微电子MCU经过多年发展和积累,已经形成了品牌化,系列化,可为客户提供一站式产品服务。近期, 士兰微电子推出了M0系列,M0双核系列,M3系列,M4系列等多系列MCU产品,可广泛支持客户的多样化需求,覆盖家电、电动工具、电动车等应用。 具体包括应用于家电空冰洗等的MCU-SC32F58/56系列产品;应用于园林工具、吸尘器、低压风机的低压合封MCU-SPC7L系列产品,应用于电动工具的低压合封MCU-SPC6L系列产品;应用于电动两轮车的SC32F56系列产品。 图1:士兰微家电及工具解决方案 在白电领域,士兰微可提供MCU-SC32F58/56系列产品,满足家电空调、冰箱、洗衣机、油烟机、洗碗机等开发需求。产品采用
[工业控制]
士兰微电子推出多款家电及工具类电机<font color='red'>控制</font><font color='red'>解决方案</font>
抢攻触摸屏商机 增你强力推Cypress电容式控制IC解决方案
消费性电子产品吹起触摸屏面板风,包括Apple、宏达电与微软推出的新款手机与平面计算机都主打触摸屏操作。看好触摸屏面板商机无限,增你强股份有限公司力推代理产品赛普拉斯半导体(Cypress)PSoC产品线的CapSense电容式触摸屏IC解决方案。 增你强表示,目前已跟台湾地区一线手机与数码相机大厂合作,进行新机种design-in,预计今年第四季会有成果展现。CapSense触摸屏解决方案可应用于便携装备(如:移动电话、数码相机)、GPS、电视/显示器等消费性电子产品。除了3C产品外,其它利基型电子产品也是触摸屏面板的潜力市场,例如跑步机、白色家电(如:洗衣机、冰箱)、遥控器、POS机等。 CapSense电容式感测
[焦点新闻]
STSTEVAL-IHM032V1150W正弦矢量控制解决方案
ST 公司的STEVAL-IHM032V1 150W矢量控制板采用600V高压器件L639x 和 快速IGBT STGD3HF60HD(4.5 A, 600 V) ,适用于永磁同步马达(PMSM)的磁场定向控制(FOC)和无刷直流马达(BLDC)基于梯形标量控制,正常输出功率高达150W.控制板和110VAC与230VAC火线电压兼容,并能和STM3210xx-EVAL,STEVAL-IHM022V1,以及STEVAL-IHM033V1通过专用连接器进行接口.主要用在洗碗机泵,冰箱压缩机和风扇.本文介绍了L6392 主要特性和方框图,150W STEVAL-IHM032V1 演示板主要特性和框图,电路图与材料清单. 150 W in
[电源管理]
STSTEVAL-IHM032V1150W正弦矢量<font color='red'>控制</font><font color='red'>解决方案</font>
慧荣科技宣布推出支持最新SD 6.0规范的SD控制解决方案
2017年6月2日,台湾台北和美国加洲MILPITAS——在设计和推广固态存储设备专用NAND闪存控制器方面处于全球领导地位的慧荣科技公司(Silicon Motion Technology Corporation, 纳斯达克交易代码: SIMO)日前宣布推出全新的SD 6.0控制器解决方案,该控制器支持SD规范6.0,并满足新的A2应用性能评级,其最小随机读/写性能高达4,000/2,000 IOPS。可扩展存储卡配置了慧荣SD 6.0新控制器后,用户将极大的提高性能,能够直接从SD卡运行Android 6.x/7.x应用程序,并支持4k视频录制和播放以及AR/VR等需要高带宽的应用。 慧荣科技的SD 6.0控制器解决方案支
[嵌入式]
慧荣科技宣布推出支持最新SD 6.0规范的SD<font color='red'>控制</font>器<font color='red'>解决方案</font>
详解充电桩控制系统解决方案
1. 方案背景 1、行业背景 我国政府顺应时代发展,超常规地、大力发展电动汽车产业,由此带动了新能源电动汽车充电桩项目的蓬勃兴起,在国内各地电动汽车充电站纷纷涌现! 充电桩是电动力车的电站,其功能类似于加油站里面的加油机。每个充电桩都装有充电插头,充电桩可以根据不同的电压等级,为各种型号的电动车充电。电动汽车充电桩采用的是交、直流供电方式,需要特制的充电卡刷卡使用,充电桩显示屏能显示充电量、费用、充电时间等数据。充电桩作为加油站、小区电动汽车充电状态的人机交互产品。可实现计时充电和计电度量充电。卡内预先充值,每次充电后根据电度数自动从卡中减去,并打印出票据。 本方案描述的是EPC-9200工控主板在电动汽车充电桩系
[嵌入式]
世强元件电商带来全品类的工业控制及自动化解决方案
深圳国际展暨第六届深圳国际嵌入式系统展于2017年12月21日-23日在深圳会展召开。世强元件电商携汽车、工业、、等领域的元件产品及解决方案亮相展会并取得圆满成功。其中在工业控制及自动化方面,带来了工业自动化、工业链接、工业机器人、工业等全品类的解决方案。 在工业机器人上,路径规划、位置记忆、自动定位是智能机器人行走时最需要具备的特性,基于此世强元件电商带来了高稳定温度特性的——XV-7001,该产品卓越的零偏稳定性能,全温偏差±5º/s让机器人实现准确路径规划,静止时输出为+-1度/秒(0 LSB Typ.),内置,可选择的数字,角速度输出达到16bit,非常符合新式电子产品高精度、低功耗、小封装的要求,可应用在智能
[机器人]
Nordic解决方案为智能家居生态系统添无线控制家用电器功能
Nordic解决方案为智能家居生态系统增添无线控制家用电器功能 Wonderlabs 公司SwitchBot智能家居生态系统使用 nRF52840 和 nRF51822 SoC实现智能手机应用程序控制功能 挪威奥斯陆 – 2021年12月2日 – Nordic Semiconductor宣布科技企业 Wonderlabs Limited已经选定Nordic 的nRF52和nRF51系列低功耗蓝牙 (Bluetooth® Low Energy (Bluetooth LE))系统级芯片(SoC)助力其“SwitchBot”智能家庭生态系统。 这款智能家居生态系统包括集成nRF52840 蓝牙5.2/低功耗蓝牙先进多协议 S
[物联网]
Nordic<font color='red'>解决方案</font>为智能家居生态系统添无线<font color='red'>控制</font>家用电器功能
Diodes智能电机控制器提供全套解决方案
Diodes 公司推出全新 AH5792 单芯片解决方案,集成了驱动低功率单线圈无刷直流风扇及电机所需的所有功能。 AH5792 在超薄 SOT553 封装中集成了霍尔传感器和放大器、全数字控制电路及全桥输出驱动器,特别适用于低压微电机及超薄冷却风扇应用。 利用其双向 H 桥输出级, AH5792 通过为流入和流出电流 (Source and Sink Current) 提供一对推挽式驱动器输出,满足单相全波无刷式直流电机控制需要。该器件的工作电压为 1.8V 至 5V ,也适用于工作电压较低、需要低压启动的微型直流风扇。 为了防止电机绕组
[工业控制]
Diodes智能电机<font color='red'>控制</font>器提供全套<font color='red'>解决方案</font>
小广播
最新电源管理文章
