概述
The MAX4144/MAX4145/MAX4146 differential line receivers offer unparalleled high-speed, low-distortion performance. Using a three op-amp instrumentation amplifier architecture, these ICs have fully symmetrical differential inputs and a single-ended output. They operate from ±5V power supplies and are capable of driving a 150Ω load to ±3.7V. The MAX4144 has an internally set closed-loop gain of +2V/V. The MAX4145 is optimized for gains from +1V/V to +10V/V, while the MAX4146 is optimized for gains from +10V/V to +100V/V. The MAX4145/MAX4146 require a single external resistor to set the closed-loop gain.
典型工作电路
These amplifiers use laser-trimmed, matched thin-film resistors to deliver a common-mode rejection (CMR) of up to 90dB at 10MHz. Using current-feedback techniques, the MAX4144 achieves a 130MHz bandwidth and a 1000V/µs slew rate. The MAX4145 achieves a bandwidth of 180MHz and a slew rate of 600V/µs while operating with a closed-loop gain of +1V/V, and the MAX4146 features a bandwidth of 70MHz and a slew rate of 800V/µs with a gain of +10V/V. Excellent differential gain/phase and noise specifications make these amplifiers ideal for a wide variety of video and RF signal-processing applications.
For a complete differential transmission link, use the MAX4144/MAX4145/MAX4146 with the MAX4147 differential line driver (see the MAX4147 data sheet for more information).
关键特性
MAX4144:
+2V/V Internally Fixed Gain
130MHz Bandwidth
1000V/µs Slew Rate
70dB CMR at 10MHz
-90dBc SFDR (f = 10kHz)
Low Differential Gain/Phase: 0.03%/0.03°
800µA Shutdown
MAX4145:
External Gain Selection from +1V/V to +10V/V
180MHz Bandwidth
90MHz 0.1dB Gain Flatness
600V/µs Slew Rate
75dB CMR at 10MHz
-92dBc SFDR (f = 10kHz)
Very Low Noise: 3.8nV per root-Hz (G = +10V/V)
800µA Shutdown
MAX4146:
External Gain Selection from +10V/V to +100V/V
70MHz Bandwidth (AV = +10V/V)
800V/µs Slew Rate
90dB CMR at 10MHz
-82dBc SFDR (f = 10kHz)
Very Low Noise: 3.45nV per root-Hz (G = +100V/V)
800µA Shutdown
应用/使用
数据采集
差分至单端转换
高速差分线接收器
高速仪表放大器
医疗仪表
双绞线至同轴电缆转换器
上一篇:计数器的同步扩展、级联及波形图
下一篇:浅析三大主流触摸屏技术
- 热门资源推荐
- 热门放大器推荐
