18b20测温c51源程序
发布者:安静的夜晚最新更新时间:2011-01-23 手机看文章 扫描二维码
随时随地手机看文章
#include
#include
#define   BUSY1    (DQ1==0)
sbit      DQ1    =  P0^4;
unsigned char idata TMP;
unsigned char idata TMP_d;
unsigned char f;
void wr_ds18_1(char dat);
unsigned char rd_ds18_1();
/***************延时程序,单位us,大于10us*************/
void time_delay(unsigned char time)
  time=time-10;
  time=time/6;
  while(time!=0)time--;
/*                reset ds18b20                      */
void ds_reset_1(void)
  unsigned char idata count=0;
  DQ1=0;
   time_delay(240);
 time_delay(240);
  DQ1=1;
  return;
void check_pre_1(void)
     while(DQ1);
     while(~DQ1);
         time_delay(30);
void read_ROM(void)
 int n;
 ds_reset_1();
  check_pre_1();
  wr_ds18_1(0x33);
  for(n=0;n<8;n++){ROM[n]=rd_ds18_1();}
/*      Read a bit from 1820      位读取             */
bit tmrbit_1(void)
        idata char i=0;
     bit dat;
     DQ1=0;_nop_();
        DQ1=1;
   _nop_();
   _nop_();
   _nop_();
 _nop_();
  _nop_();
   _nop_();
   _nop_();
   _nop_();
        _nop_();
  _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
     dat = DQ1;
        time_delay(50);
     return dat;
/*                read a bety from ds18b20 字节读取  */
  unsigned char idata i,j,dat=0;
     for(i=1;i<=8;i++)
         j=tmrbit_1();
         dat=(j<<(i-1))|dat;
     return dat;
/*         write a bety from ds18b20   写字节        */
     signed char  idata i=0;
     unsigned char idata j;
     bit testb;for(j=1;j<=8;j++)
         testb=dat & 0x01;
         dat = dat>>1;
         if(testb)
              DQ1=0;
               _nop_();
       _nop_();
              DQ1=1;
            time_delay(60);
         else
              DQ1=0;
              time_delay(50);
              DQ1=1;
               _nop_();
       _nop_();
int get_temp_1(void)
  unsigned char idata a=0,b=0;
  unsigned char idata i;
  EA=0;
  ds_reset_1();
  check_pre_1();
  wr_ds18_1(0xcc);
  wr_ds18_1(0x44);
  while(BUSY1);
  ds_reset_1();
  check_pre_1();
  wr_ds18_1(0xcc);
  wr_ds18_1(0xbe);
  a=rd_ds18_1();
  b=rd_ds18_1();
  i=b;   /*若b为1则为负温   */
  i=(i>>4);
  if(i==0)
   f=0;
   TMP=((a>>4)|(b<<4));
  a=(a&0x0f);
  if (a>8)
   TMP=(TMP+1);
  else
   f=1;
  a=a>>4;
   b=b<<4;
   TMP=(a|b);
   TMP=~TMP;
   TMP=(TMP+1);
  EA=1;
  return(TMP);
int get_temp_d(void)
  unsigned char idata i,m;
  EA=0;
  ds_reset_1();//复位
  check_pre_1();
  wr_ds18_1(0xcc);
  wr_ds18_1(0x44);
  while(BUSY1);
  ds_reset_1();
  check_pre_1();
  wr_ds18_1(0xcc);
  wr_ds18_1(0xbe);
  a=rd_ds18_1();
  b=rd_ds18_1();
  i=b;   /*若b为1则为负温   */
  i=(i>>4);
  if(i==0)
   f=0;
  a=(a&0x0f);
  TMP_d=a;
  else
   f=1;
   a=~a;
   a=(a+1);
   b=~b;
   b=(b+1);
   m=a;
   a=a>>4;
   b=b<<4;
   TMP=(a|b);
   m=(m&0x0f);
   TMP_d=m;
  EA=1;
  return(TMP);
引用地址:18b20测温c51源程序
上一篇:基于AT89C2051设计的无线防盗报警器技术
下一篇:基于AT89C2051的红外遥控学习器源程序
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
设计资源 培训 开发板 精华推荐
最新单片机文章
  • ARM裸机篇--按键中断
    先看看GPOI的输入实验:按键电路图:GPF1管教的功能:EINT1要使用GPF1作为EINT1的功能时,只要将GPFCON的3:2位配置成10就可以了!GPF1先配 ...
  • 网上下的--ARM入门笔记
    简单的介绍打今天起菜鸟的ARM笔记算是开张了,也算给我的这些笔记找个存的地方。为什么要发布出来?也许是大家感兴趣的,其实这些笔记之所 ...
  • 学习ARM开发(23)
    三个任务准备与运行结果下来看看创建任务和任运的栈空间怎么样的,以及运行输出。Made in china by UCSDN(caijunsheng)Lichee 1 0 0 ...
  • 学习ARM开发(22)
    关闭中断与打开中断中断是一种高效的对话机制,但有时并不想程序运行的过程中中断运行,比如正在打印东西,但程序突然中断了,又让另外一个 ...
  • 学习ARM开发(21)
    先要声明任务指针,因为后面需要使用。 任务指针 volatile TASK_TCB* volatile g_pCurrentTask = NULL;volatile TASK_TCB* vol ...
  • 学习ARM开发(20)
  • 学习ARM开发(19)
  • 学习ARM开发(14)
  • 学习ARM开发(15)
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
