AM12864测试C语言程序
发布者:Coboro最新更新时间:2013-01-15 来源: 51hei 关键字:AM12864测试  C语言  显示汉字 手机看文章 扫描二维码
随时随地手机看文章
AM12864测试程序(C语言)
/* AM12864测试程序 1.0 */
/* Designed by Andorin LCM R&D Group */
#include
#include
#include
#include
#include
#include
/* Define the register command code */
#define Disp_On 0x3f
#define Disp_Off 0x3e
#define Col_Add 0x40
#define Page_Add 0xb8
#define Start_Line 0xc0
#define Lcd_Bus P1 //MCU P1<------> LCM
sbit Mcs=P2^3; //Master chip enable
sbit Scs=P2^4; //Slave chip enable
sbit Enable=P2^2; //6800 mode Enable single
sbit Di=P2^0; //Data or Instrument Select
sbit RW=P2^1; //Write or Read
sbit Lcd_Rst=P2^5; //Lcm reset
sbit Test_Key=P3^1;
char code ce[]={/*-- 文字: 测 --*/0x08,0x31,0x86,0x60,0x00,0xFE,0x02,0xF2,0x02,0xFE,0x00,0xF8,0x00,0x00,0xFF,0x00,
0x04,0xFC,0x03,0x00,0x80,0x47,0x30,0x0F,0x10,0x67,0x00,0x07,0x40,0x80,0x7F,0x00};
char code shi[]={/*-- 文字: 试 --*/0x40,0x42,0xDC,0x08,0x00,0x90,0x90,0x90,0x90,0x90,0xFF,0x10,0x12,0x1C,0x10,0x00,
0x00,0x00,0x7F,0x20,0x10,0x20,0x20,0x1F,0x10,0x10,0x01,0x06,0x18,0x20,0x78,0x00};
char code kai[]={/*-- 文字: 开 --*/0x40,0x42,0x42,0x42,0x42,0xFE,0x42,0x42,0x42,0x42,0xFE,0x42,0x42,0x42,0x42,0x00,
0x00,0x40,0x20,0x10,0x0C,0x03,0x00,0x00,0x00,0x00,0x7F,0x00,0x00,0x00,0x00,0x00};
char code shi2[]={0x10,0x90,0x70,0x1F,0x12,0xF0,0x00,0x20,0x70,0x28,0x27,0x22,0x28,0x70,0x20,0x00,
0x40,0x21,0x12,0x0C,0x06,0x09,0x30,0x00,0x7F,0x21,0x21,0x21,0x21,0x7F,0x00,0x00};//始
char code wan[]={0x00,0x90,0x8C,0xA4,0xA4,0xA4,0xA5,0xA6,0xA4,0xA4,0xA4,0xA4,0x94,0x8C,0x04,0x00,
0x00,0x80,0x40,0x20,0x18,0x07,0x00,0x00,0x00,0x3F,0x40,0x40,0x40,0x70,0x00,0x00};//完
char code bi[]={0x00,0x00,0xFF,0x88,0x48,0x28,0x08,0x80,0x7F,0x88,0x88,0x88,0x84,0x84,0xE0,0x00,
0x04,0x04,0x04,0x04,0x04,0x04,0x04,0xFF,0x04,0x04,0x04,0x04,0x04,0x04,0x04,0x00};//毕
char code yang[]={0x20,0x10,0x2C,0x23,0x6A,0xAA,0x2A,0xAA,0x6A,0x2A,0x2A,0x2A,0xEA,0x02,0x00,0x00,
0x00,0x10,0x11,0x15,0x15,0x15,0xFF,0x15,0x15,0x15,0x11,0x10,0x3F,0x40,0x30,0x00};
char code qi[]={0x40,0x20,0x58,0x47,0x54,0x54,0x54,0x54,0x54,0x54,0xD4,0x14,0x06,0x04,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0x20,0x40,0x80,0x70,0x00};//气
char code nong[]={0x10 ,0x21 ,0x62 ,0x06 ,0x90 ,0x0C ,0x04 ,0x84,0x64 ,0x9F ,0x04 ,0x04 ,0x94 ,0xCC ,0x00 ,0x00,
0x04 ,0x04 ,0xFE ,0x01 ,0x04 ,0x02 ,0x01 ,0xFF, 0x40 ,0x21 ,0x06 ,0x09 ,0x10 ,0x30 ,0x10 ,0x00 };//浓
char code du[]={0x00 ,0x00 ,0x0FC ,0x24 ,0x24 ,0x24 ,0x0FC ,0xA5, 0xA6 ,0xA4 ,0x0FC ,0x24 ,0x34 ,0x26 ,0x04 ,0x00,
0x40 ,0x20 ,0x9F ,0x80 ,0x42 ,0x42 ,0x26 ,0x2A, 0x12 ,0x2A ,0x26 ,0x42 ,0x40 ,0xC0 ,0x40 ,0x00};//度
char code bi2[]={0x00, 0x00, 0xFE, 0x40, 0x40, 0x60, 0x40, 0x00,0xFF, 0x80, 0x40, 0x20, 0x30, 0x00, 0x00, 0x00,
0x00, 0x40, 0x7F, 0x20, 0x20, 0x10, 0x10, 0x00,0x3F, 0x40, 0x40, 0x40, 0x40, 0x40, 0x78, 0x00};//比
char code fen[]={0x00 ,0x80 ,0x40 ,0x20 ,0x98 ,0x86 ,0x80 ,0x80,0x83 ,0x8C ,0x90 ,0x20 ,0xC0 ,0x80 ,0x80 ,0x00,
0x01 ,0x00 ,0x80 ,0x40 ,0x20 ,0x1F ,0x00 ,0x40, 0x80 ,0x40 ,0x3F ,0x00 ,0x00 ,0x01 ,0x00 ,0x00 };// 分
char code bai[]={0x02 ,0x02 ,0x02 ,0xE2 ,0x22 ,0x32 ,0x2A ,0x26,0x22 ,0x22 ,0x22 ,0xF2 ,0x22 ,0x03 ,0x02 ,0x00,
0x00 ,0x00 ,0x00 ,0xFF ,0x42 ,0x42 ,0x42 ,0x42, 0x42 ,0x42 ,0x42 ,0xFF ,0x00 ,0x00 ,0x00 ,0x00};// 百
char code wei[]={
0x20 ,0x20 ,0x20 ,0x22 ,0x24 ,0x2C ,0x20 , 0xE0,
0x3F ,0x20 ,0x20 ,0x20 ,0x20 ,0xF0 ,0x20 ,0x00,
0x00 ,0x40 ,0x20 ,0x10 ,0x08 ,0x04 ,0x03 ,0x00,
0x02 ,0x04 ,0x4C ,0x80 ,0x40 ,0x3F ,0x00 ,0x00
};//为
 [page]
/*------------------延时子程序-----------------------------*/
void delay(unsigned int t)
unsigned int i,j;
for(i=0;ifor(j=0;j<10;j++) ;
/*------------------写命令到LCD------------------------------*/
void write_com(unsigned char cmdcode)
do{delay(0);}while(P0^7==1);
Di=0;
RW=0;
Lcd_Bus=cmdcode;
delay(0); //原来是delay(0)
Enable=1;
delay(0);
Enable=0;
/*-------------------写数据到LCD----------------------------*/
void write_data(unsigned char Dispdata)
{ do{delay(10);}while(P0^7==1);
Di=1;
RW=0;
Lcd_Bus=Dispdata;
delay(0);
Enable=1;
delay(0);
Enable=0;
/*-------------------读LCD数据----------------------------*/
unsigned char read_data()
{ //do{delay(100);}while(P0^7==1);
unsigned char tmpin;
Di=1;
RW=1;
delay(0);
Enable=1;
delay(0);
Enable=0;do{delay(100);}while(P0^7==1);
tmpin=Lcd_Bus;
return tmpin;
/*------------------显示边框-------------------------------*/
void frame()
unsigned char i;
Mcs=1;
Scs=1;
write_com(Page_Add+0);
write_com(Col_Add+0);
for(i=0;i<64;i++) write_data(0x01);
write_com(Page_Add+7);
for(i=0;i<64;i++) write_data(0x80);
for(i=0;i<8;i++)
Mcs=0;
Scs=1;
write_com(Page_Add+i);
write_com(Col_Add+63);
write_data(0x55);
Mcs=1;
Scs=0;
write_data(0x55);
/*------------------清除内存AM12864测试程序---------------*/
void Clr_Scr()
unsigned char j,k;
Mcs=1;Scs=1;
for(k=0;k<8;k++){
write_com(Page_Add+k);
for(j=0;j<64;j++)write_data(0x00);
/*------------------显示12864图片---------------------------*/
void Disp_Img(unsigned char code *img)
unsigned char j,k;
for(k=0;k<8;k++){
Mcs=1;Scs=0;delay(0);
for(j=0;j<64;j++) write_data(img[k*128+j]);
Mcs=0;Scs=1; delay(0);
for(j=64;j<128;j++) write_data(img[k*128+j]);
/*------------------显示横--------------AM12864测试程序-------------*/
void Disp_H_Line()
unsigned char i,j;
Mcs=1;
Scs=1;
write_com(Disp_On);
write_com(Page_Add);
write_com(Start_Line);
write_com(Col_Add);
for(j=0;j<8;j++)
write_com(Page_Add+j);
// write_com(Start_Line+0);
for(i=0;i<64;i++)write_data(0x00);
/*------------------显示列-----------------------------*/
void Disp_V_Line()
unsigned char i,j;
write_com(Disp_On);
write_com(Col_Add);
for(j=0;j<8;j++)
for(i=0;i<32;i++)
write_data(0x00);
write_data(0x55);
}[page]
/*------------------棋盘-----------------------------*/
void Disp_Cross_Line(unsigned char mode)
unsigned char i,j;
unsigned char data1,data2;
if(mode==0) {data1=0xaa;data2=0x55;}
else if(mode==1) {data1=0x55;data2=0xaa;}
else return;
Mcs=1;Scs=1;
write_com(Disp_On);
write_com(Col_Add);
for(j=0;j<8;j++)
for(i=0;i<32;i++){
write_data(data1);
write_data(data2);
/*---------------------指定位置显示汉字16*16-----------------------*/
void hz_disp16(unsigned char pag,unsigned char col, unsigned char code *hzk)
unsigned char j=0,i=0;
for(j=0;j<2;j++){
write_com(Page_Add+pag+j);
write_com(Col_Add+col);
for(i=0;i<16;i++) write_data(hzk[16*j+i]);
/*------------------初始化LCD屏--------------------------*/
void init_lcd()
{ Lcd_Rst=0;
delay(100);
Lcd_Rst=1;
delay(100);
Mcs=1;
Scs=1;/////////////////////////////////////////////////////////
delay(100);
write_com(Disp_Off); /////////////////////
write_com(Col_Add);
write_com(Disp_On);
/*------------------------------信息显示------------------------*/
void Msg(int flg)
Clr_Scr();
frame();
if(flg==0){ //显示"测试开始"
Mcs=1;Scs=0;
hz_disp16(3,32,ce);
delay(2000);
hz_disp16(3,48,shi);
delay(2000);
Mcs=0;Scs=1;
hz_disp16(3,0,kai);
delay(2000);
hz_disp16(3,16,shi2);
delay(2000);
else if(flg==1){ //显示"测试完毕"
Mcs=1;Scs=0;
hz_disp16(0,32,ce);
hz_disp16(0,48,shi);
Mcs=0;Scs=1;
hz_disp16(0,0,wan);
hz_disp16(0,16,bi);
Mcs=1;Scs=0;
hz_disp16(3,0,yang);
hz_disp16(3,16,qi);
hz_disp16(3,32,nong);
hz_disp16(3,48,du);
Mcs=0;Scs=1;
hz_disp16(3,0,bai);
hz_disp16(3,16,fen);
hz_disp16(3,32,bi2);
hz_disp16(3,48,wei);
/*--------------------------------键盘扫描-------------------------*/
void Key_Scan()
while(Test_Key);
while(~Test_Key);
/*--------------------主程序-----------AM12864测试程序----------------------*/
main()
unsigned char i=0;
while(1){
// Key_Scan();
init_lcd();
//Disp_Img(FirstPage);
//delay(10000);
// Key_Scan();
Msg(0);
delay(10000);
Disp_H_Line();
delay(10000);
Disp_V_Line();
delay(10000);
Msg(1);
delay(10000);
Clr_Scr();
//while(1);
关键字:AM12864测试  C语言  显示汉字 引用地址:AM12864测试C语言程序
上一篇:单片机抢答器设计
下一篇:基于STM8S207单片机的测试架系统设计
推荐阅读最新更新时间:2024-03-16 13:16
12位A/D转换器ADS7804与51单片机的接口及程序设计
1 基本特点 在计算机控制系统及各类用单片机(或微处理器)构成的智能仪器仪表中,外部的各种模拟信号必须通过A/D转换器变换为数字信号后才能送入计算机。与8位和16位的A/D转换器相比,12位A/D转换器以其较高的性能价格比而在仪器仪表中得到广泛的应用。ADS7804芯片采用28脚0.3英寸PDIP(塑料双列直插式)封装,两列管脚间距为0.3英寸,比一般DIP28封装窄一倍,所以俗称瘦型DIP;ADS7804采用单5V电源供电;芯片内部含有采样保持、电压基准和时钟等电路,可极大简化用户的电路设计和硬件开锁,并可提高系统的稳定性。ADS7804采用CMOS工艺制造,转换速度快、功耗低(最大功耗为100mW)。该A/D转换器采用逐次逼近
[单片机]
pid算法温度控制c语言程序
  温度控制PID自整定原理介绍   整定PID(三模式)控制器   整定温度控制器涉及设置比例、积分和微分值,以得到对特定过 程的可能的最佳控制。如果控制器不包含自动整定算法,或者自 动整定算法未提供适合特定应用的足够控制,则必须用试误法对 装置进行整定。   下面是温度控制器的标准整定步骤。也可以采用其他整定步骤, 但都使用类似的试误法。请注意,如果控制器使用机械式继电器 (而非固态继电器),开始时应使用较长的循环时间(20秒)。   可能需要用到以下定义 :   循环时间 – 也称为工作周期,是控制器完成一个通断循环所 用的总时间长度。示例: 对于20秒的循环时间,10秒接通时 间和10秒切断时间代表50%的功率输出
[单片机]
pid算法温度控制<font color='red'>c语言</font>程序
单片机C语言C51的运算符及表达式
1. 赋值运算符 赋值运算符“=”,在C51中,它的功能是将一个数据的值赋给一个变量,如x=10。利用赋值运算符将一个变量与一个表达式连接起来的式子称为赋值表达式,在赋值表达式的后面加一个分号“;”就构成了赋值语句,一个赋值语句的格式如下: 变量=表达式; 执行时先计算出右边表达式的值,然后赋给左边的变量。例如: x=8+9; /*将8+9的值赋绐变量x*/ x=y=5; /*将常数5同时赋给变量x和y*/ 在C51中,允许在一个语句中同时给多个变量赋值,赋值顺序自右向左。 2. 算术运算符 C51中支持的算术运算符有: + 加或取正值运算符 - 减或取负值运算符
[单片机]
单片机C语言时钟源码
此程序是在51hei单片机开发板上面做的,如需要移植到自己的电路上,修改相应的端口即可 //****80c52***时钟程序 //***手把手教你学单片开发板*** //**2012/9/7***23:02*** # include reg52.h typedef unsigned char uint8; typedef unsigned int uint16; typedef unsigned long uint32; uint8 block ={0xc0,0xf9,0xa4,0xb0,0x99, 0x92,0x82,0xf8,0x80,0x90};//显示数组 uint8 a ; uint16
[单片机]
利用循环左移函数流水灯---单片机C语言编程
#include reg51.h #include intrins.h void delayms(unsigned char ms) // 延时子程序 { unsigned char i; while(ms--) { for(i = 0; i 120; i++); } } main() { unsigned char LED; LED = 0xfe; P0 = LED; while(1) { delayms(250); LED = _crol_(LED,1); //循环左移1位,点亮下一个LED P0 = LED; } }
[单片机]
51单片机C语言教程(一) 建立第一个工程
  学习单片机实在不是件易事,一来要购买高价格的编程器,仿真器,二来要学习编程语言,还有众多种类的单片机选择真是件让人头疼的事。在众多单片机中51架构的芯片风行很久,学习资料也相对很多,是初学的较好的选择之一。51的编程语言常用的有二种,一种是汇编语言,一种是C语言。汇编语言的机器代码生成效率很高但可读性却并不强,复杂一点的程序就更是难读懂,而C语言在大多数情况下其机器代码生成效率和汇编语言相当,但可读性和可移植性却远远超过汇编语言,而且C语言还可以嵌入汇编来解决高时效性的代码编写问题。对于开发 周期 来说,中大型的软件编写用C语言的开发周期通常要小于汇编语言很多。综合以上C语言的优点,我在学习时选择了C语言。以后的教程也只是我在
[单片机]
51单片机<font color='red'>C语言</font>教程(一) 建立第一个工程
基于C语言的I2C总线软件模块设计
1 I2C总线概述   I2C(Intel-Integrated Circuit)总线是荷兰的Philips公司于八十年代初推出的一种芯片间串行总线扩展技术。它用两根线(数据线SDA、时钟线SCL)可完成总线上主机与器件的全双工同步数据传送,可极方便地构成多主机系统和外围器件扩展系统。I2C总线支持所有NMOS、CMOS、TTL等工艺制造的器件,其上所有的节点都连到同名的SDA、SCL上。I2C总方法,数据传送都有相同的操作模式,接口电器特性相同且独立,可在系统供电情况下从系统中移去或增加IC芯片,有I2C接口的外围器件都有应答能力,读写片内单元时有地址自动加1功能,易实现多个字节的自动操作。近年来,国际上有关公司制造了多达
[单片机]
基于<font color='red'>C语言</font>的I2C总线软件模块设计
2051的比较器模拟AD源程序(C语言)
2051的比较器模拟AD源程序(C语言) /* io分配: * ;* OUTPUT: * ;* P1.0 ...... 模拟量输入 * ;* P1.1 ...... DA输入比较基准电压 * ;* P1.2~7..... R-2R DA电阻网络 * ;* P3.7 ...... LED 模拟亮度输出 * ;* CPU CLOCK EQU 6M */ //xiaoqi last edit in 2001.11 //#pragma src #i nclude "AT89x0
[工业控制]
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
