基于MSP430F149单片机驱动DS2762读写操作C语言程序,能够对按键或着其他信号响应,读出电流以及电压量,并进行相应处理。
//#include
#define uchar unsigned char
#define uint unsigned int
uint A,B,C,D,E,F,G,H,I,J;//此处对io430x14x中的宏定义C进行了注释,需注意
#define IO_OUT P3DIR |= BIT0;
#define IO_INP P3DIR &= ~BIT0;
uint data;
对读写时间进行规范化
初始调试采用standard=1的参数
// Pause for exactly 'tick' number of ticks = 0.25us
实际测的A延时14Us
B125US
void SetSpeed(uint standard)
// Adjust tick values depending on speed
if (standard)
// Standard Speed
A = 6 * 4 / 2;
B = 64 * 4 / 2;
C = 60 * 4 / 2;
D = 10 * 4 / 2;
E = 9 * 4 / 2;
F = 55 * 4 / 2;
G = 0 / 2;
H = 480 * 4 / 2;
I = 70 * 4 / 2;
J = 410 * 4 / 2;
else
// Overdrive Speed
A = 1.5 * 4;
B = 7.5 * 4;
C = 7.5 * 4;
D = 2.5 * 4;
E = 0.75 * 4;
F = 7 * 4;
G = 2.5 * 4;
H = 70 * 4;
I = 8.5 * 4;
J = 40 * 4;
延时程序
注意,需要选用8M晶振,时钟周期125ns
void tickDelay(uint tick) // Implementation is platform specific
for(;tick>0;tick--);
主机复位脉冲
当接收结果result为0时,表明从机应答
uchar OWTouchReset(void)
uchar result;
IO_OUT;
tickDelay(G);
P30 = 0; // Drives DQ low
tickDelay(H);
P30 = 1; // Releases the bus
tickDelay(I);
IO_INP;
result = P3IN & 0X01; // Sample for presence pulse from slave
tickDelay(J); // Complete the reset sequence recovery
return result; // Return sample presence pulse result
像写DS2762写入一位
Send a 1-Wire write bit. Provide 10us recovery time.
void OWWriteBit(uchar bit)
if (bit)
// Write '1' bit
tickDelay(A);
tickDelay(B); // Complete the time slot and 10us recovery
else
// Write '0' bit
tickDelay(C);
tickDelay(D);
}[page]
从DS2762读出一位
Read a bit from the 1-Wire bus and return it. Provide 10us recovery time.
uchar OWReadBit(void)
uchar result;
tickDelay(A);
tickDelay(E);
result = P3IN & 0X01; // Sample the bit value from the slave
tickDelay(F); // Complete the time slot and 10us recovery
return result;
像写DS2762写入一个字节
Send a 1-Wire write . Provide 10us recovery time.
DS2762特性发送所有的命令和数据都是字节的低位在前,这与多数串行通信格式相反
void OWWriteByte(uchar data)
uchar loop;
// Loop to write each bit in the byte, LS-bit first
for (loop = 0; loop < 8; loop++)
OWWriteBit(data & 0x01);
// shift the data byte for the next bit
data >>= 1;
从DS2762中读一个字节
uchar OWReadByte(void)
uchar loop, result=0;
// shift the result to get it ready for the next bit
result >>= 1;
// if result is one, then set MS bit
if (OWReadBit())
result |= 0x80;
return result;
发送字符函数
按照论文图时序进行的操作
目前不清楚连续读需要通过测试进行优化。
方案一:发出读命令 发出一个地址 读两次 应该是正确的
方案二:发出读命令 发出两个地址 读两次
uint readvoltage(void)
uchar j = 1;
unsigned char volhigh,vollow;
while(j) //检查2762是否应答
j = OWTouchReset();
OWWriteByte(0xcc); //
OWWriteByte(0x69);
OWWriteByte(0x0c);
vollow = OWReadByte();
volhigh = OWReadByte();
return ((volhigh<<8)|(vollow)); //将两个字节进行合并
时钟初始化
void Init_clk(void)
{unsigned char i;
//时基模块的时钟设置
//单片机上电时,MCLK主时钟的源默认选择为DCO提供.F1系列DCO默认800KHZ.
//ACLK辅助时钟默认为XT1,XT1一般接32768HZ晶体.
//SMCLK子时钟默认为DCO,同样是800KHZ.
//XT2需要人为开启,并要检测其开启是否成功.
BCSCTL1 &= ~(XT2OFF + XTS); //启动XT2高速时钟模块
BCSCTL2 |= SELM1; //MCLK主时钟选XT2为时钟源.TX2输入不分频.
BCSCTL2 &= ~SELS; //SMCLK选为DCO为时钟源.(参考)
//刚才开启了XT2,需要一定时间XT2才进入稳定状态.所以需要等待并检测稳定状态.
//通常采用do...for语法,这是TI推荐的程序写法
do
IFG1 &=~OFIFG; //清OSCFault 标志
for(i=0xff;i>0;i--) //延时等待其开启稳定
while((IFG1 & OFIFG) !=0); //检查OSCFault标志位是否为0,若为0则表示XT2开启稳定.
//否则一直等下去...
主函数
void main()
WDTCTL = WDTPW | WDTHOLD; // 停止看门狗
Init_clk();
SetSpeed(1);
while(1)
data = readvoltage();
