modbus的CRC校验程序
发布者:Yuexiang666最新更新时间:2015-06-12 来源: 51hei关键字:modbus  CRC  校验程序 手机看文章 扫描二维码
随时随地手机看文章
const unsigned char code auchCRCHi[] = {
0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0,
0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0,
0x80, 0x41, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40,
0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1,
0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41,
0x81, 0x40, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0, 0x80, 0x41,
0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x00, 0xC1, 0x81, 0x40,
0x01, 0xC0, 0x80, 0x41, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1,
0x81, 0x40, 0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40,
0x01, 0xC0, 0x80, 0x41, 0x00, 0xC1, 0x81, 0x40, 0x01, 0xC0,
const unsigned char code auchCRCLo[] = {
0x00, 0xC0, 0xC1, 0x01, 0xC3, 0x03, 0x02, 0xC2, 0xC6, 0x06,
0x07, 0xC7, 0x05, 0xC5, 0xC4, 0x04, 0xCC, 0x0C, 0x0D, 0xCD,
0x0F, 0xCF, 0xCE, 0x0E, 0x0A, 0xCA, 0xCB, 0x0B, 0xC9, 0x09,
0x08, 0xC8, 0xD8, 0x18, 0x19, 0xD9, 0x1B, 0xDB, 0xDA, 0x1A,
0x1E, 0xDE, 0xDF, 0x1F, 0xDD, 0x1D, 0x1C, 0xDC, 0x14, 0xD4,
0xD5, 0x15, 0xD7, 0x17, 0x16, 0xD6, 0xD2, 0x12, 0x13, 0xD3,
0x11, 0xD1, 0xD0, 0x10, 0xF0, 0x30, 0x31, 0xF1, 0x33, 0xF3,
0xF2, 0x32, 0x36, 0xF6, 0xF7, 0x37, 0xF5, 0x35, 0x34, 0xF4,
0x3C, 0xFC, 0xFD, 0x3D, 0xFF, 0x3F, 0x3E, 0xFE, 0xFA, 0x3A,
0x3B, 0xFB, 0x39, 0xF9, 0xF8, 0x38, 0x28, 0xE8, 0xE9, 0x29,
0xEB, 0x2B, 0x2A, 0xEA, 0xEE, 0x2E, 0x2F, 0xEF, 0x2D, 0xED,
0xEC, 0x2C, 0xE4, 0x24, 0x25, 0xE5, 0x27, 0xE7, 0xE6, 0x26,
0x22, 0xE2, 0xE3, 0x23, 0xE1, 0x21, 0x20, 0xE0, 0xA0, 0x60,
0x61, 0xA1, 0x63, 0xA3, 0xA2, 0x62, 0x66, 0xA6, 0xA7, 0x67,
0xA5, 0x65, 0x64, 0xA4, 0x6C, 0xAC, 0xAD, 0x6D, 0xAF, 0x6F,
0x6E, 0xAE, 0xAA, 0x6A, 0x6B, 0xAB, 0x69, 0xA9, 0xA8, 0x68,
0x78, 0xB8, 0xB9, 0x79, 0xBB, 0x7B, 0x7A, 0xBA, 0xBE, 0x7E,
0x7F, 0xBF, 0x7D, 0xBD, 0xBC, 0x7C, 0xB4, 0x74, 0x75, 0xB5,
0x77, 0xB7, 0xB6, 0x76, 0x72, 0xB2, 0xB3, 0x73, 0xB1, 0x71,
0x70, 0xB0, 0x50, 0x90, 0x91, 0x51, 0x93, 0x53, 0x52, 0x92,
0x96, 0x56, 0x57, 0x97, 0x55, 0x95, 0x94, 0x54, 0x9C, 0x5C,
0x5D, 0x9D, 0x5F, 0x9F, 0x9E, 0x5E, 0x5A, 0x9A, 0x9B, 0x5B,
0x99, 0x59, 0x58, 0x98, 0x88, 0x48, 0x49, 0x89, 0x4B, 0x8B,
0x8A, 0x4A, 0x4E, 0x8E, 0x8F, 0x4F, 0x8D, 0x4D, 0x4C, 0x8C,
0x44, 0x84, 0x85, 0x45, 0x87, 0x47, 0x46, 0x86, 0x82, 0x42,
0x43, 0x83, 0x41, 0x81, 0x80, 0x40
//函数名:Modbus_crc16
//功能: modbus代码校验
//参数: 字符型指针或数组首地址,数据个数
//返回值: crc数据
//备注:在收到和发送的过程中都需要调用。
unsigned int modbus_crc16(unsigned char *puchMsg,unsigned  int usDataLen)
    unsigned char uchCRCHi=0xFF;  /* 高CRC字节初始化 */
    unsigned char uchCRCLo=0xFF;  /* 低CRC 字节初始化 */
    unsigned long uIndex;         /* CRC循环中的索引 */
    while(usDataLen--)
        uIndex=uchCRCHi^*puchMsg++;
        uchCRCHi=uchCRCLo^auchCRCHi[uIndex];
        uchCRCLo=auchCRCLo[uIndex];
    return (uchCRCHi<<8|uchCRCLo);
//使用时
unsigned int modbus_crc_send;                       //发送时生成crc变量
unsigned int modbus_crc_recevie;                   //接收时解析crc变量
unsigned char Modbus_send_buf[];                 //发送缓冲数组
unsigned char Modbus_recevie_buf[];             //接收缓冲数组
unsigned char len;                                           //数据长度
modbus_crc_send = modbus_crc16(Modbus_send_buf,len);             //生成数据后,将数据放在最后两个字节
modbus_crc_recevie = modbus_crc16(Modbus_recevie_buf,Modbus_recevie_count - 2);  //将生成的数据与接收到的数据进行对比来判断接收的数据是否正确
关键字:modbus  CRC  校验程序 引用地址:modbus的CRC校验程序
上一篇:关于tcp的握手与数据传输
下一篇:s8050电流驱动能力测试实验
推荐阅读最新更新时间:2024-03-16 14:03
10G以太网系统中的并行CRC编解码器的设计
摘要:为了解决10G以太网接入系统中大规模并行CRC编码器的设计问题,提出了矩阵法、代入法、流水线法等三种设计方法。以此为基础,给出了10G以太网接入系统CHC编码器的实现方案。具体计算表明,在10G以太网接入系统采用直接并行的CRC编码器是可行的。直接并行设计CRC编码器已经通过了EDA模拟,并成功地应用于10G以太网接入系统中。 关键词:10G 以太网 CRC 并行 通信系统不可避免地要受到各种干扰的影响,使接收端收到的信息与发送端发出的信息不一致,即接收端收到的信息产生了误码。为了降低数据通信线路传输的误码率,通常有改善数据通信线路传输质量和差错检测控制两种方法。差错检测控制的方法很多,本文讨论在10G以太网接人系统中
[应用]
CRC校验的原理及实现方法
一、CRC校验介绍 循环冗余校验码(CRC),是一种常用的、具有检错、纠错能力的校验码,在早期的通信中运用广泛。循环冗余校验码常用于外存储器和计算机同步通信的数据校验。循环冗余校验是通过某种数学运算来建立数据位和校验位的约定关系的。 与奇偶校验、和校验、异或校验等校验方式不同,CRC校验的计算过程相对复杂很多。 二、模2除法介绍 CRC校验原理虽然看起来比较复杂,其实也不难理解,其根本思想就是先在要发送的帧后面附加一个数,生成一个新帧发送给接收端。当然,这个附加的数不是随意的,它要使所生成的新帧能与发送端和接收端共同选定的某个特定数整除。这里不是直接采用二进制除法,而是采用一种称之为“模2除法”。到
[单片机]
<font color='red'>CRC</font><font color='red'>校验</font>的原理及实现方法
Modbus协议的传输方式
  控制器能设置为两种传输模式(ASCII或RTU)中的任何一种在标准的Modbus网络通信。用户选择想要的模式,包括串口通信参数(波特率、校验方式等),在配置每个控制器的时候,在一个Modbus网络上的所有设备都必须选择相同的传输模式和串口参数。   所选的ASCII或RTU方式仅适用于标准的Modbus网络,它定义了在这些网络上连续传输的消息段的每一位,以及决定怎样将信息打包成消息域和如何解码。   在其它网络上(象MAP和Modbus Plus)Modbus消息被转成与串行传输无关的帧。    1、ASCII模式   当控制器设为在Modbus网络上以ASCII(美国标准信息交换代码)模式通信,在消息中的每个8B
[嵌入式]
基于MODBUS协议的无线数据采集管理系统
        1 MODBUS协议简介         MODBUS是一种工业通信和分布式控制系统协议,由美国著名的可编程控制器制造公司莫迪康公司(MODICON INC)提出,已广泛地应用于工业控制中。MODBUS是一种主从协议,允许一台主机与多台从机通信。在MODBUS中有两种有效的数据传送方式,即ASCII码和RTU方式。本系统采用RTU方式,这种方式的主要优点是在同样的波特率下,RTU方式数据传送效率高。         2 用MODBUS协议构建无线数据采集系统         油田采油厂主要生产数据集中在联合站,一般采油厂有5~10个联合站,站间距离几公里到十几公里,每个联合站有3~4个操作岗位,岗位间距离20~300
[嵌入式]
MODBUS总线控系统的技术特征
  MODBUS通讯协议是一种工业 现场总线 通讯协议,它定义的是一种设备控制器可以识别和使用的信息帧结构,独立于物理层介质,可以承载于多种网络类型中。MODBUS协议把通信参与者规定为“主站”(Master)和“从站”(Slave),数据和信息的通信遵从主/从模式,当它应用于标准MODBUS网络时,信息被直接传送。MODBUS总线网络中的各个智能设备通过异步串行总线连接起来,只允许一个控制器作为主站,其余智能设备作为从站。采用命令/应答的通信方式,主站发出请求,从站应答请求并送回数据或状态信息,从站不能够自己发送信息。MODBUS协议定义的各种信息帧格式,描述了主站控制器访问从站设备的过程,规定从站怎样做出应答响应,以及检查和报告
[嵌入式]
Modbus通信在PLC通道检测中的应用
1 引言     Modbus应用层协议由美国Modicon公司(现为施耐德电气旗下品牌)于1979年开发的,用于实现其PLC产品与上位机的通信。由于其简单易用,得到了广大工业自动化仪器仪表企业的采纳与支持,实际上已成为了业界标准,我国标准化委员会已将Modbus协议作为我国工业自动化的行业标准,分别制定了GB/Z19582.1-2004(Modbus应用层协议),GB/Z19582.2-2004(串行链路上的Modbus)和GB/Z19582.3-2004(Modbus-TCP)三个标准。Modbus应用层协议位于OSI模型中的第七层,将它嵌入到不同的低层协议中形成了三种具体的通信方式:Modbus串行链路、Modbus-P
[嵌入式]
STM32 CRC32与对应的软件CRC32
简单实现STM32 CRC32使用 使用前记得使能STM32 CRC时钟 //STM32硬件CRC32 byte数据计算,将数据移到最高位,低位补上FF u32 stm32_crc32_byte(u8 *pBuff, u32 len) { u32 i; u8 buff ; u32 *p32 = (u32 *)buff; CRC- CR = 1; //复位CRC寄存器 buff = buff = buff = buff = 0XFF; for(i = 0;i len;i ++) { buff = pBuff ; CRC- DR
[单片机]
Modbus的两种传输方式
控制器能设置为两种传输模式(ASCII或RTU)中的任何一种在标准的Modbus网络通信。用户选择想要的模式,包括串口通信参数(波特率、校验方式等),在配置每个控制器的时候,在一个Modbus网络上的所有设备都必须选择相同的传输模式和串口参数。 ASCII模式 : 地址 功能代码 数据数量 数据1 ... 数据n LRC高字节 LRC低字节 回车 换行 RTU模式 地址 功能代码 数据数量 数据1 ... 数据n CRC高字节 CRC低字节
[嵌入式]
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
