最近测试了一个SD5128的驱动,感觉可以 利用M0516LAN的串口来实现,写了一下测试程序,请大家核对一下是否可行。谢谢大家。
附件源码如下:
#include
#include "M051Series.h"
#include "DriverDrvSYS.h"
#include "DriverDrvUART.h"
#include "DriverDrvGPIO.h"
//SD5128的逻辑0是25%的高75%的低,逻辑1是75%的高25%的低,那就是相当于开始25%是固定低,
//结束的25%是固定高,中间50%与逻辑相同,那么就可以简化为数据1000和1110代表逻辑0和逻辑1;
//SD5128的每个像素是3个字节的RGB数据,结束符是一位的低,25位的高,即可表示为0X7FFFFFFF
//串口UART起始位是低,结束位是高,刚好与上面的SD5128的逻辑相反,那么串口数据用6位,
//UART波形取反相后就能与SD5128的占空比符合,每个字符代表SD5128的两个BIT。编码关系如下:
// __________________________________
// |_ST_| D0 | D1 | D2 | D3 | D4 | D5 | SP |
// 00 | 0 1 1 1 0 1 1 1 | = 0x37
// 01 | 0 1 1 1 0 0 0 1 | = 0x07
// 10 | 0 0 0 1 0 1 1 1 | = 0x34
// 11 | 0 0 0 1 0 0 0 1 | = 0x04
unsigned char BIT2BYTE[4]={0x37,0x07,0x34,0x04}; //BIT2BYTE
unsigned char ENDCODE[4] ={0x7F,0xFF,0xFF,0xFF}; //ENDCODE
int SD5128_Init(void)
STR_UART_T sParam;
/* Set UART0 Pin */
DrvGPIO_InitFunction(E_FUNC_UART0);
/* Select UART0 Clock Source From 12Mhz*/
DrvSYS_SelectIPClockSource(E_SYS_UART_CLKSRC,0);
/* Select UART0 Clock Source From PLL*/
// DrvSYS_SelectIPClockSource(E_SYS_UART_CLKSRC,1);
/* UART0 Setting */
sParam.u32BaudRate = 800000; //1000K
sParam.u8cDataBits = DRVUART_DATABITS_6;
sParam.u8cStopBits = DRVUART_STOPBITS_1;
sParam.u8cParity = DRVUART_PARITY_NONE;
sParam.u8cRxTriggerLevel= DRVUART_FIFO_1BYTES;
if(DrvUART_Open(UART_PORT0,&sParam) != E_SUCCESS)
printf("UART0 open failed
return FALSE;
return TRUE;
void SD5128_BYTE(unsigned char *buf,unsigned int length)
int i;
while(length--)
i=6;
while(i>=0)
while(UART0->FSR.TX_FULL == 1);
UART0->DATA = BIT2BYTE[(*buf>>i)&0x3];// printf(" 0x%02x",BIT2BYTE[(*buf>>i)&0x3]);
i=i-2;
buf++;
void SD5128_Test(void)
unsigned int i=0;
unsigned char RGBDATA[3]; //RGB
unsigned int dly;
printf("
printf("*** 9G-M0516 V1.00 Build by yuanxihua@21cn.com on ("__DATE__ " - " __TIME__ ")
printf("*** 9G-M0516 V1.00 Rebooting ...
SD5128_Init();
while(1)
if(i++ > 0xFE) i=0;
RGBDATA[0]=RGBDATA[1]=RGBDATA[2]=i; // printf("
i=%02x |",i);
SD5128_BYTE(RGBDATA,3); // printf(" ||");//send rgbdata
SD5128_BYTE(ENDCODE,4); //send endcode
for(dly=0;dly<50;dly++) DrvSYS_Delay(1000); //delay 50ms
代码结束。
上一篇:基于新唐M0的M0516LAN的SIM900A的驱动测试
下一篇:9G-N79E8X 新唐N79E8X+Keil C51入门开发过程简介
推荐阅读最新更新时间:2024-03-16 14:26
