经典_STM32_ADC多通道采样的例子
发布者:TechVoyager最新更新时间:2015-08-14 来源: eefocus关键字:STM32  ADC  多通道采样 手机看文章 扫描二维码
随时随地手机看文章
STM32 ADC多通道转换
描述:用ADC连续采集11路模拟信号,并由DMA传输到内存。ADC配置为扫描并且连续转换模式,ADC的时钟配置为12MHZ。在每次转换结束后,由DMA循环将转换的数据传输到内存中。ADC可以连续采集N次求平均值。最后通过串口传输出最后转换的结果。
程序如下:
#i nclude "stm32f10x.h" //这个头文件包括STM32F10x所有外围寄存器、位、内存映射的定义
#i nclude "eval.h" //头文件(包括串口、按键、LED的函数声明)
#i nclude "SysTickDelay.h"
#i nclude "UART_INTERFACE.h"
#i nclude
#define N 50 //每通道采50次
#define M 12 //为12个通道
vu16 AD_Value[N][M]; //用来存放ADC转换结果,也是DMA的目标地址
vu16 After_filter[M]; //用来存放求平均值之后的结果
int i;
void GPIO_Configuration(void)
GPIO_InitTypeDef GPIO_InitStructure;
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //因为USART1管脚是以复用的形式接到GPIO口上的,所以使用复用推挽式输出
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
GPIO_Init(GPIOA, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
//PA0/1/2 作为模拟通道输入引脚
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0| GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN; //模拟输入引脚
//PB0/1 作为模拟通道输入引脚
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1;
GPIO_Init(GPIOB, &GPIO_InitStructure);
//PC0/1/2/3/4/5 作为模拟通道输入引脚
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5;
GPIO_Init(GPIOC, &GPIO_InitStructure);
void RCC_Configuration(void)
ErrorStatus HSEStartUpStatus;
RCC_DeInit(); //RCC 系统复位
RCC_HSEConfig(RCC_HSE_ON); //开启HSE
HSEStartUpStatus = RCC_WaitForHSEStartUp(); //等待HSE准备好
if(HSEStartUpStatus == SUCCESS)
FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable); //Enable Prefetch Buffer
FLASH_SetLatency(FLASH_Latency_2); //Set 2 Latency cycles
RCC_HCLKConfig(RCC_SYSCLK_Div1); //AHB clock = SYSCLK
RCC_PCLK2Config(RCC_HCLK_Div1); //APB2 clock = HCLK
RCC_PCLK1Config(RCC_HCLK_Div2); //APB1 clock = HCLK/2
RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_6); //PLLCLK = 12MHz * 6 = 72 MHz
RCC_PLLCmd(ENABLE); //Enable PLL
while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET); //Wait till PLL is ready
RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK); //Select PLL as system clock source
while(RCC_GetSYSCLKSource() != 0x08); //Wait till PLL is used as system clock source
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOB
| RCC_APB2Periph_GPIOC |RCC_APB2Periph_ADC1 | RCC_APB2Periph_AFIO |RCC_APB2Periph_USART1, ENABLE ); //使能ADC1通道时钟,各个管脚时钟
RCC_ADCCLKConfig(RCC_PCLK2_Div6); //72M/6=12,ADC最大时间不能超过14M
RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE); //使能DMA传输
void ADC1_Configuration(void)
ADC_InitTypeDef ADC_InitStructure;
ADC_DeInit(ADC1); //将外设 ADC1 的全部寄存器重设为缺省值
ADC_InitStructure.ADC_Mode = ADC_Mode_Independent; //ADC工作模式:ADC1和ADC2工作在独立模式
ADC_InitStructure.ADC_ScanConvMode =ENABLE; //模数转换工作在扫描模式
ADC_InitStructure.ADC_ContinuousConvMode = ENABLE; //模数转换工作在连续转换模式
ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None; //外部触发转换关闭
ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right; //ADC数据右对齐
ADC_InitStructure.ADC_NbrOfChannel = M; //顺序进行规则转换的ADC通道的数目
ADC_Init(ADC1, &ADC_InitStructure); //根据ADC_InitStruct中指定的参数初始化外设ADCx的寄存器
//设置指定ADC的规则组通道,设置它们的转化顺序和采样时间
//ADC1,ADC通道x,规则采样顺序值为y,采样时间为239.5周期
ADC_RegularChannelConfig(ADC1, ADC_Channel_0, 1, ADC_SampleTime_239Cycles5 );
ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 2, ADC_SampleTime_239Cycles5 );
ADC_RegularChannelConfig(ADC1, ADC_Channel_2, 3, ADC_SampleTime_239Cycles5 );
ADC_RegularChannelConfig(ADC1, ADC_Channel_3, 4, ADC_SampleTime_239Cycles5 );
ADC_RegularChannelConfig(ADC1, ADC_Channel_8, 5, ADC_SampleTime_239Cycles5 );
ADC_RegularChannelConfig(ADC1, ADC_Channel_9, 6, ADC_SampleTime_239Cycles5 );
ADC_RegularChannelConfig(ADC1, ADC_Channel_10, 7, ADC_SampleTime_239Cycles5 );
ADC_RegularChannelConfig(ADC1, ADC_Channel_11, 8, ADC_SampleTime_239Cycles5 );
ADC_RegularChannelConfig(ADC1, ADC_Channel_12, 9, ADC_SampleTime_239Cycles5 );
ADC_RegularChannelConfig(ADC1, ADC_Channel_13, 10, ADC_SampleTime_239Cycles5 );
ADC_RegularChannelConfig(ADC1, ADC_Channel_14, 11, ADC_SampleTime_239Cycles5 );
ADC_RegularChannelConfig(ADC1, ADC_Channel_15, 12, ADC_SampleTime_239Cycles5 );
// 开启ADC的DMA支持(要实现DMA功能,还需独立配置DMA通道等参数)
ADC_DMACmd(ADC1, ENABLE);[page]
ADC_Cmd(ADC1, ENABLE); //使能指定的ADC1
ADC_ResetCalibration(ADC1); //复位指定的ADC1的校准寄存器
while(ADC_GetResetCalibrationStatus(ADC1)); //获取ADC1复位校准寄存器的状态,设置状态则等待
ADC_StartCalibration(ADC1); //开始指定ADC1的校准状态
while(ADC_GetCalibrationStatus(ADC1)); //获取指定ADC1的校准程序,设置状态则等待
void DMA_Configuration(void)
DMA_InitTypeDef DMA_InitStructure;
DMA_DeInit(DMA1_Channel1); //将DMA的通道1寄存器重设为缺省值
DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)&ADC1->DR; //DMA外设ADC基地址
DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&AD_Value; //DMA内存基地址
DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC; //内存作为数据传输的目的地
DMA_InitStructure.DMA_BufferSize = N*M; //DMA通道的DMA缓存的大小
DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable; //外设地址寄存器不变
DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable; //内存地址寄存器递增
DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord; //数据宽度为16位
DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord; //数据宽度为16位
DMA_InitStructure.DMA_Mode = DMA_Mode_Circular; //工作在循环缓存模式
DMA_InitStructure.DMA_Priority = DMA_Priority_High; //DMA通道 x拥有高优先级
DMA_InitStructure.DMA_M2M = DMA_M2M_Disable; //DMA通道x没有设置为内存到内存传输
DMA_Init(DMA1_Channel1, &DMA_InitStructure); //根据DMA_InitStruct中指定的参数初始化DMA的通道
//配置所有外设
void Init_All_Periph(void)
RCC_Configuration();
GPIO_Configuration();
ADC1_Configuration();
DMA_Configuration();
//USART1_Configuration();
USART_Configuration(9600);
u16 GetVolt(u16 advalue)
return (u16)(advalue * 330 / 4096); //求的结果扩大了100倍,方便下面求出小数
void filter(void)
int sum = 0;
u8 count;
for(i=0;i<12;i++)
for ( count=0;count
sum += AD_Value[count][i];
After_filter[i]=sum/N;
sum=0;
int main(void)
u16 value[M];
init_All_Periph();
SysTick_Initaize();
ADC_SoftwareStartConvCmd(ADC1, ENABLE);
DMA_Cmd(DMA1_Channel1, ENABLE); //启动DMA通道
while(1)
while(USART_GetFlagStatus(USART1,USART_FLAG_TXE)==RESET);//等待传输完成否则第一位数据容易丢失
filter();
for(i=0;i<12;i++)
value[i]= GetVolt(After_filter[i]);
printf("value[%d]:t%d.%dvn",i,value[i]/100,value[i]0) ;
delay_ms(100);
总结
该程序中的两个宏定义,M和N,分别代表有多少个通道,每个通道转换多少次,可以修改其值。
曾出现的问题:配置时钟时要知道外部晶振是多少,以便准确配置时钟。将转换值由二进制转换为十进制时,要先扩大100倍,方便显示小数。最后串口输出时在 printf语句之前加这句代码,防止输出的第一位数据丢失:while(USART_GetFlagStatus(USART1,USART_FLAG_TXE)==RESET);
关键字:STM32  ADC  多通道采样 引用地址:经典_STM32_ADC多通道采样的例子
上一篇:STM32学习笔记——学前准备
下一篇:STM32学习笔记——RCC系统时钟配置
推荐阅读最新更新时间:2024-03-16 14:28
基于STM32LED书写点阵屏设计与实现
  近年来,随着信息产业的高速发展,点阵LED 显示屏已广泛应用于金融行业、邮电行业、体育馆、广告业等各种广告发布和信息显示系统,成为信息传送的重要手段。本文介绍的LED 书写点阵屏,不但可以像普通显示屏一样作为信息输出设备,而且可以通过光笔直接在LED 显示屏上进行信息输入,普通的显示屏也具有"手写"的功能了。    1 硬件系统设计   本系统总体框图如图1 所示,由键盘与显示模块、光笔模块、LED 点阵屏模块、STM32 控制模块、电源模块五部分组成。 图1 总体方案方框图    1. 1 核心控制模块   本系统以STM32F103VCT6 为控制核心。   STM32 是32 位微处理器,
[电源管理]
STM32_DAC输出三角波形
今天的软件工程下载地址(360云盘): https://yunpan.cn/cPi8GB2DyeKzI 访问密码 1a45 STM32F10x的资料可以在我360云盘下载: https://yunpan.cn/crBUdUGdYKam2 访问密码 ca90 工程概要说明:该工程通过配置,输出固定三角波形,频率和幅度也是固定的,当然也是可以变化,如果有朋友需要可以微信公众号中留言。 关于“STM32F103 DAC输出三角波形” 我把重要的几点在下面分别讲述,若不明白,请关注微信公众号“EmbeddDeveloper”查阅或留言。 一、RCC时钟配置 该函数位于在bsp.c文件下面; 使能RCC时钟:RC
[单片机]
STM32_DAC输出三角波形
stm32 RAM分配及占有
一个小的项目,在测试时间和产品量稍微大一些之后,出现了一些莫名其妙的非逻辑错误的Bug(最头疼的是不能每次都能复制出来)。经过修改后,最近一个月的测试都没有出现。本人在这里得到了原子哥和其他朋友的很多帮助,也把自己的一些经验分享给各位,也欢迎大家指正。 1. 程序偶尔会出现一些Bug,经过output串口信息发现一些堆栈的临时变量被莫名其妙的修改。 stm32103rbt6的内存是20K,算比较小了,看到程序出错的那个函数申请了很多零时变量,也需要访问很多全局变量。猜想是内存被其他操作更改所致。 解决ram被使用过多的一个方法是尽量少用全局变量,能用const就用一定用const变量,因为这样会放在flash,而不是ram. 我的
[单片机]
意法半导体STM32十周年:出货超过24亿,已构建起强大生态
集微网 4月25日报道 俗话说“十年磨一剑”,而从2007年起意法半导体(ST)推出第一颗STM32以来至今恰好十年,该系列产品不仅出货量超过20亿颗,而且还构建起了庞大、强壮的产业生态链。 4月25日,ST在深圳专门召开了“STM32中国峰会”。据悉,这是继2016年在深圳举行的首届STM32中国峰会取得了成功后第二次举办。本次峰会以“专注生态合作,整合技术创新”为主题,特别聚焦智能硬件、智慧城市和智能工业等热点领域。现场除了ST展示十年来STM32 的发展成果外,还邀请了众多合作伙伴分享与ST的合作经验。 会议具体安排上,4月25日为意法半导体高层主旨演讲及STM32生态系统伙伴针对智能硬件、智慧城市和智能工业的分论坛
[手机便携]
STM32】TIM---基本定时器
一、TIM 简介 定时器最基本功能:定时 定时发送 USART 数据 定时采集 AD 数据等 定时器与 GPIO 结合 测量输入信号脉冲宽度 产生输出波形 等 ▲ 各个定时器的特性 二、基本定时器 基本定时器 :TIM6 和 TIM7 ,基本功能完全一样,但所占资源彼此完全独立。 ▲ 基本定时器的功能框图 基本定时器时钟只能来自内部时钟 基本定时器的内部时钟(CK_INT)频率为 84MHz 基 本定时器还专门用于 DAC 转换触发 只要设置 CK_PSC 和 TIMx_ARR 这两个寄存器的值就可以控制事件生成的时间 三、定时器周期计算 T o u t ToutTout:溢出时间,即定时多长时间
[单片机]
【<font color='red'>STM32</font>】TIM---基本定时器
STM32串口IAP
让STM32的应用程序能够通过串口在线升级,这就是STM32的串口IAP。要实现串口升级,简单来说,就是给STM32编写一个bootloader引导程序,就想计算机的BIOS一样,在这段代码中接收串口的数据,然后将数据固化到STM32内部指定的flash地址空间中,接着再跑到这段代码执行。 接触过Linux uboot的应该会注意到,除了功能的实现外,bootloader的界面设计也非常重要。通过串口在计算机的串口软件中实现一个简洁的界面,列出bootloader的各项功能,并支持用户选择。实现这样一个人际交互的界面也是一个优秀的bootloader必不可少的一部分。 本文就要讲讲如何设计这个有功能有界面的bootloader程
[单片机]
<font color='red'>STM32</font>串口IAP
STM32 串口通讯 发送 接收
STM32的使用有利有弊,种类多---但是种类有太多,资料也是比较乱的,还有就是库的调用,经常忘记一些函数的使用------比如最常用的串口------ ------------------------------------------------------------------------------USART ----设置------------------------------- void USART1_Config(void) { GPIO_InitTypeDef GPIO_InitStructure; USART_InitTypeDef USART_InitStructure; RCC
[单片机]
详解STM32定时器捕获功能
一、STM32定时器捕获功能 STM32的定时器是支持信号输入捕获的,何为输入捕获?主要做什么应用? 输入捕获:通过检测TIMx_CHx上的边沿信号,在边沿信号发生跳变的时候,将当前的定时器的值(TIMx_CNT)存放到对应的捕获比较寄存器里面,完成一次捕获。输入捕获主要应用于测量信号的脉宽或频率。 下图是定时器原理图的输入捕获框图部分 第一部分是设置滤波器,用来对信号进行滤波,信号从TI1输入,通过滤波器,输出TIF信号,正常情况下信号没有抖动,TI1F信号等于TI1的输入信号。 ICF 用来设置输入采样频率的数字滤波器的长度,如ICF=0011,会在捕获上升沿时,以fCK_INT的频率连续采样八次通道1的信号电平,
[单片机]
详解<font color='red'>STM32</font>定时器捕获功能
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
