个人觉得这章内容过于复杂,只需要记住如果nand中4096的程序想要被拷贝出来执行,就把这个代码写进去,红色部分是真正的代码,可以复制过去,直接使用,其他就不做了解了。听了一个小时,这个老师讲的也挺乱的,也没有人能记住这么多东西吧。。。
对于这里,我是这样理解的 。head.o init.o nand.o都放在Nand flash0地址处,0x0000 0000是他的链接地址,也就是放在0x0000 0000处运行;mian.o存放在Nand flash 4096地址处,0x3000 0000是他的链接地址,也就是放在0x3000 0000处运行
#define LARGER_NAND_PAGE
#define GSTATUS1 (*(volatile unsigned int *)0x560000B0)
#define BUSY 1
#define NAND_SECTOR_SIZE 512
#define NAND_BLOCK_MASK (NAND_SECTOR_SIZE - 1)
#define NAND_SECTOR_SIZE_LP 2048
#define NAND_BLOCK_MASK_LP (NAND_SECTOR_SIZE_LP - 1)
typedef unsigned int S3C24X0_REG32;
typedef struct {
S3C24X0_REG32 NFCONF;
S3C24X0_REG32 NFCMD;
S3C24X0_REG32 NFADDR;
S3C24X0_REG32 NFDATA;
S3C24X0_REG32 NFSTAT;
S3C24X0_REG32 NFECC;
} S3C2410_NAND;
typedef struct {
S3C24X0_REG32 NFCONT;
S3C24X0_REG32 NFMECCD0;
S3C24X0_REG32 NFMECCD1;
S3C24X0_REG32 NFSECCD;
S3C24X0_REG32 NFESTAT0;
S3C24X0_REG32 NFESTAT1;
S3C24X0_REG32 NFMECC0;
S3C24X0_REG32 NFMECC1;
S3C24X0_REG32 NFSECC;
S3C24X0_REG32 NFSBLK;
S3C24X0_REG32 NFEBLK;
} S3C2440_NAND;
typedef struct {
void (*nand_reset)(void);
void (*wait_idle)(void);
void (*nand_select_chip)(void);
void (*nand_deselect_chip)(void);
void (*write_cmd)(int cmd);
void (*write_addr)(unsigned int addr);
unsigned char (*read_data)(void);
}t_nand_chip;
static S3C2410_NAND * s3c2410nand = (S3C2410_NAND *)0x4e000000;
static S3C2440_NAND * s3c2440nand = (S3C2440_NAND *)0x4e000000;
static t_nand_chip nand_chip;
void nand_init(void);
void nand_read(unsigned char *buf, unsigned long start_addr, int size);
static void nand_reset(void);
static void wait_idle(void);
static void nand_select_chip(void);
static void nand_deselect_chip(void);
static void write_cmd(int cmd);
static void write_addr(unsigned int addr);
static unsigned char read_data(void);
static void s3c2410_nand_reset(void);
static void s3c2410_wait_idle(void);
static void s3c2410_nand_select_chip(void);
static void s3c2410_nand_deselect_chip(void);
static void s3c2410_write_cmd(int cmd);
static void s3c2410_write_addr(unsigned int addr);
static unsigned char s3c2410_read_data();
static void s3c2440_nand_reset(void);
static void s3c2440_wait_idle(void);
static void s3c2440_nand_select_chip(void);
static void s3c2440_nand_deselect_chip(void);
static void s3c2440_write_cmd(int cmd);
static void s3c2440_write_addr(unsigned int addr);
static unsigned char s3c2440_read_data(void);
s3c2410_nand_select_chip();
s3c2410_write_cmd(0xff); // 复位命令
s3c2410_wait_idle();
s3c2410_nand_deselect_chip();
int i;
volatile unsigned char *p = (volatile unsigned char *)&s3c2410nand->NFSTAT;
while(!(*p & BUSY))
for(i=0; i<10; i++);
int i;
s3c2410nand->NFCONF &= ~(1<<11);
s3c2410nand->NFCONF |= (1<<11);
volatile unsigned char *p = (volatile unsigned char *)&s3c2410nand->NFCMD;
*p = cmd;
int i;
volatile unsigned char *p = (volatile unsigned char *)&s3c2410nand->NFADDR;
*p = addr & 0xff;
*p = (addr >> 9) & 0xff;
*p = (addr >> 17) & 0xff;
*p = (addr >> 25) & 0xff;
static unsigned char s3c2410_read_data(void)
volatile unsigned char *p = (volatile unsigned char *)&s3c2410nand->NFDATA;
return *p;
s3c2440_nand_select_chip();
s3c2440_write_cmd(0xff); // 复位命令
s3c2440_wait_idle();
s3c2440_nand_deselect_chip();
int i;
volatile unsigned char *p = (volatile unsigned char *)&s3c2440nand->NFSTAT;
while(!(*p & BUSY))
int i;
s3c2440nand->NFCONT &= ~(1<<1);
s3c2440nand->NFCONT |= (1<<1);
volatile unsigned char *p = (volatile unsigned char *)&s3c2440nand->NFCMD;
*p = cmd;
int i;
volatile unsigned char *p = (volatile unsigned char *)&s3c2440nand->NFADDR;
*p = addr & 0xff;
[page]
static void s3c2440_write_addr_lp(unsigned int addr)
int i;
int col, page;
col = addr & NAND_BLOCK_MASK_LP;
page = addr / NAND_SECTOR_SIZE_LP;
*p = col & 0xff;
*p = (col >> 8) & 0x0f;
*p = page & 0xff;
*p = (page >> 8) & 0xff;
*p = (page >> 16) & 0x03;
volatile unsigned char *p = (volatile unsigned char *)&s3c2440nand->NFDATA;
return *p;
nand_chip.nand_reset();
nand_chip.wait_idle();
int i;
nand_chip.nand_select_chip();
nand_chip.nand_deselect_chip();
nand_chip.write_cmd(cmd);
nand_chip.write_addr(addr);
return nand_chip.read_data();
#define TACLS 0
#define TWRPH0 3
#define TWRPH1 0
if ((GSTATUS1 == 0x32410000) || (GSTATUS1 == 0x32410002))
nand_chip.nand_reset = s3c2410_nand_reset;
nand_chip.wait_idle = s3c2410_wait_idle;
nand_chip.nand_select_chip = s3c2410_nand_select_chip;
nand_chip.nand_deselect_chip = s3c2410_nand_deselect_chip;
nand_chip.write_cmd = s3c2410_write_cmd;
nand_chip.write_addr = s3c2410_write_addr;
nand_chip.read_data = s3c2410_read_data;
s3c2410nand->NFCONF = (1<<15)|(1<<12)|(1<<11)|(TACLS<<8)|(TWRPH0<<4)|(TWRPH1<<0);
else
nand_chip.nand_reset = s3c2440_nand_reset;
nand_chip.wait_idle = s3c2440_wait_idle;
nand_chip.nand_select_chip = s3c2440_nand_select_chip;
nand_chip.nand_deselect_chip = s3c2440_nand_deselect_chip;
nand_chip.write_cmd = s3c2440_write_cmd;
#ifdef LARGER_NAND_PAGE
nand_chip.write_addr = s3c2440_write_addr_lp;
#else
nand_chip.write_addr = s3c2440_write_addr;
#endif
nand_chip.read_data = s3c2440_read_data;
s3c2440nand->NFCONF = (TACLS<<12)|(TWRPH0<<8)|(TWRPH1<<4);
s3c2440nand->NFCONT = (1<<4)|(1<<1)|(1<<0);
nand_reset();
int i, j;
if ((start_addr & NAND_BLOCK_MASK_LP) || (size & NAND_BLOCK_MASK_LP)) {
return ;
#else
if ((start_addr & NAND_BLOCK_MASK) || (size & NAND_BLOCK_MASK)) {
return ;
#endif
nand_select_chip();
for(i=start_addr; i < (start_addr + size);) {
write_cmd(0);
write_addr(i);
write_cmd(0x30);
#endif
wait_idle();
for(j=0; j < NAND_SECTOR_SIZE_LP; j++, i++) {
#else
for(j=0; j < NAND_SECTOR_SIZE; j++, i++) {
#endif
*buf = read_data();
buf++;
return ;
