stm32应用-简单的串口接收与发送程序
发布者:WanderlustGlow最新更新时间:2015-11-18 来源: eefocus关键字:stm32  串口接收  发送程序 手机看文章 扫描二维码
随时随地手机看文章
与上位机的串口通信是一个很常用的程序。碧海蓝天在刚刚接触stm32芯片时写的第一个简单程序就是串口通信,现在把程序代码甩出来与大家分享。完整的程序哦~一般人我不告诉他
 库版本  :ST3.0.0
文件:mian.c
//功能:串口初始化、打开定时器中断,然后一直接收数据状态就好了。发送在中断中实现
#include "stm32f10x.h"
#include "usart.h"
u8 USART_rx_data;
int main(void)
  RCC_Configuration();      //系统时钟配置
  GPIO_Configuration();      //端口初始化
  NVIC_Configuration();      //中断源配置
  USART_Configuration();     //串口1初始化
  Time_Init();            //定时器初始化
  #ifdef DEBUG
      debug();
  #endif
  TIM_Cmd(TIM3,ENABLE);
   while(1)
文件:usart.c
#include "stdio.h"
#include "usart.h"
  unsigned char auchCRCHi [256] ={
  0x00,0xC1,0x81,0x40,0x01,0xC0,0x80,0x41,0x01,0xC0,0x80,0x41,0x00,0xC1,0x81,0x40,
  0x01,0xC0,0x80,0x41,0x00,0xC1,0x81,0x40,0x00,0xC1,0x81,0x40,0x01,0xC0,0x80,0x41,
  0x00,0xC1,0x81,0x40,0x01,0xC0,0x80,0x41,0x01,0xC0,0x80,0x41,0x00,0xC1,0x81,0x40};
  unsigned char auchCRCLo [256] ={
  0x00,0xC0,0xC1,0x01,0xC3,0x03,0x02,0xC2,0xC6,0x06,0x07,0xC7,0x05,0xC5,0xC4,0x04,
  0xCC,0x0C,0x0D,0xCD,0x0F,0xCF,0xCE,0x0E,0x0A,0xCA,0xCB,0x0B,0xC9,0x09,0x08,0xC8,
  0xD8,0x18,0x19,0xD9,0x1B,0xDB,0xDA,0x1A,0x1E,0xDE,0xDF,0x1F,0xDD,0x1D,0x1C,0xDC,
  0x14,0xD4,0xD5,0x15,0xD7,0x17,0x16,0xD6,0xD2,0x12,0x13,0xD3,0x11,0xD1,0xD0,0x10,
  0xF0,0x30,0x31,0xF1,0x33,0xF3,0xF2,0x32,0x36,0xF6,0xF7,0x37,0xF5,0x35,0x34,0xF4,
  0x3C,0xFC,0xFD,0x3D,0xFF,0x3F,0x3E,0xFE,0xFA,0x3A,0x3B,0xFB,0x39,0xF9,0xF8,0x38,
  0x28,0xE8,0xE9,0x29,0xEB,0x2B,0x2A,0xEA,0xEE,0x2E,0x2F,0xEF,0x2D,0xED,0xEC,0x2C,
  0xE4,0x24,0x25,0xE5,0x27,0xE7,0xE6,0x26,0x22,0xE2,0xE3,0x23,0xE1,0x21,0x20,0xE0,
  0xA0,0x60,0x61,0xA1,0x63,0xA3,0xA2,0x62,0x66,0xA6,0xA7,0x67,0xA5,0x65,0x64,0xA4,
  0x6C,0xAC,0xAD,0x6D,0xAF,0x6F,0x6E,0xAE,0xAA,0x6A,0x6B,0xAB,0x69,0xA9,0xA8,0x68,
  0x78,0xB8,0xB9,0x79,0xBB,0x7B,0x7A,0xBA,0xBE,0x7E,0x7F,0xBF,0x7D,0xBD,0xBC,0x7C,
  0xB4,0x74,0x75,0xB5,0x77,0xB7,0xB6,0x76,0x72,0xB2,0xB3,0x73,0xB1,0x71,0x70,0xB0,
  0x50,0x90,0x91,0x51,0x93,0x53,0x52,0x92,0x96,0x56,0x57,0x97,0x55,0x95,0x94,0x54,
  0x9C,0x5C,0x5D,0x9D,0x5F,0x9F,0x9E,0x5E,0x5A,0x9A,0x9B,0x5B,0x99,0x59,0x58,0x98,
  0x88,0x48,0x49,0x89,0x4B,0x8B,0x8A,0x4A,0x4E,0x8E,0x8F,0x4F,0x8D,0x4D,0x4C,0x8C,
  0x44,0x84,0x85,0x45,0x87,0x47,0x46,0x86,0x82,0x42,0x43,0x83,0x41,0x81,0x80,0x40};
unsigned short CRC16(unsigned char* puchMsg, unsigned short usDataLen)
  unsigned char uchCRCHi = 0xFF ;
  unsigned char uchCRCLo = 0xFF ;
  unsigned char uIndex ;
  while (usDataLen--)
    uIndex = uchCRCHi^*puchMsg++;
    uchCRCHi = uchCRCLo^auchCRCHi[uIndex];
    uchCRCLo = auchCRCLo[uIndex];
  return (uchCRCHi << 8 | uchCRCLo) ;
void RCC_Configuration(void)
  ErrorStatus HSEStartUpStatus;      //枚举变量,定义高速时钟的启动状态
  RCC_DeInit();                   //RCC系统重置,用于Debug目的
  RCC_HSEConfig(RCC_HSE_ON);                 //使能高速时钟源HSE
  HSEStartUpStatus = RCC_WaitForHSEStartUp();    //等待HSE稳定
  if(HSEStartUpStatus == SUCCESS)
    FLASH_SetLatency(FLASH_Latency_2);
 FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
    RCC_HCLKConfig(RCC_SYSCLK_Div1);         // HCLK = SYSCLK
    RCC_PCLK2Config(RCC_HCLK_Div1);          // PCLK2 = HCLK
    RCC_PCLK1Config(RCC_HCLK_Div2);         ///PCLK1 = HCLK/2
    RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
    RCC_PLLCmd(ENABLE);
    while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET){}
    RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
    while(RCC_GetSYSCLKSource() != 0x08){}
  RCC_APB2PeriphClockCmd( RCC_APB2Periph_USART1 |RCC_APB2Periph_GPIOA |RCC_APB2Periph_AFIO |RCC_APB2Periph_GPIOB , ENABLE);
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);
//函数名:void GPIO_Configuration()
//输入参数:null
//返回参数:null
//说明:GPIO初始化函数
void GPIO_Configuration(void)
  GPIO_InitTypeDef GPIO_InitStructure;     //GPIO初始化结构体声明
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;          //USART1 TX
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;    //复用推挽输出
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_Init(GPIOA, &GPIO_InitStructure);      //A端口
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;          //USART1 RX
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;   //复用浮空输入
 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6;
 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
 GPIO_Init(GPIOB, &GPIO_InitStructure);
//函数名:void NVIC_Configuration()
//输入参数:null
//返回参数:null
//说明:NVIC初始化函数
void NVIC_Configuration(void)
  NVIC_InitTypeDef NVIC_InitStructure;       //NVIC初始化结构体声明
  #ifdef VECT_TAB_RAM
    NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0); //如果程序在RAM中调试那么定义中断向量表在RAM中否则在Flash中
  #else
    NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
  #endif
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
  NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;         //设置串口1中断
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;         //抢占优先级 0
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;    //子优先级为0
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;     //使能
  NVIC_Init(&NVIC_InitStructure);
  NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn;           //设置定时器3全局中断
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;        //抢占优先级 1
//函数名:void USART_Configuration()
//输入参数:null
//返回参数:null
//说明:串口初始化函数
void USART_Configuration(void){
  USART_InitTypeDef USART_InitStructure;                   //串口初始化结构体声明
  USART_ClockInitTypeDef USART_ClockInitStruct;
  USART_InitStructure.USART_BaudRate = 115200;      //设置波特率为115200bps
  USART_InitStructure.USART_WordLength = USART_WordLength_8b;  //数据位8位
  USART_InitStructure.USART_StopBits = USART_StopBits_1;   //停止位1位
  USART_InitStructure.USART_Parity = USART_Parity_No;    //无校验位
  USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;   //无硬件流控
  USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;     //接受和发送模式都打开
  USART_ClockInitStruct.USART_Clock=USART_Clock_Disable;      //串口时钟禁止
  USART_ClockInitStruct.USART_CPOL=USART_CPOL_Low;        //数据低电平有效
  USART_ClockInitStruct.USART_CPHA=USART_CPHA_2Edge;    //配置CPHA使数据在第2个边沿的时候被捕获
  USART_ClockInitStruct.USART_LastBit=USART_LastBit_Disable;  // 禁用最后一位,使对应的时钟脉冲不会再输出到SCLK引脚
  USART_ClockInit(USART1, &USART_ClockInitStruct);      //配置USART与时钟相关的设置
  USART_Init(USART1, &USART_InitStructure);       //配置串口参数函数
  USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);       //使能接收中断
//USART_ITConfig(USART1, USART_IT_TXE, ENABLE);    //使能发送缓冲空中断
//USART_ITConfig(USART1, USART_IT_TC, ENABLE);    //使能发送完成中断
  USART_ClearFlag(USART1,USART_FLAG_TC);         //清除发送完成标志位
  USART_Cmd(USART1, ENABLE);         //使能串口1
}[page]
//函数名:void Time_Init()
//输入参数:null
//返回参数:null
//说明:定时器初始化函数
void Time_Init(void)
  TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
  TIM_DeInit(TIM3);            //复位TIM3定时器
  TIM_TimeBaseStructure.TIM_Period =7999;          //设置自动重装载寄存器锁存值,1ms溢出
  TIM_TimeBaseStructure.TIM_Prescaler = 8;      //9分频
  TIM_TimeBaseStructure.TIM_ClockDivision = 0x0;       //时钟分频因子
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //计数器向上计数模式
  TIM_TimeBaseInit(TIM3,&TIM_TimeBaseStructure);    //写TIM3各寄存器参数
  TIM_ClearFlag(TIM3,TIM_FLAG_Update);
  TIM_ITConfig(TIM3,TIM_IT_Update,ENABLE);
文件:usart.h
#ifndef _USART_H
#define _USART_H
#include
void RCC_Configuration(void);   //声明RCC初始化函数
void GPIO_Configuration(void);   //声明GPIO初始化函数
void NVIC_Configuration(void);   //声明NVIC初始化函数
void USART_Configuration(void);   //声明串口初始化函数
void Time_Init(void);     //声明定时器初始化函数
unsigned short CRC16(unsigned char* puchMsg, unsigned short usDataLen);
#endif
文件:stm32f103x_it.c
//需要设置串口接收中断和定时器3中断,中断时间为1ms
//函数名:void USART1_IRQHandler(void)
//输入参数:null
//返回参数:null
//说明:串口接收中断服务
  if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET)          //判断读寄存器是否非空
//    GPIO_SetBits(GPIOB,GPIO_Pin_6);
    rx_data[RbufCounter++]=USART_ReceiveData(USART1);    //接收字节到接收缓冲区
    if(USART_Rsv_Status==0)
      if(RbufCounter>1)
        if(rx_data[0]==0xA5&&rx_data[1]==0x5A)    //当接收到的数据帧头两个字节同时为0xA5和0x5A时
          USART_Rsv_Status=1;
//           USART_SendData(USART1, rx_data[0]);
        else
          rx_data[0]=rx_data[1];
          RbufCounter=1;
    else
      USART_1ms_Cnt=0;
//函数名:void TIM2_IRQHandler(void)
//输入参数:null
//返回参数:null
//说明:定时器2中断服务
//函数名:void TIM3_IRQHandler(void)
//输入参数:null
//返回参数:null
//说明:定时器3中断服务
  if(TIM_GetITStatus(TIM3,TIM_IT_Update)!=RESET)        //判断是否为定时器3溢出中断
    TIM_ClearITPendingBit(TIM3, TIM_IT_Update);  //清中断标记
    if(USART_Rsv_Status==1)
    USART_1ms_Cnt++;
    if(USART_1ms_Cnt>5)
//      USART_SendData(USART1,0xAA);
      USART_Rsv_Status=0;     //连续计数超过5次对USART_Rsv_Status置0,继续等待接收
      USART_1ms_Cnt=0;         //当USART_1ms_Cnt>5时对USART_1ms_Cnt重新清零
      if(RbufCounter==(u16)rx_data[4]+7)              //检验数据的完整性
         int i;     //定义循环变量
        int j;
        data_length=rx_data[4];
        for(i=0;i
          data[i]=rx_data[i];
        CRC_data_Hi=rx_data[RbufCounter-1];
        CRC_data_Lo=rx_data[RbufCounter-2];
        CRC_data=CRC16((unsigned char*)data,data_length+5);
        CRC_data_Hi1=CRC_data>>8;
        CRC_data_Lo1=CRC_data&0x00ff;
         if(CRC_data_Hi==(u8)CRC_data_Hi1 && CRC_data_Lo==CRC_data_Lo1)
           for(j=0;rx_data[j]!='';j++)   //循环逐字输出,到结束字''
             USART_SendData(USART1, rx_data[j]);     //发送字符
             while(USART_GetFlagStatus(USART1, USART_FLAG_TXE) == RESET)
             } //等待字符发送完毕
      RbufCounter=0;
关键字:stm32  串口接收  发送程序 引用地址:stm32应用-简单的串口接收与发送程序
上一篇:STM32之串口通信
下一篇:STM32驱动TFT显示屏ILI9325
推荐阅读最新更新时间:2024-03-16 14:40
STM32中按键中断分析(附源码)
  在按键学习中,我们有用到查询的方法来判断按键事件是否发生,这种查询按键事件适用于程序工作量较少的情况下,一旦程序中工作量较大较多,则势必影响程序运行的效率,为了简化程序中控制的功能模块的执行时间,引入中断控制就很有必要,,一旦有中断时间发生,则程序立马跳转到中断向量的执行程序中,执行完成后就恢复到正常的程序状态。   在STM32F中采用中断控制器NVIC来设定中断。按照中断初始化配置的结构体文件,我们需要在NVIC初始化结构体配置如下:   void EXti_PB12_Config(void)   {   //定义结构体   GPIO_InitTypeDef GPIO_InitStructure;   EXTI_I
[单片机]
STM32硬件IIC
1 /** 2 * @brief 写一个字节到I2C设备中 3 * @param 4 * @arg pBuffer:缓冲区指针 5 * @arg WriteAddr:写地址 6 * @retval 正常返回1,异常返回0 7 */ 8 uint8_t I2C_ByteWrite(u8 pBuffer, u8 WriteAddr) 9 { 10 /* Send STRAT condition */ 11 I2C_GenerateSTART(macI2Cx, ENABLE); 12 13 I2CTimeout = I2CT_FLAG_TIMEOUT; 14 15 16 /*
[单片机]
使用STM32GPIO端口点亮LED灯(库函数)
1,先定义GPIO端口结构体 GPIO_InitTypeDef LED_GPIOA_InitStruct; 2,使用GPIO端口指定要使用的结构体 LED_GPIOA_InitStruct.GPIO_Pin = GPIO_Pin_2; //指定第2引脚 3,同上设置输出或输入的方式 LED_GPIOA_InitStruct.GPIO_Mode = GPIO_Mode_Out_PP; //设置为推挽输出 4,同上设置输出速度 LED_GPIOA_InitStruct.GPI
[单片机]
基于STM32单片机的RFID和云平台仓库管理系统设计
一.系统设计 通过STM32单片机进行主控,通过RFID检测刷卡状态 ,光电检测模块检测存货区域,检测到的数据通过ESP01S上传到上位机端进行显示。 图1 系统框图 二.硬件设计 本设计所采用的STM32F103C8T6是以Cortex-3为核心的单片机,使用光电模块进行光电检测,用RFID识别感应并解读信息,检测到的数据会通过串口发送到ESP01S,再发送到上位机端进行显示和监控。 图2 硬件电路 三.软件设计 系统在完成系统初始化后就开始通过IC卡感应模块检测存货与取货状态,检测到的信息通过ESP01S通信模块上传,通过光电识别模块检测判断存货区域。其中若检测到取货刷卡且在区域一,则显示区域1货物减1,否则显示区域2
[单片机]
基于<font color='red'>STM32</font>单片机的RFID和云平台仓库管理系统设计
STM32系列第14篇--TFTLCD驱动原理
ALINETEK2.8寸 TFTLCD模块特点 240*320分辨率 16位真彩显示(65536色) 自带电阻触摸屏 自带背光电路 注意:模块是3.3V供电的,不支持5V电压的MCU,如果是5VMCU,必须在信号线串接120R电阻使用。 ALINETEK2.8寸 TFTLCD接口说明(16位80并口) LCD_CS:LCD片选信号 LCD_WR:LCD写信号 LCD_RD:LCD读信号 DB :16位双向数据线。 LCD_RST:硬复位LCD信号 LCD_RS:命令/数据标志(0:命令,1:数据) BL_CTR:背光控制信号 T_MISO/T_MOSI/T_PEN/T_CS/T_CLK,触摸
[单片机]
<font color='red'>STM32</font>系列第14篇--TFTLCD驱动原理
STM32-systick系统定时器
systick系统定时器 系统定时器存在内核中,是24位的定时器,只能向下递减,嵌套在NVIC中 counter 在时钟的驱动下 在reload的初值开始向下递减计时到0,产生中断置位标志然后又从reload值开始重新递减计数,循环 定时时间计算 t=reload*(1/clk) clk=72M时,t=72*(1/72m)=1us clk=72M时,t=72000*(1/72m)=1ms clk=72M时,t=72000000*(1/72m)=1s 1s=1000MS =1000 000US=1000 000 000NS sysTick属于内核中的外设,他的中断优先级和外设的中断优先级相比,哪个
[单片机]
STM32-systick系统定时器
如何优雅地解决STM32的Flash写保护的问题
本文介绍了如何解决 STM32 芯片 Flash 写保护导致无法下载程序,无法在线调试的问题;如果您遇到相同的问题,希望本文可以带来一些帮助; 1 FLASH 的写保护 如果对 Flash 设置了写保护,那就无法对 Flash 进行编程和擦除。 在开发 STM32 的时候,如果出现这种情况,通常仿真器都支持对 Flash 进行解锁,像 jlink,stlink 等仿真器都支持这个功能。 2 错误提示 在使用 MDK 进行调试的时候,出现报错 ==Flash Timeout.Reset Target and try it again==,具体如下图所示; 折腾了一番之后,并没有解决问题,因为使用的仿真器是 stlink,因此
[单片机]
怎样在Linux上开发STM32程序
步骤1:下载所需的一切 您需要下载三个部分才能正常工作: 用于ARM的GCC编译器 STM32固件文件 St-link实用程序 Sample Project 编译器是将我们的C代码和所有其他库文件编译成stm32控制器可以理解的机器语言的主要软件。下载此编译器的最新预编译版本。 包含STM32固件的文件夹是保存主处理器运行所需的所有启动文件和核心文件的文件夹。我们将使用HAL已超越的标准外围设备库。我更喜欢StPeriphLibrary,因为使用该处理器的公司都在使用它们,因为它功能强大,更老旧并且受支持。它也更坚固。它不会减少初始化外围设备或打开LED所需的工作,但是会迫使您学习这些处理器的工作方式。这样一来,您将对内部工作
[单片机]
怎样在Linux上开发<font color='red'>STM32</font><font color='red'>程序</font>
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
