stm32使用超高精度的同步时钟的设计
发布者:塞上老马最新更新时间:2018-06-26 来源: eefocus关键字:stm32  超高精度  同步时钟 手机看文章 扫描二维码
随时随地手机看文章
有些场合可能需要超高精度的同步时钟,比如0.5ppm甚至更低的时钟,并且保证多台设备很好的重复率,因此这篇文章主要讲述如何设计基于stm32的超高精度的时钟。
首先时钟精度要0.5ppm甚至更低的话,显然要使用txco,也就是温补晶振,0.5ppm的温补晶振市面上比较常见,体积很小(2520),并且价格很便宜,两三元一片,因为这种类型的晶振广泛引用于手机,GPS等需要精密时钟的地方,因此种类多价格低,但是相反的振荡频率只有那么几种,这几种中我么能用的也就是19.2mhz和26mhz两种。考虑2的倍数的问题,19.2mhz的最佳。
本次设计使用19.2mhz的有源温补晶振最为stm32的时钟源,这里我选择型号KT2520F19200ACW28PAA ,-30到80度范围,0.5ppm的精度,2.8V的供电。
电路如图所示,经过验证,把有源晶振的信号输出通过一个电容直接耦合到stm32的oscin脚位即可使用。
stm32程序上主要有一下几点设计:
首先:启动函数:重新设计时间
static void SetSysClockTo72(void)
  __IO uint32_t StartUpCounter = 0, HSEStatus = 0;
  uint32_t t=100000;
  /* SYSCLK, HCLK, PCLK2 and PCLK1 configuration ---------------------------*/
  /* Enable HSE */
   while(t--);
  RCC->CR |= ((uint32_t)RCC_CR_HSEON);
  /* Wait till HSE is ready and if Time out is reached exit */
  do
    HSEStatus = RCC->CR & RCC_CR_HSERDY;
    StartUpCounter++;
  } while((HSEStatus == 0));
  if ((RCC->CR & RCC_CR_HSERDY) != RESET)
    HSEStatus = (uint32_t)0x01;
  else
    HSEStatus = (uint32_t)0x00;
  if (HSEStatus == (uint32_t)0x01)
    /* Enable Prefetch Buffer */
    FLASH->ACR |= FLASH_ACR_PRFTBE;
    /* Flash 2 wait state */
    FLASH->ACR &= (uint32_t)((uint32_t)~FLASH_ACR_LATENCY);
    FLASH->ACR |= (uint32_t)FLASH_ACR_LATENCY_2;
    /* HCLK = SYSCLK */
    RCC->CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1;
   //hserfenp
    /* PCLK2 = HCLK */
    RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE2_DIV1;
    /* PCLK1 = HCLK */
    RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE1_DIV2;
    /*  PLL configuration: PLLCLK = HSE * 9 = 72 MHz */
    RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE |
                                        RCC_CFGR_PLLMULL));
    RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLMULL5);              //5倍频,获得9.2Mhz*5=48MHz时钟
   RCC->CFGR |= (uint32_t)0x20000;         //时钟二分频        19.2MHZ分配得到    9.6Mhz
    /* Enable PLL */
    RCC->CR |= RCC_CR_PLLON;
    /* Wait till PLL is ready */
    while((RCC->CR & RCC_CR_PLLRDY) == 0)
    /* Select PLL as system clock source */
    RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW));
    RCC->CFGR |= (uint32_t)RCC_CFGR_SW_PLL;
    /* Wait till PLL is used as system clock source */
    while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)0x08)
  else
  { /* If HSE fails to start-up, the application will have wrong clock
         configuration. User can add here some code to deal with this error */
其中关键地方是将系统获得48MHz,因为我们要使用stm32的usb,usb的时钟必须是48MHz的,而usb时钟只支持1分配和1.5分频,因此系统时钟必须是72mhz和48mhz才工作。
校准
然后按照我们的需要来设定定时器,即可,此处的48mhz的时钟的精度也是非常高的,也是0.5ppm的精度。
然后再进行最后一部,校准,这里为什么校准呢,因为我们说的0.5ppm精度是频偏,也就是假设频率是19200000hz的话,在这个频率范围内因为温度导致的偏移不会超过0.5*10e-6,因为电压导致的偏移不会超过0.2*10e-6,因为负载导致的偏移不会超过0.1*10e-6 这些精度都非常高,但是他们都是频偏。晶振有一个原始频率,19.2MHz的一批晶振不一定每一个的频率都是19200000hz,可能有的是19200001hz,有的是19200002hz,因此我们需要来拟合这个固有偏差。
通过几分钟的累计测量可以得到这个固有偏差,然后计算出常数来弥合他即可。
最后经过校准后的精度,在同一温度下的偏差小于0.1ppm,非常精准,非常适合应用在各种超高精度的引用环境
关键字:stm32  超高精度  同步时钟 引用地址:stm32使用超高精度的同步时钟的设计
上一篇:STM32时钟讲解(内部构架说明)
下一篇:如何理解STM32引脚中的GPIO,AFIO时钟分配策略和管脚复用
推荐阅读最新更新时间:2024-03-16 16:07
SWD调试在STM32中REMAP调试的深入探究
首先说一下问题的现象,如果有这种现象的同学可以看看博主的这篇博文程序download一次后,第二次download就提示no target connect,除非长按reset键才能继续下载程序 首先上一组stm32的TIM2的端口使用组合有下面四种: 1.当不重映射时,默认TIM2四个的IO口是PA0、PA1、PA2、PA3 开启重映射__HAL_AFIO_REMAP_TIM2_ENABLE() 2.要使用PA15、PB3、PA2、PA3的端口组合,要调用下面的语句进行部分重映射: __HAL_AFIO_REMAP_TIM2_PARTIAL_1() 3.要使用PA0、PA1、PB10、PB11的端口组合,要调用下面的
[单片机]
基于STM32设计的智慧路灯(太阳能+华为云IOT)
1. 前言 随着工业和城市的快速发展,道路照明系统的产业也在迅速发展,并趋于复杂化,为了更经济地控制和维护复杂的路灯系统,市面上各大科技公司开发了各种路灯控制系统,并且路灯都连上物联网云端,连上了政府网络,可以远程了解路灯的工作情况,运行情况。 为了方便了解物联网平台,学习物联网开发,了解智慧路灯的开发,本文就采用华为云IOT物联网平台,选择STM32作为主控芯片,再配合相关的传感器完成智慧路灯开发。 路灯使用的相关模块与资料可以在这里下载: https://download.csdn.net/download/xiaolong1126626497/85897742 2. 具体实现的功能以及相关的硬件 当前设计的智慧路灯采
[单片机]
基于<font color='red'>STM32</font>设计的智慧路灯(太阳能+华为云IOT)
STM32串口接收数据卡死问题解决办法
在使用STM32串口时,有时候串口接受一段时间数据之后便会卡死不在进入中断接收数据。原因是串口中断标志没有清除,导致终端锁死,此时需要判断对应的标志位,重新启动中断。 if((huart1.Instance- CR1 & 0x20)==0) { HAL_UART_Receive_IT(&huart1,bsp_uart1.rx_tmp,1); }
[单片机]
说说STM32调试DEBUG相关知识
学习STM32开发,肯定少不了DEBUG调试这一步骤。那么,本文带你了解一下这个调试相关的知识。 本文以STM32F1、Cortex-M3为例,其它系列芯片或内核,原理相同或类似。 1概况 在STM32中,有很多调试组件。使用它们可以执行各种调试功能,包括断点、数据观察点、 闪存地址重载以及各种跟踪。 STM32F1使用Cortex™-M3内核,该内核内含硬件调试模块,支持复杂的调试操作。 硬件调试模块允许内核在取指(指令断点)或访问数据(数据断点)时停止。内核停止时,内核的内部状态和系统的外部状态都是可以查询的。完成查询后,内核和外设可以被复原,程序将继续执行。 当STM32F10x微控制器连接到调
[单片机]
说说<font color='red'>STM32</font>调试DEBUG相关知识
意法半导体超低功耗STM32MCU上新,让便携产品轻松拥有惊艳图效
新款STM32U5片上集成矢量图形加速器及大容量SRAM存储器 2024年2月5日, 中国 - 意法半导体推出了集成新的专用图形加速器的STM32*微控制器(MCU),让成本敏感的小型产品也能为用户带来更好的图形体验。 超低功耗MCU STM32U5F9/G9和STM32U5F7/G7集成3MB片上动态存储器(SRAM),可以为图形显示屏提供多个帧缓存区,以节省外部存储芯片。新产品还集成了意法半导体的NeoChromVG图形处理器(GPU),能够实现的图形效果可与更昂贵的高端微处理器相媲美。 新系列STM32U5内置 NeoChromVG图形处理器,是STM32首批支持硬件加速矢量运算的MCU,能够渲染 SVG图像和
[单片机]
STM32 定时器输出PWM的模式
数据手册上TIMx_CCMR1寄存器的6:4位决定了定时器输出PWM的几种模式: 000:冻结。输出比较寄存器TIMx_CCR1与计数器TIMx_CNT间的比较对OC1REF不起作用。即当计数器值与比较值相等时管脚上电平信号保持上一次的信号。 Eg:定时器设置: TIM_TimeBaseStructure.TIM_Period = 1000; // 设置自动重载周期值 TIM_TimeBaseStructure.TIM_Prescaler = 47; // 设置预分频值48分频 TIM_TimeBaseStructure.TIM_ClockDivision = 0; // 设置时钟分割:TDTS = Tck_tim
[单片机]
<font color='red'>STM32</font> 定时器输出PWM的模式
STM32单片机GPIO口配置问题
  在学习STM32F单片机时,我们常常困惑什么时候才能叫入门,采用什么样的教材入门,或者采用什么的编程软件。在学习类的教材中,以神州,原点教材布局很多,但是相信很多人看到这类教材也是一头雾水,需要你花费巨大的精力从寄存器的最底层去学习和了解,学习时间还是相对漫长。在采用的编程软件中,KEIL和IAR各有优势吧,在这里我选用的是KEIL。   在开始学习编程时,我采用的是库函数开发指南。在安装完成KEIL软件和添加项目工程时,就开始学习库函数编程。   在编写一个GPIO口控制时,首先我们要知道我们要实现的功能,连接的IO口和怎么配置GPIO口。最常见的以LED举例来说。比如我采用PB13引脚连接LED灯的负极,按照硬件的
[单片机]
为什么学习STM32时还要学习汇编
不同的平台的汇编代码是不一样的,最早的汇编在50年代就发明了,比很多人的父母的年龄都大,老掉牙,不用学习怎么写汇编。一个公司有一个人知道怎么写汇编就够了。但要学习读汇编,为什么学习汇编? 1、性能 直接翻译为机器语言,性能最高。优秀的C语言效率只能达到汇编的80%左右。其他高级语言跟汇编一比差得更远。语言越高级性能越差。很多bootloader和BIOS用汇编写,汇编操作的是电脑,手机刚刚上电时,硬件和初始化的那些命令,它们的性能的要求比较高,效率高开机速度更快。 分析问题 个人认为,编程人与机器对话,我们写C,写JAVA,但是电脑并不认识这些语言,电脑只认识0和1;所以需要一个人来翻译这些语言,这个翻译官就是编译器,但是
[单片机]
为什么学习<font color='red'>STM32</font>时还要学习汇编
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
