STM32F030Cxxx 没有SCB->VTOR,如何重定位向量表
发布者:CelestialSoul最新更新时间:2018-07-11 来源: eefocus关键字:STM32F030Cxxx  重定位  向量表 手机看文章 扫描二维码
随时随地手机看文章
最近使用了一款Cortex-M0内核的芯片STM32F030CC,发现它中断向量表的重映射方法与STM32F10x系列的有所区别,在这里记录与分享一下。
     由于需要通过IAP进行固件升级,所以芯片的FLASH里面要烧录两份代码:一个Boot loader, 一个用户应用程序。理所当然的,在用户应用程序中,必须得重新映射中断向量表。
     可是在ST提供的固件库里,我却没有发现类似于stm32f10x固件库中的voidNVIC_SetVectorTable(uint32_t NVIC_VectTab, uint32_t Offset)接口。
     浏览了一下Cortex-M0的Programmingmanual,原来M0并没有SCB->VTOR这个寄存器,难怪ST的库里没有提供NVIC_SetVectorTable这个接口。
     这下要怎么办?在网络上搜索了一下,受到网友findaway123这篇文章的启发,我在STM32F030CC的Reference manual中找到以下说明:
     Physicalremap
  Once the boot mode is selected, the application software can modify the memory accessible in the code area.This modification is performed by programming the MEM_MODE bits in the SYSCFG configuration register 1 (SYSCFG_CFGR1). Unlike Cortex? M3 and M4,the M0 CPU does not support the vector table relocation. For application code which is located in a different address than 0x0800 0000, some additional code must be added in order to be ableto serve the application interrupts. A solution will be to relocateby software the vector table to the internal SRAM:
  ? Copy the vector table from the Flash (mapped at the base of theapplication load address) to the base address of the SRAM at 0x20000000.
  ? Remap SRAM at address 0x0000 0000, using SYSCFG configuration register 1.
  ? Then once an interrupt occurs, the Cortex?-M0 processor will fetch the interrupt handler start address from the relocated vector table in SRAM, then it will jump to execute the interrupt handler located in the Flash.
  This operation should be done at the initialization phase of the application. Please refer to AN4065 and attached IAP code from www.st.com for more details.
  OK,解决方法找到了!
  在用户应用程序中,按照以上方法,添加以下两行代码:
    memcpy((void*)0x20000000, (void*)0x08004000, VECTOR_SIZE); SYSCFG_MemoryRemapConfig(SYSCFG_MemoryRemap_SRAM);
memcpy((void*)0x20000000, (void*)FLASH_MAIN_FW_START_ADDR, 0xB4);
  __HAL_SYSCFG_REMAPMEMORY_SRAM();
中括号中是我实际使用的code
   其中,0x2000 0000是SRAM的起始地址,这个不需要改动。
   而之后的两个参数需要根据实际情况作出修改。0x08004000是应用程序的起址地址,从这里开始的VECTOR_SIZE字节,存放是的应用程序的中断向量表。VECTOR_SIZE是指中断向量表的大小,具体多大可以在startup.s文件里计算得到。以下以startup_stm32f030.s为例作说明:
  我们只需关注其中的一小部分。从29行开始,直到75行,每一个DCD都代表一个中断向量(所谓中断向量,说得明白点,其实就是某个中断服务程序的入口地址)。例如第74行的:
  DCD     USART1_IRQHandler              ; USART1
  这里的“USART1_IRQHandler"其实就是UART1中断服务程序USART1_IRQHandler这个函数,同时,它也代表这个函数的入口地址。
  以上代码即定义了这样一张表,这张表包括45个元素,每个元素是一个长度为4字节的地址。除了第一个地址是SP(堆栈指针)外,其它的地址都是某个中断服务程序的入口地址。
  那么,回到我们要解决的问题上来,之前memcpy函数中的第三个参数VECTOR_SIZE,针对本例,就应该是45*4=180(0xB4)个字节。
  在执行完以上两行代码后,若发生中断,CPU就会去SRAM(即0x2000 0000处)取中断向量了,所以,以0x20000000作为起始地址之后的VECTOR_SIZE个字节就不能被改动了。为了达到这VECTOR_SIZE个字节不被修改的目的,如下两种方法可以实现。
  ?在工程文件内修改SRAM的起始地址及长度,如下图
  ?如果使用了分散加载文件,则在分散加载文件中修改SRAM的起始地址及长度也能达到目的。
  至此,STM32F0系列Cortex-M0内核芯片中断向量表重映射的问题已解决。
关键字:STM32F030Cxxx  重定位  向量表 引用地址:STM32F030Cxxx 没有SCB->VTOR,如何重定位向量表
上一篇:STM32L4xx下bootloader重设中断向量表的一个问题
下一篇:为什么中断向量表重映射到高地址
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
