main.c
程序功能:动态显示文字“welcome!”
测试说明:观察液晶显示
#include
#include "Cry1602.h"
#define uchar unsigned char
uchar *s1 = "welcome!";
void main( void )
uchar i;
WDTCTL = WDT_ADLY_250; //间隔定时器,定时16ms
LcdReset();
DispStr(4,0,s1);
LocateXY(0,9); //确定写入字符的显示位置
LcdWriteCommand(0x07, 1); //整体显示左移
for(i = 12; i > 0; i--)
LcdWriteData(0x20);
//延时250ms
IFG1 &= ~WDTIFG;
while(!(IFG1 & WDTIFG));
IFG1 &= ~WDTIFG;
while(1)
LcdWriteCommand(0x05, 1); //整体显示右移
for(i = 24; i > 0; i--)
LcdWriteData(0x20);
//延时250ms
IFG1 &= ~WDTIFG;
IFG1 &= ~WDTIFG;
LcdWriteData(0x20);
//延时250ms
IFG1 &= ~WDTIFG;
IFG1 &= ~WDTIFG;
cry1602.h
void DispStr(unsigned char x,unsigned char y,unsigned char *ptr);
void DispNChar(unsigned char x,unsigned char y, unsigned char n,unsigned char *ptr);
void LocateXY(unsigned char x,unsigned char y);
void Disp1Char(unsigned char x,unsigned char y,unsigned char data);
void LcdReset(void);
void LcdWriteCommand(unsigned char cmd,unsigned char chk);
void LcdWriteData( unsigned char data );
void WaitForEnable(void);
void Delay5ms(void);
cry1602.c
#include
#include "cry1602.h"
typedef unsigned char uchar;
typedef unsigned int uint;
/**************宏定义***************/
#define DataDir P4DIR
#define DataPort P4OUT
#define Busy 0x80
#define CtrlDir P3DIR
#define CLR_RS P3OUT&=~BIT0; //RS = P3.0
#define SET_RS P3OUT|=BIT0;
#define CLR_RW P3OUT&=~BIT1; //RW = P3.1
#define SET_RW P3OUT|=BIT1;
#define CLR_EN P3OUT&=~BIT2; //EN = P3.2
#define SET_EN P3OUT|=BIT2;
函数名称:DispStr
功 能:让液晶从某个位置起连续显示一个字符串
参 数:x--位置的列坐标
y--位置的行坐标
ptr--指向字符串存放位置的指针
返回值 :无
void DispStr(uchar x,uchar y,uchar *ptr)
uchar *temp;
uchar i,n = 0;
temp = ptr;
while(*ptr++ != '\0') n++; //计算字符串有效字符的个数
for (i=0;i { Disp1Char(x++,y,temp[i]); if (x == 0x0f) { x = 0; y ^= 1; } } } /******************************************* 函数名称:DispNchar 功 能:让液晶从某个位置起连续显示N个字符 参 数:x--位置的列坐标 y--位置的行坐标 n--字符个数 ptr--指向字符存放位置的指针 返回值 :无 ********************************************/ void DispNChar(uchar x,uchar y, uchar n,uchar *ptr) { uchar i; for (i=0;i { Disp1Char(x++,y,ptr[i]); if (x == 0x0f) { x = 0; y ^= 1; } } } /******************************************* 函数名称:LocateXY 功 能:向液晶输入显示字符位置的坐标信息 参 数:x--位置的列坐标 y--位置的行坐标 返回值 :无 ********************************************/ void LocateXY(uchar x,uchar y) { uchar temp; temp = x&0x0f; y &= 0x01; if(y) temp |= 0x40; //如果在第2行 temp |= 0x80; LcdWriteCommand(temp,1); } /******************************************* 函数名称:Disp1Char 功 能:在某个位置显示一个字符 参 数:x--位置的列坐标 y--位置的行坐标 data--显示的字符数据 返回值 :无 ********************************************/ void Disp1Char(uchar x,uchar y,uchar data) { LocateXY( x, y ); LcdWriteData( data ); } /******************************************* 函数名称:LcdReset 功 能:对1602液晶模块进行复位操作 参 数:无 返回值 :无 ********************************************/ void LcdReset(void) { CtrlDir |= 0x07; //控制线端口设为输出状态 DataDir = 0xFF; //数据端口设为输出状态 LcdWriteCommand(0x38, 0); //规定的复位操作 Delay5ms(); LcdWriteCommand(0x38, 0); Delay5ms(); LcdWriteCommand(0x38, 0); Delay5ms(); LcdWriteCommand(0x38, 1); //显示模式设置 LcdWriteCommand(0x08, 1); //显示关闭 LcdWriteCommand(0x01, 1); //显示清屏 LcdWriteCommand(0x06, 1); //写字符时整体不移动 LcdWriteCommand(0x0c, 1); //显示开,不开游标,不闪烁 } /******************************************* 函数名称:LcdWriteCommand 功 能:向液晶模块写入命令 参 数:cmd--命令, chk--是否判忙的标志,1:判忙,0:不判 返回值 :无 ********************************************/ void LcdWriteCommand(uchar cmd,uchar chk) { if (chk) WaitForEnable(); // 检测忙信号? CLR_RS; CLR_RW; _NOP(); DataPort = cmd; //将命令字写入数据端口 _NOP(); SET_EN; //产生使能脉冲信号 _NOP(); _NOP(); CLR_EN; } /******************************************* 函数名称:LcdWriteData 功 能:向液晶显示的当前地址写入显示数据 参 数:data--显示字符数据 返回值 :无 ********************************************/ void LcdWriteData( uchar data ) { WaitForEnable(); //等待液晶不忙 SET_RS; CLR_RW; _NOP(); DataPort = data; //将显示数据写入数据端口 _NOP(); SET_EN; //产生使能脉冲信号 _NOP(); _NOP(); CLR_EN; } /******************************************* 函数名称:WaitForEnable 功 能:等待1602液晶完成内部操作 参 数:无 返回值 :无 ********************************************/ void WaitForEnable(void) { P4DIR &= 0x00; //将P4口切换为输入状态 CLR_RS; SET_RW; _NOP(); SET_EN; _NOP(); _NOP(); while((P4IN & Busy)!=0); //检测忙标志 CLR_EN; P4DIR |= 0xFF; //将P4口切换为输出状态 } /******************************************* 函数名称:Delay5ms 功 能:延时约5ms 参 数:无 返回值 :无 ********************************************/ void Delay5ms(void) { uint i=40000; while (i != 0) { i--; } }
上一篇:NRF24L01实现msp430单片机通信(SPI)
下一篇:单片机MSP430 - 定时器Timer_A
推荐阅读最新更新时间:2024-03-16 16:08
