STM8常用中断指令
开总中断
_asm(“rim”);
禁止中断
_asm(“sim”);
进入停机模式
_asm(“halt”);
中断返回
_asm(“iret”);
等待中断
_asm(“wfi”);
软件中断
_asm(“trap”);
STM8S常用中断映射
如使用中断函数时,可以通过在上图中查找相对应的中断向量号,而中断函数的名字可以自定义
/* BASIC INTERRUPT VECTOR TABLE FOR STM8 devices
* Copyright (c) 2007 STMicroelectronics
typedef void @far (*interrupt_handler_t)(void);
struct interrupt_vector {
unsigned char interrupt_instruction;
interrupt_handler_t interrupt_handler;
@far @interrupt void NonHandledInterrupt (void)
/* in order to detect unexpected events during development,
it is recommended to set a breakpoint on the following instruction
return;
extern void _stext(); /* startup routine */
extern @far @interrupt void EXTI2_Hand_Fun(void);
extern @far @interrupt void TIM1_UPD_OVF_TRG_BRK_IRQHandler(void);
struct interrupt_vector const _vectab[] = {
{0x82, (interrupt_handler_t)_stext}, /* reset */
{0x82, NonHandledInterrupt}, /* trap */
{0x82, NonHandledInterrupt}, /* irq0 */
{0x82, NonHandledInterrupt}, /* irq1 */
{0x82, NonHandledInterrupt}, /* irq2 */
{0x82, NonHandledInterrupt}, /* irq3 */
{0x82, NonHandledInterrupt}, /* irq4 */
{0x82, EXTI2_Hand_Fun}, /* irq5 */
{0x82, NonHandledInterrupt}, /* irq6 */
{0x82, NonHandledInterrupt}, /* irq7 */
{0x82, NonHandledInterrupt}, /* irq8 */
{0x82, NonHandledInterrupt}, /* irq9 */
{0x82, NonHandledInterrupt}, /* irq10 */
{0x82, TIM1_UPD_OVF_TRG_BRK_IRQHandler}, /* irq11 */
{0x82, NonHandledInterrupt}, /* irq12 */
{0x82, NonHandledInterrupt}, /* irq13 */
{0x82, NonHandledInterrupt}, /* irq14 */
{0x82, NonHandledInterrupt}, /* irq15 */
{0x82, NonHandledInterrupt}, /* irq16 */
{0x82, NonHandledInterrupt}, /* irq17 */
{0x82, NonHandledInterrupt}, /* irq18 */
{0x82, NonHandledInterrupt}, /* irq19 */
{0x82, NonHandledInterrupt}, /* irq20 */
{0x82, NonHandledInterrupt}, /* irq21 */
{0x82, NonHandledInterrupt}, /* irq22 */
{0x82, NonHandledInterrupt}, /* irq23 */
{0x82, NonHandledInterrupt}, /* irq24 */
{0x82, NonHandledInterrupt}, /* irq25 */
{0x82, NonHandledInterrupt}, /* irq26 */
{0x82, NonHandledInterrupt}, /* irq27 */
{0x82, NonHandledInterrupt}, /* irq28 */
{0x82,
NonHandledInterrupt}, /* irq29 */
外部中断长按键识别相关配置
STM8S为外部中断事件专门分配了五个中断向量:
PortA 口的5个引脚:PA[6:2]
PortB 口的8个引脚:PB[7:0]
PortC 口的8个引脚:PC[7:0]
PortD 口的7个引脚:PD[6:0]
PortE口的8个引脚:PE[7:0]
PD7是最高优先级的中断源(TLI);
中断IO设置
这里选用EXTI2(端口C外部中断)。那么需要将中断促发的IO(PC5)设置为上拉输入或中断上拉输入,悬浮输入的话很容易受干扰。
/*PC5设置为上拉输入*/
void Init_EXTI2_GPIO(void)
PC_DDR &= 0XDF;
PC_CR1 &= 0XDF;
PC_CR2 |= 0x20;
外部中断寄存器配置
CPU CC寄存器中断位:
I1 I0不能直接写,只能通过开中断或关中断来写,上电默认是11;当用指令开中断时( _asm(“rim\n”);),为00;当发生中断时,由当前中断(ITC_SPRx)载入I[1:0],主要用于做中断优先级;退出中断自动清0;因此在写EXTI_CR1,需将ITC_SPRx配置成11,或加入禁中断指令 。
EXTI_CR1:
配置促发方式;
测试代码
#include
char keyFlag;
char keyPressStatus = 1;
unsigned int keyCount;
/*Output Pin*/
_Bool PD2 @PD_ODR:2;
_Bool PC7 @PC_ODR:7;
_Bool PC6 @PC_ODR:6;
_Bool PC3 @PC_ODR:3;
/*Input Pin*/
_Bool PC5 @PC_IDR:5;
/*电量指示灯*/
#define LED1 PD2
#define LED2 PC7
#define LED3 PC6
#define LED4 PC3
/*按键*/
#define KEY PC5
/*主时钟频率为8Mhz*/
void Init_CLK(void)
CLK_ICKR |= 0X01; //使能内部高速时钟 HSI
CLK_CKDIVR = 0x08; //16M内部RC经2分频后系统时钟为8M
while(!(CLK_ICKR&0x02)); //HSI准备就绪
CLK_SWR=0xE1; //HSI为主时钟源
void Init_LED(void)
/*LED 配置为推挽输出*/
PD_DDR |= 0X04; //PD2输出模式,0为输入模式
PD_CR1 |= 0X04; //PD2模拟开漏输出
PD_CR2 &= 0XFB; //PD2输出速度最大为2MHZ,CR1/CR2悬浮输入
PC_DDR |= 0XC8;
PC_CR1 |= 0XC8;
PC_CR2 &= 0X27;
/*PC5设置为上拉输入*/
PC_DDR &= 0XDF;
PC_CR1 &= 0XDF;
PC_CR2 |= 0X20;
void Init_EXTI2(void)
EXTI_CR1 |= 0x30; //上升沿和下降沿促发
void Init_TIM1(void)
TIM1_IER = 0x00;
TIM1_CR1 = 0x00;
TIM1_EGR |= 0x01;
TIM1_PSCRH = 199/256; // 8M系统时钟经预分频f=fck/(PSCR+1) TIM1 为16位分频器
TIM1_PSCRL = 199%256; // PSCR=0x1F3F,f=8M/(200)=40000Hz,每个计数周期1/40000ms
TIM1_CNTRH = 0x00;
TIM1_CNTRL = 0x00;
TIM1_ARRH = 400/256; // 自动重载寄存器ARR=400
TIM1_ARRL = 400%256; // 每记数400次产生一次中断,即10ms
TIM1_CR1 |= 0x81;
TIM1_IER |= 0x01;
unsigned int Key_Scan_Test(void)
unsigned int count = 0;
unsigned char keyMode;
if(0 == keyPressStatus)
keyFlag = 1;
while(!keyPressStatus);
keyFlag = 0;
count = keyCount;
keyCount = 0;
else
count = 0;
/*10ms * 150 = 1.5s*/
if(count >= 150)keyMode = 2; //长按
else if(count >= 4)keyMode = 1; //短按
else keyMode = 0; //抖动
return keyMode;
main()
char keynum = 0;
_asm("sim");
Init_CLK();
Init_LED();
Init_EXTI2_GPIO();
Init_EXTI2();
Init_TIM1();
_asm("rim");
while (1)
keynum = Key_Scan_Test();
if(1 == keynum)LED3 = ~LED3;
if(2 == keynum)LED4 = ~LED4;
keyPressStatus = !keyPressStatus;
LED1 = ~LED1;
static unsigned int i = 0;
TIM1_SR1 &= ~(0X01);
++i;
if(50 == i)
LED2 = ~LED2;
i = 0;
/*Within Key Press Hand*/
if(1 == keyFlag)
++keyCount;
注意:
中断向量需声明,在stm8_interrupt_vector.c中加入:
另参见不用外部中断长按键识别:不用外部中断识别长按键
上一篇:STM8S关于TIM最高频率设置的坑
下一篇:STM8S定时器基本中断定时
推荐阅读最新更新时间:2024-03-16 16:10
设计资源 培训 开发板 精华推荐
- 独乐乐不如众乐乐——TI培训“荐课”功能上线公测,邀你提议,参与抢楼!
- 精选PI InnoSwitch 产品系列文档,为您的设计添光溢彩! 下载有好礼!
- 【看电源研讨会,瓜分3000元红包】 如何正确完成模块化DC-DC系统设计
- Vicor白皮书下载——双向电源:“安静”改变世界的驱动力
- EEWORLD社区-2010年度风云人物评选
- 【有奖问答】术业有专攻,电容我在行!
- 西门子精彩视频限时免费|利用电子产品生命周期管理 (PLM) 更快地交付更多产品
- 艾睿电子直播:聚焦“TI FPD-Link III 汽车芯片组” ,汽车视频传输理想解决方案
- 有奖直播:清洁水源的守护 —— ADI 水质监测方案
- ADI 伺服电机控制解决方案
