ADC的初始化步骤:
1.初始化ADC所用的通道IO
2.开启ADC的时钟并初始化ADC的结构体
3.调用ADC_Cmd函数进行使能ADC,目的是可以进行读写ADC的寄存器
4.校准ADC(这一步不是必须的,校准ADC时ADC硬件会生成一个校准码,来减小测量误差,校准过的ADC比不校准的准确)
5.调用ADC_RegularChannelConfig写入规则通道的信息(包括写入SQR寄存器的值,采样时间等)
6.调用ADC_SoftwareStartConvCmd函数开启ADC采样
7.等待采样完成,并读取ADC数据
ADC部分代码如下:
#include "adc.h"
static void ADC_GPIO_Config(void)
GPIO_InitTypeDef GPIO_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE); //ʹÄÜPB,PE¶Ë¿ÚʱÖÓ
GPIO_InitStructure.GPIO_Pin=GPIO_Pin_1;
GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AIN;
GPIO_Init(GPIOA, &GPIO_InitStructure);
void ADC_Mode_Config(void)
ADC_InitTypeDef ADC_InitStructure;
ADC_GPIO_Config();
RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1,ENABLE);
ADC_DeInit(ADC1);
ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
ADC_InitStructure.ADC_ContinuousConvMode = DISABLE;
ADC_InitStructure.ADC_ScanConvMode=DISABLE;
ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
ADC_InitStructure.ADC_NbrOfChannel=ADC_Channel_1;
ADC_Init(ADC1,&ADC_InitStructure);
ADC_Cmd(ADC1,ENABLE);
ADC_ResetCalibration(ADC1);
while(ADC_GetResetCalibrationStatus(ADC1)==SET);
ADC_StartCalibration(ADC1);
while(ADC_GetCalibrationStatus(ADC1)==SET);
u16 ADC_STARTConver(void)
u16 adcconverdata;
ADC_RegularChannelConfig(ADC1,ADC_Channel_1,1,ADC_SampleTime_239Cycles5);
ADC_SoftwareStartConvCmd(ADC1,ENABLE);
while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC ));
adcconverdata=ADC_GetConversionValue(ADC1);
return adcconverdata;
main函数中执行如下循环
AdcConverValue=ADC_STARTConver();
printf("AdcConverValue=%d \r\n",AdcConverValue);
接下来就是执行结果了:
上面是我引脚悬空时候的结果,下图是测量0V时的图片:
值得注意的是ADC_Cmd这个命令,当把上面程序的ADC_SoftwareStartConvCmd(ADC1,ENABLE);命令更换为ADC_Cmd(ADC1,ENABLE);命令时程序仍然正常运行,原因如下:
void ADC_Cmd(ADC_TypeDef* ADCx, FunctionalState NewState)
assert_param(IS_ADC_ALL_PERIPH(ADCx));
assert_param(IS_FUNCTIONAL_STATE(NewState));
if (NewState != DISABLE)
ADCx->CR2 |= CR2_ADON_Set;
else
ADCx->CR2 &= CR2_ADON_Reset;
从上面的函数原型可以看出ADC_CMD函数设置的是CR2寄存器的ADON位
打开参考手册,找到这个位,解释如下:
从上图中我们可以看到,当该位为1时,再写入1的话则是启动ADC转换,而不是无效命令,我们程序在ADC初始化的时候已经调用过一次ADC_CMD函数,所以该位为1,所以当我们将ADC_SoftwareStartConvCmd(ADC1,ENABLE);函数更换为ADC_Cmd(ADC1,ENABLE)时,程序一点影响都没有,照常运行。
上一篇:STM32 ADC转换中断读取
下一篇:stm32标准库dma初始化详解
推荐阅读最新更新时间:2024-03-16 16:14
设计资源 培训 开发板 精华推荐
- 1.39亿美元!英飞凌宣布收购Siltectra,有望将晶圆生产芯片数
- 谷歌AI新突破:实时聊天中识别“谁说了什么”正确率高达92%
- 想与高通抗衡?Intel提前半年发布XMM 8160 5G基带
- 告别耗电卡顿,首批支持统一推送标准的手机明年Q1登场
- 库存少 + “抽奖”机制不明确,小米手机 1 英镑抢购活动惹
- 三星 Galaxy S22 Ultra 最新渲染图:外观硬朗
- iPhone 14取代iPhone 13S:苹果或完全砍掉S命名
- 三星One UI 4.0升级:官方App适配Material You的设计
- 华为将于10月21日在海外推nova系列新品
- iQOO Z5造梦空间配色来了 搭骁龙778+44W闪充
