OK6410裸机之DDR片外内存访问
发布者:码上奇迹最新更新时间:2018-10-11 来源: eefocus关键字:OK6410  裸机  DDR  片外内存访问 手机看文章 扫描二维码
随时随地手机看文章
start.S源码:
.globl _start
_start:
// 硬件相关的设置
    // Peri port setup
    ldr r0, =0x70000000
    orr r0, r0, #0x13
    mcr p15,0,r0,c15,c2,4       @ 256M(0x70000000-0x7fffffff)
// 关看门狗
    // 往WTCON(0x7E004000)写0
    ldr r0, =0x7E004000       // 伪指令
    mov r1, #0
    str r1, [r0]
    bl clock_init
// 为调用C函数准备环境
    ldr sp, =8*1024
    bl sdram_init
// 重定位代码
    // 把片内内存中程序的代码段、数据段复制到它的链接地址去
    adr r0, _start         // 获得_start指令当前所在的地址 : 0
    ldr r1, =_start       // _start的链接地址 0x50000000
    ldr r2, =bss_start  // bss段的起始链接地址
    cmp r0,r1
    beq clean_bss
copy_loop:
    ldr r3, [r0], #4
    str r3, [r1], #4
    cmp r1, r2
    bne copy_loop
// 把BSS段对应的内存清零
clean_bss:
    ldr r0, =bss_start
    ldr r1, =bss_end
    mov r3, #0
    cmp r0, r1
    beq on_ddr
clean_loop:
    str r3, [r0], #4
    cmp r0, r1
    bne clean_loop
on_ddr:
    // 调用C函数
    ldr pc, =main  // pc等于main的链接地址
clock.S源码:
#define APLL_LOCK    0x7e00f000
#define MPLL_LOCK    0x7e00f004
#define EPLL_LOCK    0x7e00f008
#define LOCK_TIME    0xffff
#define OTHERS       0x7e00f900
#define CLK_DIV0     0x7e00f020
#define CLK_SRC      0x7e00f01c
.text
.global clock_init
clock_init:                //初始化系统时钟
    @ set the lock time to max
    ldr r0, =LOCK_TIME
    ldr r1, =APLL_LOCK
    str r0, [r1]
    ldr r1, =MPLL_LOCK
    str r0, [r1]
    ldr r1, =EPLL_LOCK
    str r0, [r1]
    @ set async mode
    ldr r0, =OTHERS
    ldr r1, [r0]
    bic r1, #0xc0
    str r1, [r0]
    loop1:
    ldr r0, =OTHERS
    ldr r1, [r0]
    and r1, #0xf00
    cmp r1, #0
    bne loop1
    @ set the divider
    #define DIV_VAL    ( (0)|(1<<4)|(1<<8)|(1<<9)|(3<<12) )
    ldr r0, =CLK_DIV0
    ldr r1, =DIV_VAL
    str r1, [r0]
    @ set APLL, MPLL, EPLL
    #define SDIV    1
    #define PDIV    3
    #define MDIV    266
    #define PLL_ENABLE    ( 1 << 31 )
    #define APLL_VAL    ( (SDIV<<0)|(PDIV<<8)|(MDIV<<16)|(PLL_ENABLE) )
    #define MPLL_VAL    APLL_VAL
    #define EPLL0_VAL    ( (2<<0)|(1<<8)|(32<<16)|PLL_ENABLE)
    #define EPLL1_VAL    ( 0 )
    #define APLL_CON    0x7e00f00c
    #define MPLL_CON    0x7e00f010
    #define EPLL_CON0    0x7e00f014
    #define EPLL_CON1    0x7e00f018
    ldr r0, =APLL_CON
    ldr r1, =APLL_VAL
    str r1, [r0]
    ldr r0, =MPLL_CON
    ldr r1, =MPLL_VAL
    str r1, [r0]
    ldr r0, =EPLL_CON0
    ldr r1, =EPLL0_VAL
    str r1, [r0]
    ldr r0, =EPLL_CON1
    ldr r1, =EPLL1_VAL
    str r1, [r0]
    @ select the source
    ldr r0, =CLK_SRC
    mov r1, #7
    str r1, [r0]
    mov pc, lr
sdram.c源码:
#include "common.h"
#define MEMCCMD         0x7e001004
#define P1REFRESH         0x7e001010
#define P1CASLAT           0x7e001014
#define MEM_SYS_CFG    0x7e00f120
#define P1MEMCFG         0x7e00100c
#define P1T_DQSS            0x7e001018
#define P1T_MRD             0x7e00101c
#define P1T_RAS              0x7e001020
#define P1T_RC                0x7e001024
#define P1T_RCD              0x7e001028
#define P1T_RFC               0x7e00102c
#define P1T_RP                 0x7e001030
#define P1T_RRD              0x7e001034
#define P1T_WR               0x7e001038
#define P1T_WTR             0x7e00103c
#define P1T_XP                0x7e001040
#define P1T_XSR              0x7e001044
#define P1T_ESR              0x7e001048
#define P1MEMCFG2      0X7e00104c
#define P1_chip_0_cfg     0x7e001200
#define P1MEMSTAT       0x7e001000
#define P1MEMCCMD     0x7e001004
#define P1DIRECTCMD    0x7e001008
#define HCLK    133000000
#define nstoclk(ns)    (ns/( 1000000000/HCLK)+1)
//初始化DDR
int sdram_init( void )
    // tell dramc to configure
    set_val( MEMCCMD, 0x4 );
    // set refresh period
    set_val( P1REFRESH, nstoclk(7800) );
    // set timing para
    set_val( P1CASLAT, ( 3 << 1 ) );
    set_val( P1T_DQSS, 0x1 );    // 0.75 - 1.25
    set_val( P1T_MRD, 0x2 );
    set_val( P1T_RAS, nstoclk(45) );
    set_val( P1T_RC, nstoclk(68) );
    u32 trcd = nstoclk( 23 );
    set_val( P1T_RCD, trcd | (( trcd - 3 ) << 3 ) );
    u32 trfc = nstoclk( 80 );
    set_val( P1T_RFC, trfc | ( ( trfc-3 ) << 5 ) );
    u32 trp = nstoclk( 23 );
    set_val( P1T_RP, trp | ( ( trp - 3 ) << 3 ) );
    set_val( P1T_RRD, nstoclk(15) );
    set_val( P1T_WR, nstoclk(15) );
    set_val( P1T_WTR, 0x7 );
    set_val( P1T_XP, 0x2 );
    set_val( P1T_XSR, nstoclk(120) );
    set_val( P1T_ESR, nstoclk(120) );
    // set mem cfg
    set_nbit( P1MEMCFG, 0, 3, 0x2 );     // 10 column address
    // set_nbit: 把从第bit位开始的一共len位消零,然后把这几位设为val
    //set_nbit( P1MEMCFG, 3, 3, 0x2 );  // 13 row address
    set_nbit( P1MEMCFG, 3, 3, 0x3 );     // 14 row address
    set_zero( P1MEMCFG, 6 );                // A10/AP
    set_nbit( P1MEMCFG, 15, 3, 0x2 );   // Burst 4
    set_nbit( P1MEMCFG2, 0, 4, 0x5 );
    set_2bit( P1MEMCFG2, 6, 0x1 );       // 32 bit
    set_nbit( P1MEMCFG2, 8, 3, 0x3 );   // Mobile DDR SDRAM
    set_2bit( P1MEMCFG2, 11, 0x1 );
    set_one( P1_chip_0_cfg, 16 );           // Bank-Row-Column organization
    // memory init
    set_val( P1DIRECTCMD, 0xc0000 );  // NOP
    set_val( P1DIRECTCMD, 0x000 );      // precharge
    set_val( P1DIRECTCMD, 0x40000 );  // auto refresh
    set_val( P1DIRECTCMD, 0xa0000 );  // EMRS
    set_val( P1DIRECTCMD, 0x80032 );  // MRS
    set_val( MEM_SYS_CFG, 0x0 );
    // set dramc to "go" status
    set_val( P1MEMCCMD, 0x000 );
    // wait ready
    while( !(( read_val( P1MEMSTAT ) & 0x3 ) == 0x1));
led.c源码:
void delay(volatile int count)
    volatile int i = count;
    while(i)
        i--;
//int i = 0xf;                                     // 位于数据段
int i = 0;                                           // 位于BSS段
volatile const int j = 0x12345678;  // 位于只读数据段
//volatile int k=0;                            // bss段
int main()
    // 配置GPMCON让GPM0,1,2,3作为输出引脚
    volatile unsigned long *gpmcon = (volatile unsigned long *)0x7F008820;
    volatile unsigned long *gpmdat = (volatile unsigned long *)0x7F008824;
    *gpmcon &= ~(0xffff);
    *gpmcon |= 0x1111;
    // 循环点亮这4个LED
    while (1)
        *gpmdat &= ~0xf;
        *gpmdat |= i;
        i++;
        delay(20000);
        if (i == 16)
            i = 0;
    return 0;
Makefile文件:
led.bin : start.o clock.o sdram.o led.o
    arm-linux-ld  -T led.lds -o led.elf $^
    arm-linux-objcopy -O binary led.elf led.bin
    arm-linux-objdump -D led.elf > led.dis
%.o : %.S
    arm-linux-gcc -g -c -O2 -o $@ $^
%.o : %.c
clean:
    rm -f *.o *.bin *.elf *.dis
led.lds文件:
SECTIONS
    . = 0x50000000;
    .text :
        start.o
        * (.text)
    . = ALIGN(4);
    .rodata :
        * (.rodata)
    . = ALIGN(4);
    .data :
        * (.data)
    . = ALIGN(4);
    bss_start = . ;  // 0x50000450
    .bss :
        * (.bss)        // i
        * (.common)
    bss_end = . ;    // 0x50000450
引脚定义:Xm1RAS :Row address strobe (active low),行地址锁存信号
                 Xm1CAS : Column address strobe (active low),列地址锁存信号
                 Xm1WEN:Write enable (active low) ,写使能
关键字:OK6410  裸机  DDR  片外内存访问 引用地址:OK6410裸机之DDR片外内存访问
上一篇:OK6410裸机之NAND Flash操作更新固件
下一篇:OK6410裸机片内内存中重定位代码
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
