驱动程序:
return (mylog_r == mylog_w);
return (mylog_r_for_read == mylog_w);
return ((mylog_w + 1)% MYLOG_BUF_LEN == mylog_r);
if (is_mylog_full())
// 丢弃一个数据 //
mylog_r = (mylog_r + 1) % MYLOG_BUF_LEN;
if ((mylog_r_for_read + 1) % MYLOG_BUF_LEN == mylog_r)
mylog_r_for_read = mylog_r;
mylog_buf[mylog_w] = c;
mylog_w = (mylog_w + 1) % MYLOG_BUF_LEN;
// 唤醒等待数据的进程 //
wake_up_interruptible(&mymsg_waitq); // 唤醒休眠的进程 //
if (is_mylog_empty())
return 0;
*p = mylog_buf[mylog_r];
return 1;
if (is_mylog_empty_for_read())
return 0;
*p = mylog_buf[mylog_r_for_read];
mylog_r_for_read = (mylog_r_for_read + 1) % MYLOG_BUF_LEN;
return 1;
va_list args;
int i;
int j;
va_start(args, fmt);
i = vsnprintf(tmp_buf, INT_MAX, fmt, args);
va_end(args);
for (j = 0; j < i; j++)
mylog_putc(tmp_buf[j]);
return i;
size_t count, loff_t *ppos)
int error = 0;
int i = 0;
char c;
// 把mylog_buf的数据copy_to_user, return //
if ((file->f_flags & O_NONBLOCK) && is_mylog_empty_for_read())
return -EAGAIN;
//printk("%s %d\n", __FUNCTION__, __LINE__);
//printk("count = %d\n", count);
//printk("mylog_r = %d\n", mylog_r);
//printk("mylog_w = %d\n", mylog_w);
error = wait_event_interruptible(mymsg_waitq, !is_mylog_empty_for_read());
while (!error && (mylog_getc_for_read(&c)) && i < count) {
error = __put_user(c, buf);
buf++;
i++;
if (!error)
error = i;
return error;
return 0;
.open = mymsg_open,
.read = mymsg_read,
myentry = create_proc_entry("mymsg", S_IRUSR, &proc_root);
if (myentry)
myentry->proc_fops = &proc_mymsg_operations;
return 0;
remove_proc_entry("mymsg", &proc_root);
关键字:print函数 打印数据 环形缓冲区
引用地址:自定义print函数缓存打印数据到环形缓冲区
#include "linux/module.h"
#include "linux/kernel.h"
#include "linux/fs.h"
#include "linux/init.h"
#include "linux/delay.h"
#include "asm/uaccess.h"
#include "asm/irq.h""
#include "asm/io.h"
#include "asm/arch/regs-gpio.h"
#include ""asm/hardware.h"
#include "linux/proc_fs.h"
#define MYLOG_BUF_LEN 1024
struct proc_dir_entry *myentry;
static char mylog_buf[MYLOG_BUF_LEN];
static char tmp_buf[MYLOG_BUF_LEN];
static int mylog_r = 0;
static int mylog_r_for_read = 0;
static int mylog_w = 0;
static DECLARE_WAIT_QUEUE_HEAD(mymsg_waitq);
static int is_mylog_empty(void)
static int is_mylog_empty_for_read(void)
static int is_mylog_full(void)
static void mylog_putc(char c)
static int mylog_getc(char *p)
static int mylog_getc_for_read(char *p)
int myprintk(const char *fmt, ...)
static ssize_t mymsg_read(struct file *file, char __user *buf,
static int mymsg_open(struct inode *inode, struct file *file)
const struct file_operations proc_mymsg_operations = {
static int mymsg_init(void)
static void mymsg_exit(void)
module_init(mymsg_init);
module_exit(mymsg_exit);
EXPORT_SYMBOL(myprintk);
MODULE_LICENSE("GPL");
解析:
当其他驱动程序调用自定义的myprintk函数打印数据时不会立即把数据打印在前台显示,而是把数据放在mylog_buf环形缓冲区中保存,当应用程序查看proc/mymsg时,即执行:cat /proc/mymsg时会调用mymsg_read函数读取环型缓冲区,如果缓冲区中有数据会调用__put_user返回,如果没有数据系统会休眠。
上一篇:应用调试-----使用strace命令来跟踪系统调用
下一篇:位置无关和位置相关
小广播
热门活动
换一批
更多
设计资源 培训 开发板 精华推荐
最新单片机文章
更多精选电路图
更多热门文章
更多每日新闻
更多往期活动
11月14日历史上的今天
厂商技术中心
随便看看
