STM32串口库函数版例程
发布者:暮烟微雨最新更新时间:2016-06-15 来源: eefocus关键字:STM32  串口  库函数 手机看文章 扫描二维码
随时随地手机看文章
定义:
TXD1----- PA9-US1-TX
RXD1----- PA10-US1-RX
速率:115200,n,8,1
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x.h"
#include "platform_config.h"
#include "stm32f10x_usart.h"
#include "misc.h"
#include "stdarg.h"
/* Private variables ---------------------------------------------------------*/
USART_InitTypeDef USART_InitStructure;
uint8_t TxBuffer1[] = "USART Interrupt Example: This is USART1 DEMO";
uint8_t RxBuffer1[],rec_f,tx_flag;
__IO uint8_t TxCounter1 = 0x00;
__IO uint8_t RxCounter1 = 0x00;
uint32_t Rec_Len;
/* Private function prototypes -----------------------------------------------*/
void RCC_Configuration(void);
void GPIO_Configuration(void);
void NVIC_Configuration(void);
void Delay(__IO uint32_t nCount);
void USART_OUT(USART_TypeDef* USARTx, uint8_t *Data,...);
char *itoa(int value, char *string, int radix);
void USART_Config(USART_TypeDef* USARTx);
GPIO_InitTypeDef GPIO_InitStructure;
USART_InitTypeDef USART_InitStruct;
USART_ClockInitTypeDef USART_ClockInitStruct;
* 名    称:void ili9325_DrawPicture(u16 StartX,u16 StartY, u8 Dir,u8 *pic)
* 功    能:在指定座标范围显示一副图片
* 入口参数:StartX     行起始座标
*           StartY     列起始座标
*			Dir		   图像显示方向
*           pic        图片头指针
* 出口参数:无
* 说    明:图片取模格式为水平扫描,16位颜色模式  取模软件img2LCD
* 调用方法:ili9325_DrawPicture(0,0,0,(u16*)demo);
void USART_Config(USART_TypeDef* USARTx){
  USART_InitStructure.USART_BaudRate = 115200;						//速率115200bps
  USART_InitStructure.USART_WordLength = USART_WordLength_8b;		//数据位8位
  USART_InitStructure.USART_StopBits = USART_StopBits_1;			//停止位1位
  USART_InitStructure.USART_Parity = USART_Parity_No;				//无校验位
  USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;   //无硬件流控
  USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;					//收发模式
  /* Configure USART1 */
  USART_Init(USARTx, &USART_InitStructure);							//配置串口参数函数
  /* Enable USART1 Receive and Transmit interrupts */
  USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);                    //使能接收中断
  USART_ITConfig(USART1, USART_IT_TXE, ENABLE);						//使能发送缓冲空中断
  /* Enable the USART1 */
  USART_Cmd(USART1, ENABLE);
* 名    称:int main(void)
* 功    能:主函数
* 入口参数:无
* 出口参数:无
* 说    明:
* 调用方法:无
int main(void)
   uint8_t a=0;
  /* System Clocks Configuration */
  RCC_Configuration();											  //系统时钟设置
  /*嵌套向量中断控制器
      说明了USART1抢占优先级级别0(最多1位) ,和子优先级级别0(最多7位) */
  NVIC_Configuration();											  //中断源配置
  /*对控制LED指示灯的IO口进行了初始化,将端口配置为推挽上拉输出,口线速度为50Mhz。PA9,PA10端口复用为串口1的TX,RX。
  在配置某个口线时,首先应对它所在的端口的时钟进行使能。否则无法配置成功,由于用到了端口B, 因此要对这个端口的时钟
  进行使能,同时由于用到复用IO口功能用于配置串口。因此还要使能AFIO(复用功能IO)时钟。*/
  GPIO_Configuration();											  //端口初始化
  USART_Config(USART1);											  //串口1初始化
  USART_OUT(USART1,"测试串口 *\r\n");    	  //向串口1发送开机字符。
  USART_OUT(USART1,"*\r\n");
  USART_OUT(USART1,"\r\n");
   while (1)
	if(rec_f==1){												  //判断是否收到一帧有效数据
		rec_f=0;
		USART_OUT(USART1,"\r\n您发送的信息为: \r\n");
		USART_OUT(USART1,&TxBuffer1[0]);
		if(a==0) {GPIO_SetBits(GPIOB, GPIO_Pin_5); a=1;}          //LED1  V6(V3板) V2(MINI板) 明暗闪烁
		else {GPIO_ResetBits(GPIOB, GPIO_Pin_5);a=0;  }
* 名    称:void Delay(__IO uint32_t nCount)
* 功    能:延时函数
* 入口参数:无
* 出口参数:无
* 说    明:
* 调用方法:无
  for(; nCount != 0; nCount--);
* 名    称:void USART_OUT(USART_TypeDef* USARTx, uint8_t *Data,...)
* 功    能:格式化串口输出函数
* 入口参数:USARTx:  指定串口
			Data:   发送数组
			...:     不定参数
* 出口参数:无
* 说    明:格式化串口输出函数
        	"\r"	回车符	   USART_OUT(USART1, "abcdefg\r")
			"\n"	换行符	   USART_OUT(USART1, "abcdefg\r\n")
			"%s"	字符串	   USART_OUT(USART1, "字符串是:%s","abcdefg")
			"%d"	十进制	   USART_OUT(USART1, "a=%d",10)
* 调用方法:无
void USART_OUT(USART_TypeDef* USARTx, uint8_t *Data,...){
	const char *s;
    int d;
    char buf[16];
    va_list ap;
    va_start(ap, Data);
	while(*Data!=0){				                          //判断是否到达字符串结束符
		if(*Data==0x5c){									  //'\'
			switch (*++Data){
				case 'r':							          //回车符
					USART_SendData(USARTx, 0x0d);
					Data++;
					break;
				case 'n':							          //换行符
					USART_SendData(USARTx, 0x0a);
					Data++;
					break;
				default:
					Data++;
				    break;
		else if(*Data=='%'){									  //
			switch (*++Data){
				case 's':										  //字符串
                	s = va_arg(ap, const char *);
                	for ( ; *s; s++) {
                    	USART_SendData(USARTx,*s);
						while(USART_GetFlagStatus(USARTx, USART_FLAG_TC)==RESET);
					Data++;
                	break;
            	case 'd':										  //十进制
                	d = va_arg(ap, int);
                	itoa(d, buf, 10);
                	for (s = buf; *s; s++) {
					Data++;
                	break;
				default:
					Data++;
				    break;
		else USART_SendData(USARTx, *Data++);
		整形数据转字符串函数
		radix=10 标示是10进制	非十进制,转换结果为0;
	    例:d=-379;
		执行	itoa(d, buf, 10); 后
		buf="-379"
    int     i, d;
    int     flag = 0;
    char    *ptr = string;
    /* This implementation only works for decimal numbers. */
    if (radix != 10)
        *ptr = 0;
        return string;
    if (!value)
        *ptr++ = 0x30;
        *ptr = 0;
        return string;
    /* if this is a negative value insert the minus sign. */
    if (value < 0)
        *ptr++ = '-';
        /* Make the value positive. */
        value *= -1;
    for (i = 10000; i > 0; i /= 10)
        d = value / i;
        if (d || flag)
            *ptr++ = (char)(d + 0x30);
            value -= (d * i);
            flag = 1;
    /* Null terminate the string. */
    *ptr = 0;
    return string;
} /* NCL_Itoa */
* 名    称:void RCC_Configuration(void)
* 功    能:系统时钟配置为72MHZ, 外设时钟配置
* 入口参数:无
* 出口参数:无
* 说    明:
* 调用方法:无
   SystemInit();
   RCC_APB2PeriphClockCmd( RCC_APB2Periph_USART1 |RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB |RCC_APB2Periph_AFIO  , ENABLE);
* 名    称:void GPIO_Configuration(void)
* 功    能:通用IO口配置
* 入口参数:无
* 出口参数:无
* 说    明:
* 调用方法:
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;				     //LED1控制--PB5
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;			 //推挽输出
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;	         		 //USART1 TX
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;    		 //复用推挽输出
  GPIO_Init(GPIOA, &GPIO_InitStructure);		    		 //A端口
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;	         	 //USART1 RX
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;   	 //复用开漏输入
* 名    称:void NVIC_Configuration(void)
* 功    能:中断源配置
* 入口参数:无
* 出口参数:无
* 说    明:
* 调用方法:无
  /*  结构声明*/
  NVIC_InitTypeDef NVIC_InitStructure;
  /* Configure the NVIC Preemption Priority Bits */
  /* Configure one bit for preemption priority */
  /* 优先级组 说明了抢占优先级所用的位数,和子优先级所用的位数   在这里是1, 7 */
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
  NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQn;			     	//设置串口1中断
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;	     	//抢占优先级 0
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;				//子优先级为0
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;					//使能
  NVIC_Init(&NVIC_InitStructure);
/*            STM32F10x Peripherals Interrupt Handlers                        */
  * @brief  This function handles USART1 global interrupt request.
  * @param  None
  * @retval : None
void USART1_IRQHandler(void)      //串口1 中断服务程序
  unsigned int i;
  if(USART_GetITStatus(USART1, USART_IT_RXNE) != RESET)	   //判断读寄存器是否非空
    RxBuffer1[RxCounter1++] = USART_ReceiveData(USART1);   //将读寄存器的数据缓存到接收缓冲区里
    if(RxBuffer1[RxCounter1-2]==0x0d&&RxBuffer1[RxCounter1-1]==0x0a)     //判断结束标志是否是0x0d 0x0a
	  for(i=0; i< RxCounter1; i++) TxBuffer1[i]	= RxBuffer1[i]; 	     //将接收缓冲器的数据转到发送缓冲区,准备转发
	  rec_f=1;															 //接收成功标志
	  TxBuffer1[RxCounter1]=0;		                                     //发送缓冲区结束符
	  RxCounter1=0;
  if(USART_GetITStatus(USART1, USART_IT_TXE) != RESET)                   //这段是为了避免STM32 USART 第一个字节发不出去的BUG
     USART_ITConfig(USART1, USART_IT_TXE, DISABLE);					     //禁止发缓冲器空中断,
关键字:STM32  串口  库函数 引用地址:STM32串口库函数版例程
上一篇:avr单片机USART串口通讯初始化配置说明
下一篇:AVR单片机红外解码程序
推荐阅读最新更新时间:2024-03-16 14:57
【实验三】外部中断实验
一、实验目的 1)了解STM32外部中断相关知识; 2)使用STM32外部中断,实现两个LED灯亮灭; 二、STM32外部中断简介 1)STM32F103系列有60个可屏蔽中断;支持19个外部中断/事件请求。每个中断设有状态位,每个中断/事件都有独立的触发和屏蔽设置。 STM32F103 的19 个外部中断为: 线 0~15:对应外部 IO 口的输入中断。 线 16:连接到 PVD 输出。 线 17:连接到 RTC 闹钟事件。 线 18:连接到 USB 唤醒事件。 中断线对应为: 2)外部中断函数: EXPORT EXTI0_IRQHandler EXPORT EXTI2_IRQHandler EXPO
[单片机]
【实验三】外部中断实验
STM32】MDK中寄存器地址名称映射分析
对于MCU,一切底层配置,最终都是在配置寄存器。 STM32F1xx官方资料: 《STM32中文参考手册V10》-第8章通用和复用功能IO(GPIO和AFIO) 51单片机访问地址 51单片机经常会引用一个reg51.h的头文件。下面看看它是怎么把名字和寄存器联系在一起的: sfr p0=0x80; p0=0x00; sfr是一种扩充数据类型,点用一个内存单位,值域为0-255.利用它可以访问51单片机内部所有的特殊功能寄存器。前一句“sfr p0=0x80”就是将P0映射到地址0x80。后一句“p0=0x00”就是往p0地址(0x80)代表的寄存器写值。 STM32访问地址 寄存器地址名称映射 STM32肯定也是
[单片机]
【<font color='red'>STM32</font>】MDK中寄存器地址名称映射分析
w5500网络连接
w5500_conf.h 文件内容 包含一些相关的硬件初始化和用户参数配置。 #ifndef _W5500_CONF_H_ #define _W5500_CONF_H_ #include stm32f10x.h #include stdio.h #include types.h #define __GNUC__ typedef void (*pFunction)(void); extern uint8 remote_ip ; /* 远端IP地址 */ extern uint16 remote_port; /* 远端端口号
[单片机]
stm32专题十八:SPI框图及通讯过程
stm32的SPI外设: 1 通讯引脚和结构框图 不同的SPI设备(由于挂载在不同的总线上),通讯速率不同 结构框图: 2 通讯速度 由控制寄存器CR1的BR 位来控制,主要就是对Fpclk(APB1时钟为72M,APB2时钟为36M)进行分频。 3 数据控制逻辑 SPI的MOSI及MISO都连接到数据移位寄存器上,数据移位寄存器的数据来源来源于接收缓冲区及发送缓冲区。 通过写SPI的“数据寄存器DR”把数据填充到发送缓冲区中。 通过读“数据寄存器DR”,可以获取接收缓冲区中的内容。 其中数据帧长度可以通过“控制寄存器CR1”的“DFF位”配置成8位及16位 模式;配置“LSBFIRST位”可选
[单片机]
<font color='red'>stm32</font>专题十八:SPI框图及通讯过程
ST 发布新STM32G0微控制器,增加USB和CAN接口和更大存储器
意法半导体发布新STM32G0微控制器,增加USB-C全速双模端口、CAN FD接口和更大容量的存储器 中国,2021年7月8日——意法半导体 STM32G0* 系列Arm® Cortex®-M0+ 微控制器 (MCU)新增多款产品和更多新功能,例如,双区闪存、CAN FD接口和无晶振USB全速数据/主机支持功能。 对于注重预算的应用,新的STM32G050超值产品线、STM32G051和STM32G061主流产品线增加了丰富的模拟功能和最大容量18KB 的 RAM存储器,以及多达 48 引脚且售价极具竞争力的封装。 此外,STM32G0B0 超值产品线、STM32G0B1和STM32G0C1主流产品线给STM3
[单片机]
STM32 定时器输入捕获实现红外遥控数据接收
一、原理 1、红外发射协议 红外发射协议已经在之前的 文章 中写过,在此就不赘述。 2、定时器计数和输入捕获 定时器就是按照一个特定的频率对计数值进行加一或减一操作,当数值溢出时则产生一个标志或中断。 定时器的输入捕获就是可以测量输入信号的脉冲宽度。 本次就是通过普通计数和输入捕获的结合来实现的。 3、实现方法 利用定时器记录输入信号高脉冲的时间,通过该时间来判断数据是否是同步头信息、数据 1 或者数据 0。 二、实现 1、配置 定时器2 输入捕获通道 示例代码中使用 PA1 管脚,配置为上拉输入模式,复用功能为定时器2的通道2。 定时器采用普通定时器,定时器2,该定时器具有输入捕获功能。 配置定时
[单片机]
用qt编写上位机与stm32通信
好的文章 1、Qt5.5.1实现通用串口程序https://www.2cto.com/kf/201607/524028.html 2、QT实现串口通信 https://www.2cto.com/kf/201610/558768.html 资源下载:https://download.csdn.net/download/hellybobo/9950904?web=web 本文采用的的开发环境是VS2010+Qt5.5.1版本,所有程序不是通过Qt Creator编译的,如果有需要可以介绍VS2010和Qt环境的搭建和简单的使用。 QSerialPort QSerialPort这个类是从QT5.1开始引入的,之前都是通过
[单片机]
用qt编写上位机与<font color='red'>stm32</font>通信
分享一个STM32菜单框架
相信很多攻城狮都用过液晶屏,想写好一点的ui好像不太可能或且花费很多时间,直接写吧,感觉好像很零碎,coding都怕了。 下面介绍一个简单易用的菜单框架,你会发现它能做多层菜单而且结果清晰。 基本原理: 如上图液晶显示一屏我们定义为一个page,page中的项目定义为i te m;这样page就是item的容器了。当我们选中其中的一个item进去后是不是又是一个page呢,如下图。 这样的话每一个item的下面都对应一个page,这样是不是就构成一个多层的菜单了。 他们是什么关系呢? 一个page中有item,那么用结构体就可以实现啦;item下面又有page,那么在item中加一个page的指针指向item
[单片机]
分享一个<font color='red'>STM32</font>菜单框架
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
