#include "INTRINS.H"
#include "LCD.h"
#define CLR_RI (RI=0)
#define CLR_TI (TI=0)
unsigned char code ID[2][8]={ 0x28,0x1D,0x25,0x1D,0x00,0x00,0x00,0x80,
0x28,0x0e,0x9e,0x1c,0x00,0x00,0x00,0x32};
unsigned char currSensorNo=0;
sbit TMDAT = P1^7;
sbit RUN_LED = P1^6;
void serial_initial()
TMOD=0X20;
SCON=0X50;
PCON=0X00;
TL1=TH1=0XE8;
TR1=1;
void send(unsigned char count,unsigned char SEND_Buf[])
unsigned char i;
for(i=0;i
SBUF=SEND_Buf[i];
while(!TI);
CLR_TI;
* delay N ms
void Delay_ms (unsigned int Nms )
unsigned char i;
while(Nms--)
for(i=0; i<125; i++) ;
* delay N count
void Delay_Count (unsigned char Count )
while(Count>0) Count--;
* start Reset Pulse
void tmreset(void)
TMDAT=0;
Delay_Count(103);
TMDAT=1;
Delay_Count(4);
* ACK
void tmpre(void)
while(TMDAT);
while(~TMDAT);
Delay_Count(4);
* Read a bit from 1820
bit tmrbit(void)
int i=0;
bit dat;
TMDAT=0;i++;
TMDAT=1;i++;i++;
dat = TMDAT;
Delay_Count(8);
return dat;
* Read a byte from 1820
unsigned char tmrbyte(void)
unsigned char i,j,dat=0;
for(i=1;i<=8;i++)
j=tmrbit();
dat=(j<<7)|(dat>>1);
return dat;
void tmwbyte(unsigned char dat)
signed char i=0;
unsigned char j;
bit testb;
for(j=1;j<=8;j++)
testb=dat & 0x01;
dat = dat>>1;
if(testb)
TMDAT=0;
i++;i++;
TMDAT=1;
Delay_Count(8);
else
TMDAT=0;
Delay_Count(8);
TMDAT=1;
i++;i++;
* send convert command to 1820
void tmstart(void)
unsigned char i;
tmreset();
tmpre();
Delay_ms(1);
/* tmwbyte(0xcc);*/
tmwbyte(0x55);
for(i=0;i<8;i++)
tmwbyte(ID[currSensorNo][i]);
tmwbyte(0x44);
* Read tempreature from 1820
unsigned int tmrtemp_all(void)
unsigned char a,b;
unsigned int y3;
unsigned char i;
tmreset();
tmpre();
Delay_ms(1);
/*tmwbyte(0xcc);*/
tmwbyte(0x55);
for(i=0;i<8;i++)
tmwbyte(0xbe);
a = tmrbyte();
b = tmrbyte();
y3 = ((unsigned int)b) << 8;
return ((y3+a) & 0x7ff) ;
* Start Test tempreature, All
void Display_AllTemp(void )
unsigned int last;
unsigned char i,Dot;
RUN_LED=0;
Part=0;
LED_DISPLAY();
Delay_ms(1);
tmstart();
Delay_ms(800);
last=tmrtemp_all();
RUN_LED=1;
Dot= (last & 0x0f)*6.25 ;
Digit[0]= Dot%10;
Digit[1]=Dot/10;
last=(last>>4) & 0x7f ;
if( (last == 0x7f) ) // erro
for(i=0;i<5;i++) Digit[i]=16;
else
for(i=2;i<5;i++)
Digit[i] = last %10;
last = last/10;
if(Digit[4]==0)Digit[4]=17;
Part=1;
Digit[5]=currSensorNo;
LED_DISPLAY();
/* void Read_Id()
unsigned char i,id[8];
tmreset();
tmpre();
Delay_ms(1);
tmwbyte(0x33);
for(i=0;i<8;i++)
id[i]=tmrbyte();
send(8,id);
* Main
void main(void)
unsigned char id[8]={1,2,3,4,5,6,7,8};
serial_initial();
send(8,id);
for(;;)
RUN_LED=!RUN_LED;
/* Read_Id();*/
TX_C =!TX_C ;
currSensorNo=(currSensorNo==1)?0:1;
Display_AllTemp();
/*Change();*/
send(6,Digit);
Delay_ms(1000);
_nop_();
上一篇:单片机超声波传感器测量距离
下一篇:单片机中使用DS18B20温度传感器C语言程序(参考7)
推荐阅读最新更新时间:2024-03-16 15:10
