STM8L152模拟IIC程序
发布者:创意旅程最新更新时间:2016-10-05 来源: eefocus关键字:STM8L152  模拟IIC 手机看文章 扫描二维码
随时随地手机看文章
本篇仍然是模拟IIC,基本思路仍然是STM32的模拟IIC思路。具体内容还是参考STM32使用模拟IIC操作EEPROM。
示例代码如下:
stm8_iic.h文件内容如下:
#ifndef _stm8_iic_h_
#define _stm8_iic_h_
#include "stm8l15x.h"
extern unsigned char BQ25890x_write_reg(unsigned char *buffer,unsigned char addr,unsigned char num);
extern unsigned char BQ25890x_read_reg(unsigned char *buffer,unsigned char addr,unsigned char num);
#define IICSPEED 100000
#define BQ25890_I2C_ADDR (0x6A)
#endif
stm8_iic.c内容如下:
#define SlaveAddress (BQ25890_I2C_ADDR)
#define IIC_SDA_GPIO_Pin GPIO_Pin_0
#define IIC_SCL_GPIO_Pin GPIO_Pin_1
#define IIC_GPIOx GPIOC
void Delay(void)
nop();
nop();
nop();
nop();
nop();
nop();
//使用软件模拟IIC //PC0--SDA PC1---SCL
//初始化
void BQ25890H_init(void)
GPIO_Init(IIC_GPIOx, IIC_SDA_GPIO_Pin, GPIO_Mode_Out_PP_High_Fast);
GPIO_Init(IIC_GPIOx, IIC_SCL_GPIO_Pin, GPIO_Mode_Out_PP_High_Fast);
//读取数据
unsigned char SDA_READ(void)
//return GPIO_ReadInputPin(IIC_GPIOx, IIC_SDA_GPIO_Pin);
return GPIO_ReadInputDataBit(IIC_GPIOx, IIC_SDA_GPIO_Pin);
//产生起始信号
void IIC_Start(void)
GPIO_Init(GPIOC,GPIO_Pin_0,GPIO_Mode_Out_PP_High_Slow);//set SDA pin as output high
Delay();
GPIO_Init(GPIOC,GPIO_Pin_1,GPIO_Mode_Out_PP_High_Slow);//set SCL pin as output high
Delay();
GPIO_Init(GPIOC,GPIO_Pin_0,GPIO_Mode_Out_PP_Low_Slow);//set SDA pin as output low
Delay();
GPIO_Init(GPIOC,GPIO_Pin_1,GPIO_Mode_Out_PP_Low_Slow);//set SCL pin as output low
Delay();
//产生停止信号
void IIC_Stop(void)
Delay();
Delay();
Delay();
//等待响应信号
//0--接收应答成功 1-接收应答失败
unsigned char IIC_Wait_Ack(void)
unsigned char ucErrTime = 0;
Delay();
GPIO_Init(GPIOC,GPIO_Pin_0,GPIO_Mode_In_PU_No_IT); //set sda as input with pull up
while(SDA_READ())
ucErrTime++;
if(ucErrTime > 250)
IIC_Stop();
return 1;
GPIO_Init(GPIOC,GPIO_Pin_1,GPIO_Mode_Out_PP_Low_Slow); //set SCL pin as output low
Delay();
return 0;
//产生ACK信号
void IIC_Ack(void)
GPIO_Init(GPIOC,GPIO_Pin_1,GPIO_Mode_Out_PP_High_Slow);//set SCL pin as output low
Delay(); //延时
Delay();
Delay();
GPIO_Init(GPIOC,GPIO_Pin_1,GPIO_Mode_Out_PP_High_Slow); //set SCL pin as output low
Delay();
Delay();
Delay();
//No ACK
void IIC_NAck(void)
Delay();
Delay();
Delay(); //延时
Delay(); //延时
//IIC发送一个字节
void IIC_Send_Byte(unsigned char txd)
unsigned char i;
Delay();
for(i = 0; i < 8; i++)
if(txd & 0x80)
else
txd <<= 1;
Delay();
Delay();
//读取一个字节
unsigned char IIC_Read_Byte(unsigned char ack)
unsigned char i, res = 0;
for(i = 0; i < 8; ++i ){
GPIO_Init(GPIOC,GPIO_Pin_1,GPIO_Mode_Out_PP_Low_Slow);//set SCL pin as output high
Delay();
Delay();
res <<= 1;
if(SDA_READ()){
res ++;
return res;
//写数据
unsigned char BQ25890x_write_reg(unsigned char *pBuffer,unsigned char WriteAddr,unsigned char NumToWrite)
unsigned char u_wait_err = 0;
IIC_Start();
IIC_Send_Byte(SlaveAddress << 1);//slave addr
u_wait_err |= IIC_Wait_Ack();
IIC_Send_Byte(WriteAddr); //register addr
while(NumToWrite--)
IIC_Send_Byte(*pBuffer);
pBuffer++;
IIC_Stop();
if(u_wait_err == 0)
return 0;
return 1;
unsigned char BQ25890x_read_reg(unsigned char *pBuffer,unsigned char WriteAddr,unsigned char NumToRead)
IIC_Start();
IIC_Send_Byte(SlaveAddress<<1); // SlaveAddress 0x7e
IIC_Send_Byte(WriteAddr); // address
IIC_Start();
IIC_Send_Byte((SlaveAddress<<1)+1); // SlaveAddress 0x7e
while(--NumToRead)
*pBuffer = IIC_Read_Byte(1);
IIC_Ack();
pBuffer++;
IIC_NAck();
IIC_Stop();
if(u_wait_err == 0)
return 0;
return 1;
好了,这就是这部分的内容了。
关键字:STM8L152  模拟IIC 引用地址:STM8L152模拟IIC程序
上一篇:单片机驱动 Led 灯应注意
下一篇:触控温度计设计
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
