mega16试验板测试代码2-液晶1602四线显示
发布者:化羽2015最新更新时间:2016-10-28 来源: eefocus关键字:mega16  液晶1602  四线显示 手机看文章 扫描二维码
随时随地手机看文章
//delay.h
/**********延时函数*****************/
delay_us    :1us延时函数
void delay_us(void)
 asm("nop");
delay_nus          :长延时函数
输入参数: t        :延时时间 us
void delay_nus(unsigned int t)
 while(t--)
  delay_us();
delay_ms    :1ms延时函数
void delay_ms(void)
 unsigned int i;
 for(i=0;i<1140;i++);
delay_nms          :长延时函数
输入参数: t        :延时时间 ms
void delay_nms(unsigned int t)
 while(t--)
  delay_ms();
//lcd1602.h
   RS----------PC2
   RW----------GND
   EN----------PC3
   D4-D7-------PC4-PC7
//定义MCU与LCD的接口
#define LCD_EN_PORT   PORTC
#define LCD_EN_DDR    DDRC
#define LCD_RS_PORT   PORTC
#define LCD_RS_DDR    DDRC
#define LCD_DATA_PORT PORTC
#define LCD_DATA_DDR  DDRC
#define LCD_DATA_PIN  PINC
#define LCD_EN        0x08   //portc3 out
#define LCD_RS        0x04   //portc2 out
#define LCD_DATA      0xf0 //portc4/5/6/7 out
Public function prototypes
void LCD_init (void);
void LCD_en_write (void);
void clear(void);
void LCD_write_char(unsigned command,unsigned data);
void LCD_set_xy(unsigned char x, unsigned char y);
函数: lcd1602口线初始化和液晶初始化
void LCD_init(void) //液晶初始化
 LCD_DATA_DDR|=LCD_DATA;
 LCD_EN_DDR|=LCD_EN;
 LCD_RS_DDR|=LCD_RS;
 delay_nms(15);
 LCD_write_char(0x28,0); //4位显示
 delay_nms(15);
 LCD_write_char(0x0c,0); //显示开
 delay_nms(15);
 LCD_write_char(0x01,0); //清屏
函数: 设置显示地址
para: x---the display address of a line limit: 0---15
      y---the display line limit 0 or 1
void LCD_set_xy(unsigned char x, unsigned char y) //写地址函数
  unsigned char address;
  if(y ==0)
   address=0x80+x; //the first line
  else
   address=0xc0+x; //the second line
  LCD_write_char(address,0);
函数: lcd1602使能
void LCD_en_write(void) //液晶使能
 LCD_EN_PORT|=LCD_EN;
 delay_nus(5);
 LCD_EN_PORT&=~LCD_EN;
函数: 写命令或数据到lcd1602
参数:command: 0---写数据, 1---写命令
      data: 所要写的命令或数据
 unsigned command_temp,data_temp;
 command_temp=command;
 data_temp=data;
 delay_nus(25);
 if(command==0)
  LCD_RS_PORT|=LCD_RS; //RS=1
  LCD_DATA_PORT&=0X0f;
  LCD_DATA_PORT|=data_temp&0xf0; //写高四位
  LCD_en_write();
  data_temp=data_temp<<4;
  LCD_DATA_PORT|=data_temp&0xf0; //写低四位
  LCD_en_write();
 else
  LCD_RS_PORT&=~LCD_RS; //RS=0
  LCD_DATA_PORT|=command_temp&0xf0; //写高四位
  LCD_en_write();
  command_temp=command_temp<<4;
  LCD_DATA_PORT&=0x0f;
  LCD_DATA_PORT|=command_temp&0xf0; //写低四位
  LCD_en_write();
函数: 清屏lcd1602
void clear(void)
 unsigned char i;
 LCD_set_xy(0,0);
 for(i=0;i<16;i++)
 LCD_write_char(0,' ');
 LCD_set_xy(0,1);
 for(i=0;i<16;i++)
函数: 写字符串
参数:列---X=0~15,行---Y=0~1 写地址
      s为所要写的字符串
void LCD_write_string(unsigned char X,unsigned char Y,unsigned char *s)
 LCD_set_xy(X,Y);
 while(*s)
  LCD_write_char(0,*s);
  s++;
函数: 写数字
      dat为所要写的数字
void LCD_write_data(unsigned char X,unsigned char Y,int dat)
 unsigned char fuhao;
 unsigned char data[5];
 unsigned char i;
 if(dat<0)
  fuhao='-';
  dat=0-dat;
 else
  fuhao=' ';
 data[0]=fuhao;
 data[1]=dat/1000+0x30; dat%=1000;
 data[2]=dat/100+0x30;  dat%=100;
 data[3]=dat/10+0x30;
 data[4]=dat%10+0x30;
 LCD_set_xy(X,Y);
 for(i=0;i<5;i++)
  LCD_write_char(0,data[i]);
//test.c
//ICC-AVR application builder : 2008-11-4 9:30:11
// Target : M16
// Crystal: 7.3728Mhz
#include
#include
#include "delay.h"
#include "lcd1602.h"
unsigned char string1[]={"LCD1602 DIS TEST"};
unsigned char string2[]={" Number:"};
void main(void)
 LCD_init();
 clear();
 delay_nms(10);
 LCD_write_string(0,0,string1);
 LCD_write_string(0,1,string2);
 while(1)
  LCD_write_data(10,1,-1234);
关键字:mega16  液晶1602  四线显示 引用地址:mega16试验板测试代码2-液晶1602四线显示
上一篇:基于队列的UART通信模块
下一篇:mega16试验板测试代码1-串口测试程序
推荐阅读最新更新时间:2024-03-16 15:17
DS18B20 1602液晶显示、DS18B20时序太难调了
注意:无论写时隙,还是读时隙,都以主机驱动数据线(DQ)为低电平开始。数据线的下降沿触发从机内部的延时电路,使之与主机取得同步!!注意主从机采样时间! 复位脉冲 一开始错误出现在复位脉冲。 while(PIND&0x01); //正确!!等待被拉低。。18B20拉低60-240 us 我写出这样子//while((PIND&0x01)==0); XXXXXXXXXXX这样写是错误的XXXXXXXXXXXXXX //读出来的是255(0xff) ///////////////// // 8Mhz晶振 ////////////////// #include iom16v.h #include 1602.c
[单片机]
DS18B20 <font color='red'>1602</font><font color='red'>液晶</font><font color='red'>显示</font>、DS18B20时序太难调了
51单片机驱动 LCD1602液晶显示系统
废话不多说先上实物图 LCD1602+51单片机最小系统应用仿真及制作 好了,接下来正式进入制作环节: 第一步:仿真 绘制好原理图,仿真时单片机最小系统只放一个单片机就可以了,但实际电路中需要加上电源模块、复位模块。如下图: 原理图文件请在附件中找。 原理图绘制好后,编写代码并生成hex文件。参考代码如下: /*功能/ /使用外部中断INTO改变LED状态,并且用1602显示出其状态/ #include reg51.h #include intrins.h #define uint unsigned int #define uchar unsigned char uchar code table = H
[单片机]
51单片机驱动 LCD<font color='red'>1602</font><font color='red'>液晶</font><font color='red'>显示</font>系统
51单片机+ds1302+ds18b20+1602液晶万年历
这是我写的单片机小程序,将单片机开发板上的ds1302,ds18b20和1602综合起来,在1602上显示年月日周时分秒和温度;望各位好友指点,此程序仅适用于我的开发板,用在其他开发板上应该改下端口就可以。 #include reg52.h typedef unsigned char uint8; typedef unsigned int uint16; typedef long int uint32; //**************************************************************************************************** sbit DQ
[单片机]
51单片机+ds1302+ds18b20+<font color='red'>1602</font><font color='red'>液晶</font>万年历
1602液晶显示DS1302+S51时钟+温度显示
/*============================================================ 使用1602液晶显示DS1302+S51时钟+温度显示 zhaojun 2007/06/29 ============================================================== 声明:1. 1602驱动程序照搬 明皓 的,非常好用 2. DS1302驱动程序是参考网友修改而来 NS1602R(16*2)模拟口线接线方式 连接线图: --------------------------------------------------- | LCM--
[单片机]
MSP430控制1602液晶显示
简介:MSP430控制1602液晶显示 上面既是效果图了。。 /*////////////////////////////////////////////////////////////////////////// 文件名:液晶显示 时间:2011年8月24日 */////////////////////////////////////////////////////////////////////////// #include msp430x24x.h //加载头文件 #define E (0x0004u)//确定E的位 #define RW (0x0002u) #define RS (0x0001u) unsigne
[单片机]
MSP430控制<font color='red'>1602</font><font color='red'>液晶</font><font color='red'>显示</font>
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
