PID调节C51程序(4)
发布者:yuehui最新更新时间:2016-11-17 来源: eefocus关键字:PID调节  C51程序 手机看文章 扫描二维码
随时随地手机看文章
typedef struct PID
     double     SetPoint;         // Desired Value
     double     Proportion;         // Proportional Const
     double     Integral;         // Integral Const
     double     Derivative;         // Derivative Const
     double     LastError;         // Error[-1]
     double     PrevError;         // Error[-2]
     double     SumError;         // Sums of Errors
}   PID;
     Perform One PID Iteration
double PIDCalc ( PID     *pp,    double NextPoint )
{   double     dError, Error;
     pp->SumError += (Error = pp->SetPoint - NextPoint);
     dError = pp->LastError - pp->PrevError;
     pp->PrevError = pp->LastError;
     pp->LastError = Error;
     return     (   pp->Proportion * Error
                     +   pp->Integral * pp->SumError
                     +   pp->Derivative * dError
     Initialize PID Structure
void PIDInit   ( PID *pp )
{       memset ( pp,0,sizeof(PID) );
     Main Program
double sensor ( void )                         // Dummy Sensor Function
{       return 100.0;
void actuator ( double rDelta )             // Dummy Actuator Function
void main ( void )
{     PID             sPID;                              // PID Control Structure
     double         rOut;                              // PID Response (Output)
     double         rIn;                              // PID Feedback (Input)
     PIDInit ( &sPID );                         // Initialize Structure
     sPID.Proportion     = 0.5;                 // Set PID Coefficients
     sPID.Integral       = 0.5;
     sPID.Derivative     = 0.0;
     sPID.SetPoint       = 100.0;                 // Set PID Setpoint
     for (;;)                                         // Mock Up of PID Processing
     {     rIn = sensor ();                         // Read Input
         rOut = PIDCalc ( &sPID,rIn );         // Perform PID Interation
         actuator ( rOut );                     // Effect Needed Changes
关键字:PID调节  C51程序 引用地址:PID调节C51程序(4)
上一篇:PID调节C51程序(3)
下一篇:PID调节C51程序(5)
推荐阅读最新更新时间:2024-03-16 15:20
4线EEPROM的C51程序
sbit RomCS = 0xA0^3; sbit RomCLK = 0xA0^2; sbit RomDI = 0xA0^1; sbit RomDO = 0xA0^0; #define OPCODE_BIT 3 /*功能码位数*/ #define ADDRESS_BIT 8 /*地址位数*/ #define DATA_BIT 16 /*数据位数*/ #define WAITE_TIME 500 /*设置一个最大延时等待数值.注意在不同的晶振下延时是不同的*/ /***********************************************************************/ /*名称: main()
[单片机]
如何使用AVR单片机进行数字PID调节器的设计
数字PID调节器具有操作简单,控制精度准确,安全可靠性高等优点,广泛应用于工业生产过程中。提出一种以AVR单片机ATmega16为核心的数字PID调节器,该调节器充分利用了高性能AVR单片机的片内资源及外围扩展电路,能够接收多种类型的测量信号,具有较强的在线修改和丰富的控制功能,并且采取硬件和软件双重抗干扰措施提高了调节器的可靠性。 在连续生产过程控制中,按偏差的比例(P)、积分(I)、微分(D)进行控制的PID调节器是应用最为广泛的一种自动控制器。 它具有原理简单、易于实现、适用面广等优点。在计算机用于生产过程控制之前,模拟PID控制器一直占主导地位。单片机的出现,使以单片机为核心的数字PID调节器迅速成为应用最广泛的自
[单片机]
如何使用AVR单片机进行数字<font color='red'>PID</font><font color='red'>调节</font>器的设计
一个简单的流水灯c51程序
//代码 #include reg52.h //头文件 #define uchar unsigned char //宏定义 #define uint unsigned int void delay(uint x) //延时函数(控制灯亮与灭的间隔) {  uint i,j; for(i=500;i 0;i--) for(j=x;j 0;j--); } void main() //主函数 {   uchar i; //定义局部变量   P2=0x00; //关闭所有发光二极管   while(1) //死循环   {    P2=0xfe; //第一个二极管亮    delay(100); //延时     fo
[单片机]
C51学习心得体会,递归调用程序设计举例
迭代(循环)与递归(调用)对比 (1)二者都是建立在控制结构基础上的,迭代使用的是循环结构,递归使用的是选择机构; (2)二者都用到了循环,迭代明确使用循环结构,递归通过反复调用函数实现循环; (3)二者都用到了终止条件测试,迭代在继续循环条件为假时结束,递归在到达基本实例时终止的。 (4)二者都可能是无限的。 递归举例 1、阶乘 N!=N*(N-1)*...*2*1 long factorial(long number) { if(number =1) return 1; else return (number*factorial(number-1)); } 2、求和N+(N-1)+(N-2)+...+2+1 int s
[单片机]
X5045读写一体化C51程序
void X5045SpiOpen(void);//打开X5045片选 void X5045SpiClose(void);//关闭X5045片选 void X5045WriteEnable(void);//软件使能X5045写操作 void X5045WriteDisable(void);//软件禁止X5045写操作 unsigned char X5045SpiSend(unsigned char val);//X5045收发SPI协议 void X5045WriteByte(unsigned int addr, unsigned char val);//写X5045一个字节 void X5045WriteWord(unsigned
[单片机]
C51的串口中断处理子程序
此串口处理程序是基于以下的协议写成的: 帧内容FRAME=帧头FA+帧长度len(不包括帧头帧尾)+数据流data+帧尾FB。 串口中断子程序里对整个数据流进行处理,而不是一个字节一个字节地处理,在中断中等待处理完所有的字节。 void Uart_Int(void) interrupt 4 //串口要加帧头与FA帧尾FB { unsigned char len, i; unsigned int j=0; unsigned char serialStart; if(RI) //收到数据 { serialStart=SBUF; RI=0; if(serialStart==0xFA) { w
[单片机]
C51通用串口收发数据C语言程序
#include reg52.h //C51通用串口收发数据C语言程序模块 #define uchar unsigned char #define uint unsigned int uchar shu; bit i; sbit led1=P0^0; void delayms(uint xms) //1ms; { uint i,j; for(i=xms;i 0;i--) for(j=110;j 0;j--) ; } /************************************************************************/ void UART_ini
[单片机]
24C01的IIC 读写的C51程序
/*------------------------------------------------------------------------------ 为了安全起见,程序中很多NOP是冗余的,希望读者能进一步精简,但必须经过验证。 Atmel 24C01 比较特殊,为简约型. 51晶振为11.0592MHz 〖参考〗 http://www.c51bbs.com 〖版本〗V1.00A Build 0918 -----------------------------------------------------------------------------*/ #include reg51.h #incl
[单片机]
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
