//FileName:delay.h
#ifndef __LZP_DELAY_H_
#define __LZP_DELAY_H_
#define TRUE 1
#define FALSE 0
//设置波特率
#define OSC_FREQ 11059200L
#define BAUD_115200 256 - (OSC_FREQ/192L)/115200L // 255
#define BAUD_57600 256 - (OSC_FREQ/192L)/57600L // 254
#define BAUD_38400 256 - (OSC_FREQ/192L)/38400L // 253
#define BAUD_28800 256 - (OSC_FREQ/192L)/28800L // 252
#define BAUD_19200 256 - (OSC_FREQ/192L)/19200L // 250
#define BAUD_14400 256 - (OSC_FREQ/192L)/14400L // 248
#define BAUD_9600 256 - (OSC_FREQ/192L)/9600L // 244
// Timer2
#define RCAP2_50us 65536L - OSC_FREQ/240417L
#define RCAP2_1ms 65536L - OSC_FREQ/12021L
void delay_ms(unsigned int num);
void delay_50us(unsigned char num);
void delay_us(unsigned char num);
#endif
//FileName:delay.c
** start51 study board
** delay function implementation
** author:bluehacker
** QQ:282074921
#include "delay.h"
#include "reg52.h"
RCAP2H = (RCAP2_1ms>>8);
RCAP2L=(RCAP2_1ms&0x00ff);
TH2=(RCAP2_1ms>>8);;
TL2=(RCAP2_1ms&0x00ff);;
ET2 = 0; // Disable timer2 interrupt
T2CON = 0x04; // 16-bit auto-reload, clear TF2, start timer
while (num--)
while (!TF2);
TF2 = FALSE;
TR2 = FALSE;
RCAP2H=(RCAP2_50us>>8);
RCAP2L=(RCAP2_50us&0x00ff);
TH2=(RCAP2_50us>>8);
TL2=(RCAP2_50us&0x00ff);
ET2=0;
T2CON=0x04;
while(num--)
while(!TF2)
TF2=FALSE;
TR2=FALSE;
unsigned char i;
for (i=0;i
//FileName:lcd.h
#ifndef __LZP_LCD_H_
#define __LZP_LCD_H_
#include "reg52.h"
//定义LCD控制引脚
sbit LCDRS="P2"^0;
sbit LCDRW="P2"^1;
sbit LCDE="P2"^2;
void lcd_write_cmd(unsigned char cmd);
void lcd_write_data(unsigned char dat);
void lcd_clear(void);
void lcd_init(void);
unsigned char lcd_status(void);
void lcd_set_mode(unsigned char cursor, unsigned char text);
void lcd_write_str(unsigned char x,unsigned char y,unsigned char *s);
void lcd_write_char(unsigned char x,unsigned char y, unsigned char d);
#endif
//FileName:lcd.c
**本开发板支持1602 字符型LCD
**这种LCD的接口资料可以用google找到很多
**引脚定义:
* 1---GND
* 2---VDD
* 3---VLCD:对比度调节
* 4---RS:寄存器选择,高电平时选择数据寄存器、低电平时选择指令寄存器
* 5---R/W:读写信号线,高电平时进行读操作,低电平时进行写操作。
当RS和RW共同为低电平时可以写入指令或者显示地址,当RS为低电平
RW为高电平时可以读忙信号,当RS为高电平RW为低电平时可以写入数据。
* 6---E:使能端,当E端由高电平跳变成低电平时,液晶模块执行命令。
* 7~14---DB0~DB7数据线、
* 15---A:背光引脚,"A"接正
* 16---K:背光引脚,"K"接负
#include "lcd.h"
#include "delay.h"
#include "intrins.h"
/*向LCD写入命令*/
unsigned char status;
P0=cmd;
LCDRS="0";
LCDRW="0";
LCDE="0";
delay_us(5);
do{
status="lcd"_status();
}while(status&0x80);
LCDE="1";
P0=dat;
LCDRS="1";
LCDRW="0";
LCDE="0";
delay_us(5);
do{
LCDE="1";
lcd_write_cmd(0x01);
/*显示屏字符串写入函数*/
if (y == 0) {
lcd_write_cmd(0x80 + x);
else {
lcd_write_cmd(0xC0 + x);
while (*s) {
lcd_write_data( *s);
s ++;
unsigned char i;
for(i=0;i<16&&s!=0;i++)
lcd_write_char(x+i,y,s);
if(y==0)
lcd_write_cmd(0x80+x);
else
lcd_write_cmd(0xc0+x);
lcd_write_data(d);
//光标复位
void lcd_reset_cursor(void)
lcd_write_cmd(0x02);
//设置显示模式
unsigned char mode="0x04";
if(cursor){//光标右移
mode|=0x02;
else{//光标左移
mode|=0x00;
if(text){//文字移动
mode|=0x01;
else{//文字不移动
mode|=0;
lcd_write_cmd(mode);
void lcd_init(void)
P0=0;
LCDE="1";
delay_ms(500);
lcd_clear();
lcd_write_cmd(0x38);//设置lcd功能:8位总线,双行显示,5X7点阵字符
lcd_write_cmd(0x0f);//显示开关控制:显示ON,光标ON,闪烁ON
lcd_write_cmd(0x06);//光标输入方式增量移位
lcd_write_cmd(0x80);
//lcd_write_cmd(0x0c);
//lcd_clear();
//读取状态,是否忙
unsigned char tmp="0";
P0=0xff;
LCDRS="0";
LCDRW="1";
LCDE="0";
_nop_();
LCDE="1";
//_nop_();
tmp="P0";
return tmp;
//FileName:test.c
** Start51 study board test software
** test 1602LCD
** author: bluehacker
** QQ:282074921
#include "lcd.h"
#include "delay.h"
void main(void)
//初始化串口
SCON="0x50";/*mode 1,1 start bit ,8 data bit ,1 stop bit,enable receive*/
PCON="0x80";/*SMOD=1, Baud Rate twice*/
TMOD="0x21";/*timer 0--mode 1 and timer 1 ---mode2*/
//set baud rate,use timer 1 as baud rate generator
TH1=BAUD_19200;
TL1=TH1;
TR1=TRUE;
ET1=FALSE;//disable timer 1 interrupt
EA="0";
//delay_ms(400);
lcd_init();
// lcd_set_mode(1,0);
//lcd_reset_cursor();
// lcd_write_char(3,1,'c');
lcd_write_str(2,0,"bluehacker");
lcd_write_str(2,1,"QQ:282074921");
while(1)
上一篇:51单片机低功耗工作模式
下一篇:Keil C51编写的192*64液晶片驱动程序
推荐阅读最新更新时间:2024-03-16 15:25
设计资源 培训 开发板 精华推荐
- 看视频答题,玩转幸运大抽奖:Littelfuse汽车电子电路保护知多少
- TI 嵌入式产品研讨会视频曝光,下载有礼!
- 有奖活动|NI 助您设计更靠谱的数据采集系统
- TE Connectivity 小有乾坤蕴藏无限可能
- EEWorld有奖主题征文来了~现金奖励等你来拿!
- TI直播| 低功耗技术在 Wi-Fi 摄像头及 PIR 红外传感器设计中的应用
- 阅读TI Think.lnnovate 神级DIY系列博文,你来畅想我送礼!
- 看视频赢好礼:泰克MIPI家族介绍和测试方案,迎接未来的测试挑战
- 有奖直播|Keysight World 2020【电信基础设施、云与人工智能分论坛】
- TTI Asia 2016慕尼黑上海电子展关注有礼活动
