CA12864K 串口C51演示程序
// CA12864K 测试程序(串口)
//连线表: CPU=89C52 SystemClock=12Mhz *
//CS=P3.0 SCLK=P3.1 SID=P3.2 Reset=RC in Board *
#include
#include
#include
#include
sbit CS =P3^0;
sbit SCK=P3^1;
sbit SID=P3^2;
sbit Key=P3^4;
unsigned char code AC_TABLE[]={
0x80,0x81,0x82,0x83,0x84,0x85,0x86,0x87, //第一行汉字位置
0x90,0x91,0x92,0x93,0x94,0x95,0x96,0x97, //第二行汉字位置
0x88,0x89,0x8a,0x8b,0x8c,0x8d,0x8e,0x8f, //第三行汉字位置
0x98,0x99,0x9a,0x9b,0x9c,0x9d,0x9e,0x9f, //第四行汉字位置
unsigned char code str2[]="欢迎光临sunson!!";
unsigned char code str1[]="黄河远上白云间,一片孤城万仞山。羌笛何须怨杨柳,春风不度玉门关。";
unsigned char code bmp1[];
//串口发送一个字节
void SendByte(unsigned char Dbyte)
unsigned char i;
for(i=0;i<8;i++)
SCK = 0;
Dbyte=Dbyte<<1; //左移一位
SID = CY; //移出的位给SID
SCK = 1;
SCK = 0;
//串口接收一个字节
//仅在读取数据的时候用到
//而读出的数据是一次只能读出4bit的
unsigned char ReceiveByte(void)
unsigned char i,temp1,temp2;
temp1=temp2=0;
for(i=0;i<8;i++)
temp1=temp1<<1;
SCK = 0;
SCK = 1;
SCK = 0;
if(SID) temp1++;
for(i=0;i<8;i++)
temp2=temp2<<1;
SCK = 0;
SCK = 1;
SCK = 0;
if(SID) temp2++;
return ((0xf0&temp1)+(0x0f&temp2));
void CheckBusy( void )
do SendByte(0xfc); //11111,RW(1),RS(0),0
while(0x80&ReceiveByte()); //BF(.7)=1 Busy
void WriteCommand( unsigned char Cbyte )
CS = 1;
CheckBusy();
SendByte(0xf8); //11111,RW(0),RS(0),0
SendByte(0xf0&Cbyte); //高四位
SendByte(0xf0&Cbyte<<4);//低四位(先执行<<)
CS = 0;
void WriteData( unsigned char Dbyte )
CS = 1;
CheckBusy();
SendByte(0xfa); //11111,RW(0),RS(1),0
SendByte(0xf0&Dbyte); //高四位
SendByte(0xf0&Dbyte<<4);//低四位(先执行<<)
CS = 0;
unsigned char ReadData( void )
CheckBusy();
SendByte(0xfe); //11111,RW(1),RS(1),0
return ReceiveByte();
void Delay(unsigned int MS)
unsigned char us,usn;
while(MS!=0) //for 12M
{ usn = 2;
while(usn!=0)
us=0xf5;
while (us!=0){us--;};
usn--;
MS--;
//松山电子测试架专用延时函数
void DelayKey(unsigned int Second , unsigned int MS100)
{ //输入精确到0.1S,是用","
unsigned int i;
for(i=0;i { if(Key==0) { Delay(20); while(Key==0) {Delay(20);} break; } else Delay(10); } } void LcmInit( void ) { WriteCommand(0x30); //8BitMCU,基本指令集合 WriteCommand(0x03); //AC归0,不改变DDRAM内容 WriteCommand(0x0C); //显示ON,游标OFF,游标位反白OFF WriteCommand(0x01); //清屏,AC归0 WriteCommand(0x06); //写入时,游标右移动 } //文本区清RAM函数 void LcmClearTXT( void ) { unsigned char i; WriteCommand(0x30); //8BitMCU,基本指令集合 WriteCommand(0x80); //AC归起始位 for(i=0;i<64;i++) WriteData(0x20); } //图形区和文本区显示在两个不同的RAM区 //图形区清RAM函数 void LcmClearBMP( void ) { unsigned char i,j; WriteCommand(0x34); //8Bit扩充指令集,即使是36H也要写两次 WriteCommand(0x36); //绘图ON,基本指令集里面36H不能开绘图 for(i=0;i<32;i++) //12864实际为256x32 { WriteCommand(0x80|i); //行位置 WriteCommand(0x80); //列位置 for(j=0;j<32;j++) //256/8=32 byte WriteData(0); } } void PutStr(unsigned char row,unsigned char col,unsigned char *puts) { WriteCommand(0x30); //8BitMCU,基本指令集合 WriteCommand(AC_TABLE[8*row+col]); //起始位置 while(*puts != '/0') //判断字符串是否显示完毕 { if(col==8) //判断换行 { //若不判断,则自动从第一行到第三行 col=0; row++; } if(row==4) row=0; //一屏显示完,回到屏左上角 WriteCommand(AC_TABLE[8*row+col]); WriteData(*puts); //一个汉字要写两次 puts++; WriteData(*puts); puts++; col++; } } void PutBMP(unsigned char *puts) { unsigned int x=0; unsigned char i,j; WriteCommand(0x34); //8Bit扩充指令集,即使是36H也要写两次 WriteCommand(0x36); //绘图ON,基本指令集里面36H不能开绘图 for(i=0;i<32;i++) //12864实际为256x32 { WriteCommand(0x80|i); //行位置 WriteCommand(0x80); //列位置 for(j=0;j<32;j++) //256/8=32 byte { //列位置每行自动增加 WriteData(puts[x]); x++; } } } //松山电子测试用点阵显示 void DisplayDots(unsigned char DotByte) { unsigned char i,j; WriteCommand(0x34); //8Bit扩充指令集,即使是36H也要写两次 WriteCommand(0x36); //绘图ON,基本指令集里面36H不能开绘图 for(i=0;i<32;i++) //12864实际为256x32 { WriteCommand(0x80|i); //行位置 WriteCommand(0x80); //列位置 for(j=0;j<32;j++) //256/8=32 byte { //列位置每行自动增加 WriteData(DotByte); } DotByte=~DotByte; } } void main( void ) { Delay(100); //等待复位 LcmInit(); LcmClearTXT(); LcmClearBMP(); while(1) { LcmClearTXT(); PutBMP(bmp1); DelayKey(1,5); DisplayDots(0x55); DelayKey(1,5); LcmClearBMP(); PutStr(0,0,str1); DelayKey(1,5); LcmClearTXT(); DisplayDots(0xaa); DelayKey(1,5); } } unsigned char code bmp1[]={ //********************************************************// //***** 转换的文件:E:/!Program/!BmpSample/25632.bmp //***** 源图形宽度 * 高度:256 * 32 //***** 调整后宽度 * 高度:256 * 32 //***** 字模格式:横向取模,冗余模式,字节正序,正色取模, //***** 点阵转换时间:2005/03/ 2 16:4:32 //***** 位图点阵占用1024字节 //********************************************************// 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, 0x80,0x00,0x0F,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x70,0x00,0x00,0x01, 0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01, 0x80,0x00,0x3F,0xC0,0x00,0x07,0x07,0x00,0x04,0x01,0x00,0x00,0x38,0x60,0x00,0x01, 0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01, 0x80,0x00,0x78,0xE0,0x00,0x3F,0x83,0x80,0x06,0x03,0x80,0x00,0x1C,0x70,0x00,0x01, 0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01, 0x80,0x02,0x38,0x70,0x00,0xFF,0x07,0x80,0x06,0x39,0x80,0x00,0x1F,0x70,0x00,0x01, 0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01, 0x80,0x02,0x1C,0x30,0x00,0x7C,0x0E,0x00,0x06,0x19,0xC0,0x00,0x1F,0x80,0x00,0x01, 0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01, 0x80,0x02,0x1C,0x30,0x00,0x3E,0x1C,0x00,0x06,0x1F,0xC0,0x00,0x7F,0x00,0x00,0x01, 0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01, 0x80,0x03,0x3E,0x30,0x00,0x62,0x1A,0x00,0x0F,0x79,0x00,0x03,0xFE,0x00,0x00,0x01, 0x80,0x00,0x00,0x60,0x0F,0x00,0x3F,0x00,0x00,0x00,0x3C,0x00,0xC0,0x00,0x00,0x01, 0x80,0x07,0x76,0x18,0x00,0xC3,0xC1,0x00,0x1F,0xFB,0x00,0x03,0xFE,0x00,0x00,0x01, 0x80,0x00,0x01,0xE0,0x3F,0xC0,0xF1,0xC0,0x00,0x00,0xF0,0x01,0xC0,0x00,0x00,0x01, 0x80,0x07,0x6E,0x18,0x00,0xCF,0xC1,0x80,0x7E,0x3F,0x80,0x01,0xE2,0x00,0x00,0x01, 0x80,0x00,0x07,0xE0,0x7F,0xE0,0xE0,0xE0,0x00,0x03,0xC0,0x03,0xC0,0x00,0x00,0x01, 0x80,0x07,0x7F,0x98,0x00,0xFE,0x83,0x81,0xFC,0x1E,0xC0,0x00,0x83,0x00,0x00,0x01, 0x80,0x00,0x0F,0xE0,0x63,0xE1,0xE0,0xE0,0x00,0x07,0x00,0x03,0xC0,0x00,0x00,0x01, 0x80,0x06,0xFF,0xD8,0x01,0xFA,0x87,0x00,0xFD,0xF8,0xC0,0x01,0x73,0x00,0x00,0x01, 0x80,0x00,0x01,0xE0,0xC1,0xE1,0xE0,0xE0,0x00,0x0F,0x00,0x07,0xC0,0x00,0x00,0x01, 0x80,0x0F,0xD9,0xD8,0x03,0xE3,0x0E,0x80,0xFE,0x7E,0xC0,0x03,0xF9,0x80,0x00,0x01, 0x80,0x00,0x01,0xE0,0x01,0xE1,0xF0,0xE0,0x00,0x1E,0x00,0x0B,0xC0,0x00,0x00,0x01, 0x80,0x0D,0xB8,0x18,0x1F,0xC3,0x08,0xC0,0x0E,0x6D,0x80,0x03,0xF1,0x80,0x00,0x01, 0x80,0x00,0x01,0xE0,0x01,0xE0,0xFD,0xC7,0xEF,0x9E,0x00,0x13,0xC0,0x00,0x00,0x01, 0x80,0x0D,0xFE,0x18,0x0F,0xC2,0x10,0xE0,0x1C,0x3F,0x00,0x03,0xE0,0xC0,0x00,0x01, 0x80,0x00,0x01,0xE0,0x01,0xC0,0xFF,0x83,0xC6,0x1F,0xE0,0x13,0xC0,0x00,0x00,0x01, 0x80,0x0D,0xCE,0x18,0x06,0xC2,0x01,0xC0,0x38,0x3E,0x00,0x00,0xE8,0xC0,0x00,0x01, 0x80,0x00,0x01,0xE0,0x01,0x80,0x3F,0x81,0xE4,0x3C,0x78,0x23,0xC0,0x00,0x00,0x01, 0x80,0x0C,0x4C,0x18,0x00,0xC2,0x03,0x80,0x78,0x1F,0xF0,0x00,0xFC,0x60,0x00,0x01, 0x80,0x00,0x01,0xE0,0x03,0x80,0x3F,0xC1,0xE8,0x3C,0x78,0x43,0xC0,0x00,0x00,0x01, 0x80,0x0C,0x5E,0x18,0x00,0xC2,0x07,0x00,0x68,0x3F,0xF8,0x03,0xFC,0x22,0x00,0x01, 0x80,0x00,0x01,0xE0,0x03,0x00,0x6F,0xC0,0xF0,0x3C,0x3C,0x83,0xC0,0x00,0x00,0x01, 0x80,0x06,0x3F,0x38,0x01,0x82,0x0E,0x00,0x09,0xF8,0x00,0x03,0xC0,0x32,0x00,0x01, 0x80,0x00,0x01,0xE0,0x06,0x00,0xC3,0xE0,0x78,0x3C,0x3C,0xFF,0xF0,0x00,0x00,0x01, 0x80,0x07,0x10,0x38,0x00,0x82,0x1C,0x00,0x0B,0x99,0xC0,0x03,0x00,0x1A,0x00,0x01, 0x80,0x00,0x01,0xE0,0x0C,0x11,0xC3,0xE0,0x78,0x3C,0x3C,0xFF,0xF0,0x00,0x00,0x01, 0x80,0x03,0xFF,0xF0,0x00,0x02,0x38,0x00,0x08,0x30,0xE0,0x02,0x00,0x1E,0x00,0x01, 0x80,0x00,0x01,0xE0,0x08,0x11,0xC1,0xE0,0x7C,0x3C,0x3C,0xFF,0xF0,0x00,0x00,0x01, 0x80,0x01,0xEF,0xF0,0x00,0x00,0xE0,0x00,0x08,0xE0,0x60,0x00,0x00,0x0E,0x00,0x01, 0x80,0x00,0x01,0xE0,0x1F,0xF1,0xC1,0xE0,0xBC,0x1C,0x3C,0x03,0xC0,0x00,0x00,0x01, 0x80,0x00,0x03,0xE0,0x00,0x00,0x00,0x00,0x04,0x00,0x00,0x00,0x00,0x07,0x00,0x01, 0x80,0x00,0x01,0xE0,0x3F,0xE1,0xC1,0xC0,0x9E,0x1E,0x38,0x03,0xC0,0x00,0x00,0x01, 0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x00,0x01, 0x80,0x00,0x01,0xF0,0x7F,0xE0,0xE3,0x83,0x1F,0x0E,0x70,0x03,0xC0,0x00,0x00,0x01, 0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01, 0x80,0x00,0x0F,0xFC,0xFF,0xE0,0x3F,0x07,0xDF,0x83,0xE0,0x03,0xC0,0x00,0x00,0x01, 0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01, 0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01, 0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01, 0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01, 0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01, 0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01, 0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01, 0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01, 0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01, 0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01, 0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01, 0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01, 0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01, 0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x60,0x00,0x00,0x01, 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF, };
上一篇:74LS164(74HC164)单片机C51驱动
下一篇:单片机C51编程入门最好的例子(跑马灯)
推荐阅读最新更新时间:2024-03-16 15:28
