pic16f877a.h中文注释
发布者:未来感觉最新更新时间:2017-01-04 来源: eefocus关键字:pic16f877a  中文注释 手机看文章 扫描二维码
随时随地手机看文章
存放路径:在PICC软件hi-tech安装目录下,?:\Microchip\cc8.05\include,找到pic1687xa.h,里面即有
以下是头文件内容及详细注释:
 * Header file for the Microchip
 * PIC 16F873A chip
 * PIC 16F874A chip
 * PIC 16F876A chip
 * PIC 16F877A chip
 * Midrange Microcontroller
#if defined(_16F874A) || defined(_16F877A)
#define __PINS_40
#endif
static volatile unsigned char INDF @ 0x00;   //间接寻址寄存器
static volatile unsigned char TMR0 @ 0x01;   //定时器0
static volatile unsigned char PCL  @ 0x02;   //低8位程序计数器
static volatile unsigned char STATUS @ 0x03;   //程序状态寄存器
static          unsigned char FSR  @ 0x04;   //特殊功能寄存器
static volatile unsigned char PORTA @ 0x05;   //端口A寄存器
static volatile unsigned char PORTB @ 0x06;   //端口B寄存器
static volatile unsigned char PORTC @ 0x07;   //端口C寄存器
#ifdef __PINS_40
static volatile unsigned char PORTD @ 0x08;   //端口D寄存器
static volatile unsigned char PORTE @ 0x09;   //端口E寄存器
#endif
static          unsigned char PCLATH @ 0x0A;   //高5位程序计数器
static volatile unsigned char INTCON @ 0x0B;   //中断控制寄存器
static volatile unsigned char PIR1 @ 0x0C;   //中断标志寄存器PIR1
static volatile unsigned char PIR2 @ 0x0D;   //中断标志寄存器PIR2
static volatile unsigned char TMR1L @ 0x0E;   //低字节计数寄存器
static volatile unsigned char TMR1H @ 0x0F;   //高字节计数寄存器
static volatile unsigned char T1CON @ 0x10;   //TMR1控制寄存器
static volatile unsigned char TMR2 @ 0x11;   //定时/计数器TMR2
static volatile unsigned char T2CON @ 0x12;   //TMR2控制寄存器
static volatile unsigned char SSPBUF @ 0x13;   //收/发数据缓冲器
static volatile unsigned char SSPCON @ 0x14;   //同步串口控制寄存器,对MSSP模块的功能和指标进行设置和定义
static volatile unsigned char CCPR1L @ 0x15;   //捕获/比较/PWM寄存器低字节
static volatile unsigned char CCPR1H @ 0x16;   //捕获/比较/PWM寄存器低字节
static volatile unsigned char CCP1CON @ 0x17;   //CCP1CON寄存器
static volatile unsigned char RCSTA @ 0x18;   //USART接收控制兼状态寄存器
static volatile unsigned char TXREG @ 0x19;   //USART发生缓冲器
static volatile unsigned char RCREG @ 0x1A;   //USART接收缓冲器
static volatile unsigned char CCPR2L @ 0x1B;   //捕获/比较/PWM寄存器低字节
static volatile unsigned char CCPR2H @ 0x1C;   //捕获/比较/PWM寄存器低字节
static volatile unsigned char CCP2CON @ 0x1D;   //CCP2CON寄存器
static volatile unsigned char ADRESH @ 0x1E;   //ADC转换结果寄存器高字节
static volatile unsigned char ADCON0 @ 0x1F;   //A/D转换器开关位
/* bank 1 registers */
static unsigned char bank1 OPTION @ 0x81;  //选择寄存器,用于配置TMR0/WDT预分频系数、外部INT中断、TMR0和端口B的弱上拉。
static volatile unsigned char bank1 TRISA @ 0x85;  //A口方向寄存器
static volatile unsigned char bank1 TRISB @ 0x86;  //B口方向寄存器
static volatile unsigned char bank1 TRISC @ 0x87;  //C口方向寄存器
#ifdef __PINS_40
static volatile unsigned char bank1 TRISD @ 0x88;  //D口方向寄存器
static volatile unsigned char bank1 TRISE @ 0x89;  //E口方向寄存器
#endif
static volatile unsigned char bank1 PIE1 @ 0x8C;  //中断允许寄存器PIE1
static volatile unsigned char bank1 PIE2 @ 0x8D;  //中断允许寄存器PIE2
static volatile unsigned char bank1 PCON @ 0x8E;  //电源控制状态寄存器
static volatile unsigned char bank1 SSPCON2 @ 0x91;  //MSSP控制寄存器2
static volatile unsigned char bank1 PR2  @ 0x92;  //TMR2周期寄存器
static volatile unsigned char bank1 SSPADD @ 0x93;  //同步串口地址寄存器
static volatile unsigned char bank1 SSPSTAT @ 0x94;  //同步串口状态寄存器
static volatile unsigned char bank1 TXSTA @ 0x98;  //USART发生控制兼状态寄存器
static volatile unsigned char bank1 SPBRG @ 0x99;  //USART波特率发生器初值寄存器
static volatile unsigned char bank1 CMCON @ 0x9C;  //比较控制寄存器
static volatile unsigned char bank1 CVRCON @ 0x9D;  //比较电压参考控制寄存器
static volatile unsigned char bank1 ADRESL @ 0x9E;  //ADC转换结果寄存器低字节
static volatile unsigned char bank1 ADCON1 @ 0x9F;  //ADC控制寄存器ADCON1
/* bank 2 registers */
static volatile unsigned char bank2 EEDATA @ 0x10C; //EEPROM数据寄存器低字节
static volatile unsigned char bank2 EEADR @ 0x10D; //EEPROM地址寄存器低字节
static volatile unsigned char bank2 EEDATH @ 0x10E; //EEPROM数据寄存器高字节
static volatile unsigned char bank2 EEADRH @ 0x10F; //EEPROM地址寄存器高字节
/* bank 3 registers */
static volatile unsigned char bank3 EECON1 @ 0x18C; //EEPROM控制寄存器1
static volatile unsigned char bank3 EECON2 @ 0x18D; //EEPROM控制寄存器2
//* STATUS bits状态寄存器 */
static volatile bit IRP     @ (unsigned)&STATUS*8+7; //寄存器bank选择位(用于间接寻址)。0:bank0,1;1:bank2,3
static volatile bit RP1  @ (unsigned)&STATUS*8+6; //寄存器bank选择位(用于直接寻址)
PR1:PR0:00:BANK0;01:BANK1;10:BANK2;11BANK3.
static volatile bit RP0     @ (unsigned)&STATUS*8+5; //
static volatile bit TO  @ (unsigned)&STATUS*8+4; //超时位。0:WDT超时发生;1:上电后,执行了CLRWDT或者SLEEP指令
static volatile bit PD  @ (unsigned)&STATUS*8+3; //掉电标志位。0:执行完SLEEP指令;1:上电后或者执行CLRWDT指令
static volatile bit ZERO    @ (unsigned)&STATUS*8+2; //零标志位。0:算术或逻辑操作结果不为0;1:反之。
static volatile bit DC      @ (unsigned)&STATUS*8+1; //数字进位/退位标志位。0:结果的低4位没有发生进位;1:反之。
static volatile bit CARRY   @ (unsigned)&STATUS*8+0; //进位/退位标志位。0:结果的高4位没有发生进位;1:反之。
/*      PORTA bits      */
static volatile bit RA5 @ (unsigned)&PORTA*8+5;   //RA5
static volatile bit RA4 @ (unsigned)&PORTA*8+4;   //RA4
static volatile bit RA3 @ (unsigned)&PORTA*8+3;   //RA3
static volatile bit RA2 @ (unsigned)&PORTA*8+2;   //RA2
static volatile bit RA1 @ (unsigned)&PORTA*8+1;   //RA1
static volatile bit RA0 @ (unsigned)&PORTA*8+0;   //RA0
/*      PORTB bits      */
static volatile bit RB7 @ (unsigned)&PORTB*8+7;   //RB7
static volatile bit RB6 @ (unsigned)&PORTB*8+6;   //RB6
static volatile bit RB5 @ (unsigned)&PORTB*8+5;   //RB5
static volatile bit RB4 @ (unsigned)&PORTB*8+4;   //RB4
static volatile bit RB3 @ (unsigned)&PORTB*8+3;   //RB3
static volatile bit RB2 @ (unsigned)&PORTB*8+2;   //RB2
static volatile bit RB1 @ (unsigned)&PORTB*8+1;   //RB1
static volatile bit RB0 @ (unsigned)&PORTB*8+0;   //RB0
/*      PORTC bits      */
static volatile bit RC7 @ (unsigned)&PORTC*8+7;   //RC7
static volatile bit RC6 @ (unsigned)&PORTC*8+6;   //RC6
static volatile bit RC5 @ (unsigned)&PORTC*8+5;   //RC5
static volatile bit RC4 @ (unsigned)&PORTC*8+4;   //RC4
static volatile bit RC3 @ (unsigned)&PORTC*8+3;   //RC3
static volatile bit RC2 @ (unsigned)&PORTC*8+2;   //RC2
static volatile bit RC1 @ (unsigned)&PORTC*8+1;   //RC1
static volatile bit RC0 @ (unsigned)&PORTC*8+0;   //RC0
/*      PORTD bits      */
#ifdef __PINS_40
static volatile bit RD7 @ (unsigned)&PORTD*8+7;   //RD7
static volatile bit RD6 @ (unsigned)&PORTD*8+6;   //RD6
static volatile bit RD5 @ (unsigned)&PORTD*8+5;   //RD5
static volatile bit RD4 @ (unsigned)&PORTD*8+4;   //RD4
static volatile bit RD3 @ (unsigned)&PORTD*8+3;   //RD3
static volatile bit RD2 @ (unsigned)&PORTD*8+2;   //RD2
static volatile bit RD1 @ (unsigned)&PORTD*8+1;   //RD1
static volatile bit RD0 @ (unsigned)&PORTD*8+0;   //RD0
/*      PORTE bits      */
static volatile bit RE2 @ (unsigned)&PORTE*8+2;   //RE2
static volatile bit RE1 @ (unsigned)&PORTE*8+1;   //RE1
static volatile bit RE0 @ (unsigned)&PORTE*8+0;   //RE0
#endif
//* INTCON bits 中断控制寄存器 */
static volatile bit GIE  @ (unsigned)&INTCON*8+7; //总中断使能位。0:屏蔽所有的中断请求;1:允许非屏蔽的中断。
static volatile bit PEIE @ (unsigned)&INTCON*8+6; //外部中断使能位。0:禁止;1:使能
static volatile bit T0IE @ (unsigned)&INTCON*8+5; //TMR0溢出中断使能位。0:禁止;1:使能
static volatile bit INTE @ (unsigned)&INTCON*8+4; //RB0/INT外部中断使能位。0:不使能;1:使能。
static volatile bit RBIE @ (unsigned)&INTCON*8+3; //RB端口变化中断时能位。0:不使能;1:使能。
static volatile bit T0IF @ (unsigned)&INTCON*8+2; //TMR0溢出中断标志位。0:无溢出;1:溢出。
static volatile bit INTF @ (unsigned)&INTCON*8+1; //RB0/INT外部中断标志位。0:RB0外部中断未发生;1:RB0外部中断发生。
static volatile bit RBIF @ (unsigned)&INTCON*8+0; //RB端口变化中断标志位。0:RB口无变化;1:RB口至少有一个引脚变化。
// alternate definitions
static volatile bit TMR0IE @ (unsigned)&INTCON*8+5; //
static volatile bit TMR0IF @ (unsigned)&INTCON*8+2; //
//* PIR1 bits中断标志寄存器PIR1 */
#ifdef __PINS_40
static volatile bit PSPIF @ (unsigned)&PIR1*8+7;  //并行从端口读写中断标志位。0:没有读写操作发生;1:反之
#endif
static volatile bit ADIF @ (unsigned)&PIR1*8+6;  //A/D转换器中断标志位。0:A/D转换没有完成;1:A/D转换完成。
static volatile bit RCIF @ (unsigned)&PIR1*8+5;  //USART接收中断标志位。0:接收缓冲器空;1:反之。
static volatile bit TXIF @ (unsigned)&PIR1*8+4;  //USART发送中断标志位。0:发生缓冲器满;1:反之。
static volatile bit SSPIF @ (unsigned)&PIR1*8+3;  //同步串行端口(ssp)中断标志位。0:没有ssp中断条件发生;
static volatile bit CCP1IF @ (unsigned)&PIR1*8+2;  //CCP1中断标志位。
static volatile bit TMR2IF @ (unsigned)&PIR1*8+1;  //TMR2 TO PR2匹配中断标志位。0:没有匹配发生
static volatile bit TMR1IF @ (unsigned)&PIR1*8+0;  //TMR1溢出中断标志位,0:无溢出
/* PIR2 bits */
static volatile bit CMIF @ (unsigned)&PIR2*8+6;  //比较器中断标志位;0:比较器输入没有改变
static volatile bit EEIF @ (unsigned)&PIR2*8+4;  //EEPROM写操作中断标志位。0:写操作没有完成或没有开始
static volatile bit BCLIF @ (unsigned)&PIR2*8+3;  //总线冲突中断标志位。0:没有总线冲突发生
static volatile bit CCP2IF @ (unsigned)&PIR2*8+0;  //CCP2中断标志位
//* T1CON bits TMR1控制寄存器 */
static volatile bit T1CKPS1 @ (unsigned)&T1CON*8+5;  //TMR1输入时钟预分频选择位
static volatile bit T1CKPS0 @ (unsigned)&T1CON*8+4;  //TMR1输入时钟预分频选择位
static volatile bit T1OSCEN @ (unsigned)&T1CON*8+3;  //TMR1震荡器使能控制位。0:振荡器关闭
static volatile bit T1SYNC  @ (unsigned)&T1CON*8+2;  //TMR1外部时钟输入同步控制位。
static volatile bit TMR1CS  @ (unsigned)&T1CON*8+1;  //TMR1时钟源选择位。0:内部时钟的/4
static volatile bit TMR1ON  @ (unsigned)&T1CON*8+0;  //TMR1使能位。0:禁止
//* T2CON bits TMR2控制寄存器 */
static volatile bit TOUTPS3 @ (unsigned)&T2CON*8+6;  //TMR2后分频选择位。
static volatile bit TOUTPS2 @ (unsigned)&T2CON*8+5;  //TMR2后分频选择位
static volatile bit TOUTPS1 @ (unsigned)&T2CON*8+4;  //TMR2后分频选择位
static volatile bit TOUTPS0 @ (unsigned)&T2CON*8+3;  //TMR2后分频选择位。
static volatile bit TMR2ON  @ (unsigned)&T2CON*8+2;  //TMR2使能位。
static volatile bit T2CKPS1 @ (unsigned)&T2CON*8+1;  //TMR2预分频选择位。
static volatile bit T2CKPS0 @ (unsigned)&T2CON*8+0;  //TMR2预分频选择位
关键字:pic16f877a  中文注释 引用地址:pic16f877a.h中文注释
上一篇:PIC 里面关于 __CONFIG( ) 配置位
下一篇:PIC877a总结1
推荐阅读最新更新时间:2024-03-16 15:28
PIC单片机(PIC16F877A)外部中断程序
正常运行为流水灯,发生中断则灯全亮。 #include pic.h __CONFIG(0x3B31); //4M #define uchar unsigned char #define uint unsigned int #define DELAY 500 uint j=50000; void delay(uint x) //1ms { uint y,z; for(y=x;y 0;y--) for(z=25;z 0;z--); } void init(void) { TRISB0=0; RB0=1; //为下降沿创造高电平的初始条件 TRISB0=1; //输入
[单片机]
PIC单片机(<font color='red'>PIC16F877A</font>)外部中断程序
基于PIC16F877A的太阳能与市电互补照明系统控制器的设
利用太阳能 led /' target='_blank' 照明 是人类开发利用太阳能的一个主要用途,然而,由于太阳能辐射的不连续性和间歇性,以及目前单纯太阳能 led /' target='_blank' 照明 系统的投资和成本较高、部分技术不够成熟等原因,太阳能照明系统经常出现在连续阴雨天时,由于蓄 电池 电压不足而导致负载不能点亮的情况。将太阳能与市电组成双 电源 互补供电照明系统,不仅可以有效解决太阳能利用不稳定的问题,还可以适当减小太阳能 电池 和蓄电池的容量,降低开发利用太阳能技术的成本,同时满足系统的可靠性和经济性要求 。 1 控制 器的主要功能及组成 本文所设计的控制器供街道和住宅小区夜间利用太阳能和市电互补照明
[模拟电子]
PIC16F877A开发板 数码管动态扫描实验
//************************************************************************* #include pic.h #include ../head/config.h __CONFIG(HS&WDTDIS&LVPDIS&PWRTEN); //HS振荡,禁止看门狗,低压编程关闭,启动延时定时器 #define srclk RC3 //移位寄存器时钟 (74595:11脚) #define rclk RC4 //存储寄存器时钟 (74595:12脚) #define ser RC5 //串行数据口 (74595:14脚)
[单片机]
PIC16F877A单片机 (ADC)
1 基本原理 1.1 ADC基本原理 根据微芯的ADC手册,ADC可以分为单端ADC和差分ADC。 1.1.1 单端ADC 单端ADC的输出范围是 。 根据标黄的这句话,就可以得知,如果电压高于参考电压,ADC的输出结果仍然为全1,如果电压低于0V,ADC的输出结果为全零。 1.1.2 差分ADC 差分ADC的输出范围一般为 。编码一般采用补码,最高位表示符号位。 视频教程链接 1.2 PIC16F877A单片机的ADC模式 2 实现原码 /*---------------------------------函数功能:-------------------------------------
[单片机]
<font color='red'>PIC16F877A</font>单片机 (ADC)
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
随便看看
