液晶12864显示汉字程序,经过调试发现,两个汉字行中间隔一行,为了达到不隔行的目的,我拆分开来,这样分4行分别显示,就达到了,代码虽然多,但简单,可以通过复制粘贴达到效果。
以下为行行正确显示汉字的C程序,想显示什么,改掉那些初始字就可以了。
#include
#include
#include
#include
sbit RS=P2^4;
sbit WRD=P2^5;
sbit E=P2^6;
sbit PSB=P2^1;
sbit RES=P2^3;
void TransferData(char data1,bit DI);
void delayms(unsigned int n);
void delay(unsigned int m);
void lcd_mesg(unsigned char code *addr1);
void lcd_mesg2(unsigned char code *addr1);
void lcd_mesg3(unsigned char code *addr1);
void lcd_mesg4(unsigned char code *addr1);
//汉字定义,8个汉字或是16个字符,一行。
unsigned char code IC_DAT[]={
"我我我我我我我我"};
unsigned char code IC_DAT2[]={
"是是是是是是是是"};
unsigned char code IC_DAT3[]={
"中中中中中中中中"};
unsigned char code IC_DAT4[]={
"国国国国国国国国"};
unsigned char code IC_DAT5[]={
"人人人人人人人人"};
unsigned char code IC_DAT6[]={
"当当当当当当当当"};
unsigned char code IC_DAT7[]={
"自自自自自自自自"};
unsigned char code IC_DAT8[]={
"强强强强强强强强"};
//程序要初始化,即液晶12864要初始化。
void initinal(void)
delay(40);
PSB=1; //并口工作模式
delay(1);
RES=0; //复位
delay(1);
RES=1; //复位置高
delay(10);
TransferData(0x30,0);
delay(100);
delay(37);
TransferData(0x08,0);
delay(100);
TransferData(0x10,0);
delay(100);
TransferData(0x0C,0);
delay(100);
TransferData(0x01,0);
delay(10);
TransferData(0x06,0);
delay(100);
void main(void) //分两屏显示汉字。
while(1)
initinal();//调用LCD字库初始化程序
delay(100);
lcd_mesg(IC_DAT);
lcd_mesg2(IC_DAT2);
lcd_mesg3(IC_DAT3);
lcd_mesg4(IC_DAT4);
delayms(240);
delayms(240);
initinal();
delay(100);
lcd_mesg(IC_DAT5);
lcd_mesg2(IC_DAT6);
lcd_mesg3(IC_DAT7);
lcd_mesg4(IC_DAT8);
delayms(240);
delayms(240);
//显示时,由于地址不同,显示所在行不同,这里分别列出四行的地址。
unsigned char i;
//第一行
TransferData(0x80,0);
delay(100);
for(i=0;i<16;i++)
TransferData(*addr1,1);
addr1++;
unsigned char i;
//第一行
TransferData(0x90,0);
delay(100);
for(i=0;i<16;i++)
addr1++;
unsigned char i;
//第一行
TransferData(0x88,0);
delay(100);
for(i=0;i<16;i++)
addr1++;
unsigned char i;
//显示一行
TransferData(0x98,0);
delay(100);
for(i=0;i<16;i++)
addr1++;
void TransferData(char data1,bit DI) //传送数据或是命令,当DI=0时,传送命令,当DI=1时,传送数据
WRD=0;
RS=DI;
delay(1);
P0=data1;
E=1;
delay(1);
E=0;
unsigned int i,j;
for(i=0;i
unsigned int i,j;
for(i=0;i
以上程序在AT89s52单片机+带字库12864液晶上调试OK。
上一篇:单片机按键与数码管试验程序 Proteus仿真
下一篇:51单片机之串口操作入门经验总结与C源程序
推荐阅读最新更新时间:2024-03-16 15:39
