蜂鸣器唱《祝你平安》51单片机
发布者:hylh2008最新更新时间:2018-01-24 来源: eefocus关键字:蜂鸣器  51单片机 手机看文章 扫描二维码
随时随地手机看文章
蜂鸣器唱《祝你平安》 *
SPK bit P1.4
ORG 0000H
LJMP START
ORG 000BH
INC 20H ;中断服务,中断计数器加1
MOV TH0,#0D8H
MOV TL0,#0EFH ;12M晶振,形成10毫秒中断
RETI
START:
MOV SP,#50H
MOV TH0,#0D8H
MOV TL0,#0EFH
MOV TMOD,#01H
MOV IE,#82H
MUSIC0:
NOP
MOV DPTR,#DAT ;表头地址送DPTR
MOV 20H,#00H ;中断计数器清0
MOV B,#00H ;表序号清0
MUSIC1:
NOP
CLR A
MOVC A,@A DPTR ;查表取代码
JZ END0 ;是00H,则结束
CJNE A,#0FFH,MUSIC5
LJMP MUSIC3
MUSIC5:
NOP
MOV R6,A
INC DPTR
MOV A,B
MOVC A,@A DPTR ;取节拍代码送R7
MOV R7,A
SETB TR0 ;启动计数
MUSIC2:
NOP
CPL SPK
MOV A,R6
MOV R3,A
LCALL DEL
MOV A,R7
CJNE A,20H,MUSIC2 ;中断计数器(20H)=R7否?
;不等,则继续循环
MOV 20H,#00H ;等于,则取下一代码
INC DPTR
; INC B
LJMP MUSIC1
MUSIC3:
NOP
CLR TR0 ;休止100毫秒
MOV R2,#0DH
MUSIC4:
NOP
MOV R3,#0FFH
LCALL DEL
DJNZ R2,MUSIC4
INC DPTR
LJMP MUSIC1
END0:
NOP
MOV R2,#64H ;歌曲结束,延时1秒后继续
MUSIC6:
MOV R3,#00H
LCALL DEL
DJNZ R2,MUSIC6
LJMP MUSIC0
DEL:
NOP
DEL3:
MOV R4,#02H
DEL4:
NOP
DJNZ R4,DEL4
NOP
DJNZ R3,DEL3
RET
NOP
DAT:
db 26h,20h,20h,20h,20h,20h,26h,10h,20h,10h,20h,80h,26h,20h,30h,20h
db 30h,20h,39h,10h,30h,10h,30h,80h,26h,20h,20h,20h,20h,20h,1ch,20h
db 20h,80h,2bh,20h,26h,20h,20h,20h,2bh,10h,26h,10h,2bh,80h,26h,20h
db 30h,20h,30h,20h,39h,10h,26h,10h,26h,60h,40h,10h,39h,10h,26h,20h
db 30h,20h,30h,20h,39h,10h,26h,10h,26h,80h,26h,20h,2bh,10h,2bh,10h
db 2bh,20h,30h,10h,39h,10h,26h,10h,2bh,10h,2bh,20h,2bh,40h,40h,20h
db 20h,10h,20h,10h,2bh,10h,26h,30h,30h,80h,18h,20h,18h,20h,26h,20h
db 20h,20h,20h,40h,26h,20h,2bh,20h,30h,20h,30h,20h,1ch,20h,20h,20h
db 20h,80h,1ch,20h,1ch,20h,1ch,20h,30h,20h,30h,60h,39h,10h,30h,10h
db 20h,20h,2bh,10h,26h,10h,2bh,10h,26h,10h,26h,10h,2bh,10h,2bh,80h
db 18h,20h,18h,20h,26h,20h,20h,20h,20h,60h,26h,10h,2bh,20h,30h,20h
db 30h,20h,1ch,20h,20h,20h,20h,80h,26h,20h,30h,10h,30h,10h,30h,20h
db 39h,20h,26h,10h,2bh,10h,2bh,20h,2bh,40h,40h,10h,40h,10h,20h,10h
db 20h,10h,2bh,10h,26h,30h,30h,80h,00H
END
关键字:蜂鸣器  51单片机 引用地址:蜂鸣器唱《祝你平安》51单片机
上一篇:8051系列单片机Basic开发环境
下一篇:全数字信号发生器的软件设计
推荐阅读最新更新时间:2024-03-16 15:53
51单片机六个常见问题解析
一,为何51单片机爱用11.0592MHZ晶振? 其一:由于它能够精确地划分红时钟频率,与UART(通用异步接纳器/发送器)量常见的波特率有关。特别是较高的波特率(19600,19200),不论多么古怪的值,这些晶振都是精确,常被运用的。 其二:用11.0592晶振的缘由是51单片机的定时器致使的。用51单片机的定时器做波特率发生器时,假如用11.0592Mhz的晶振,根据公式算下来需求定时器设置的值都是整数;假如用12Mhz晶振,则波特率都是有误差的,比如9600,用定时器取0XFD,实践波特率10000,通常波特率误差在4%摆布都是能够的,所以也还能用STC90C516 晶振12M 波特率9600 ,倍数时误差率6.99%
[单片机]
51单片机心形灯实现按键控制流水编程
实现按键K1实现从左向右流水,按键K2实现从右往左流水,按键K3实现暂停流水,按键K4实现继续流水 注意:本代码存在小小BUG即按键K1以后可以按键K3和K4控制流水,不能按K2中断K1流水操作来实现K2从右向左流水。按键K2对于K1也同理! 心形灯原理图 编译软件:Keil uVision5 (如有需要可点此链接下载:https://download.csdn.net/download/qq_36931762/11343174) 单片机程序下载软件:STC-ISP (如有需要可点此链接下载:https://download.csdn.net/download/qq_36931762/11343157) 程序代码:
[单片机]
<font color='red'>51单片机</font>心形灯实现按键控制流水编程
51单片机——IIC、EEPROM数据存储 C语言入门编程
IIC: I2C(Inter-Integrated Circuit)总线是由 PHILIPS 公司开发的两线式串行总线,用于连接微控制器及其外围设备。是微电子通信控制领域广泛采用的一种总线标准。它是同步通信的一种特殊形式,具有接口线少,控制方式简单, 器件封装形式小,通信速率较高等优点。I2C总线只有两根双向信号线。一根是数据线SDA,另一根是时钟线SCL。由于其管脚少,硬件实现简单,可扩展性强等特点,因此被广泛的使用在各大集成芯片内。 (1)它是一个支持多设备的总线。“总线”指多个设备共用的信号线。在 一个I2C通讯总线中,可连接多个I2C通讯设备,支持多个通讯主机及多个通 讯从机。 (2)一个I2C总线只使用两条总线
[单片机]
<font color='red'>51单片机</font>——IIC、EEPROM数据存储 C语言入门编程
51单片机实现能设置速度档位的数码管倒计时程序
一、使用proteus绘制简单的电路图,用于后续仿真 二、编写程序 /******************************************************************************************************************** ---- @Project: LED-74HC595 ---- @File: main.c ---- @Edit: ZHQ ---- @Version: V1.0 ---- @CreationTime: 20200607 ---- @ModifiedTime: 20200619
[单片机]
<font color='red'>51单片机</font>实现能设置速度档位的数码管倒计时程序
基于AT89C51单片机设计的简易智能机器人的设计
简介:随着微电子技术的不断发展,微处理器芯片的集成程度越来越高,单片机已可以在一块芯片上同时集成CPU、存储器、定时器/计数器、并行和串行接口、看门狗、前置放大器、A/D转换器、D/A转换器等多种电路,这就很容易将计算机技术与测量控制技术结合,组成智能化测量控制系统。这种技术促使机器人技术也有了突飞猛进的发展,目前人们已经完全可以设计并制造出具有某些特殊功能的简易智能机器人。 1 设计思想与总体方案 1.1 简易智能机器人的设计思想 本机器人能在任意区域内沿引导线行走,自动绕障,在有光源引导的条件下能沿光源行走。同时,能检测埋在地下的金属片,发出声光指示信息,并能实时存储、显示检测到的断点数目以及各断点至起跑线间的距离
[单片机]
基于AT89C<font color='red'>51单片机</font>设计的简易智能机器人的设计
基于51单片机的大屏幕LED显示屏高速控制方案
引言   LED显示屏的基本工作原理是动态扫描。显示控制的过程是先从数据存储器读得字模数据,再通过单片机的串行口或并行口将数据写给LED点阵片,然后再行扫描。   动态扫描方案和静态显示方案相比节省驱动元件,但要求刷新频率高于50 Hz,以避免显示的图像或文字出现闪烁。由于刷新频率的限制,一片单片机能控制显示元件的片数是较少的。   现在大屏幕LED显示屏的应用已越来越广泛。为了对成百、上千片的LED点阵片实现有序的、快速的显示控制,人们动了许多脑筋,双CPU、双RAM的方案,FPGA的方案等都获得了成功的应用;但是这些方案的显示控制过程还是先读后写。   本方案另开思路:用一条读指令,将读和写合在一步完成,可大大地提高显
[单片机]
基于<font color='red'>51单片机</font>的大屏幕LED显示屏高速控制方案
51单片机控制液晶12864源代码
/********************************************/ /* AM12864系列测试程序 1.0 */ /* Designed by Andorin LCM R&D Group */ /* 2003.04.23 */ /********************************************/ #include reg51.h #include ctype.h #include string.h #include stdlib.h #include stdio.h #include math.h /**********************************
[单片机]
从零开始51单片机教程 —— 23 单片机串行口通信程序设计
单片机串行口通信程序设计范例及注释 1.串行口方式0应用编程 8051单片机串行口方式0为移位寄存器方式,外接一个串入并出的移位寄存器,就能扩展一个并行口。 单片机串行口通信程序设计硬件连接图 例:用8051单片机串行口外接CD4094扩展8位并行输出口,如图所示,8位并行口的各位都接一个发光二极管,要求发光管呈流水灯状态。 串行口方式0的数据传送可采用中断方式,也可采用查询方式,无论哪种方式,都要借助于TI或RI标志。串行发送时,能靠TI置位(发完一帧数据后)引起中断申请,在中断服务程序中发送下一帧数据,或者通过查询TI的状态,只要TI为0就继续查询,TI为1就结束查询,发送下一帧数据。在串行接收时,则由RI引起
[单片机]
从零开始<font color='red'>51单片机</font>教程 —— 23 单片机串行口通信程序设计
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
