STM32学习之路:I2C的基本读写
发布者:柳絮轻风最新更新时间:2018-04-16 来源: eefocus关键字:STM32  I2C  基本读写 手机看文章 扫描二维码
随时随地手机看文章
宏定义:
/*I2C传输速度,最高为400kHz*/
#define I2C_SPEED     400000
/* STM32 自身的 I2C 地址, 这个地址只要与 STM32 外挂的 I2C 器件地址不一样即可 */
#define I2C_OWN_ADDR 0x77
/*EEPROM地址*/
#define EEPROM_ADDR (0x50<<1)   //0xA0
#define EEPROM_SCL_GPIO_CLK   RCC_AHB1Periph_GPIOB
#define EEPROM_SCL_PIN        GPIO_Pin_6
#define EEPROM_SCL_GPIO_PORT GPIOB
#define EEPROM_SCL_AF          GPIO_AF_I2C1
#define EEPROM_SCL_SOURCE           GPIO_PinSource6
#define EEPROM_SDA_GPIO_CLK   RCC_AHB1Periph_GPIOB
#define EEPROM_SDA_PIN        GPIO_Pin_7
#define EEPROM_SDA_GPIO_PORT GPIOB
#define EEPROM_SDA_AF                    GPIO_AF_I2C1
#define EEPROM_SDA_SOURCE  GPIO_PinSource7
#define EEPROM_I2C_CLK  RCC_APB1Periph_I2C1
#define EEPROM_I2C                    I2C1
/*================1-初始化 EEPROM_GPIO 口(复用引脚功能参照USART)==========================*/
void EEPROM_GPIO_Config(void)
  GPIO_InitTypeDef GPIO_InitStructure;
RCC_AHB1PeriphClockCmd(EEPROM_SCL_GPIO_CLK|EEPROM_SDA_GPIO_CLK,ENABLE);
/* GPIO初始化 */
/* 推挽输出/上拉电阻/50M输出速度 */
  GPIO_InitStructure.GPIO_OType = GPIO_OType_OD;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
/* 配置SCL引脚为复用功能  */
/* 选择复用功能模式/选择SCL引脚*/
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
        GPIO_InitStructure.GPIO_Pin = EEPROM_SCL_PIN ;
  GPIO_Init(EEPROM_SDA_GPIO_PORT, &GPIO_InitStructure);
  /* 配置SDA引脚为复用功能 */
 /* 选择复用功能模式/选择SDA引脚*/
  GPIO_InitStructure.GPIO_Pin = EEPROM_SDA_PIN;
  GPIO_Init(EEPROM_SCL_GPIO_PORT, &GPIO_InitStructure);
/* 连接 PXx 到 EEPROM_SCL*/
  GPIO_PinAFConfig(EEPROM_SCL_GPIO_PORT,EEPROM_SCL_SOURCE,EEPROM_SCL_AF);
  /*  连接 PXx 到 EEPROM_SDA*/
  GPIO_PinAFConfig(EEPROM_SDA_GPIO_PORT,EEPROM_SDA_SOURCE,EEPROM_SDA_AF);
/*================2-初始化 IIC 模式==========================================*/
I2C结构体
ClockSpeed :设置I2C的传输速率
要求:低于400kHz
Mode :I2C的使用模式
I2C_Mode_I2C :I2C正常模式
I2C主从模式
I2C_Mode_SMBusDevice
I2C_Mode_SMBusHost
DutyCycle: 设置的是 I2C的 SCL 线时钟的占空比
I2C_DutyCycle_16_9 占空比16:9
I2C_DutyCycle_2    占空比 2:1
OwnAddress1 : STM32 的 I2C 设备自己的地址
Ack: I2C 应答使能设置
I2C_Ack_Enable:使能
I2C_Ack_Disable:不使能
AcknowledgedAddress:I2C 的寻址模式
I2C_AcknowledgedAddress_7bit 7位寻址
I2C_AcknowledgedAddress_10bit 10位寻址
void EEPROM_I2C_ModeConfig(void)
/* 定义 I2C 结构体声明 */
I2C_InitTypeDef I2C_InitStruct;
/* 打开外设 I2C 时钟 */
RCC_APB1PeriphClockCmd(EEPROM_I2C_CLK,ENABLE);
/* I2C 传输速率 */
I2C_InitStruct.I2C_ClockSpeed = I2C_SPEED;
/* I2C 模式*/
I2C_InitStruct.I2C_Mode = I2C_Mode_I2C;
/* 占空比 */
I2C_InitStruct.I2C_DutyCycle = I2C_DutyCycle_2;
/* I2C 本身地址 */
I2C_InitStruct.I2C_OwnAddress1 = I2C_OWN_ADDR;
/* 答应使能 */
I2C_InitStruct.I2C_Ack = I2C_Ack_Enable;
/* 寻址模式 */
I2C_InitStruct.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
/* 初始化 I2C */
I2C_Init(EEPROM_I2C,&I2C_InitStruct);
  /* 使能 I2C */
  I2C_Cmd(EEPROM_I2C,ENABLE);
/*==============3-写一个字节函数==============================================*/
void EEPROM_Byte_Write(uint8_t* pData,uint8_t addr)
/* 起始信号 */
  I2C_GenerateSTART(EEPROM_I2C,ENABLE);
/* 检测 EV5 事件,用于起始信号后 */
  while(I2C_CheckEvent(EEPROM_I2C,I2C_EVENT_MASTER_MODE_SELECT) != SUCCESS )
/* 发送 EEPROM 地址 */
  I2C_Send7bitAddress(EEPROM_I2C,EEPROM_ADDR,I2C_Direction_Transmitter);
  /* 检测 EV6 事件,用于从机地址后 */
  while(I2C_CheckEvent(EEPROM_I2C,I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED) != SUCCESS )
  /* 发送储存地址,即 EEPROM 内部地址 */
  I2C_SendData(EEPROM_I2C,addr);
  /* 检测 EV8 事件,用于传输数据后 */
  while(I2C_CheckEvent(EEPROM_I2C,I2C_EVENT_MASTER_BYTE_TRANSMITTED) != SUCCESS )
  /* 发送数据 */
  I2C_SendData(EEPROM_I2C,*pData);
  /* 检测 EV8 事件 */
  /* 停止信号 */
  I2C_GenerateSTOP(EEPROM_I2C,ENABLE);
/*==============4-读一个字节函数==============================================*/
uint8_t EEPROM_Byte_Read(uint8_t addr)
  uint8_t readTemp;
  /* 等待 EEPROM 内部写完毕 */
  Wait_for_EEPROM();
  /* 起始信号 */
  /* 发送 EEPROM 地址 */
  /* 发送读取数据的 EEPROM 内部地址 */
  /* 检测 EV8_2 事件 */
  /* 起始信号 */
  /* 发送 EEPROM 地址 */
  I2C_Send7bitAddress(EEPROM_I2C,EEPROM_ADDR,I2C_Direction_Receiver);
  while(I2C_CheckEvent(EEPROM_I2C,I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED) != SUCCESS )
  /* 终止使能应答 */
  I2C_AcknowledgeConfig(EEPROM_I2C,DISABLE);
  /* 检测 EV7 事件 */
  while(I2C_CheckEvent(EEPROM_I2C,I2C_EVENT_MASTER_BYTE_RECEIVED) != SUCCESS )
  /* 读取接收数据 */
  readTemp = I2C_ReceiveData(EEPROM_I2C);
  /* 停止信号 */
  return readTemp;
/*==============5-等待EEPROM内部写完毕(具体的我也不是很明白)==============================================*/
void Wait_for_EEPROM(void)
  do
//    while(I2C_CheckEvent(EEPROM_I2C,I2C_EVENT_MASTER_MODE_SELECT) != SUCCESS )
  }while(I2C_GetFlagStatus(EEPROM_I2C,I2C_FLAG_ADDR) == RESET);
  //等待ADDR = 1 才执行下面的语句
  I2C_ClearFlag(EEPROM_I2C,I2C_FLAG_AF);
  while(I2C_GetFlagStatus(EEPROM_I2C,I2C_FLAG_BUSY) == SET);
  //总线空闲,执行下面的语句
关键字:STM32  I2C  基本读写 引用地址:STM32学习之路:I2C的基本读写
上一篇:两片STM32之间I2C通信
下一篇:STM32 FSMC的用法--LCD
小广播
添点儿料...
无论热点新闻、行业分析、技术干货……
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
