//LED8*8滚动显示
//列扫描,低电平有效
//包含头文件
#include #include "74HC595.H" #include /*--------------------------------------------------------------*/ //全局变量定义 unsigned char i,flag,t,w,t; unsigned int m,n; unsigned char t1,t2,t3,t4; /*--------------------------------------------------------------*/ //代码库 #define num sizeof(buff) //代码长度 unsigned char code aa[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f}; unsigned char code table2[]={ 0x60,0x60,0x00,0x3E,0x7F,0x41,0x7F,0x3E,/*"0",0*/ 0x60,0x60,0x00,0x42,0x7F,0x7F,0x40,0x00,/*"1",1*/ 0x60,0x60,0x00,0x62,0x73,0x59,0x4F,0x46,/*"2",2*/ 0x60,0x60,0x00,0x22,0x6B,0x49,0x7F,0x36,/*"3",3*/ 0x60,0x60,0x00,0x38,0x3E,0x7F,0x7F,0x20,/*"4",4*/ 0x60,0x60,0x00,0x4F,0x4F,0x49,0x79,0x31,/*"5",5*/ 0x60,0x60,0x00,0x3E,0x7F,0x49,0x7B,0x32,/*"6",6*/ 0x60,0x60,0x00,0x03,0x73,0x79,0x0F,0x07,/*"7",7*/ 0x60,0x60,0x00,0x36,0x7F,0x49,0x7F,0x36,/*"8",8*/ 0x60,0x60,0x00,0x26,0x6F,0x49,0x7F,0x3E,/*"9",9*/ }; unsigned char code table1[]= { //取模方式 阴码 列扫描 逆向 0x00,0x3E,0x7F,0x41,0x7F,0x3E,0x00,0x00,/*"0",0*/ 0x00,0x42,0x7F,0x7F,0x40,0x00,0x00,0x00,/*"1",1*/ 0x00,0x62,0x73,0x59,0x4F,0x46,0x00,0x00,/*"2",2*/ 0x00,0x22,0x6B,0x49,0x7F,0x36,0x00,0x00,/*"3",3*/ 0x00,0x38,0x3E,0x7F,0x7F,0x20,0x00,0x00,/*"4",4*/ 0x00,0x4F,0x4F,0x49,0x79,0x31,0x00,0x00,/*"5",5*/ 0x00,0x3E,0x7F,0x49,0x7B,0x32,0x00,0x00,/*"6",6*/ 0x00,0x03,0x73,0x79,0x0F,0x07,0x00,0x00,/*"7",7*/ 0x00,0x36,0x7F,0x49,0x7F,0x36,0x00,0x00,/*"8",8*/ 0x00,0x26,0x6F,0x49,0x7F,0x3E,0x00,0x00,/*"9",9*/ 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",10*/ }; unsigned char buff[]={ 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",10*/ 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",10*/ 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",10*/ 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",10*/ 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",10*/ 0x00,0x03,0x03,0x3E,0x7F,0x41,0x63,0x22,/*"C",0*/ 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",10*/ }; /************************************************************************ 以下是DS18B20的操作程序 ************************************************************************/ sbit DQ=P3^3; unsigned char time; //设置全局变量,专门用于严格延时 /***************************************************** 函数功能:将DS18B20传感器初始化,读取应答信号 出口参数:flag ***************************************************/ bit Init_DS18B20(void) { bit flag; //储存DS18B20是否存在的标志,flag=0,表示存在;flag=1,表示不存在 DQ = 1; //先将数据线拉高 for(time=0;time<2;time++) //略微延时约6微秒 ; DQ = 0; //再将数据线从高拉低,要求保持480~960us for(time=0;time<200;time++) //略微延时约600微秒 ; //以向DS18B20发出一持续480~960us的低电平复位脉冲 DQ = 1; //释放数据线(将数据线拉高) for(time=0;time<10;time++) ; //延时约30us(释放总线后需等待15~60us让DS18B20输出存在脉冲) flag=DQ; //让单片机检测是否输出了存在脉冲(DQ=0表示存在) for(time=0;time<200;time++) //延时足够长时间,等待存在脉冲输出完毕 ; return (flag); //返回检测成功标志 } /***************************************************** 函数功能:从DS18B20读取一个字节数据 出口参数:dat ***************************************************/ unsigned char ReadOneChar(void) { unsigned char i=0; unsigned char dat; //储存读出的一个字节数据 for (i=0;i<8;i++) { DQ =1; // 先将数据线拉高 _nop_(); //等待一个机器周期 DQ = 0; //单片机从DS18B20读书据时,将数据线从高拉低即启动读时序 dat>>=1; _nop_(); //等待一个机器周期 DQ = 1; //将数据线"人为"拉高,为单片机检测DS18B20的输出电平作准备 for(time=0;time<2;time++) ; //延时约6us,使主机在15us内采样 if(DQ==1) dat|=0x80; //如果读到的数据是1,则将1存入dat else dat|=0x00;//如果读到的数据是0,则将0存入dat //将单片机检测到的电平信号DQ存入r[i] for(time=0;time<8;time++) ; //延时3us,两个读时序之间必须有大于1us的恢复期 } return(dat); //返回读出的十进制数据 } /***************************************************** 函数功能:向DS18B20写入一个字节数据 入口参数:dat ***************************************************/ WriteOneChar(unsigned char dat) { unsigned char i=0; for (i=0; i<8; i++) { DQ =1; // 先将数据线拉高 _nop_(); //等待一个机器周期 DQ=0; //将数据线从高拉低时即启动写时序 DQ=dat&0x01; //利用与运算取出要写的某位二进制数据, //并将其送到数据线上等待DS18B20采样 for(time=0;time<10;time++) ;//延时约30us,DS18B20在拉低后的约15~60us期间从数据线上采样 DQ=1; //释放数据线 for(time=0;time<1;time++) ;//延时3us,两个写时序间至少需要1us的恢复期 dat>>=1; //将dat中的各二进制位数据右移1位 } for(time=0;time<4;time++) ; //稍作延时,给硬件一点反应时间 } void ReadyReadTemp(void) { Init_DS18B20(); //将DS18B20初始化 WriteOneChar(0xCC); // 跳过读序号列号的操作 WriteOneChar(0x44); // 启动温度转换 for(time=0;time<100;time++) ; //温度转换需要一点时间 Init_DS18B20(); //将DS18B20初始化 WriteOneChar(0xCC); //跳过读序号列号的操作 WriteOneChar(0xBE); //读取温度寄存器,前两个分别是温度的低位和高位 } /*--------------------------------------------------------------*/ //显示函数 void Display(void) { if(flag==2){ Ser_IN[[aa[i]]]; //列扫描数据 Ser_IN(buff[i + n]); //查表取出行扫描数据 Par_OUT(); //输出显示 i++; if(i == 8) i = 0; //循环扫描 m++; if(m == 100) {m = 0; n++;} //滚动速度控制 if(n == num-7) { n = 0; //循环显示 flag=1; } } } /*--------------------------------------------------------------*/ //定时器初始化 void T_init(void) { TMOD = 0x11; TH0 = 0xfc; //1MS TL0 = 0x66; EA = 1; //允许CPU中断 ET0 = 1; //定时器0中断打开 TR0 = 1; } /*--------------------------------------------------------------*/ //定时器中断服务 void T0_intservice(void) interrupt 1 using 0 { TH0 = 0xfc; TL0 = 0x66; Display(); } /*--------------------------------------------------------------*/ //主函数 void main (void) { unsigned char TL; //储存暂存器的温度低位 unsigned char TH; //储存暂存器的温度高位 unsigned char TN; //储存温度的整数部分 unsigned char TD; //储存温度的小数部分 flag=1; T_init(); while(1){ if(flag==1){ ReadyReadTemp(); //读温度准备 TL=ReadOneChar(); //先读的是温度值低位 TH=ReadOneChar(); //接着读的是温度值高位 TN=TH*16+TL/16; //实际温度值=(TH*256+TL)/16,即:TH*16+TL/16 //这样得出的是温度的整数部分,小数部分被丢弃了 TD=(TL%16)*10/16; //计算温度的小数部分,将余数乘以10再除以16取整, t1=TN/100; //取百位 t2=(TN%100)/10; //取十位 t3=TN%10; //取个位 t4=TD; flag=0; } if(flag==0){ for(w=1;w<6;w++){ if(w==5){ flag=2; } for(t=0;t<8;t++){ switch(w){ case 1:
上一篇:数码管动态静态显示原理
下一篇:51单片机遥控解码通过电脑串口显示--C51源代码
设计资源 培训 开发板 精华推荐
- LT1109CZ 3 引脚封装闪存 VPP 发生器的典型应用电路
- LT3091MPT7 线性稳压器在并联器件中的典型应用
- LT1943,具有 4.5V 至 8V 输入电压范围的四路输出 TFT LCD 电源
- 具有 AVP 的 LTC1736 电流模式控制示例
- R_75_V10基于IPS2电机换向传感器的设计
- 驭风Mini遥控器
- 简单实用低成本加热台 BGA焊台
- 使用 ADA4077-1ARMZ-RL 双电源高精度放大器用于低功耗线性化 RTD 电路的典型应用电路
- 用于完整 3V、12 位、1MHz 模数转换系统的 AD8601WDRTZ-REEL 运算放大器的典型应用
- HV9861ADB2、HV9861A LED 驱动器演示板升压辅助、谷值填充、120VAC 输入、7W 输出、350mA、20V、功率因数 93%
