nRF24L01p+AVR单片机ATmage88射频收发程序
发布者:EtherealGaze最新更新时间:2019-10-16 来源: eefocus关键字:nRF24L01p  AVR单片机  ATmage88  射频收发 手机看文章 扫描二维码
随时随地手机看文章
单片机源程序如下:
#define _nRF24L01_C_
#include "nRF24L01.h"
INT8U CE_Status = 0;
Function : L01_GetCEStatus( )
Description : Get the status of the CE PIN
Input : NONE
Output: 1:CE=1, 0:CE=0
INT8U L01_GetCEStatus( void )
        return CE_Status;
Function : L01_SetCE( )
Description : Set the CE PIN as 1 or 0
Input : -status, 1: CE=1, 0: CE=0
Output: None
void L01_SetCE( INT8U status )
        CE_Status = status;
        if( status == 0 )  { L01_CE_LOW( ); }
        else               { L01_CE_HIGH( ); }
Function : L01_ReadSingleReg( )
Description : Read a single register of nRF24L01
Input : -Addr, The address of the register
Output: The value read from the register
INT8U L01_ReadSingleReg( INT8U Addr )
    INT8U btmp;
    L01_CSN_LOW( );//PB2输出低电平
    SPI_ExchangeByte( R_REGISTER | Addr );
    btmp = SPI_ExchangeByte( 0xFF );
    L01_CSN_HIGH( );//PB2输出高电平
    return btmp;
Function : L01_ReadMultiReg( )
Description : Read several registers of nRF24L01
Input : -StartAddr, The start address of the registers
        -nBytes, How many registers do you want to read
        -pBuff, The buffer to save the values
Output: None
/*void L01_ReadMultiReg( INT8U StartAddr, INT8U nBytes, INT8U *pBuff )
    INT8U btmp;
    L01_CSN_LOW( );
    SPI_ExchangeByte( R_REGISTER | StartAddr );
    for( btmp = 0; btmp < nBytes; btmp ++ )
        *( pBuff + btmp ) = SPI_ExchangeByte( 0xFF );
    L01_CSN_HIGH( );
Function : L01_WriteSingleReg( )
Description : Write a single byte to a register
        -Value, The value to be written
Output: None
void L01_WriteSingleReg( INT8U Addr, INT8U Value )
        INT8U tmp = L01_GetCEStatus( );
        L01_SetCE( 0 );
    L01_CSN_LOW( );
    SPI_ExchangeByte( W_REGISTER | Addr );
    SPI_ExchangeByte( Value );
    L01_CSN_HIGH( );
        L01_SetCE( tmp );
Function : L01_WriteMultiReg( )
        -pBuff, The buffer store the values
        -Length, How many registers do you want to write
Output: None
void L01_WriteMultiReg( INT8U StartAddr, INT8U *pBuff, INT8U Length )
    INT8U i;
        L01_SetCE( 0 );
    L01_CSN_LOW( );
    SPI_ExchangeByte( W_REGISTER | StartAddr );
    for( i = 0; i < Length; i ++ )
        SPI_ExchangeByte( *( pBuff + i ) );
    L01_CSN_HIGH( );
        L01_SetCE( tmp );
Function : L01_FlushTX( )
Description : Flush the TX buffer
Input : None
Output: None
void L01_FlushTX( void )
    L01_CSN_LOW( );
    SPI_ExchangeByte( FLUSH_TX );
    L01_CSN_HIGH( );
Function : L01_FlushRX( )
Description : Flush the RX buffer
Input : None
Output: None
void L01_FlushRX( void )
    L01_CSN_LOW( );
    SPI_ExchangeByte( FLUSH_RX );
    L01_CSN_HIGH( );
Function : L01_ReuseTXPayload( )
Description : Reuse the last transmitted payload
Input : None
Output: None
void L01_ReuseTXPayload( void )
    L01_CSN_LOW( );
    SPI_ExchangeByte( REUSE_TX_PL );
    L01_CSN_HIGH( );
Function : L01_Nop( )
Description : nop operation of nRF24L01
Input : None
Output: None
void L01_Nop( void )
    L01_CSN_LOW( );
    SPI_ExchangeByte( L01_NOP );
    L01_CSN_HIGH( );
Function : L01_ReadStatusReg( )
Description : Read statu register of nRF24L01
Input : None
Output: Statu register of nRF24L01
INT8U L01_ReadStatusReg( void )
    INT8U Status;
    L01_CSN_LOW( );
    Status = SPI_ExchangeByte( R_REGISTER + L01REG_STATUS );
    L01_CSN_HIGH( );
    return Status;
Function : L01_ClearIRQ( )
Description : Clear IRQ cuased by nRF24L01
Input : None
Output: None
void L01_ClearIRQ( INT8U IRQ_Source )
    INT8U btmp = 0;
    IRQ_Source &= ( 1<    btmp = L01_ReadStatusReg( );
    L01_CSN_LOW( );
        L01_WriteSingleReg( L01REG_STATUS, IRQ_Source | btmp );
    L01_CSN_HIGH( );
Function : L01_ReadIRQSource( )
Description : Read the IRQ source of nRF24L01+
Input : None
Output: IRQ source mask code
INT8U L01_ReadIRQSource( void )
    return ( L01_ReadStatusReg( ) & ( ( 1<}
Function : L01_ReadTopFIFOWidth( )
Description : Read the payload width of the top buffer of FIFO
Input : None
Output: The width of the pipe buffer
INT8U L01_ReadTopFIFOWidth( void )
    INT8U btmp;
    L01_CSN_LOW( );
    SPI_ExchangeByte( R_RX_PL_WID );
    L01_CSN_HIGH( );
    return btmp;
Function : L01_ReadRXPayload( )
Description : Read the RX payload from internal buffer
Input : -pBuff, buffer to store the data
Output: The length of data read
INT8U L01_ReadRXPayload( INT8U *pBuff )
    INT8U width, PipeNum;
    PipeNum = ( L01_ReadSingleReg( L01REG_STATUS ) >> 1 ) & 0x07;
    width = L01_ReadTopFIFOWidth( );
    L01_CSN_LOW( );
    SPI_ExchangeByte( R_RX_PAYLOAD );
    for( PipeNum = 0; PipeNum < width; PipeNum ++ )
        *( pBuff + PipeNum ) = SPI_ExchangeByte( 0xFF );
    L01_CSN_HIGH( );
    L01_FlushRX( );
    return width;
Function : L01_WriteTXPayload( )
Description : Write TX payload to a pipe and prx will return ack back
Input : -PipeNum, number of the pipe
        -pBuff, A buffer stores the data
        -nBytes, How many bytes to be wrote to
Output: None
void L01_WriteTXPayload_Ack( INT8U *pBuff, INT8U nBytes )
    INT8U btmp;
    INT8U length = ( nBytes > 32 ) ? 32 : nBytes;
    L01_FlushTX( );
    L01_CSN_LOW( );
    SPI_ExchangeByte( W_TX_PAYLOAD );
    for( btmp = 0; btmp < length; btmp ++ )
        SPI_ExchangeByte( *( pBuff + btmp ) );
    L01_CSN_HIGH( );
Function : L01_WritePayload_NoAck( )
Description : write data in tx mode, and prx won't return ack back
Input : -Data, A buffer stores the address data
        -Data_Length, How many bytes of the data buff
Output: None
void L01_WriteTXPayload_NoAck( INT8U *Data, INT8U Data_Length )
    if( Data_Length > 32 || Data_Length == 0 )
        return ;
    L01_CSN_LOW( );
[1] [2]
关键字:nRF24L01p  AVR单片机  ATmage88  射频收发 引用地址:nRF24L01p+AVR单片机ATmage88射频收发程序
上一篇:avr单片机atmega16自动浇花器Proteus仿真+源程序
下一篇:基于AVR单片机的汽车空调控制系统设计
小广播
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
随便看看
