单片机源程序如下:
* $Id[ DISCUZ_CODE_1 ]nbsp; mcu_main_new.c 2012-05-04
* @file mcu_main_new.c
* @brief User program.
* @version 1.0
* @date 04. May. 2012
* @author NXP MCU SW Application Team
* Copyright(C) 2011, NXP Semiconductor
* All rights reserved.
* Software that is described herein is for illustrative purposes only
* which provides customers with programming information regarding the
* products. This software is supplied "AS IS" without any warranties.
* NXP Semiconductors assumes no responsibility or liability for the
* use of the software, conveys no license or title under any patent,
* copyright, or mask work right to the product. NXP Semiconductors
* reserves the right to make changes in the software without
* notification. NXP Semiconductors also make no representation or
* warranty that such application will be suitable for the specified
* use without further testing or modification.
* Permission to use, copy, modify, and distribute this software and its
* documentation is hereby granted, under NXP Semiconductors'
* relevant copyright in the software, without fee, provided that it
* is used in conjunction with NXP Semiconductors microcontrollers. This
* copyright, permission, and disclaimer notice must appear in all copies of
* this code.
#include "includes.h"
#define VTOR_OFFSET (0x00001000)
SBL_FirmVerion_Type firm_vers __attribute__((section("firmware_id_section")))= {0,1,'b'};
/************************** PRIVATE DEFINITIONS *************************/
#ifdef __MCU_LPC17xx
#define MCB_1700
//#define IAR_LPC_1768
#elif defined (__MCU_LPC11xx)
#define MCB_1100
#endif
#if defined (MCB_1700)
/* Number of user LEDs */
#define LED_NUM 4
const unsigned long led_mask[] = { 1<<3, 1<<4, 1<<5, 1<<6 };
#elif defined(MCB_1100)
#define LED_NUM 4
const unsigned long led_pin[] = { 3, 4, 5, 6 };
#endif
/************************** PRIVATE VARIABLES *************************/
/* SysTick Counter */
volatile unsigned long SysTickCnt;
/************************** PRIVATE FUNCTIONS *************************/
void SysTick_Handler (void);
void ReAllocateNVIC(void);
/*----------------- INTERRUPT SERVICE ROUTINES --------------------------*/
* @brief SysTick handler sub-routine (1ms)
* @param[in] None
* @return None
void SysTick_Handler (void) {
SysTickCnt++;
/*-------------------------PRIVATE FUNCTIONS------------------------------*/
* @brief Re-allocate vector interrupt table
* @param[in] None
* @return int
__disable_irq();
NVIC_SetVTOR(VTOR_OFFSET);
__enable_irq();
uint32_t* src,*dst;
int32_t size;
__disable_irq();
// copy vector table
src = (uint32_t*)VTOR_OFFSET;
dst = (uint32_t*)0x10000000;
size = 192;
while(size > 0)
*dst++ = *src++;
size -= 4;
LPC_SYSCON->SYSMEMREMAP = 0x1; /* remap to internal RAM */
__enable_irq();
#endif
/*-------------------------MAIN FUNCTION------------------------------*/
* @brief c_entry: Main program body
* @param[in] None
* @return None
void c_entry(void)
int num = 0;
uint32_t systickcnt;
SBL_SlaveInit();
/* Relocate NVIC */
ReAllocateNVIC();
SystemCoreClockUpdate();
SysTick_Config(SystemCoreClock/1000 - 1); /* Generate interrupt each 1 ms */
GPIO_SetDir(2, 0x0000007C, 1); /* LEDs on PORT2 defined as Output */
GPIO_ClearValue(2, 0x0000007C);
for(num = LED_NUM-1;num>=0;num--)
GPIO_SetDir(2, led_pin[num],1);
GPIO_SetValue(2, led_pin[num]);
#elif defined(IAR_LPC_1768)
GPIO_SetDir(1, (1<<25), 1);
GPIO_ClearValue(1, (1<<25));
#endif
while(1)
if(SBL_SlaveCmdRecv())
SBL_SlaveCmdHandler(SBL_SlaveGetRecvCmd());
else
if(((SysTickCnt - systickcnt) < 500))
GPIO_SetValue(2, led_mask[num]);
#else
GPIO_SetValue(2,(1<<25));
#endif
else if(((SysTickCnt - systickcnt) < 1000))
#ifdef MCB_1700
GPIO_ClearValue(2, led_mask[num]);
GPIO_ClearValue(2, led_pin[num]);
#else
GPIO_ClearValue(1,(1<<25));
#endif
else
systickcnt = SysTickCnt;
//SBL_DeInit();
/* With ARM and GHS toolsets, the entry point is main() - this will
allow the linker to generate wrapper code to setup stacks, allocate
heap area, and initialize and copy code and data segments. For GNU
toolsets, the entry point is through __start() in the crt0_gnu.asm
file, and that startup code will setup stacks and data */
int main(void)
c_entry();
return 0;
