/**这里是STM32比较重要的头文件
* @file stm32f10x.h ST 标准的头文件
* @author MCD Application Team 微控制器开发小组。
* @version V3.5.0 版本
* @date 11-March-2011 2011年3月11
* @brief CMSIS Cortex-M3 Device Peripheral Access Layer Header File.(CMSIS:Cortex Microcontroller Software Interface Standard) 是 Cortex-M 处理器系列的与供应商无关的硬件抽象层。
* This file contains all the peripheral register's definitions, bits
* definitions and memory mapping for STM32F10x Connectivity line,
* High density, High density value line, Medium density,
* Medium density Value line, Low density, Low density Value line
* and XL-density devices.
* 这个文件包含了芯片STM32F10X(接口增强型)内部的寄存器定义,位定义,内存地址变换定义,还有一些相应的高密度,低密度产品线的设备。
* The file is the unique include file that the application programmer
* is using in the C source code, usually in main.c. This file contains:
* - Configuration section that allows to select:
* - The device used in the target application
* - To use or not the peripherals drivers in application code(i.e.
* code will be based on direct access to peripherals registers
* rather than drivers API), this option is controlled by
* "#define USE_STDPERIPH_DRIVER"
* - To change few application-specific parameters such as the HSE
* crystal frequency
* - Data structures and the address mapping for all peripherals
* - Peripheral's registers declarations and bits definition
* - Macros to access peripheral registers hardware
*这个文件在应用程序中是至关重要的头文件,它是用C代码编写而成。通常包括在MAIN主程序中。它包括:1 设备中使用的目标应用程序。
2 决定是否使用外部设备的代码(例如使用基于寄存器的代码,而不是我们所熟悉的API应用程序接口代码)。这一设备可以通过设置 "#define USE_STDPERIPH_DRIVER" 来实现。
3 通过这一文件可以改变诸如外部设备的频率参数。
4 可以了解程序的数据结构以及外设的地址映射。
5 外设的寄存器声明和位定义可以在这个文件里面了解到。
* @attention
* THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
* WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
* TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
* DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
* FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
* CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
*注意:这一文件代码供应给用户,旨在帮助用户提升效率节约时间。ST将不会提供任何对于用户自己代码的解释和帮助。也不会解决其在代码中的任何BUG。
© COPYRIGHT 2011 STMicroelectronics
/** @addtogroup CMSIS
*/这个不需要关心,只是说明这个文件的作者,公司产品等等,你贴出来的估计是小小的广而告之,这也是程序员的一点小小的特权嘛
/** @addtogroup stm32f10x
#ifndef __STM32F10x_H//如果没有定义__STM32F10x_H ,则定义__STM32F10x_H
#define __STM32F10x_H
#ifdef __cplusplus//
extern "C" {
#endif
这里是一种条件编译。extern "C"指令非常有用,因为C和C++的近亲关系。注意:extern "C"指令中的C,表示的一种编译和连接规约,而不是一种语言。C表示符合C语言的编译和连接规约的任何语言,如Fortran、assembler等。
还有要说明的是,extern "C"指令仅指定编译和连接规约,但不影响语义。例如在函数声明中,指定了extern "C",仍然要遵守C++的类型检测、参数转换规则。/** @addtogroup Library_configuration_section
/* Uncomment the line below according to the target STM32 device used in your
application
#if !defined (STM32F10X_LD) && !defined (STM32F10X_LD_VL) && !defined (STM32F10X_MD) && !defined (STM32F10X_MD_VL) && !defined (STM32F10X_HD) && !defined (STM32F10X_HD_VL) && !defined (STM32F10X_XL) && !defined (STM32F10X_CL)
/* #define STM32F10X_LD */ /*!< STM32F10X_LD: STM32 Low density devices */
/* #define STM32F10X_LD_VL */ /*!< STM32F10X_LD_VL: STM32 Low density Value Line devices */
/* #define STM32F10X_MD */ /*!< STM32F10X_MD: STM32 Medium density devices */
/* #define STM32F10X_MD_VL */ /*!< STM32F10X_MD_VL: STM32 Medium density Value Line devices */
/* #define STM32F10X_HD */ /*!< STM32F10X_HD: STM32 High density devices */
/* #define STM32F10X_HD_VL */ /*!< STM32F10X_HD_VL: STM32 High density value line devices */
/* #define STM32F10X_XL */ /*!< STM32F10X_XL: STM32 XL-density devices */
/* #define STM32F10X_CL */ /*!< STM32F10X_CL: STM32 Connectivity line devices */
#endif
STM32启动文件选择:
- startup_stm32f10x_ld_vl.s: for STM32 Low density Value line devices - startup_stm32f10x_ld.s: for STM32 Low density devices - startup_stm32f10x_md_vl.s: for STM32 Medium density Value line devices - startup_stm32f10x_md.s: for STM32 Medium density devices - startup_stm32f10x_hd.s: for STM32 High density devices - startup_stm32f10x_xl.s: for STM32 XL density devices - startup_stm32f10x_cl.s: for STM32 Connectivity line devices
cl:互联型产品,stm32f105/107系列
vl:超值型产品,stm32f100系列
xl:超高密度产品,stm32f101/103系列
ld:低密度产品,FLASH小于64K
md:中等密度产品,FLASH=64 or 128
hd:高密度产品,FLASH大于128
/* Tip: To avoid modifying this file each time you need to switch between these
devices, you can define the device in your toolchain compiler preprocessor.
提示:为了避免每次编译都要修改这些文件,意思是可以使用编译器的preprocessor选项来定义芯片型号等,免得反复更新这个文件。...
- Low-density devices are STM32F101xx, STM32F102xx and STM32F103xx microcontrollers
where the Flash memory density ranges between 16 and 32 Kbytes.
- Low-density value line devices are STM32F100xx microcontrollers where the Flash
- Medium-density devices are STM32F101xx, STM32F102xx and STM32F103xx microcontrollers这里定义的是各种产品线的FLASH的大小。
where the Flash memory density ranges between 64 and 128 Kbytes.
- Medium-density value line devices are STM32F100xx microcontrollers where the
- High-density devices are STM32F101xx and STM32F103xx microcontrollers where
the Flash memory density ranges between 256 and 512 Kbytes.
- High-density value line devices are STM32F100xx microcontrollers where the
- XL-density devices are STM32F101xx and STM32F103xx microcontrollers where
the Flash memory density ranges between 512 and 1024 Kbytes.
- Connectivity line devices are STM32F105xx and STM32F107xx microcontrollers.
#error "Please select first the target STM32F10x device used in your application (in stm32f10x.h file)"
#endif 如果设备类型选择不正确,这里会报错的。
#if !defined USE_STDPERIPH_DRIVER
* @brief Comment the line below if you will not use the peripherals drivers.
In this case, these drivers will not be included and the application code will
/*#define USE_STDPERIPH_DRIVER*/
#endif
* @brief In the following line adjust the value of External High Speed oscillator (HSE)
Tip: To avoid modifying this file each time you need to use different HSE, you
can define the HSE value in your toolchain compiler preprocessor.
#if !defined HSE_VALUE
#ifdef STM32F10X_CL
#define HSE_VALUE ((uint32_t)25000000) /*!< Value of the External oscillator in Hz */
#else
#define HSE_VALUE ((uint32_t)8000000) /*!< Value of the External oscillator in Hz */
#endif /* STM32F10X_CL */
#endif /* HSE_VALUE */
* @brief In the following line adjust the External High Speed oscillator (HSE) Startup
Timeout value
*/①、HSI是高速内部时钟,RC振荡器,频率为8MHz。 ②、HSE是高速外部时钟,可接石英/陶瓷谐振器,或者接外部时钟源,频率范围为4MHz~16MHz。
③、LSI是低速内部时钟,RC振荡器,频率为40kHz。
④、LSE是低速外部时钟,接频率为32.768kHz的石英晶体。
⑤、PLL为锁相环倍频输出,其时钟输入源可选择为HSI/2、HSE或者HSE/2。倍频可选择为2~16倍,但是其输出频率最大不得超过72MHz。
#define HSE_STARTUP_TIMEOUT ((uint16_t)0x0500) /*!< Time out for HSE start up */
高速外部时钟启动时间
#define HSI_VALUE ((uint32_t)8000000) /*!< Value of the Internal oscillator in Hz*/
外部时钟设置的值
* @brief STM32F10x Standard Peripheral Library version number
#define __STM32F10X_STDPERIPH_VERSION_MAIN (0x03) /*!< [31:24] main version */
#define __STM32F10X_STDPERIPH_VERSION_SUB1 (0x05) /*!< [23:16] sub1 version */
#define __STM32F10X_STDPERIPH_VERSION_SUB2 (0x00) /*!< [15:8] sub2 version */
#define __STM32F10X_STDPERIPH_VERSION_RC (0x00) /*!< [7:0] release candidate */
#define __STM32F10X_STDPERIPH_VERSION ( (__STM32F10X_STDPERIPH_VERSION_MAIN << 24)
|(__STM32F10X_STDPERIPH_VERSION_SUB1 << 16)
|(__STM32F10X_STDPERIPH_VERSION_SUB2 << 8)
|(__STM32F10X_STDPERIPH_VERSION_RC))
/** @addtogroup Configuration_section_for_CMSIS
* @brief Configuration of the Cortex-M3 Processor and Core Peripherals
#ifdef STM32F10X_XL
#define __MPU_PRESENT 1 /*!< STM32 XL-density devices provide an MPU */
#else
#define __MPU_PRESENT 0 /*!< Other STM32 devices does not provide an MPU */
#endif /* STM32F10X_XL */
#define __NVIC_PRIO_BITS 4 /*!< STM32 uses 4 Bits for the Priority Levels */
#define __Vendor_SysTickConfig 0 /*!< Set to 1 if different SysTick Config is used */
* @brief STM32F10x Interrupt Number Definition, according to the selected device
* in @ref Library_configuration_section
typedef enum IRQn
/****** Cortex-M3 Processor Exceptions Numbers ***************************************************/
NonMaskableInt_IRQn = -14, /*!< 2 Non Maskable Interrupt */
MemoryManagement_IRQn = -12, /*!< 4 Cortex-M3 Memory Management Interrupt */
BusFault_IRQn = -11, /*!< 5 Cortex-M3 Bus Fault Interrupt */
UsageFault_IRQn = -10, /*!< 6 Cortex-M3 Usage Fault Interrupt */
SVCall_IRQn = -5, /*!< 11 Cortex-M3 SV Call Interrupt */
DebugMonitor_IRQn = -4, /*!< 12 Cortex-M3 Debug Monitor Interrupt */
PendSV_IRQn = -2, /*!< 14 Cortex-M3 Pend SV Interrupt */
上一篇:关于stm32中bool类型定义的问题
下一篇:STM32之GPIO操作(库函数版)
推荐阅读最新更新时间:2024-11-21 11:23
