Kernel Memory Layout on ARM Linux
Russell King November 17, 2005 (2.6.15) This document describes the virtual memory layout which the Linux kernel uses for ARM processors. It indicates which regions are free for platforms to use, and which are used by generic code. The ARM CPU is capable of addressing a maximum of 4GB virtual memory space, and this must be shared between user space processes, the kernel, and hardware devices. As the ARM architecture matures, it becomes necessary to reserve certain regions of VM space for use for new facilities; therefore this document may reserve more VM space over time. Start End Use -------------------------------------------------------------------------- ffff8000 ffffffff copy_user_page / clear_user_page use. For SA11xx and Xscale, this is used to setup a minicache mapping. ffff1000 ffff7fff Reserved. Platforms must not use this address range. ffff0000 ffff0fff CPU vector page. The CPU vectors are mapped here if the CPU supports vector relocation (control register V bit.) ffc00000 fffeffff DMA memory mapping region. Memory returned by the dma_alloc_xxx functions will be dynamically mapped here. ff000000 ffbfffff Reserved for future expansion of DMA mapping region. VMALLOC_END feffffff Free for platform use, recommended. VMALLOC_END must be aligned to a 2MB boundary. VMALLOC_START VMALLOC_END-1 vmalloc() / ioremap() space. Memory returned by vmalloc/ioremap will be dynamically placed in this region. VMALLOC_START may be based upon the value of the high_memory variable. PAGE_OFFSET high_memory-1 Kernel direct-mapped RAM region. This maps the platforms RAM, and typically maps all platform RAM in a 1:1 relationship. TASK_SIZE PAGE_OFFSET-1 Kernel module space Kernel modules inserted via insmod are placed here using dynamic mappings. 00001000 TASK_SIZE-1 User space mappings Per-thread mappings are placed here via the mmap() system call. 00000000 00000fff CPU vector page / null pointer trap CPUs which do not support vector remapping place their vector page here. NULL pointer dereferences by both the kernel and user space are also caught via this mapping. Please note that mappings which collide with the above areas may result in a non-bootable kernel, or may cause the kernel to (eventually) panic at run time. Since future CPUs may impact the kernel mapping layout, user programs must not access any memory which is not mapped inside their 0x0001000 to TASK_SIZE address range. If they wish to access these areas, they must set up their own mappings using open() and mmap().
上一篇:ARM命令LDREX和STREX实现spinlock
下一篇:ARMv8中branch指令分类、格式及用法
推荐阅读最新更新时间:2024-11-21 20:32
设计资源 培训 开发板 精华推荐
- LTC1064-1,用于抗混叠应用的开关电容器低通
- LT3463、双路输出 20V 转换器
- 有源桥式整流器可减少用于辅助输入和 PoE 电源架构的 PoE 安全摄像头内的散热
- LTC3622EDE-2 5V/3.3V 串联输出、降压型稳压器突发模式操作的典型应用电路
- DC2174A-B,用于 LTC3882EUJ 双相单输出 PMBU 降压的演示板,7V = VIN = 14V,0.5V = VOUT0 = 2V @ 70A
- LT1303-5 升压型 DC/DC 转换器用于设置输出电压的典型应用电路
- DC538A,LTC3734EUH 演示板,单相 IMVP4 电源,Vin=7.5V 至 24V,Vout= 0.6V-1.75V@15A
- 用于高输出电流短路保护的 L78L33AB 正电压稳压器的典型应用
- 基于MCU的人脸识别解决方案
- 使用 Microchip Technology 的 U429B-FP 的参考设计
