MSP430F5529硬件IIC驱动IIC接口的OLED
发布者:柳絮轻风最新更新时间:2020-07-21 来源: 51hei关键字:MSP430F5529  硬件IIC  IIC接口  OLED 手机看文章 扫描二维码
随时随地手机看文章
//   MSP430F552x Demo - USCI_B0, I2C Master multiple byte TX/RX
//   Description: I2C master communicates to I2C slave sending and receiving
//   3 different messages of different length. I2C master will enter LPM0 mode
//   while waiting for the messages to be sent/receiving using I2C interrupt.
//   ACLK = NA, MCLK = SMCLK = DCO 16MHz.
//                   MSP430F5529       4.7k |
//                 -----------------    |  4.7k
//            /| |             P3.1|---+---|-- I2C Clock (UCB0SCL)
//             ---|RST          P3.0|-------+-- I2C Data (UCB0SDA)
//   Nima Eskandari
//   Texas Instruments Inc.
//   April 2017
//   Built with CCS V7.0
#include
#include
#include
#include "oledfont.h"
// Example Commands ************************************************************
#define X_WIDTH         128
#define Y_WIDTH         64
#define OLED_CMD  0        //写命令
#define OLED_DATA 1        //写数据
#define SLAVE_ADDR  0x3C
/* CMD_TYPE_X_SLAVE are example commands the master sends to the slave.
* The slave will send example SlaveTypeX buffers in response.
* CMD_TYPE_X_MASTER are example commands the master sends to the slave.
* The slave will initialize itself to receive MasterTypeX example buffers.
#define CMD_TYPE_0_SLAVE      0
#define CMD_TYPE_1_SLAVE      1
#define CMD_TYPE_2_SLAVE      2
#define CMD_TYPE_0_MASTER      3
#define CMD_TYPE_1_MASTER      4
#define CMD_TYPE_2_MASTER      5
#define TYPE_0_LENGTH   1
#define TYPE_1_LENGTH   2
#define TYPE_2_LENGTH   6
#define MAX_BUFFER_SIZE     20
/* MasterTypeX are example buffers initialized in the master, they will be
* sent by the master to the slave.
* SlaveTypeX are example buffers initialized in the slave, they will be
* sent by the slave to the master.
uint8_t MasterType2 [TYPE_2_LENGTH] = {'F', '4', '1', '9', '2', 'B'};
uint8_t MasterType1 [28] = {0xae,0x00,0x10,0x40,0x81,0xcf,0xa1,0xc8,0xa6,0xa8,0x3f,0xd3,0x00,0xd5,0x80,0xd9,0xf1,0xda,0x12,0xdb,0x40,0x20,0x02,0x8d,0x14,0xa4,0xa6,0xaf};
uint8_t MasterType0 [1] = {0};
uint8_t SlaveType2 [TYPE_2_LENGTH] = {0};
uint8_t SlaveType1 [TYPE_1_LENGTH] = {0};
uint8_t SlaveType0 [TYPE_0_LENGTH] = {0};
void delay(unsigned int z)
  unsigned int x,y;
  for(x=z;x>0;x--)
    for(y=5000;y>0;y--);
// General I2C State Machine ***************************************************
typedef enum I2C_ModeEnum{
    IDLE_MODE,
    NACK_MODE,
    TX_REG_ADDRESS_MODE,
    RX_REG_ADDRESS_MODE,
    TX_DATA_MODE,
    RX_DATA_MODE,
    SWITCH_TO_RX_MODE,
    SWITHC_TO_TX_MODE,
    TIMEOUT_MODE
} I2C_Mode;
/* Used to track the state of the software state machine*/
I2C_Mode MasterMode = IDLE_MODE;
/* The Register Address/Command to use*/
uint8_t TransmitRegAddr = 0;
/* ReceiveBuffer: Buffer used to receive data in the ISR
* RXByteCtr: Number of bytes left to receive
* ReceiveIndex: The index of the next byte to be received in ReceiveBuffer
* TransmitBuffer: Buffer used to transmit data in the ISR
* TXByteCtr: Number of bytes left to transfer
* TransmitIndex: The index of the next byte to be transmitted in TransmitBuffer
uint8_t ReceiveBuffer[MAX_BUFFER_SIZE] = {0};
uint8_t RXByteCtr = 0;
uint8_t ReceiveIndex = 0;
uint8_t TransmitBuffer[MAX_BUFFER_SIZE] = {0};
uint8_t TXByteCtr = 0;
uint8_t TransmitIndex = 0;
/* I2C Write and Read Functions */
/* For slave device with dev_addr, writes the data specified in *reg_data
* dev_addr: The slave device address.
*           Example: SLAVE_ADDR
* reg_addr: The register or command to send to the slave.
*           Example: CMD_TYPE_0_MASTER
* *reg_data: The buffer to write
*           Example: MasterType0
* count: The length of *reg_data
*           Example: TYPE_0_LENGTH
I2C_Mode I2C_Master_WriteReg(uint8_t dev_addr, uint8_t reg_addr, uint8_t *reg_data, uint8_t count);
/* For slave device with dev_addr, read the data specified in slaves reg_addr.
* The received data is available in ReceiveBuffer
*           Example: CMD_TYPE_0_SLAVE
* count: The length of data to read
I2C_Mode I2C_Master_ReadReg(uint8_t dev_addr, uint8_t reg_addr, uint8_t count);
void CopyArray(uint8_t *source, uint8_t *dest, uint8_t count);
    /* Initialize state machine */
    MasterMode = TX_REG_ADDRESS_MODE;
    TransmitRegAddr = reg_addr;
    RXByteCtr = count;
    TXByteCtr = 0;
    ReceiveIndex = 0;
    TransmitIndex = 0;
    /* Initialize slave address and interrupts */
    UCB0I2CSA = dev_addr;
    UCB0IFG &= ~(UCTXIFG + UCRXIFG);       // Clear any pending interrupts
    UCB0IE &= ~UCRXIE;                       // Disable RX interrupt
    UCB0IE |= UCTXIE;                        // Enable TX interrupt
    UCB0CTL1 |= UCTR + UCTXSTT;             // I2C TX, start condition
    __bis_SR_register(LPM0_bits + GIE);              // Enter LPM0 w/ interrupts
    return MasterMode;
    //Copy register data to TransmitBuffer
    CopyArray(reg_data, TransmitBuffer, count);
    TXByteCtr = count;
    RXByteCtr = 0;
    ReceiveIndex = 0;
    TransmitIndex = 0;
    return MasterMode;
    uint8_t copyIndex = 0;
    for (copyIndex = 0; copyIndex < count; copyIndex++)
        dest[copyIndex] = source[copyIndex];
// Device Initialization *******************************************************
void initClockTo16MHz()
    UCSCTL3 |= SELREF_2;                      // Set DCO FLL reference = REFO
    UCSCTL4 |= SELA_2;                        // Set ACLK = REFO
    __bis_SR_register(SCG0);                  // Disable the FLL control loop
    UCSCTL0 = 0x0000;                         // Set lowest possible DCOx, MODx
[1] [2] [3]
关键字:MSP430F5529  硬件IIC  IIC接口  OLED 引用地址:MSP430F5529硬件IIC驱动IIC接口的OLED
上一篇:MSP430FR2433 用driverlib方式 SPI调试记录
下一篇:MSP430状态寄存器SR的使用实验及小结
小广播
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
