TCRT5000+STM32红外循迹小车程序
发布者:心若澄明最新更新时间:2020-08-11 来源: 51hei关键字:TCRT5000  STM32  红外循迹小车 手机看文章 扫描二维码
随时随地手机看文章
用正点原子的精英版作为主控,红外循迹用TCRT5000芯片。
单片机源程序如下:
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x.h"
#include "stm32f10x_tim.h"
#include "stm32f10x_flash.h"
#include "stm32f10x_exti.h"
#include "stm32f10x_rcc.h"
#include "systick.h"
#include "stdio.h"
#include "misc.h"
#define infra1 GPIO_ReadInputDataBit(GPIOC, GPIO_Pin_7);
#define infra2 GPIO_ReadInputDataBit(GPIOC, GPIO_Pin_8);
#define tube1 GPIO_ReadInputDataBit(GPIOC, GPIO_Pin_0);
#define tube2 GPIO_ReadInputDataBit(GPIOC, GPIO_Pin_1);
#define tube3 GPIO_ReadInputDataBit(GPIOC, GPIO_Pin_2);
#define tube4 GPIO_ReadInputDataBit(GPIOC, GPIO_Pin_3);
TIM_OCInitTypeDef  TIM1_OCInitStructure;
extern FlagStatus  Status;
extern u16 TIM1Compare1[3] = {0,0x3FFF,0x1FFF};
extern u16 TIM1Compare2[3] = {0x7FFF,0x3FFF,0x1FFF};
extern u16 TIM1Compare3[3] = {0,0x3FFF,0x1FFF};
extern u16 TIM1Compare4[3] = {0x7FFF,0x3FFF,0x1FFF};
extern u16 tubecnt;
extern u16 flag;
extern int add;
void GPIO_Configuration(void);
void TIM_Configuration(void);
void tim2_Configuration(void);
void exti_Configuration(void);
void nvic_Configuration(void);
void zhi1(void);
void zhi2(void);
void zhi3(void);
void zuoxiao(void);
void zuoda(void);
void youxiao(void);
void youda(void);
void xunji(void);
u16 ceju(void);
int main(void)
        RCC_Configuration();
        GPIO_Configuration();
        TIM_Configuration();
        delay_init();
        while(1)
         GPIO_ResetBits(GPIOE,GPIO_Pin_15);
         GPIO_ResetBits(GPIOB,GPIO_Pin_11);
  GPIO_InitTypeDef GPIO_InitStructure;
/*TIM1  PWM  输出:A9:CH1/A10:CH2                */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10|GPIO_Pin_9;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
/*LED显示:LED5:PE15 / LED6:PB11 / LED7:PE14 / LED8:PB10         */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10|GPIO_Pin_11;
  GPIO_InitStructure.GPIO_Mode =GPIO_Mode_Out_PP;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
                 GPIO_SetBits(GPIOB,GPIO_Pin_10);
                GPIO_SetBits(GPIOB,GPIO_Pin_11);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_14|GPIO_Pin_15;
  GPIO_Init(GPIOE, &GPIO_InitStructure);
                  GPIO_SetBits(GPIOE,GPIO_Pin_14);
                GPIO_SetBits(GPIOE,GPIO_Pin_15);
/*红外管:infra1-> PC7, infra2-> PC8         浮空输入  */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7 | GPIO_Pin_8 ;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
/*光电管:tube1-> PC0, tube2-> PC1, tube3-> PC2, tube4-> PC3        浮空输入*/
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1|GPIO_Pin_2 | GPIO_Pin_3;
/*超声波:Trig:PB9                Echo:PB8   */
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
        GPIO_ResetBits( GPIOB, GPIO_Pin_9);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;            //PB1接受采集上升沿 PB6低电平
        GPIO_ResetBits(GPIOB,GPIO_Pin_8);
        TIM_TimeBaseInitTypeDef  TIM1_TimeBaseStructure;
          TIM_DeInit(TIM1);
         /* Time Base configuration */
          TIM1_TimeBaseStructure.TIM_Prescaler = 0x0; //设置了用来作为TIMx时钟频率除数的预分频值
        TIM1_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;         //选择了计数器模式
        TIM1_TimeBaseStructure.TIM_Period = 0xFFFF;  //设置了在下一个更新事件装入活动的自动重装载寄存器周期  ARR
        TIM1_TimeBaseStructure.TIM_ClockDivision = 0x0;  //设置了时钟分割
        TIM1_TimeBaseStructure.TIM_RepetitionCounter = 0x0;         //设置了周期计数器值
        TIM_TimeBaseInit(TIM1,&TIM1_TimeBaseStructure);//根据TIM_TimeBaseInitStruct中指定的参数初始化TIMx的时间基数单位(5个参数)
        //TIM1基本计数器设置(设置PWM频率) //频率=TIM1_CLK/(ARR+1)
        /* Channel 1, 2,3 and 4 Configuration in PWM mode */
        TIM1_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;
        TIM1_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
        TIM1_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
        TIM1_OCInitStructure.TIM_Pulse = 0x0;
        TIM1_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
        TIM1_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_Low;
        TIM1_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
        TIM1_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset;
        TIM_OC1Init(TIM1,&TIM1_OCInitStructure);          //同TimeBaseStructure        (8个参数)        //TIM1_OC1模块设置(设置1通道占空比)
        TIM1_OCInitStructure.TIM_Pulse = 0x7fff;
        TIM_OC2Init(TIM1,&TIM1_OCInitStructure);         //同TimeBaseStructure
        TIM_OC3Init(TIM1,&TIM1_OCInitStructure);         //同TimeBaseStructure
        TIM_OC4Init(TIM1,&TIM1_OCInitStructure);         //同TimeBaseStructure
        TIM_Cmd(TIM1,ENABLE);                  //先设置好了TimeBase、OC、BDTR  使能或者失能TIM1外设
        /* Main Output Enable */
        TIM_CtrlPWMOutputs(TIM1,DISABLE);        //TIM1_CtrlPWMOutputs(ENABLE); 使能或者失能TIM1的主输出
void zhi1(void)                //直走速度1
        TIM_SetCompare1(TIM1,TIM1Compare1[0]);
        TIM_SetCompare2(TIM1,TIM1Compare2[0]);
        TIM_SetCompare3(TIM1,TIM1Compare3[0]);
        TIM_SetCompare4(TIM1,TIM1Compare4[0]);
        TIM_CtrlPWMOutputs(TIM1,ENABLE);
void zhi2(void)                //直走速度2(慢)
        TIM_SetCompare2(TIM1,TIM1Compare2[1]);
        TIM_SetCompare4(TIM1,TIM1Compare4[1]);
void zhi(void)                //直走速度3(很慢)
        TIM_SetCompare2(TIM1,TIM1Compare2[2]);
        TIM_SetCompare4(TIM1,TIM1Compare4[2]);
void zuoxiao(void)                   //左小转
[1] [2]
关键字:TCRT5000  STM32  红外循迹小车 引用地址:TCRT5000+STM32红外循迹小车程序
上一篇:STM32做的64通道数据采集程序
下一篇:二氧化碳传感器MH-Z19/STM32代码(串口传输数据)
小广播
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
