SI SO应该对调过来用。。
TX
** Tx.c
** Transmit test program for PIC18F4520 and nRF24L01 or nRF24L01+
** Uses the Microchip C18 compiler
** Based on SFE code for the CC5X compiler in 24L01demo_V01.c
#include #include #include // Pragmas #pragma config OSC = INTIO67 #pragma config PWRT = ON //#pragma config MCLRE = OFF #pragma config BOREN = OFF //function prototypes void init(void); void transmit_data(void); void configure_transmitter(void); unsigned char spi_Send_Read(unsigned char); unsigned char spi1_send_read_byte(unsigned char byte); void dly(unsigned int); // Defines #define SPI_SCK LATCbits.LATC3 // Clock pin, PORTC pin 3 #define SPI_SO LATCbits.LATC5 // Serial output pin, PORTC pin 5 #define SPI_SI PORTCbits.RC4 // Serial input pin, PORTC pin 4 #define SPI_CSN LATCbits.LATC2 // CSN output pin, PORTC pin 2 #define SPI_CE LATCbits.LATC1 // CE output pin, PORTC pin 1 #define SPI_IRQ PORTBbits.RB0 // IRQ input pin, PORTB pin 0 #define SPI_SCALE 4 // postscaling of signal #define LED LATDbits.LATD1 #define PB PORTAbits.RA1 // Macros #define nop() _asm nop _endasm void main(void) { init(); configure_transmitter(); while (1) { transmit_data(); LED = 1; dly(63973); //200 ms delay LED = 0; dly(40000); //3.27 s delay nop(); } } void init(void) { // run internal oscillator at 8 MHz OSCCON = OSCCON | 0x70; while (OSCCONbits.IOFS == 0) ; PORTA = 0x00; PORTD = 0X00; ADCON1 = 0x0F; // set up PORTA to be digital I/Os TRISA = 0x02; // PORTA<7.2,0> outputs PORTA<1> input TRISD = 0XFD; TRISCbits.TRISC3 = 0; // SDO output TRISCbits.TRISC4 = 1; TRISCbits.TRISC5 = 0; // SCK output TRISCbits.TRISC2 = 0; // CSN output TRISCbits.TRISC1 = 0; // CE output TRISBbits.TRISB0 = 1; // IRQ input OpenSPI(SPI_FOSC_16, MODE_00, SMPMID); //open SPI1 OpenTimer0( TIMER_INT_OFF & T0_16BIT & T0_SOURCE_INT & T0_PS_1_256 ); } void configure_transmitter(void) { unsigned char i, j, data, cmd; SPI_CE = 0; SPI_CSN = 0; // PTX, CRC enabled, mask a couple of ints spi_Send_Read(0x20); spi_Send_Read(0x38); SPI_CSN = 1; SPI_CSN = 0; //auto retransmit off spi_Send_Read(0x24); spi_Send_Read(0x00); SPI_CSN = 1; SPI_CSN = 0; //address width = 5 spi_Send_Read(0x23); spi_Send_Read(0x03); SPI_CSN = 1; SPI_CSN = 0; //data rate = 1MB spi_Send_Read(0x26); spi_Send_Read(0x07); SPI_CSN = 1; SPI_CSN = 0; //set channel 2, this is default but we did it anyway... spi_Send_Read(0x25); spi_Send_Read(0x02); SPI_CSN = 1; SPI_CSN = 0; //set address E7E7E7E7E7, also default... spi_Send_Read(0x30); for (j = 0; j < 5; j++) { spi_Send_Read(0xE7); } SPI_CSN = 1; SPI_CSN = 0; //disable auto-ack, RX mode //shouldn't have to do this, but it won't TX if you don't spi_Send_Read(0x21); spi_Send_Read(0x00); SPI_CSN = 1; } void transmit_data(void) { unsigned char i, data, cmd; SPI_CSN = 0; //clear previous ints spi_Send_Read(0x27); spi_Send_Read(0x7E); SPI_CSN = 1; SPI_CSN = 0; //PWR_UP = 1 spi_Send_Read(0x20); spi_Send_Read(0x3A); SPI_CSN = 1; SPI_CSN = 0; //clear TX fifo //the data sheet says that this is supposed to come up 0 after POR, but that doesn't seem to be the case spi_Send_Read(0xE1); SPI_CSN = 1; SPI_CSN = 0; //4 byte payload spi_Send_Read(0xA0); spi_Send_Read(0x34); spi_Send_Read(0x33); spi_Send_Read(0x32); spi_Send_Read(0x31); SPI_CSN = 1; //Pulse CE to start transmission SPI_CE = 1; dly(65000); //delay 69 ms SPI_CE = 0; } unsigned char spi_Send_Read(unsigned char byte) { SSPBUF = byte; while(!DataRdySPI()) ; return SSPBUF; } void dly(unsigned int c) { INTCONbits.TMR0IF = 0; WriteTimer0(c); while (INTCONbits.TMR0IF == 0) ; } RX /* ** Rx.c ** Receive test program for PIC18F4520 and nRF24L01 or nRF24L01+ ** Uses the Microchip C18 compiler ** Based on SFE code for the CC5X compiler in 24L01demo_V01.c ** ** The LED is flashed five times when data are received. ** The received data in the buffer may be checked using the ** debugger Watch window.*/ #include #include #include // Pragmas #pragma config OSC = INTIO67 #pragma config PWRT = ON #pragma config MCLRE = OFF #pragma config BOREN = OFF //function prototypes void init(void); void reset_RX(void); void configure_RX(void); unsigned char spi_Send_Read(unsigned char); void dly(unsigned int); // Defines #define SPI_SCK LATCbits.LATC3 // Clock pin, PORTC pin 3 #define SPI_SO LATCbits.LATC5 // Serial output pin, PORTC pin 5 #define SPI_SI PORTCbits.RC4 // Serial input pin, PORTC pin 4 #define SPI_CSN LATCbits.LATC2 // CSN output pin, PORTC pin 2 #define SPI_CE LATCbits.LATC1 // CE output pin, PORTC pin 1 #define SPI_IRQ PORTBbits.RB0 // IRQ input pin, PORTB pin 0 #define SPI_SCALE 4 // postscaling of signal #define LED LATDbits.LATD1 #define PB PORTAbits.RA1 // Macros #define nop() _asm nop _endasm void main(void) { unsigned char i; init(); configure_RX(); while(1) { if (SPI_IRQ == 0) //wait for anything { for (i = 0; i < 5; i++) //flash LED 5 times if data received { LED = 1; dly(63973); // 200 ms delay LED = 0; dly(63973); // 196 ms } dly(63973); // 196 ms reset_RX(); } } } // initialise 18F4520 void init(void) { // run internal oscillator at 8 MHz OSCCON = OSCCON | 0x70; while (OSCCONbits.IOFS == 0) ; PORTA = 0x00; PORTD = 0X00; ADCON1 = 0x0F; // set up PORTA to be digital I/Os TRISA = 0x02; // PORTA<7.2,0> outputs PORTA<1> input TRISD = 0XFD; TRISCbits.TRISC3 = 0; // SDO output TRISCbits.TRISC4 = 1; TRISCbits.TRISC5 = 0; // SCK output TRISCbits.TRISC2 = 0; // CSN output TRISCbits.TRISC1 = 0; // CE output TRISBbits.TRISB0 = 1; // IRQ input OpenSPI(SPI_FOSC_16, MODE_00, SMPMID); //open SPI1 OpenTimer0( TIMER_INT_OFF & T0_16BIT & T0_SOURCE_INT & T0_PS_1_256 ); } //configure nRF24L01 for receive void configure_RX(void) { unsigned char i, j; SPI_CSN = 0; SPI_CE = 0; //PRX, CRC enabled spi_Send_Read(0x20); spi_Send_Read(0x39); SPI_CSN = 1; SPI_CSN = 0; //disable auto-ack for all channels spi_Send_Read(0x21); spi_Send_Read(0x00); SPI_CSN = 1; SPI_CSN = 0; //address width = 5 bytes spi_Send_Read(0x23); spi_Send_Read(0x03); SPI_CSN = 1; SPI_CSN = 0; //data rate = 1MB spi_Send_Read(0x26); spi_Send_Read(0x07); SPI_CSN = 1; SPI_CSN = 0; //4 byte payload spi_Send_Read(0x31); spi_Send_Read(0x04); SPI_CSN = 1; SPI_CSN = 0; //set channel 2 spi_Send_Read(0x25); spi_Send_Read(0x02); SPI_CSN = 1; SPI_CSN = 0; //set address E7E7E7E7E7 spi_Send_Read(0x30); for (j = 0; j < 5; j++) spi_Send_Read(0xE7); SPI_CSN = 1; SPI_CSN = 0; //PWR_UP = 1 spi_Send_Read(0x20); spi_Send_Read(0x3B); SPI_CSN = 1; SPI_CE = 1; } void reset_RX(void) { unsigned char i, j; unsigned char buffer[4]; //Read RX payload SPI_CSN = 0; spi_Send_Read(0x61); for (j = 0; j < 4; j++) { buffer[j] = spi_Send_Read(0); } SPI_CSN = 1; //Flush RX FIFO SPI_CSN = 0;
上一篇:PIC EEPROM问题
下一篇:pic减法进位问题
推荐阅读最新更新时间:2024-11-01 07:34
