keil编译中所有编译的错误信息
发布者:创意航海最新更新时间:2020-10-15 来源: 51hei关键字:keil  编译  错误信息 手机看文章 扫描二维码
随时随地手机看文章
1."c" not an argument in function sum 该标识符不是函数的参数
2.array bounds missing ] in function main 缺少数组界限符 "]"
3.Array size too large in function main 数组规模太大
4.bad file name format in include directive 在包含指令中的文件名格式不正确.
5.Call of non-function in function main 调用未经过定义的函数.
6.cannot modify a const object in function main 对常量不能进行修改.
7.character constant too long in function main 字符常量太大
8.constant expression required in funtion main 数组定义的时候,数组大小要求是常数
9.compound statment missing } in function main 复合语句漏掉符号 "{"
10.declaration syntax error in function main 宣告语法错误
11.expression syntax in function main 表达式语法错误
12. extra parameter in call to sum in function 调用函数时使用了过多的参数
13.illegal use of floating point in function main 浮点数的不合法使用
14.illegal pionter subtraction in function main 不合法的指针相减
15.invalid pointer addition in function main 无效的指针相加
16.out of memory in function main 内存不足
17.statement missing ; in function main 语句后面漏掉分号.
警告报错
1."k" is assigned a value which is never used 定义了一个变量,但程序从来没用过
2.possibiy incorrect assignment in function main 这样的赋值可能不正确
3. suspicious pointer conversion in function main 可疑的指针转换
4.code has no effect in funtion main 代码对程序没效果
Ambiguous operators need parentheses:不明确的运算需要用括号括起
Ambiguous symbol 'xxx' :不明确的符号
Argument list syntax error:参数表语法错误
Array bounds missing :丢失数组界限符
Array size toolarge :数组尺寸太大
Bad character in paramenters :参数中有不适当的字符
Bad file name format in include directive :包含命令中文件名格式不正确
Bad ifdef directive synatax :编译预处理ifdef有语法错
Bad undef directive syntax :编译预处理undef有语法错
Bit field too large :位字段太长
Call of non-function :调用未定义的函数
Call to function with no prototype :调用函数时没有函数的说明
Cannot modify a const object :不允许修改常量对象
Case outside of switch :漏掉了case 语句
Case syntax error :Case 语法错误
Code has no effect :代码不可述不可能执行到
Compound statement missing{ :分程序漏掉"{"
Conflicting type modifiers :不明确的类型说明符
Constant expression required :要求常量表达式
Constant out of range in comparison :在比较中常量超出范围
Conversion may lose significant digits :转换时会丢失意义的数字
Conversion of near pointer not allowed :不允许转换近指针
Could not find file 'xxx' :找不到XXX文件
Declaration missing ; :说明缺少";"
Declaration syntax error :说明中出现语法错误
Default outside of switch :Default 出现在switch语句之外
Define directive needs an identifier :定义编译预处理需要标识符
Division by zero :用零作除数
Do statement must have while :Do-while语句中缺少while部分
Enum syntax error :枚举类型语法错误
Enumeration constant syntax error :枚举常数语法错误
Error directive :xxx :错误的编译预处理命令
Error writing output file :写输出文件错误
Expression syntax error :表达式语法错误
Extra parameter in call :调用时出现多余错误
File name too long :文件名太长
Function call missing ) :函数调用缺少右括号
Fuction definition out of place :函数定义位置错误
Fuction should return a value :函数必需返回一个值
Goto statement missing label :Goto语句没有标号
Hexadecimal or octal constant too large :16进制或8进制常数太大
Illegal character 'x' :非法字符x
Illegal initialization :非法的初始化
Illegal octal digit :非法的8进制数字
Illegal pointer subtraction :非法的指针相减
Illegal structure operation :非法的结构体操作
Illegal use of floating point :非法的浮点运算
Illegal use of pointer :指针使用非法
Improper use of a typedefsymbol :类型定义符号使用不恰当
In-line assembly not allowed :不允许使用行间汇编
Incompatible storage class :存储类别不相容
Incompatible type conversion :不相容的类型转换
Incorrect number format :错误的数据格式
Incorrect use of default
Default使用不当
Invalid indirection 无效的间接运算
Invalid pointer addition 指针相加无效
Irreducible expression tree 无法执行的表达式运算
Lvalue required 需要逻辑值0或非0值
Macro argument syntax error 宏参数语法错误
Macro expansion too long 宏的扩展以后太长
Mismatched number of parameters in definition 定义中参数个数不匹配
Misplaced break 此处不应出现break语句
Misplaced continue 此处不应出现continue语句
Misplaced decimal point 此处不应出现小数点
Misplaced elif directive 不应编译预处理elif
Misplaced else 此处不应出现else
Misplaced else directive 此处不应出现编译预处理else
Misplaced endif directive 此处不应出现编译预处理endif
Must be addressable 必须是可以编址的
Must take address of memory location 必须存储定位的地址
No declaration for function 'xxx' 没有函数xxx的说明
No stack 缺少堆栈
No type information 没有类型信息
Non-portable pointer assignment 不可移动的指针(地址常数)赋值
Non-portable pointer comparison 不可移动的指针(地址常数)比较
Non-portable pointer conversion 不可移动的指针(地址常数)转换
Not a valid expression format type 不合法的表达式格式
Not an allowed type 不允许使用的类型
Numeric constant too large 数值常太大
Out of memory 内存不够用
Parameter 'xxx' is never used 能数xxx没有用到
Pointer required on left side of -> 符号->的左边必须是指针
Possible use of 'xxx' before definition 在定义之前就使用了xxx(警告)
Possibly incorrect assignment 赋值可能不正确
Redeclaration of 'xxx' 重复定义了xxx
Redefinition of 'xxx' is not identical xx的两次定义不一致
Register allocation failure 寄存器定址失败
Repeat count needs an lvalue 重复计数需要逻辑值
Size of structure or array not known 结构体或数给大小不确定
Statement missing ; 语句后缺少";"
Structure or union syntax error X构体或联合体语法错误
Structure size too large 结构体尺寸太大
Sub scripting missing ] 下标缺少右方括号
Superfluous & with function or array 函数或数组中有多余的"&"
Suspicious pointer conversion 可疑的指针转换
Symbol limit exceeded 符号超限
Too few parameters in call 函数调用时的实参少于函数的参数不
Too many default cases Default太多(switch语句中一个)
Too many error or warning messages 错误或警告信息太多
Too many type in declaration 说明中类型太多
Too much auto memory in function 函数用到的局部存储太多
Too much global data defined in file 文件中全局数据太多
Two consecutive dots 两个连续的句点
Type mismatch in parameter xxx 数xxx类型不匹配
Type mismatch in redeclaration of 'xxx' xx重定义的类型不匹配
Unable to create output file 'xxx' 无法建立输出文件xxx
Unable to open include file 'xxx' 无法打开被包含的文件xxx
Unable to open input file 'xxx' 无法打开输入文件xxx
Undefined label 'xxx' 没有定义的标号xxx
Undefined structure 'xxx' 没有定义的结构xxx
Undefined symbol 'xxx' 没有定义的符号xxx
Unexpected end of file in comment started on line xxx
从xxx行开始的注解尚未结束文件不能结束
Unexpected end of file in conditional started on line xxx 从xxx
开始的条件语句尚未结束文件不能结束
Unknown assemble instruction 未知的汇编结构
Unknown option 未知的操作
Unknown preprocessor directive: 'xxx' 不认识的预处理命令xxx
Unreachable code 无路可达的代码
Unterminated string or character constant 字符串缺少引号
User break 用户强行中断了程序
Void functions may not return a value Void类型的函数不应有返回值
Wrong number of arguments 调用函数的参数数目错
'xxx' not an argument xxx不是参数
'xxx' not part of structure xxx不是结构体的一部分
xxx statement missing ( xx语句缺少左括号
xxx statement missing ) xxx语句缺少右括号
xxx statement missing ; xxx缺少分号
xxx' declared but never used 说明了xxx但没有使用
xxx' is assigned a value which is never used 给xxx赋了值但未用过
关键字:keil  编译  错误信息 引用地址:keil编译中所有编译的错误信息
上一篇:用单片机产生38KHz较为实用的方法
下一篇:基于51单片机+0038红外发射与接收C程序
推荐阅读最新更新时间:2024-11-12 13:12
keil软件的使用及工程的建立
keil软件是常用的编译软件,keil工程的建立过程如下: 建立一个新工程单击{【project】菜单中的【new project……】选项。 选择工程保存路径,输入工程名,单击保存。 在弹出的对话框内选择自己正在使用的单片机品牌和型号。在选择相应的单片机型号后,还可以在右边的【deion】栏查看该品牌型号单片机的基本说明。最后单击确定选择好单片机型号。 完成以上步骤只是建立了工程,但这不是一个完整的工程。我们必须添加文件以及代码使之完善。 单击【file】菜单中的【new】菜单项新建文件。然后单击保存,输入要保存的文件名,同时需要注意的是必须输入正确的扩展名。如果我们用C语言编写程序扩展名必须是.C,如果使用的是汇编语言扩展名则
[单片机]
keil+env在STM32H743上实现pwm呼吸灯
一、工具 keil+Env+STM32CubeMX 二、在Env中勾选本工程需要的pkgs 在RT-Thread Components—- Device Drivers下勾选 Using hardware timer device drivers和Using PWM device drivers 勾选完成后保存、退出更新,再返回此界面查看是否已经更新好(勾好) 最后使用 scons —target=mdk5生成新的工程 会发现工程中多出了一个关键性的文件drv_pwm.c 三、修改配置文件 在 rtconfig.h 中可以查看 RT_USING_HWTIMER 和 RT_USING_PWM 的设备驱动宏定义。 s
[单片机]
<font color='red'>keil</font>+env在STM32H743上实现pwm呼吸灯
STM8的AIR与STM32的Keil的指定地址存数据
一, 经验分享描述 写这篇经验分享的原因是,之前有一个客户,他希望在KE02的芯片中,不要出现使用EEPROM操作命令的形式初始化EEPROM,但是需要芯片的EEPROM中就有他所规定好的数据,以便于程序直接调用。其实就把EEPROM中的数据当做固定在flash的数据一样使用。而目前也没有看到使用具体的工具去直接烧写EEPROM,所以我们就想是否能够像flash的constant的定义一样定义EEPROM的数据呢?通过实际操作发现还是切实可行的,于是就分享了这篇在IAR与KEIL中如何直接定义常量到EEPROM中的经验分享。其实方法和之前本人分享过的经验分享“KE02在CW中使用常量形式初始化EEPROM值”合为姐妹篇,当然这种方
[单片机]
STM8的AIR与STM32的<font color='red'>Keil</font>的指定地址存数据
使用Keil MDK运行第一个STM32程序
1.1.1 使用Keil MDK运行第一个STM32F10X程序 在上一小节中已经详细介绍了使用Keil MDK和标准外设库创建一个工程的过程,下面将介绍基于这个工程来编写一个小程序,通过这个程序我们可以初步了解: l STM32标准外设库的简单使用过程 l STM32外设的使用方法和大致流程 l 程序的编译、链接、下载步骤 l 利用Keil MDK的在线仿真功能进行软件仿真的简要步骤 1. 程序的编写 (1)程序实现的功能 为了方便各位读者的入门和理解,这个小程序的功能非常简单,作为本书功能实践的第一个程序,其功能当然也是最为经典的“Hello World!”了,只不过不是简单的屏幕输出,而是利用硬件的串口进行输出,同时作为单片
[单片机]
使用<font color='red'>Keil</font> MDK运行第一个STM32程序
[keil][python][单片机] keil 集成bin文件生成 boot+app合并 dfu生成
一、 首先配置keil执行工具 .file_handling.bat @L !L $K 输出文件名根据自身定义 二、 编写bat脚本(此处需要根据工具存放路径进行更改 xBin2Dfu/merge_file) @echo off set bin=%1 set axf=%2 set keilpath=%3 echo current file:%bin%.bin echo current axf:%axf% echo current keilpath:%keilpath% :: 生成bin %keilpath%ARMARMCCbinfromelf.exe --bin --output=.outbin%bin%.b
[单片机]
[<font color='red'>keil</font>][python][单片机] <font color='red'>keil</font> 集成bin文件生成 boot+app合并 dfu生成
KEIL C51 printf格式化输出特殊用法
/******************************************* KEIL里扩展出了b,h,l来对输入字节宽的设置: (1)b八位 (2)h十六位(默认) (3)l三十二位 在Keil C51中用printf输出一个单字节变量时要使用%bd,如 unsigned char counter; printf(“Current count: %bd\n”, counter);//输出8位”十进制有符号整数” printf(“Current count: %bx\n”, counter);//输出8位”无符号以十六进制表示的整数” 而在标准C语言中都是使用%d: printf(“Current count: %d\
[单片机]
Keil C51中断程序规则
interrupt 函数属性当包含在一个声明中指定函数为一个中断函数例如 unsigned int interruptcnt; unsigned char second; void timer0 (void) interrupt 1 using 2 { if (++interruptcnt == 4000) { /* count to 4000 */ second++; /* second counter */ interruptcnt = 0; /* clear int counter */ } interrupt 属性的参数为0 到31 的整常数值 函数属性用来选择和非中断程序不同的寄存器组 带操作数的表达式和in
[单片机]
keil c51程序设计中集中精确延时方法
1使用定时器/计数器实现精确延时 单片机系统一般常选用11.059 2 MHz、12 MHz或6 MHz晶振。第一种更容易产生各种标准的波特率,后两种的一个机器周期分别为1 μs和2 μs,便于精确延时。本程序中假设使用频率为12 MHz的晶振。最长的延时时间可达216=65 536 μs。若定时器工作在方式2,则可实现极短时间的精确延时;如使用其他定时方式,则要考虑重装定时初值的时间(重装定时器初值占用2个机器周期)。 在实际应用中,定时常采用中断方式,如进行适当的循环可实现几秒甚至更长时间的延时。使用定时器/计数器延时从程序的执行效率和稳定性两方面考虑都是最佳的方案。但应该注意,C51编写的中断服务程序编译后会自动加上
[单片机]
小广播
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
