* Memory Setup stuff - taken from blob memsetup.S
* Copyright (C) 1999 2000 2001 Erik Mouw (J.A.K.Mouw@its.tudelft.nl) and
* Jan-Derk Bakker (J.D.Bakker@its.tudelft.nl)
* Modified for the Samsung SMDK2410 by
* (C) Copyright 2002
* David Mueller, ELSOFT AG, * * See file CREDITS for list of people who contributed to this * project. * * This program is free software; you can redistribute it and/or * modify it under the terms of the GNU General Public License as * published by the Free Software Foundation; either version 2 of * the License, or (at your option) any later version. * * This program is distributed in the hope that it will be useful, * but WITHOUT ANY WARRANTY; without even the implied warranty of * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the * GNU General Public License for more details. * * You should have received a copy of the GNU General Public License * along with this program; if not, write to the Free Software * Foundation, Inc., 59 Temple Place, Suite 330, Boston, * MA 02111-1307 USA */ #include #include #include #include "tq210_val.h" @ 讲start.S的时候已经说过这个TEXT_BASE了 _TEXT_BASE: .word TEXT_BASE .globl lowlevel_init lowlevel_init: push {lr} @ 将上一个函数的返回地址压入栈中 /* check reset status */ @ 检查复位标志,如果是睡眠唤醒,跳过接下来的初始化 ldr r0, =(ELFIN_CLOCK_POWER_BASE+RST_STAT_OFFSET) @ 跳转到目的地Reset Control Register的地址传送给r0 Address = 0xE010_A000 =0xE010_0000+0xA000 ldr r1, [r0] @ 将存储器地址为 R0(内存储的值) 的字数据读入寄存器 R1 bic r1, r1, #0xfff6ffff @将r1与0xfff6ffff的反码按位进行与运算(既和0xfff6ffff进行与非运算),并写入r1;结合上一步,可知,这一步的作用是16和19bit置一,其他位清零 cmp r1, #0x10000 @ 判断16bit是不是等于1 beq wakeup_reset_pre @ 如果是从睡眠状态唤醒,就跳转到wakeup_reset_pre,既跳过接下来的初始化 cmp r1, #0x80000 @ 判断是不是从深度空闲(Deep-IDLE)状态唤醒 beq wakeup_reset_from_didle @ 如果是,就跳转到wakeup_reset_from_didle /* IO Retention release */ ldr r0, =(ELFIN_CLOCK_POWER_BASE + OTHERS_OFFSET) @ 将跳转目的地址MISC Register的地址传送给r0 Address = 0xE010_E000 =0xE010_0000+0xE000 ldr r1, [r0] @ 将存储器地址为 R0(内存储的值) 的字数据读入寄存器 R1 ldr r2, =IO_RET_REL @将IO_RET_REL( ((1 << 31) | (1 << 29) | (1 << 28)) )存入r2 orr r1, r1, r2 @ 将r1和r2的值进行或运算,结果存入r1 str r1, [r0] @ 将r1的值写入以r0内的值为地址的内存空间 /* Disable Watchdog */ @ 关闭看门狗 ldr r0, =ELFIN_WATCHDOG_BASE /* 0xE2700000 */ mov r1, #0 str r1, [r0] /* SRAM(2MB) init for SMDKC110 */ /* GPJ1 SROM_ADDR_16to21 */ @ 配置sram引脚,16位数据宽度,22位地址宽度 ldr r0, =ELFIN_GPIO_BASE ldr r1, [r0, #GPJ1CON_OFFSET] bic r1, r1, #0xFFFFFF ldr r2, =0x444444 orr r1, r1, r2 str r1, [r0, #GPJ1CON_OFFSET] ldr r1, [r0, #GPJ1PUD_OFFSET] ldr r2, =0x3ff bic r1, r1, r2 str r1, [r0, #GPJ1PUD_OFFSET] /* GPJ4 SROM_ADDR_16to21 */ ldr r1, [r0, #GPJ4CON_OFFSET] bic r1, r1, #(0xf<<16) ldr r2, =(0x4<<16) orr r1, r1, r2 str r1, [r0, #GPJ4CON_OFFSET] ldr r1, [r0, #GPJ4PUD_OFFSET] ldr r2, =(0x3<<8) bic r1, r1, r2 str r1, [r0, #GPJ4PUD_OFFSET] /* CS0 - 16bit sram, enable nBE, Byte base address */ ldr r0, =ELFIN_SROM_BASE /* 0xE8000000 */ mov r1, #0x1 str r1, [r0] /* PS_HOLD pin(GPH0_0) set to high */ @ 设置PMIC(Power Management IC)控制引脚,既电源管理ic引脚(基于I2C) ldr r0, =(ELFIN_CLOCK_POWER_BASE + PS_HOLD_CONTROL_OFFSET) ldr r1, [r0] orr r1, r1, #0x300 orr r1, r1, #0x1 str r1, [r0] /* when we already run in ram, we don't need to relocate U-Boot. * and actually, memory controller must be configured before U-Boot * is running in ram. */ /*下面的代码事实上只是判断pc和_TEXT_BASE(0X23e00000)的最高两位是否相同*/ /* 根据s5pv210的数据手册可知,首先,系统会运行固化在irom的BL0,紧接着会从外部nand * 或sdcard等设备读取前16K的BL1代码到IRAM中的0xD0020000处。然后从0xD0020010处运行(因为前16byte是校验和的值) * BL1的作用是初始化DRAM,拷贝BL2到DRAM中_TEXT_BASE(0X23e00000)处,然后跳到DRAM中运行 * 因此可以通过最高两位来判断代码是在哪里运行 * 同时可知,当代码已经就在DRAM中运行时,就必须跳过DRAM的初始化 */ ldr r0, =0xff000fff bic r1, pc, r0 /* r0 <- current base addr of code */ ldr r2, _TEXT_BASE /* r1 <- original base addr in ram */ bic r2, r2, r0 /* r0 <- current base addr of code */ cmp r1, r2 /* compare r0, r1 */ beq 1f /* r0 == r1 then skip sdram init */ /* init PMIC chip */ #ifdef CONFIG_TQ210_IIC_PM_CHIP bl PMIC_InitIp #endif /* init system clock */ @ 时钟初始化 PLL初始化,要想看懂此汇编,请查看datsheet中,clk control章节 bl system_clock_init /* Memory initialize */ @ 内存初始化 bl mem_ctrl_asm_init 1: /* for UART */ @ 串口初始化,要看懂此汇编, 请查看datsheet中, 请查看串口章节 bl uart_asm_init bl tzpc_init @ 这段不执行 #if defined(CONFIG_ONENAND) bl onenandcon_init #endif @ nand初始化 #if defined(CONFIG_NAND) /* simple init for NAND */ bl nand_asm_init #endif /* check reset status */ ldr r0, =(ELFIN_CLOCK_POWER_BASE+RST_STAT_OFFSET) ldr r1, [r0] bic r1, r1, #0xfffeffff cmp r1, #0x10000 beq wakeup_reset_pre /* ABB disable */ ldr r0, =0xE010C300 orr r1, r1, #(0x1<<23) str r1, [r0] /* Print 'K' */ ldr r0, =ELFIN_UART_CONSOLE_BASE ldr r1, =0x4b4b4b4b str r1, [r0, #UTXH_OFFSET] pop {pc} @ 返回到start.S wakeup_reset_from_didle: @ 从深度睡眠中唤醒 /* Wait when APLL is locked */ ldr r0, =ELFIN_CLOCK_POWER_BASE lockloop: ldr r1, [r0, #APLL_CON0_OFFSET] and r1, r1, #(1<<29) cmp r1, #(1<<29) bne lockloop @ 这里使用循环 beq exit_wakeup wakeup_reset_pre: mrc p15, 0, r1, c1, c0, 1 @Read CP15 Auxiliary control register and r1, r1, #0x80000000 @Check L2RD is disable or not cmp r1, #0x80000000 bne wakeup_reset @if L2RD is not disable jump to wakeup_reset bl disable_l2cache bl v7_flush_dcache_all /* L2 cache enable at sleep.S of kernel * bl enable_l2cache */ #ifdef CONFIG_TQ210 bl enable_l2cache #endif wakeup_reset: /* init system clock */ bl system_clock_init bl mem_ctrl_asm_init bl tzpc_init #if defined(CONFIG_ONENAND) bl onenandcon_init #endif #if defined(CONFIG_NAND) bl nand_asm_init #endif exit_wakeup: /*Load return address and jump to kernel*/ ldr r0, =(INF_REG_BASE+INF_REG0_OFFSET) ldr r1, [r0] /* r1 = physical address of s5pc110_cpu_resume function*/ mov pc, r1 /*Jump to kernel */ nop nop /* * system_clock_init: Initialize core clock and bus clock. * void system_clock_init(void) */ system_clock_init: /* 这一段的作用是将Clock Source Control Registers值清空 * 具体的作用是将VPLL_SEL、EPLL_SEL、MPLL_SEL和APLL_SEL的时钟源设置为FINVPLL,将MUX_MSYS_SEL、MUX_DSYS_SEL和MUX_PSYS_SEL时钟源设置为SCLKMPLL * 将ONENAND_SEL时钟源设置为HCLK_PSYS * 为什么这样设置,因为未设置 PLL 和各种分频系数之前,我们不能使用 PLL,为了保险起见,暂时直接使用频率较低 * 的外接的 24MHz 晶振,待设置好 PLL 和分频系数后再重新设置各种时钟开关 */ ldr r0, =ELFIN_CLOCK_POWER_BASE @0xe0100000 /* Set Mux to FIN */ ldr r1, =0x0 str r1, [r0, #CLK_SRC0_OFFSET] ldr r1, =APLL_LOCKTIME_VAL @将APLL_LOCKTIME_VAL(0x2cf)装入r1 str r1, [r0, #APLL_LOCK_OFFSET] @将r1内的值装入地址为(r0内的值+CLK_SRC0_OFFSET = 0xe0100000)的内存,即设置APLL的锁定周期 /* * A PLL requires locking period when input frequency is changed or frequency division (multiplication) values are * changed.PLL_LOCK register specifies this locking period, which is based on PLL’s source clock. During this * period, output will be low state */ /* Disable PLL */ #if defined(CONFIG_CHECK_MPLL_LOCK) retryloop: #endif ldr r1, =0x0 str r1, [r0, #APLL_CON0_OFFSET] @ 将APLL控制寄存器的值清空,这个寄存器的第31位置零关闭APLL 25-16bit配置MDIV的分频 @ 13-8bit配置PDIV的分频 2-0bit配置SDIV的分频 ldr r1, =0x0 str r1, [r0, #MPLL_CON_OFFSET] @ 配置MPLL ldr r1, =0x0 str r1, [r0, #MPLL_CON_OFFSET] @ 重复配置MPLL,确保MPLL配置成功 ldr r1, [r0, #CLK_DIV0_OFFSET] @ Clock Divider Control Register(0xe0100300) ldr r2, =CLK_DIV0_MASK @ CLK_DIV0_MASK(0x7fffffff) bic r1, r1, r2 @ 首先清零 ldr r2, =CLK_DIV0_VAL @ CLK_DIV0_VAL orr r1, r1, r2 str r1, [r0, #CLK_DIV0_OFFSET] /* *CLK_DIV0_VAL = ((0< *#define A2M_RATIO 4 *#define HCLK_MSYS_RATIO 8 *#define PCLK_MSYS_RATIO 12 *#define HCLK_DSYS_RATIO 16 *#define PCLK_DSYS_RATIO 20 *#define HCLK_PSYS_RATIO 24 *#define PCLK_PSYS_RATIO 28 */ ldr r1, =APLL_VAL str r1, [r0, #APLL_CON0_OFFSET] ldr r1, =MPLL_VAL str r1, [r0, #MPLL_CON_OFFSET] ldr r1, =VPLL_VAL str r1, [r0, #VPLL_CON_OFFSET] #if defined(CONFIG_EVT1) ldr r1, =AFC_ON str r1, [r0, #APLL_CON1_OFFSET] #endif mov r1, #0x10000 1: subs r1, r1, #1 @ 延时 将r1-1的值存入r1 bne 1b @ 如果运算结果不等零(即CPSR寄存器标志位Z不等于一),退回到前面标签“1”处执行 当 CPSR 寄存器中的 Z @ 条件码置位时(即前面的计算结果为零),则顺序执行(即运行接下来的:ldr r1, [r0, #CLK_SRC0_OFFSET])
上一篇:TQ210 —— s5pv210 board.c分析(uboot第二阶段)
下一篇:TQ210 —— s5pv210 start.S分析
推荐阅读最新更新时间:2024-11-17 03:55
设计资源 培训 开发板 精华推荐
- TWR-K20D72M,开发板 Kinetis K20 72 MHz MCU 塔式系统模块
- AM2G-4812SH30Z 12V 2瓦DC-DC转换器的典型应用
- LTC3624HMSE-2 具有 800mA 突发钳位、fSW = 1MHz 的可调输出电压、2A 同步降压型稳压器的典型应用
- LT8705EUHF 12V 输出转换器的典型应用电路接受 4V 至 80V 输入(最低启动电压为 5.5V)
- 使用 ON Semiconductor 的 FAN2510 的参考设计
- STR-FAN65004B-GEVB:Strata Enabled FAN65004B 65V 同步降压
- C8051F560DK,C8051F553 8051 MCU 工业应用开发系统
- 具有大接地回路电压的 LTC2862AIDD-1 RS485 链路的典型应用
- OP413ESZ-REEL耳机放大器多媒体声音编解码器典型应用
- NE555八音电子琴
