net_device_ops中方法的相应说明
* This structure defines the management hooks for network devices.
* The following hooks can be defined; unless noted otherwise, they are
* optional and can be filled with a null pointer.
* int (*ndo_init)(struct net_device *dev);
* This function is called once when network device is registered.
* The network device can use this to any late stage initializaton
* or semantic validattion. It can fail with an error code which will
* be propogated back to register_netdev
* void (*ndo_uninit)(struct net_device *dev);
* This function is called when device is unregistered or when registration
* fails. It is not called if init fails.
* int (*ndo_open)(struct net_device *dev);
* This function is called when network device transistions to the up
* state.
* int (*ndo_stop)(struct net_device *dev);
* This function is called when network device transistions to the down
* state.
* netdev_tx_t (*ndo_start_xmit)(struct sk_buff *skb,
* struct net_device *dev);
* Called when a packet needs to be transmitted.
* Must return NETDEV_TX_OK , NETDEV_TX_BUSY.
* (can also return NETDEV_TX_LOCKED iff NETIF_F_LLTX)
* Required can not be NULL.
* u16 (*ndo_select_queue)(struct net_device *dev, struct sk_buff *skb);
* Called to decide which queue to when device supports multiple
* transmit queues.
* void (*ndo_change_rx_flags)(struct net_device *dev, int flags);
* This function is called to allow device receiver to make
* changes to configuration when multicast or promiscious is enabled.
* void (*ndo_set_rx_mode)(struct net_device *dev);
* This function is called device changes address list filtering.
* void (*ndo_set_multicast_list)(struct net_device *dev);
* This function is called when the multicast address list changes.
* int (*ndo_set_mac_address)(struct net_device *dev, void *addr);
* This function is called when the Media Access Control address
* needs to be changed. If this interface is not defined, the
* mac address can not be changed.
* int (*ndo_validate_addr)(struct net_device *dev);
* Test if Media Access Control address is valid for the device.
* int (*ndo_do_ioctl)(struct net_device *dev, struct ifreq *ifr, int cmd);
* Called when a user request an ioctl which can't be handled by
* the generic interface code. If not defined ioctl's return
* not supported error code.
* int (*ndo_set_config)(struct net_device *dev, struct ifmap *map);
* Used to set network devices bus interface parameters. This interface
* is retained for legacy reason, new devices should use the bus
* interface (PCI) for low level management.
* int (*ndo_change_mtu)(struct net_device *dev, int new_mtu);
* Called when a user wants to change the Maximum Transfer Unit
* of a device. If not defined, any request to change MTU will
* will return an error.
* void (*ndo_tx_timeout)(struct net_device *dev);
* Callback uses when the transmitter has not made any progress
* for dev->watchdog ticks.
* struct net_device_stats* (*ndo_get_stats)(struct net_device *dev);
* Called when a user wants to get the network device usage
* statistics. If not defined, the counters in dev->stats will
* be used.
* void (*ndo_vlan_rx_register)(struct net_device *dev, struct vlan_group *grp);
* If device support VLAN receive accleration
* (ie. dev->features & NETIF_F_HW_VLAN_RX), then this function is called
* when vlan groups for the device changes. Note: grp is NULL
* if no vlan's groups are being used.
* void (*ndo_vlan_rx_add_vid)(struct net_device *dev, unsigned short vid);
* If device support VLAN filtering (dev->features & NETIF_F_HW_VLAN_FILTER)
* this function is called when a VLAN id is registered.
* void (*ndo_vlan_rx_kill_vid)(struct net_device *dev, unsigned short vid);
* this function is called when a VLAN id is unregistered.
* void (*ndo_poll_controller)(struct net_device *dev);
#define HAVE_NET_DEVICE_OPS
struct net_device_ops {
netdev_tx_t (*ndo_start_xmit) (struct sk_buff *skb,
#define HAVE_CHANGE_RX_FLAGS
int flags);
#define HAVE_SET_RX_MODE
#define HAVE_MULTICAST
#define HAVE_SET_MAC_ADDR
void *addr);
#define HAVE_VALIDATE_ADDR
#define HAVE_PRIVATE_IOCTL
#define HAVE_SET_CONFIG
struct ifmap *map);
#define HAVE_CHANGE_MTU
int new_mtu);
int (*ndo_neigh_setup)(struct net_device *dev,
struct neigh_parms *);
#define HAVE_TX_TIMEOUT
void (*ndo_tx_timeout) (struct net_device *dev);
#ifdef CONFIG_NET_POLL_CONTROLLER
#define HAVE_NETDEV_POLL
#endif
#if defined(CONFIG_FCOE) || defined(CONFIG_FCOE_MODULE)
int (*ndo_fcoe_enable)(struct net_device *dev);
int (*ndo_fcoe_disable)(struct net_device *dev);
int (*ndo_fcoe_ddp_setup)(struct net_device *dev,
u16 xid,
struct scatterlist *sgl,
unsigned int sgc);
int (*ndo_fcoe_ddp_done)(struct net_device *dev,
u16 xid);
#endif
ethtool_ops 中方法的相应说明
* ðtool_ops - Alter and report network device settings
* get_settings: Get device-specific settings
* set_settings: Set device-specific settings
* get_drvinfo: Report driver information
* get_regs: Get device registers
* get_wol: Report whether Wake-on-Lan is enabled
* set_wol: Turn Wake-on-Lan on or off
* get_msglevel: Report driver message level
* set_msglevel: Set driver message level
* nway_reset: Restart autonegotiation
* get_link: Get link status
* get_eeprom: Read data from the device EEPROM
* set_eeprom: Write data to the device EEPROM
* get_coalesce: Get interrupt coalescing parameters
* set_coalesce: Set interrupt coalescing parameters
* get_ringparam: Report ring sizes
* set_ringparam: Set ring sizes
* get_pauseparam: Report pause parameters
* set_pauseparam: Set pause parameters
* get_rx_csum: Report whether receive checksums are turned on or off
* set_rx_csum: Turn receive checksum on or off
* get_tx_csum: Report whether transmit checksums are turned on or off
* set_tx_csum: Turn transmit checksums on or off
* get_sg: Report whether scatter-gather is enabled
* set_sg: Turn scatter-gather on or off
* get_tso: Report whether TCP segmentation offload is enabled
* set_tso: Turn TCP segmentation offload on or off
* get_ufo: Report whether UDP fragmentation offload is enabled
* set_ufo: Turn UDP fragmentation offload on or off
* self_test: Run specified self-tests
* get_strings: Return a set of strings that describe the requested objects
* phys_id: Identify the device
* get_stats: Return statistics about the device
* get_flags: get 32-bit flags bitmap
* set_flags: set 32-bit flags bitmap
* Description:
* get_settings:
* @get_settings is passed an ðtool_cmd to fill in. It returns
* an negative errno or zero.
* set_settings:
* @set_settings is passed an ðtool_cmd and should attempt to set
* all the settings this device supports. It may return an error value
* if something goes wrong (otherwise 0).
* get_eeprom:
* Should fill in the magic field. Don't need to check len for zero
* or wraparound. Fill in the data argument with the eeprom values
* from offset to offset + len. Update len to the amount read.
* Returns an error or zero.
* set_eeprom:
* Should validate the magic field. Don't need to check len for zero
* or wraparound. Update len to the amount written. Returns an error
* or zero.
struct ethtool_ops {
int (*get_settings)(struct net_device *, struct ethtool_cmd *);
上一篇:mini2440一线总线移植tslib1.4
下一篇:Mini2440 DM9000 驱动分析(三)
推荐阅读最新更新时间:2024-11-10 10:16
推荐帖子
- 直流供电电路中,关于电源并联二极管、电容作用的思考与总结
- 问题:直流供电电路中,电源并联一个整流二极管的作用。解析:1.防止电源接反。a)电源接反,二极管导通相当于电源短路,电流很大(2A甚至更大),如果电源有保护就保护了,没保护就烧电源。对于有保护的电源,要求二极管的耐压值高于电源电压和最大正向电流高于电源的限制电流(保护电路的保护值或者保险丝的电流值),否则烧坏二极管,并且电路依然会在二极管烧坏之后被烧坏(待补充)。2.防止外电路反灌。a)电源没反接的情况下,如果外电路接了储能元件如电
- 木犯001号 电源技术
- 开放式现场总线CC-Link特性
- 1996年,三菱电机以“多厂家设备环境、高性能、省配线”理念开发、公布和开放了现场总线CC-Link。 CC-Link是Control&CommunicationLink(控制与通信链路系统)的简称。具有性能卓越、应用广泛使用简单节省成本等突出优点。 一般而言,我们将网络系统分为3至4个层次:管理层、控制器层、部件层,部件层也就是指装置层和传感器层。由于CC-Link的数据容量大,通信速度多级可选择,CC-Link是一个复合的、开放的、适应性强的网络系统,能够适应于较高的管理
- totopper 工控电子
- 线性相位
- 本帖最后由paulhyde于2014-9-1509:33编辑线性相位线性相位本帖最后由paulhyde于2014-9-1509:33编辑嗯,直流放大用的,楼主有心了。本帖最后由paulhyde于2014-9-1509:33编辑嗯,直流放大用的,楼主有心了本帖最后由paulhyde于2014-9-1509:33编辑谢谢。。。真的是需要这个理论呢。。。本帖最后由paulhyde于2014-9-15
- miaorui2008 电子竞赛
- 高手谈嵌入式调试的复杂性
- 嵌入式系统的调试往往很复杂,可用的手段并不像PC编程那么多,开发成本较PC系统也要大很多。嵌入式系统调试主要手段只有JTAG为代表的单步追踪、printf夹杀大法等。这两种调试方法在嵌入式中也不尽然全部能解决问题。Jtag需要调试者有一个调试设备(有可能很昂贵),和目标系统相连。使用类似GDBClient等软件登录调试设备,跟踪运行程序。说实话,这个方法对嵌入式来讲是终极的调试办法,也是比较好的调试方法。但仍然有几个不足,当断点过多时,超出硬件的限制,某些低档的CPU不支持更多的断
- jingcheng stm32/stm8
- 有没有人给点PID控制的程序?
- 拜托各位了,小弟最近在高PID控制,自己用C语言写的不准确,请高手赐教一下,最好是解释的比较清楚的那种。我的邮箱:sishuiliunian902@163.com有没有人给点PID控制的程序?
- wzh320 单片机
- 请问这个红外接收头是什么型号?能用哪个型号代替?谢谢
- 网络电视盒子上的,SEK1FN3L|K1EA请问这个红外接收头是什么型号?能用哪个型号代替?谢谢 现在一般都是一体化红外接收头只要管脚对得起来一般都能用。具体可以试试在看。 手里有两个VS1838B,昨天试了一下,不能用,所以来问问。今天再试试看。谢谢 看看手里的和你板子上的引脚是否对得上,不行得画要把管脚交叉连起来。就算电压地输出三个腿要能连接对。看板子看你手上得接收头资料。红外遥控接收?不同型号的应该可以互相替用吧
- liys_sunny RF/无线
