Tiny4412中断介绍
发布者:达文西happy最新更新时间:2022-01-16 来源: eefocus关键字:Tiny4412  中断介绍 手机看文章 扫描二维码
随时随地手机看文章
Tiny4412中断介绍
  通过几天裸板驱动开发,今天对ARM的中断做一些简单总结,前面我们已经了解了ARM的7种异常模式,中断是异常模式的一种,在ARM中异常事件发生将会触发中断,但是,所有的中断都不能直接访问cpu,而是都统一由GIC(中断管理器)来管理;下面是samsung提供的模式图:
其中GIC管理的中断有分为:
  (1)SGI:一个cpu中断另一个cpu(cpu0 ->cpu1)
  (2)PPI:一个中断只能中断一个cpu
  (3)SPI:一个中断可以中断多个cpu
  处理一个中断大致需要三步:
  (1)cpu permit interrupt (cpu允许中断)
  (2)GIC enable (启用GIC)
  (3)SET Interrupt source (设置中断源)
  下面是用SGI实现的一个程序:
  头文件:
 1 #ifndef __BUNFLY_H
 2 #define __BUNFLY_H
 4 #define ICCICR_CPU0    (*(volatile unsigned long *)0x10480000)
 5 #define ICCPMR_CPU0    (*(volatile unsigned long *)0x10480004)
 6 #define ICDDCR        (*(volatile unsigned long *)0x10490000)
 7 #define ICDIPR2_CPU0    (*(volatile unsigned long *)0x10490408)
 8 #define ICDIPTR2_CPU0    (*(volatile unsigned long *)0x10490808)
 9 #define ICDISER0_CPU0    (*(volatile unsigned long *)0x10490100)
10 #define ICDSGIR        (*(volatile unsigned long *)0x10490f00)
11 #define ICCEOIR_CPU0 (*(volatile unsigned long *)0x10480010)
12 #define ICCIAR_CPU0  (*(volatile unsigned long *)0x1048000c)
14 #endif    //__BUNFLY_H
  1 #include "bunfly.h"
  3 int (*printf)(char *, ...) = 0xc3e114d8;
  4 void enable_mmu();
  5 void init_table(unsigned long *addr);
  6 void memcpy(unsigned char *dest, unsigned char *src, int len);
  7 extern unsigned long  vector_start;
  8 void do_irq();
 10 int main()
 11 {
 12     memcpy(0x70000000, vector_start, 0x1000);
 13     enable_mmu();
 15     *(unsigned long *)0x47000000 = do_irq;
 17     //step 1: set cpu permit interrupt
 18     __asm__ __volatile__(
 19         "mrs r0, cpsrn"
 20         "bic r0,r0, #0x80n"
 21         "msr cpsr, r0n"
 22         :::"r0"
 23     );
 24
 25     //step 2: set GIC (cgi) enable
 26     ICCICR_CPU0 = 1;//cpu接口控制寄存器(总开关)
 27     ICCPMR_CPU0 =0xff;//中断总优先级(门槛)
 28     ICDDCR = 1;//本中断开关
 29     ICDIPR2_CPU0 = (3 << 9);//本中断优先级
 30     ICDIPTR2_CPU0 = (1 << 9);//目标cpu
 31     ICDISER0_CPU0 = (1 << 9);//启用本中断
 32
 33     //step 3: set interrupt source
 34     ICDSGIR = 9 | (1 << 16);
 36     printf("welcom backn");
 37 }
 38
 39 void do_irq()
 40 {
 41     unsigned long ack_id = 0;
 42     unsigned long cpu_id = 0;
 43     unsigned long data = ICCIAR_CPU0;
 44
 45     /*clean interrupt*/
 46     ack_id = data & 0x3ff;
 47     cpu_id = data & (0x7 << 10);
 48     ICCEOIR_CPU0 = ack_id | cpu_id;
 49
 50     printf("this is interruptn");
 51     printf("cup_id is %dn", cpu_id >> 10);
 52     printf("ack_id is %dn", ack_id);
 53
 54 }
 55
 56 void memcpy(unsigned char *dest, unsigned char *src, int len)
 57 {
 58     int i = 0;
 59     for(i = 0; i < len; i++) {
 60         dest[i] = src[i];
 61     }
 62 }
 63
 64 void enable_mmu()
 65 {
 66     /*构建表*/
 67     unsigned long addr = 0x50000000;
 68     init_table(addr);
 69     /*打开mmu*/
 70     unsigned long mmu = 0;
 71     mmu = 1 | (1 << 1) | (1 << 3) | (1 << 8);
 72     __asm__ __volatile__ (
 73         "mov r0, #3n"
 74         "MCR p15, 0, r0, c3, c0, 0n"//设置为管理员
 75         "MCR p15, 0, %0, c2, c0, 0n"//设置表的地址
 76         "MCR p15, 0, %1, c1, c0, 0n"//开启mmu
 77         :
 78         :    "r" (addr), "r" (mmu)
 79         :
 80     );
 81
 82 }
 83
 84 __asm__(
 85
 86 "vector: n"
 87 "    b resetn"
 88 "    b undn"
 89 "    b swin"
 90 "    b pre_abtn"
 91 "    b data_abtn"
 92 "    .word 0x0n"
 93 "    b irqn"
 94 "    b fiqn"
 95 "reset:n"
 96 "und:n"
 97 "    mov sp, #0x47000000n"
 98 "    stmdb sp!, {r0-r12, lr}n"
 99
100 "    ldr r3, =0x47000004n"
101 "    ldr r2, [r3]n"
102 "    blx r2n"
103
104 "    mov sp, #0x47000000n"
105 "    ldmdb sp, {r0-r12, pc}^    n"
106
107 "swi:n"
108 "    mov sp, #0x47000000n"
109 "    stmdb sp!, {r0-r12, lr}^n"
110
111 "    mov sp, #0x47000000n"
112 "    ldmdb sp, {r0-r12, pc}^    n"
113
114 "pre_abt:n"
115
116 "data_abt:n"
117 "    mov sp, #0x47000000n"
118 "    sub lr, lr, #4n"
119 "    stmdb sp!, {r0-r12, lr}n"
121 "    ldr r3, =0x47000008n"
122 "    ldr r2, [r3]n"
123 "    blx r2n"
124
125 "    mov sp, #0x47000000n"
126 "    ldmdb sp, {r0-r12, pc}^    n"
127 "irq:n"
128
129 "    mov sp, #0x47000000n"
130 "    sub lr, lr, #4n"
131 "    stmdb sp!, {r0-r12, lr}n"
132
133 "    ldr r3, =0x47000000n"
134 "    ldr r2, [r3]n"
135 "    blx r2n"
136
137 "    mov sp, #0x47000000n"
138 "    ldmdb sp, {r0-r12, pc}^    n"
139
140 "fiq:n"
141
142     ".global vector_startn"
143 "vector_start: n"
144     ".word vector n "
145
146 );
147
148 void init_table(unsigned long *addr)
149 {
150     unsigned long va = 0;
151     unsigned long phys = 0;
152
153     //0x40000000-0x80000000 -> 0x40000000-0x80000000
154     for(va = 0x40000000; va < 0x80000000; va += 0x100000) {
155         phys = va;
156         addr[va >> 20] = phys | 2;
157     }
158
159     //0x10000000-0x14000000 -> 0x10000000-0x140000000
160     for(va = 0x10000000; va < 0x14000000; va += 0x100000) {
161         phys = va;
162         addr[va >> 20] = phys | 2;
163     }
164     //0x10000000-0x14000000 -> 0x10000000-0x140000000
165     for(va = 0x0; va < 0x10000000; va += 0x100000) {
166         phys = va + 0x70000000;
167         addr[va >> 20] = phys | 2;
168     }
169
170 }
运行结果如下:
关键字:Tiny4412  中断介绍 引用地址:Tiny4412中断介绍
上一篇:Tiny4412中断之看门狗
下一篇:Tiny4412模式跳转
推荐阅读最新更新时间:2024-11-11 11:57
Tiny4412中断控制器(GIC)之外部中断
#include regs.h void enable_mmu(unsigned long ttb); void init_ttb(unsigned long *ttb_base); void mmap(unsigned long *ttb_base, unsigned long va, unsigned long pa); void memset(char *buf, char ch, int size); void memcpy(char *dst, char *src, int size); void do_irq(unsigned long regs ); void (*printf)(char *, ...) = 0x
[单片机]
tiny4412 裸机程序 一、说明
首先、我想说明为什么我写这个文档?我自己想学点东西,过于求成,又过于自信,直接买了Tiny4412的板子,但网上关于4412的资料太少,我一直没办法啃动,只能尽可能找来各种相关资料进行参考分析。我想在U-Boot程序中加入LCD显示功能,但始终都没有正常点亮LCD,放弃的心都有了,后来在网上找到一份《Linux平台下Mini210S裸机程序开发指南》的文档,我觉得写的挺清楚的,我也只能二一点了,先把4412当单片机玩吧,也给自己树点信心吧,我想能参考完成这些裸机程序后,再来搞U-Boot的LCD功能应会有新的收获吧,所以我就参考着这份文档,进行了一些裸机程序实验。写这份文档中,一是给自己学习用,二是希望能帮助到一些像我一样的朋友。
[单片机]
C51/C52单片机的中断(EXTI)介绍(一)
一、什么是中断 打断:打断当前做的事情,去执行中断函数里的程序,执行完过后回来接着执行原来未执行完的程序。如下图所示: 二、中断源及中断号 注意:写中断服务函数时,中断源与中断号要一一对应,否则不能进入中断服务函数,比如: void Timer0IRQ(void) interrupt 1 //1就是中断号,默认工作组0 格式如下: void 函数名(void) interrupt 中断号 using 工作组 { 中断服务函数内容; } 三、中断相关寄存器介绍 1、中断允许控制寄存器IE 2、扩展中断控制寄存器XICON(STC89C52RC) 四、中断优先级
[单片机]
C51/C52单片机的<font color='red'>中断</font>(EXTI)<font color='red'>介绍</font>(一)
第十三章、Tiny4412 U-BOOT移植十三 DDR3初始化源码分析
第一步、设置时钟 按上一章中步骤来说明: 1. DMC must assert and hold CKE to a logic lowlevel to provide stable power for memory device and then apply stable clock. 设置DMC,由于时钟已经在clock_init_mytiny4412.S中进行了设置,这里可以不用再做设置了。只要保持CKE为低电平。 第二步、设置Phycontrol_n寄存器 2. Set the PhyControl0.ctrl_start_point andPhyControl0.ctrl_inc bit-fields to a cor
[单片机]
第十三章、<font color='red'>Tiny4412</font> U-BOOT移植十三 DDR3初始化源码分析
推荐帖子
单口RAM、伪双口RAM、双口RAM与FIFO的区别
常用到的数据缓存IP有FIFO和RAM,其中RAM又分单口RAM、伪双口RAM、双口RAM。单口与双口的区别在于,单口只有一组数据线与地址线,因此读写不能同时进行。而双口有两组数据线与地址线,读写可同时进行。FIFO读写可同时进行,可以看作是双口。双口RAM分伪双口RAM(Xilinx称为Simpletwo-dualRAM)与双口RAM(Xilinx称为truetwo-dualRAM)。伪双口RAM,一个端口只读,另一个端口只写;而双口RAM两个端口都可以读写。
Aguilera DSP 与 ARM 处理器
903恒温电烙铁电路图
核心的IC就是运放,或者LM324,LM358,通过双向可控硅来控制加热芯通断!温度控制采用热电偶,或者热敏电阻;电源采用220VAC直接RC降压。成本比较低廉,损坏之后可以参考此电路进行维修!903恒温电烙铁电路图903恒温电烙铁,通过运放温度控制双向可控硅来控制加热芯通断!下来看一看,学一学ok是用变压器降压的吗模糊到爆炸
threetigher 家电维修集锦
关于testbench连接模块的问题
编了一个程序,用quartus调用modelsim的时候出现了下面的这个错误。。。Error:(vsim-3389)E:/project/test2/simulation/modelsim/hm.vt(53):Port\'counter\'notfoundintheconnectedmodule(7thconnection).出问题的代码是这个位置:hmi1(.clk(clk),.data(data),.key(key),.pulse(puls
txws007 FPGA/CPLD
PIC基本型8 位A-D 转换器.pdf
PIC基本型8位A-D转换器很详细的介绍8位AD转换器原理和装配图内型,PDF电子书PIC基本型8位A-D转换器.pdf
rain Microchip MCU
最后一天!有奖直播 | RSL15 - 安森美更高效更智能更安全的 BLE 5.2 蓝牙芯片
直播时间:2022年03月31日(周四)上午10:00-11:30直播主题:RSL15-安森美更高效更智能更安全的BLE5.2蓝牙芯片预约报名直播内容:从BLE背景以及市场分析着手,介绍安森美BLE家族并重点解析安森美最新推出的BLE5.2蓝牙芯片RSL15的新功能,例如CryptoCell-312与TrustZone安全性支持,AngleofArrival(AoA)与AngleofDeparture
EEWORLD社区 RF/无线
verilog如何用矩阵键盘按三次输入三位数(0-999)?
verilog如何用矩阵键盘按三次输入三位数(0-999)?modulekey4x4(clk,rst_n,row,col,key_val);inputclk;inputrst_n;inputrow;//矩阵键盘行outputregcol;//矩阵键盘列outputregkey_val;//键盘值按键每按一次只会输出一个数字,连续按需要如下处理:n
yuxuanwlfei FPGA/CPLD
小广播
设计资源 培训 开发板 精华推荐
最新单片机文章
何立民专栏 单片机及嵌入式宝典
换一换 更多 相关热搜器件
