基于讯为4412开发板:
插上U盘
[ 2407.650440] usb 1-3.3: new high speed USB device number 7 using s5p-ehci
[ 2407.887332] usb 1-3.3: New USB device found, idVendor=0951, idProduct=1666, bcdDevice=0100
[ 2407.894249] usb 1-3.3: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2407.901651] usb 1-3.3: New USB device Class: class="0", SubClass=0, Protocol=0
[ 2407.908558] usb 1-3.3: Product: DataTraveler 3.0
[ 2407.913150] usb 1-3.3: Manufacturer: Kingston
[ 2407.917488] usb 1-3.3: SerialNumber: 50E5495131F7B0A0495A3E9A
[ 2407.945454] scsi3 : usb-storage 1-3.3:1.0
[ 2408.981773] scsi 3:0:0:0: Direct-Access Kingston DataTraveler 3.0 PMAP PQ: 0 ANSI: 6
[ 2409.002820] sd 3:0:0:0: Attached scsi generic sg0 type 0
[ 2410.472934] sd 3:0:0:0: [sda] 60632064 512-byte logical blocks: (31.0 GB/28.9 GiB)
[ 2410.482241] sd 3:0:0:0: [sda] Write Protect is off
[ 2410.486619] sd 3:0:0:0: [sda] No Caching mode page present
[ 2410.491237] sd 3:0:0:0: [sda] Assuming drive cache: write through
[ 2410.503131] sd 3:0:0:0: [sda] No Caching mode page present
[ 2410.507269] sd 3:0:0:0: [sda] Assuming drive cache: write through
[ 2410.527868] sda: sda1
[ 2410.549386] sd 3:0:0:0: [sda] No Caching mode page present
[ 2410.553692] sd 3:0:0:0: [sda] Assuming drive cache: write through
[ 2410.585133] sd 3:0:0:0: [sda] Attached SCSI removable disk
挂载U盘失败
~ # mount /dev/sda1 /mnt/udisk/
mount: mounting /dev/sda1 on /mnt/udisk/ failed: No such device or address
~ # mount /dev/sda /mnt/udisk/
mount: mounting /dev/sda on /mnt/udisk/ failed: Invalid argument
查看/dev
~ # ls /dev/
/dev中没有sdb1这个设备节点
手动创建节点
~ # mknod /dev/sda1 b 8 1
挂载U盘
~ # ls /mnt/udisk/
Linux
挂载U盘成功
上一篇:iTOP-4412开发板-Android-RFID 使用文档
下一篇:处理器开发平台4412开发板学习-NFS服务器的搭建方法
推荐阅读最新更新时间:2024-11-10 12:23
推荐帖子
- Raw-OS开源操作系统在EEWORLD安家,祝贺一下!
- Raw-OS(www.raw-os.com)起飞于2012年,Raw-OS志在制作中国人自己的、开源的、免费的实时操作系统。Raw-OS理念:稳定、高效、移植、开源期待通过EEWORLDRaw-OS板块,能将更多的Raw-OS爱好者聚集起来,一起交流、推广、使用该系统。Raw-OS开源操作系统在EEWORLD安家,祝贺一下!给力啊板凳了支持一下txj希望自己学到点东西后能够为Raw做点贡献~!祝贺RAW-OS在eeword安家!:rose::rose::rose
- EEWORLD社区 嵌入式系统
- 【BIGTREETECH PI开发板】vnc远程桌面连接
- 前言板载的HDMI2.0A接口一般需要专用的组焊接头,没有的话就不好连接HDMI显示器,此时我们可以使用vnc远程桌面。本片详解配置过程。过程安装vncserversudoaptinstalltigervnc-standalone-server-y安装桌面环境sudoaptinstallxfce4-ysudoaptinstallxfce4-terminalsuroot进入root用户vncpasswd设置密码
- qinyunti 国产芯片交流
- Linux 性能监测:介绍
- 看了某某教程、读了某某手册,按照要求改改某某设置、系统设定、内核参数就认为做到系统优化的想法很傻很天真:)系统优化是一项复杂、繁琐、长期的工作,优化前需要监测、采集、测试、评估,优化后也需要测试、采集、评估、监测,而且是一个长期和持续的过程,不是说现在优化了,测试了,以后就可以一劳永逸了,也不是说书本上的优化就适合眼下正在运行的系统,不同的系统、不同的硬件、不同的应用优化的重点也不同、优化的方法也不同、优化的参数也不同。性能监测是系统优化过程中重要的一环,如果没有监测、不清楚性能瓶颈在哪里,优
- chenzhufly Linux与安卓
- 基于研祥的产品EC3-1547CLDNA的嵌入式linux开发
- 在宿主机上建立linux开发环境,要想把剪裁后的内核移植到EC3-1547CLDNA上,就要在宿主机上建立交叉编译环境,但不知道交叉编译工具怎样去选???网上大多都是基于arm板子的。那位高手能帮帮我????先谢了!基于研祥的产品EC3-1547CLDNA的嵌入式linux开发
- whbahx Linux与安卓
- 【NXP Rapid IoT评测】Rapid IoT Studio 简单编程第二步 计数器加蓝牙
- 【NXPRapidIoT评测】RapidIoTStudio简单编程第二步计数器加蓝牙1,打开RapidIoTStudioIDE2,RapidIoTStudio简单编程第一步工程,加上蓝牙GATT控件。3,设置读写(其实这里只用了读)允许。4,把蓝牙GATT控件和ToggleBacklight控件连接起来。设置让它的REIGGER触发发送的字符串发送给蓝牙。这里没有进行转换直接把字符串发给蓝牙所以值为0就是301就是312就是32.今
- damiaa RF/无线
- lan8720A 奇怪的复位问题?
- 使用stm32f407芯片做了一块板,网络方案使用lan8720A芯片,但是,碰到了一个奇怪的问题:将板子和电源系统接好,这时打开电源开关。网络系统就可以工作。如果:使用复位按键复位系统则网络就不工作。如果将5V电源打开,通过鳄鱼夹给板子供电,网络也不工作。通过在芯片启动前增加延时也不管用。有网友说变压器中间抽头的电容换成0.1uF(104)、0.01uF(103)都不行,手册上参考的电容是0.022uF,但是,我手里没有22nF的电容。所以没有测试。nRST是和STM32F407的nRST信
- bigbat stm32/stm8
设计资源 培训 开发板 精华推荐
- ADI【混合动力汽车(HEV)/电动汽车(EV)】锂电池管理解决方案
- 邀您注册 VICOR 电池化成与测试迷你站
- 据说,来挑战的都是“老司机”,TE答题排位赛火热进行中,不服来战!
- ADI有奖下载活动之22:针对电子测试和测量的RF和微波解决方案
- 有奖直播:AC/DC 在 ATX 及 Server 电源解決方案及应用 报名开始啦!
- 6月6日 Microchip 直播|利用单片机设计安全关键型应用时应采取的最佳实践方法
- TE Connectivity 提供更懂你的连接解决方案
- 电阻哪个强?看Vishay演示视频 抢楼发言赢好礼
- 看咱坛友自己的研讨会~ST-EEWORLD线下网友见面会实录
- 端午节芯币大兑换
