参考《韦东山1期视频》第09课第3节 u-boot分析之源码第1阶段.WMV
一:第一阶段
(1)打开u-boot-1.1.6_JZ2440cpuarm920tstart.S
_start: b reset(跳转到reset):
1.设置SVC32 模式;
reset:
* set the cpu to SVC32 mode
mrs r0,cpsr
bic r0,r0,#0x1f
orr r0,r0,#0xd3
msr cpsr,r0
2.关看门狗;
/* turn off the watchdog */
#if defined(CONFIG_S3C2400)
# define pWTCON 0x15300000
# define INTMSK 0x14400008 /* Interupt-Controller base addresses */
# define CLKDIVN 0x14800014 /* clock divisor register */
#elif defined(CONFIG_S3C2410)
# define pWTCON 0x53000000
# define INTMOD 0X4A000004
# define INTMSK 0x4A000008 /* Interupt-Controller base addresses */
# define INTSUBMSK 0x4A00001C
# define CLKDIVN 0x4C000014 /* clock divisor register */
#endif
#if defined(CONFIG_S3C2400) || defined(CONFIG_S3C2410)
ldr r0, =pWTCON
mov r1, #0x0
str r1, [r0]
3.关中断;
* mask all IRQs by setting all bits in the INTMR - default
mov r1, #0xffffffff
ldr r0, =INTMSK
str r1, [r0]
# if defined(CONFIG_S3C2410)
ldr r1, =0x3ff
ldr r0, =INTSUBMSK
str r1, [r0]
# endif
#if 0
/* FCLK:HCLK:PCLK = 1:2:4 */
/* default FCLK is 120 MHz ! */
ldr r0, =CLKDIVN
mov r1, #3
str r1, [r0]
#endif
#endif /* CONFIG_S3C2400 || CONFIG_S3C2410 */
* we do sys-critical inits only at reboot,
* not when booting from ram!
4.cpu_init_crit(SDRAM初始化);
#ifndef CONFIG_SKIP_LOWLEVEL_INIT
adr r0, _start /* r0 <- current position of code */
ldr r1, _TEXT_BASE /* test if we run from flash or RAM */
cmp r0, r1 /* don't reloc during debug */
blne cpu_init_crit
#endif
5.设置栈;
6.时钟初始化clock_init;
bl clock_init
#endif
7.重定位:把代码从flash读到SDRAM里面去,读到链接地址去。
#ifndef CONFIG_SKIP_RELOCATE_UBOOT
relocate: /* relocate U-Boot to RAM */
beq clear_bss
ldr r2, _armboot_start
ldr r3, _bss_start
sub r2, r3, r2 /* r2 <- size of armboot */
8.清bss段
9.调用C函数start_armboot
以上9部称为硬件相关初始化。
前8部称为第一阶段。
第二阶段从start_armboot开始。
1.gd指针指向(128字节内存)
2.一系列初始化
for (init_fnc_ptr = init_sequence; *init_fnc_ptr; ++init_fnc_ptr) {
if ((*init_fnc_ptr)() != 0) {
hang ();
CPU初始化
单板初始化
init_fnc_t *init_sequence[] = {
cpu_init, /* basic cpu dependent setup */
board_init, /* basic board dependent setup */
interrupt_init, /* set up exceptions */
env_init, /* initialize environment */
init_baudrate, /* initialze baudrate settings */
serial_init, /* serial communications setup */
console_init_f, /* stage 1 init of console */
display_banner, /* say that we are here */
flash初始化:
#ifndef CFG_NO_FLASH
/* configure available FLASH banks */
size = flash_init ();
display_flash_config (size);
#endif /* CFG_NO_FLASH */
malloc初始化(192K)
/* armboot_start is defined in the board-specific linker script */
mem_malloc_init (_armboot_start - CFG_MALLOC_LEN);
nand 初始化
#if (CONFIG_COMMANDS & CFG_CMD_NAND)
puts ("NAND: ");
nand_init(); /* go init the NAND */
#endif
环境变量初始化:默认值或者在flash上存储的值
env_relocate ();
死循环:
for (;;) {
main_loop ();
s = getenv ("bootcmd");
倒计时:
if (bootdelay >= 0 && s && !abortboot (bootdelay)) {
# ifdef CONFIG_AUTOBOOT_KEYED
int prev = disable_ctrlc(1); /* disable Control C checking */
# endif
# ifndef CFG_HUSH_PARSER
printf("Booting Linux ...n");
run_command (s, 0);
# else
parse_string_outer(s, FLAG_PARSE_SEMICOLON |
FLAG_EXIT_FROM_LOOP);
# endif
上一篇:04-S3C2440u-boot学习之u-boot分析(4)之u-boot命令实现
下一篇:04-S3C2440u-boot学习之u-boot分析(1)编译体验
推荐帖子
- 时尚手机变手镯 Dial Phone美丽创意
- 由JungDaeHoon设计的一款前卫的手镯式概念手机DialPhone,外形时尚,设计师将手机设计成环形,可以像手镯一样戴在手腕上,相当有创意。该手机的数字键通过手镯边缘透射出来,然后根据手镯上对应的按键拨号,接听来电应该是要靠外接耳机来协助完成。在手镯接口处有一个小型的LED显示屏,可以刚好显示下时间、信号强度或来电号码,并且还可以将时间透射到人的手上,以方便查看。时尚手机变手镯DialPhone美丽创意发光很有意思
- xyh_521 创意市集
- MAX32630FTHR-一种人体脉搏呼吸率及血氧浓度在线监测系统
- (1)作品名称:一种人体脉搏呼吸率及血氧浓度在线监测系统(2)作品实现功能简介:首先,本系统通过压力传感技术监测人体的心率、呼吸率和体动状态,提供一种非穿戴式的人体基本体征信息监测方案。其次,本系统利用MAX30102心率血氧传感器实现人体心率、血氧参数的采集,提供一种穿戴式的人体基本信息监测方案。再次,本系统接入到云平台(米家智能平台),手机APP可以直观地观察人体的体征信息,查看某段时间的生命体征曲线变化。同时将数据存入SD卡中,方便利用数据校准算法。
- Justice_Gao MAX32630FTHR设计大赛
- textbox获得焦点时打开输入法出现的问题
- 我想在textbox获得焦点时,自动打开输入法我在textbox的getfocus事件中时这样写的:inputMethod.setIME(true);inputPanel1.Enabled=true;inputMethod是callInputMethod的一个实例publicclasscallInputMethod{publicstaticexternIntPtrImmGetContext(IntPt
- zhaojiang1 嵌入式系统
- 俺的C习题(5)——这个很简单,圈哥看你能挑出什么?
- 如题/*practise8.2*//*这个程序很简单,就是把输入的整数转换成字符型输出*/#includestdio.hchar*itoa(intn,charstr)//鬼知道我当时怎么会起了这么一个名字...{ intnegative=0; inti=0; charbuffer=0; /*处理负数*/ if(n0) {n=-n;negative=1;//那一年,哥真的是不懂MCU,以至于动不动就int...
- 辛昕 编程基础
- 机载 SAR 运动补偿传感器研究
- 提出一种不依赖于机载主惯导的运动传感器方案———基于GNSS/SINS的组合运动信息系统。即在SAR成像期间输出以纯惯性为主的信息以保证较高的相对定位精度,供SAR成像补偿;同时,GNSS/SINS的组合保证了长时间的绝对定位精度。介绍了这种运动传感器的原理、数学模型、工作流程控制。实验结果表明,基于GNSS/SINS的运动传感器具有很高的精度,完全满足了SAR成像的精度要求,特别适合于没有机载主惯导机载SAR运动补偿传感器研究
- frozenviolet 测试/测量
- 老师是这么教我们进修单片机的
- 看到不少网友都在问怎样提高自己的能力,我在这里想谈一下我自己当年的学习过程。我学的是计算机系的通讯工程专业,主要的发展方向是做计算机网络偏软件这一块,这点从我的毕业设计课题《宾馆客房管理系统》就能看出来。因为带到通讯,所以学校里也教数电模电单片机什么的。其中《单片机和通讯接口》这门课我学到了很多东西,可以说,整个大学觉得最有收获的就是这门课。我的老师上课很有特性,首先没有教材,理由是现在技术一日千里,等到教材出来就已经淘汰了。我们直接拿磁盘从老师的电脑上拷课件,然后打印。通常讲到单片机这
- ssjatq 单片机
设计资源 培训 开发板 精华推荐
- 两路继电器
- MPC86XADS、MPC8xx 参考板,基于 MPC860EN MPU PowerQUICC MPC8xx 处理器
- LM2902DTBR2G 函数发生器运算放大器的典型应用
- TRESOR 夹层板使 96Boards 能够在基于 SLB9670x 安全 MCU 和可信平台模块 (TPM) 的项目中实施不同的安全元素
- 使用 Richtek Technology Corporation 的 RT7297A 的参考设计
- SY58038U,用于 GB 以太网交换机的时钟缓冲器的评估板
- 使用 Analog Devices 的 LTC1517CS5-5 的参考设计
- ADR280 低成本电流源的典型应用
- MP2315S多路供电模块
- 5V模块
