GPIO_Init(GPIOE, &GPIO_InitStructure);
函数实体定义是:
void GPIO_Init(GPIO_TypeDef* GPIOx, GPIO_InitTypeDef* GPIO_InitStruct) //结构体的指针,指向结构体变量的首地址2020.2.18 //疑问?为什么用结构体指针类型定义,而不用结构体类型定义GPIOx,
对应的外设的内部地址单片机第一好的 对应自定义的结构体指针变量的地址,编译器自动分配识别地址 //GPIO_InitStruct2020.2.19
//猜测可以用结构体,但是要和绝对地址相联系实现起来麻烦
GPIO_TypeDef*结构体的指针指向结构体
typedef struct
__IO uint32_t CRL;
__IO uint32_t CRH;
__IO uint32_t IDR;
__IO uint32_t ODR;
__IO uint32_t BSRR;
__IO uint32_t BRR;
__IO uint32_t LCKR;
} GPIO_TypeDef;
包含每个IO端口的7个寄存器
GPIOx //IO端口外设
assert_param(IS_GPIO_ALL_PERIPH(GPIOx)); //外设插入参数判断
#define IS_GPIO_ALL_PERIPH(PERIPH) (((PERIPH) == GPIOA) || //带参数的宏定义中,参数类型不用指定,只是符号代换,和函数的形参是不一样的
((PERIPH) == GPIOB) ||
((PERIPH) == GPIOC) ||
((PERIPH) == GPIOD) ||
((PERIPH) == GPIOE) ||
((PERIPH) == GPIOF) ||
((PERIPH) == GPIOG))
GPIOE 外设
#define GPIOE ((GPIO_TypeDef *) GPIOE_BASE) //疑问?宏定义属于变量范畴吗 好像不是 宏定义可以表示常亮 3.1415926可以用宏定义
#define GPIOE_BASE (APB2PERIPH_BASE + 0x1800) //疑问?常量地址可以被强制转化为结构指针吗?2020.2.19
#define APB2PERIPH_BASE (PERIPH_BASE + 0x10000) //指针就是地址,常量可以被强制转化int * p;int a;p=&a;
#define PERIPH_BASE ((uint32_t)0x40000000) /*!< Peripheral base address in the alias region */
找到外设的地址
GPIO_InitTypeDef*结构体指针指向结构体
typedef struct
uint16_t GPIO_Pin; /*!< Specifies the GPIO pins to be configured.
This parameter can be any value of @ref GPIO_pins_define */ //引脚序号
GPIOSpeed_TypeDef GPIO_Speed; /*!< Specifies the speed for the selected pins.
This parameter can be a value of @ref GPIOSpeed_TypeDef */ //速度
GPIOMode_TypeDef GPIO_Mode; /*!< Specifies the operating mode for the selected pins.
This parameter can be a value of @ref GPIOMode_TypeDef */ //推挽等模式
}GPIO_InitTypeDef;
assert_param(IS_GPIO_PIN(GPIO_InitStruct->GPIO_Pin));
assert_param(IS_GPIO_SPEED(GPIO_InitStruct->GPIO_Speed));
assert_param(IS_GPIO_MODE(GPIO_InitStruct->GPIO_Mode));
#define IS_GPIO_MODE(MODE) (((MODE) == GPIO_Mode_AIN) || ((MODE) == GPIO_Mode_IN_FLOATING) ||
((MODE) == GPIO_Mode_IPD) || ((MODE) == GPIO_Mode_IPU) ||
((MODE) == GPIO_Mode_Out_OD) || ((MODE) == GPIO_Mode_Out_PP) ||
((MODE) == GPIO_Mode_AF_OD) || ((MODE) == GPIO_Mode_AF_PP))
GPIO_Mode的数据类型为 GPIOMode_TypeDef 枚举类型
typedef enum
{ GPIO_Mode_AIN = 0x0,
GPIO_Mode_IN_FLOATING = 0x04,
GPIO_Mode_IPD = 0x28,
GPIO_Mode_IPU = 0x48,
GPIO_Mode_Out_OD = 0x14,
GPIO_Mode_Out_PP = 0x10,
GPIO_Mode_AF_OD = 0x1C,
GPIO_Mode_AF_PP = 0x18
}GPIOMode_TypeDef;
GPIO_Speed的数据类型为GPIOSpeed_TypeDef 枚举类型
typedef enum
GPIO_Speed_10MHz = 1,
GPIO_Speed_2MHz,
GPIO_Speed_50MHz
}GPIOSpeed_TypeDef;
#define IS_GPIO_SPEED(SPEED) (((SPEED) == GPIO_Speed_10MHz) || ((SPEED) == GPIO_Speed_2MHz) ||
((SPEED) == GPIO_Speed_50MHz)) //带参数宏定义2020.2.19
GPIO_Pin的数据类型 uint16_t
#define GPIO_Pin_0 ((uint16_t)0x0001) /*!< Pin 0 selected */
#define GPIO_Pin_1 ((uint16_t)0x0002) /*!< Pin 1 selected */
#define GPIO_Pin_2 ((uint16_t)0x0004) /*!< Pin 2 selected */
#define GPIO_Pin_3 ((uint16_t)0x0008) /*!< Pin 3 selected */
#define GPIO_Pin_4 ((uint16_t)0x0010) /*!< Pin 4 selected */
#define GPIO_Pin_5 ((uint16_t)0x0020) /*!< Pin 5 selected */
#define GPIO_Pin_6 ((uint16_t)0x0040) /*!< Pin 6 selected */
#define GPIO_Pin_7 ((uint16_t)0x0080) /*!< Pin 7 selected */
#define GPIO_Pin_8 ((uint16_t)0x0100) /*!< Pin 8 selected */
#define GPIO_Pin_9 ((uint16_t)0x0200) /*!< Pin 9 selected */
#define GPIO_Pin_10 ((uint16_t)0x0400) /*!< Pin 10 selected */
#define GPIO_Pin_11 ((uint16_t)0x0800) /*!< Pin 11 selected */
#define GPIO_Pin_12 ((uint16_t)0x1000) /*!< Pin 12 selected */
#define GPIO_Pin_13 ((uint16_t)0x2000) /*!< Pin 13 selected */
#define GPIO_Pin_14 ((uint16_t)0x4000) /*!< Pin 14 selected */
#define GPIO_Pin_15 ((uint16_t)0x8000) /*!< Pin 15 selected */
#define GPIO_Pin_All ((uint16_t)0xFFFF) /*!< All pins selected */
#define IS_GPIO_PIN(PIN) ((((PIN) & (uint16_t)0x00) == 0x00) && ((PIN) != (uint16_t)0x00))
#define IS_GET_GPIO_PIN(PIN) (((PIN) == GPIO_Pin_0) ||
((PIN) == GPIO_Pin_1) ||
((PIN) == GPIO_Pin_2) ||
((PIN) == GPIO_Pin_3) ||
((PIN) == GPIO_Pin_4) ||
((PIN) == GPIO_Pin_5) ||
((PIN) == GPIO_Pin_6) ||
((PIN) == GPIO_Pin_7) ||
((PIN) == GPIO_Pin_8) ||
((PIN) == GPIO_Pin_9) ||
((PIN) == GPIO_Pin_10) ||
((PIN) == GPIO_Pin_11) ||
((PIN) == GPIO_Pin_12) ||
((PIN) == GPIO_Pin_13) ||
上一篇:单片机STM32学习笔记之寄存器映射详解
下一篇:STM32参考说明中SPI数据发送接收过程数据寄存器缓冲区移位寄存器工作过程
推荐阅读最新更新时间:2024-11-08 02:02
