在上一篇中probe函数中的一个很重要的函数nand_scan函数,现在来说另外一个很重要的函数add_mtd_partitions函数,add_mtd_partitions()会对每一个新建分区建立一个新的mtd_part 结构体,将其加入mtd_ partitions中,并调用add_mtd_device()将此分区作为MTD设备加入mtd_table。成功时返回0,如果分配mtd_part时内存不足,则返回-ENOMEM。
1、在说这个函数前,先说下,与这有关的结构体struct mtd_part和struct mtd_partition结构体,如下所示:
mtd_part结构体用于描述分区,其mtd_info结构体成员用于描述本分区
/* Our partition node structure */
struct mtd_part {
struct mtd_info mtd; 分区的信息(大部分由其master决定
struct mtd_info *master; 该分区的主分区
u_int32_t offset; 该分区的偏移地址
int index; 分区号
struct list_head list;
int registered;
* Partition definition structure:
* An array of struct partition is passed along with a MTD object to
* add_mtd_partitions() to create them.
* For each partition, these fields are available:
* name: string that will be used to label the partition's MTD device.
* size: the partition size; if defined as MTDPART_SIZ_FULL, the partition
* will extend to the end of the master MTD device.
* offset: absolute starting position within the master MTD device; if
* defined as MTDPART_OFS_APPEND, the partition will start where the
* previous one ended; if MTDPART_OFS_NXTBLK, at the next erase block.
* mask_flags: contains flags that have to be masked (removed) from the
* master MTD flag set for the corresponding MTD partition.
* For example, to force a read-only partition, simply adding
* MTD_WRITEABLE to the mask_flags will do the trick.
* Note: writeable partitions require their size and offset be
* erasesize aligned (e.g. use MTDPART_OFS_NEXTBLK).
struct mtd_partition {
char *name; /* identifier string */ 标识字符串
u_int32_t size; /* partition size */ 分区大小
u_int32_t offset; /* offset within the master MTD space */ 主MTD空间内的偏移
u_int32_t mask_flags; /* master MTD flags to mask out for this partition */
struct nand_ecclayout *ecclayout; /* out of band layout for this partition (NAND only)*/
struct mtd_info **mtdp; /* pointer to store the MTD object */
现在来看下6410中的定义:
struct mtd_partition s3c_partition_info[] = {
.name = "Bootloader",
.offset = 0,
.size = (256*SZ_1K),
.mask_flags = MTD_CAP_NANDFLASH,
.name = "Kernel",
.offset = (256*SZ_1K),
.size = (4*SZ_1M) - (256*SZ_1K),
#if defined(CONFIG_SPLIT_ROOT_FILESYSTEM)
.name = "Rootfs",
.offset = (4*SZ_1M),
// .size = (512*SZ_1M),//(48*SZ_1M),
.size = (80*SZ_1M),//(48*SZ_1M),
#endif
.name = "File System",
.offset = MTDPART_OFS_APPEND,
.size = MTDPART_SIZ_FULL,
struct s3c_nand_mtd_info s3c_nand_mtd_part_info = {
.chip_nr = 1,
.mtd_part_nr = ARRAY_SIZE(s3c_partition_info),
.partition = s3c_partition_info,
2、下面来看add_mtd_partitions函数,源码如下:
* This function, given a master MTD object and a partition table, creates
* and registers slave MTD objects which are bound to the master according to
* the partition definitions.
* (Q: should we register the master MTD object as well?)
int add_mtd_partitions(struct mtd_info *master,
const struct mtd_partition *parts,
int nbparts)
struct mtd_part *slave;
u_int32_t cur_offset = 0;
int i;
printk(KERN_NOTICE "Creating %d MTD partitions on "%s":n", nbparts, master->name);
for (i = 0; i < nbparts; i++) { 主要就是这个循环体,应该是分别添加每个struct mtd_partition结构
slave = add_one_partition(master, parts + i, i, cur_offset);
if (!slave)
return -ENOMEM;
cur_offset = slave->offset + slave->mtd.size;
return 0;
接着看add_one_partition函数,源码如下:
static struct mtd_part *add_one_partition(struct mtd_info *master,
const struct mtd_partition *part, int partno,
u_int32_t cur_offset)
struct mtd_part *slave; 新建的struct mtd_part结构
/* allocate the partition structure */
slave = kzalloc(sizeof(*slave), GFP_KERNEL);
if (!slave) {
printk(KERN_ERR"memory allocation error while creating partitions for "%s"n",
master->name);
del_mtd_partitions(master);
return NULL;
list_add(&slave->list, &mtd_partitions);
这里有个定义:static LIST_HEAD(mtd_partitions);
/* set up the MTD object for this partition */ 其实下面这么多,基本上都是根据主分区和我们定义的
struct mtd_partition中的信息去初始化新建的分区
slave->mtd.type = master->type;
slave->mtd.flags = master->flags & ~part->mask_flags;
slave->mtd.size = part->size;
slave->mtd.writesize = master->writesize;
slave->mtd.oobsize = master->oobsize;
slave->mtd.oobavail = master->oobavail;
slave->mtd.subpage_sft = master->subpage_sft;
slave->mtd.name = part->name;
slave->mtd.owner = master->owner;
slave->mtd.read = part_read;
slave->mtd.write = part_write;
if (master->panic_write)
slave->mtd.panic_write = part_panic_write;
if (master->point && master->unpoint) {
slave->mtd.point = part_point;
slave->mtd.unpoint = part_unpoint;
if (master->read_oob)
slave->mtd.read_oob = part_read_oob;
if (master->write_oob)
slave->mtd.write_oob = part_write_oob;
if (master->read_user_prot_reg)
slave->mtd.read_user_prot_reg = part_read_user_prot_reg;
if (master->read_fact_prot_reg)
slave->mtd.read_fact_prot_reg = part_read_fact_prot_reg;
if (master->write_user_prot_reg)
slave->mtd.write_user_prot_reg = part_write_user_prot_reg;
if (master->lock_user_prot_reg)
slave->mtd.lock_user_prot_reg = part_lock_user_prot_reg;
if (master->get_user_prot_info)
slave->mtd.get_user_prot_info = part_get_user_prot_info;
if (master->get_fact_prot_info)
slave->mtd.get_fact_prot_info = part_get_fact_prot_info;
if (master->sync)
slave->mtd.sync = part_sync;
if (!partno && master->suspend && master->resume) {
slave->mtd.suspend = part_suspend;
slave->mtd.resume = part_resume;
if (master->writev)
slave->mtd.writev = part_writev;
if (master->lock)
slave->mtd.lock = part_lock;
if (master->unlock)
slave->mtd.unlock = part_unlock;
if (master->block_isbad)
slave->mtd.block_isbad = part_block_isbad;
if (master->block_markbad)
slave->mtd.block_markbad = part_block_markbad;
slave->mtd.erase = part_erase;
slave->master = master;
slave->offset = part->offset;
slave->index = partno;
if (slave->offset == MTDPART_OFS_APPEND)
slave->offset = cur_offset;
if (slave->offset == MTDPART_OFS_NXTBLK) {
if ((cur_offset % master->erasesize) != 0) {
/* Round up to next erasesize */
slave->offset = ((cur_offset / master->erasesize) + 1) * master->erasesize;
printk(KERN_NOTICE "Moving partition %d: "
"0x%08x -> 0x%08xn", partno,
cur_offset, slave->offset);
if (slave->mtd.size == MTDPART_SIZ_FULL)
slave->mtd.size = master->size - slave->offset;
printk(KERN_NOTICE "0x%08x-0x%08x : "%s"n", slave->offset,
slave->offset + slave->mtd.size, slave->mtd.name);
/* let's do some sanity checks */
if (slave->offset >= master->size) {
/* let's register it anyway to preserve ordering */
slave->offset = 0;
slave->mtd.size = 0;
printk(KERN_ERR"mtd: partition "%s" is out of reach -- disabledn",
part->name);
goto out_register;
if (slave->offset + slave->mtd.size > master->size) {
printk(KERN_WARNING"mtd: partition "%s" extends beyond the end of device "%s" -- size truncated to %#xn",
part->name, master->name, slave->mtd.size);
if (master->numeraseregions > 1) {
/* Deal with variable erase size stuff */
int i, max = master->numeraseregions;
u32 end = slave->offset + slave->mtd.size;
struct mtd_erase_region_info *regions = master->eraseregions;
/* Find the first erase regions which is part of this
* partition. */
for (i = 0; i < max && regions[i].offset <= slave->offset; i++)
/* The loop searched for the region _behind_ the first one */
i--;
/* Pick biggest erasesize */
for (; i < max && regions[i].offset < end; i++) {
if (slave->mtd.erasesize < regions[i].erasesize) {
slave->mtd.erasesize = regions[i].erasesize;
BUG_ON(slave->mtd.erasesize == 0);
} else {
/* Single erase size */
slave->mtd.erasesize = master->erasesize;
if ((slave->mtd.flags & MTD_WRITEABLE) &&
(slave->offset % slave->mtd.erasesize)) {
/* Doesn't start on a boundary of major erase size */
/* FIXME: Let it be writable if it is on a boundary of
* _minor_ erase size though */
slave->mtd.flags &= ~MTD_WRITEABLE;
printk(KERN_WARNING"mtd: partition "%s" doesn't start on an erase block boundary -- force read-onlyn",
part->name);
(slave->mtd.size % slave->mtd.erasesize)) {
printk(KERN_WARNING"mtd: partition "%s" doesn't end on an erase block -- force read-onlyn",
上一篇:s3c6410的RTC在linux中的驱动(1)
下一篇:linux串口终端驱动——s3c6410平台(四)
推荐阅读最新更新时间:2024-10-26 21:28
设计资源 培训 开发板 精华推荐
- LTC6990HS6#TRMPBF 超声波扫频发生器的典型应用
- ESP32蓝牙键盘(四层)
- 201889218AD9846A,使用 AD9846、10 位、30 MSPS 串行输出模数转换器的评估板
- LT8303HS5 30 至 80 Vin、3.3Vout 隔离反激式转换器的典型应用电路
- CH340C
- 具有跟踪功能的 LTM4650AIY 2.5V 和 3.3V 输出的典型应用电路
- FAH4840 线性谐振驱动器 (LRA) 触觉驱动器的典型应用电路
- T12外壳面板
- AM1S-0515SH30Z 1W DC-DC转换器典型应用
- LT3756IUD 降压-升压模式 LED 驱动器的典型应用电路
