外部中断
中断就是主程序在正常执行时,CPU发出一个中断请求,然后程序就会跳到中断子程序去执行,执行完后会返回主程序。
一、概述
组成结构
1-15中断号用于系统异常
16开始是外部中断
1、GPIO引脚0对应的是外部中断0 2、一个中断对应了9个IO口(PA0~PA9) 3、同一时刻一个中断只能对应一个IO口,不能PA0链接了外部中断0,PB0再链接外部中断0 二、使用步骤 1.GPIO端口设置为外部中断输入----参考stm32f10x_gpio.c 代码如下(示例): void GPIO_Init(GPIO_TypeDef* GPIOx, GPIO_InitTypeDef* GPIO_InitStruct) 2.把引脚与EXIT0链接----参考stm32f10x_gpio.c 代码如下(示例): void GPIO_EXTILineConfig(uint8_t GPIO_PortSource, uint8_t GPIO_PinSource); 函数原型: /** * @brief Selects the GPIO pin used as EXTI Line. * @param GPIO_PortSource: selects the GPIO port to be used as source for EXTI lines. * This parameter can be GPIO_PortSourceGPIOx where x can be (A..G). * @param GPIO_PinSource: specifies the EXTI line to be configured. * This parameter can be GPIO_PinSourcex where x can be (0..15). * @retval None */ void GPIO_EXTILineConfig(uint8_t GPIO_PortSource, uint8_t GPIO_PinSource) { uint32_t tmp = 0x00; /* Check the parameters */ assert_param(IS_GPIO_EXTI_PORT_SOURCE(GPIO_PortSource)); assert_param(IS_GPIO_PIN_SOURCE(GPIO_PinSource)); tmp = ((uint32_t)0x0F) << (0x04 * (GPIO_PinSource & (uint8_t)0x03)); AFIO->EXTICR[GPIO_PinSource >> 0x02] &= ~tmp; AFIO->EXTICR[GPIO_PinSource >> 0x02] |= (((uint32_t)GPIO_PortSource) << (0x04 * (GPIO_PinSource & (uint8_t)0x03))); } 3.EXIT配置----参考stm32f10x_exti.c 代码如下(示例): void EXTI_Init(EXTI_InitTypeDef* EXTI_InitStruct); 1 EXTI_InitTypeDef 初始化结构体成员: /** * @brief EXTI Init Structure definition */ typedef struct { uint32_t EXTI_Line; /*中断线标号范围 0-15*/ EXTIMode_TypeDef EXTI_Mode; /*中断模式/事件模式*/ EXTITrigger_TypeDef EXTI_Trigger; /*中断触发方式 上升沿、下降沿、双边沿都触发*/ FunctionalState EXTI_LineCmd; /*中断线使能/不使能*/ }EXTI_InitTypeDef; ①中断模式 EXTIMode_TypeDef /** * @brief EXTI mode enumeration */ typedef enum { EXTI_Mode_Interrupt = 0x00,//中断 EXTI_Mode_Event = 0x04//事件 }EXTIMode_TypeDef; ②中断触发方式结构体 EXTITrigger_TypeDef /** * @brief EXTI Trigger enumeration */ typedef enum { EXTI_Trigger_Rising = 0x08,//上升沿触发 EXTI_Trigger_Falling = 0x0C,//下降沿 EXTI_Trigger_Rising_Falling = 0x10///*//双边沿都触发 }EXTITrigger_TypeDef; 4.NVIC中断优先级配置------参考misc.c 代码如下(示例): void NVIC_Init(NVIC_InitTypeDef* NVIC_InitStruct) 1 中断优先级管理结构体 NVIC_InitTypeDef /** * @brief NVIC Init Structure definition */ typedef struct { uint8_t NVIC_IRQChannel; /*使能按 键外部中断通道*/ uint8_t NVIC_IRQChannelPreemptionPriority; /*抢占优先级 2*/ uint8_t NVIC_IRQChannelSubPriority; /*响应优先级 2 */ FunctionalState NVIC_IRQChannelCmd; /*使能/不使能 */ } NVIC_InitTypeDef; 抢占优先级 EXIT0 最高优先级 /************************************************ 函数功能:中断0优先级配置函数 ************************************************/ void Nvic0_Config(void) { /*中断优先级配置*/ NVIC_InitTypeDef NVIC_InitStruct;//配置中断分组NVIC NVIC_InitStruct.NVIC_IRQChannel = EXTI0_IRQn; NVIC_InitStruct.NVIC_IRQChannelPreemptionPriority = 0x00; NVIC_InitStruct.NVIC_IRQChannelSubPriority = 0x00; NVIC_InitStruct.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStruct); } EXIT3------响应优先级2 /************************************************ 函数功能:中断3优先级配置函数 ************************************************/ void Nvic3_Config(void) { /*中断优先级配置*/ NVIC_InitTypeDef NVIC_InitStruct;//配置中断分组NVIC NVIC_InitStruct.NVIC_IRQChannel = EXTI3_IRQn; NVIC_InitStruct.NVIC_IRQChannelPreemptionPriority = 0x02; NVIC_InitStruct.NVIC_IRQChannelSubPriority = 0x02; NVIC_InitStruct.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStruct); } EXIT4—响应优先级1 /************************************************ 函数功能:中断4优先级配置函数 ************************************************/ void Nvic4_Config(void) { /*中断优先级配置*/ NVIC_InitTypeDef NVIC_InitStruct;//配置中断分组NVIC NVIC_InitStruct.NVIC_IRQChannel = EXTI4_IRQn; NVIC_InitStruct.NVIC_IRQChannelPreemptionPriority = 0x02;//抢占优先级 NVIC_InitStruct.NVIC_IRQChannelSubPriority = 0x01;//响应优先级 NVIC_InitStruct.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStruct); } EXIT3:绿灯 响应优先级0x01 EXIT4:红灯 0x02 外部中断0先按下,然后依次按下外部中断4,外部中断3,CPU记录下中断。 现象: LED绿灯亮起,后LED红灯亮起。 5.中断服务函数(中断后你想让CPU做的事情) 部分代码如下(示例): ; External Interrupts DCD WWDG_IRQHandler ; Window Watchdog DCD PVD_IRQHandler ; PVD through EXTI Line detect DCD TAMPER_IRQHandler ; Tamper DCD RTC_IRQHandler ; RTC DCD FLASH_IRQHandler ; Flash DCD RCC_IRQHandler ; RCC DCD EXTI0_IRQHandler ; EXTI Line 0 DCD EXTI1_IRQHandler ; EXTI Line 1 DCD EXTI2_IRQHandler ; EXTI Line 2 DCD EXTI3_IRQHandler ; EXTI Line 3 DCD EXTI4_IRQHandler ; EXTI Line 4 三、应用实例 EXIT.c /************************************************ 函数功能:中断初始化函数 ************************************************/ void EXIT_Init(void)//初始化 { RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE); //使能复用功能时钟 KEY_Init(); Exit9_5_Config(); Nvic_Config(); } /************************************************ 函数功能:EXIT中断配置函数 ************************************************/ void Exit9_5_Config(void) { //初始的结构体定义 EXTI_InitTypeDef EXTI_InitStruct;//中断初始化的结构体 //将引脚与中断链接 GPIO_EXTILineConfig(GPIO_PortSourceGPIOE,GPIO_PinSource4); EXTI_InitStruct.EXTI_Line = EXTI_Line4;//外部中断4 EXTI_InitStruct.EXTI_Mode = EXTI_Mode_Interrupt;//中断模式 EXTI_InitStruct.EXTI_Trigger = EXTI_Trigger_Falling;//任意电平 EXTI_InitStruct.EXTI_LineCmd = ENABLE;//使能 EXTI_Init(&EXTI_InitStruct); } /************************************************ 函数功能:中断优先级配置函数 ************************************************/ void Nvic_Config(void) { /*中断优先级配置*/ NVIC_InitTypeDef NVIC_InitStruct;//配置中断分组NVIC NVIC_InitStruct.NVIC_IRQChannel = EXTI2_IRQn; NVIC_InitStruct.NVIC_IRQChannelPreemptionPriority = 0x02; NVIC_InitStruct.NVIC_IRQChannelSubPriority = 0x02; NVIC_InitStruct.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStruct); } /************************************************ 函数功能:中断服务函数 ************************************************/ void EXTI4_IRQHandler(void) { //判断是否有中断请求 delay_ms(10);//消抖 if(PEin(4)==1) { PEout(5) = 0; } EXTI_ClearITPendingBit(EXTI_Line4); //清除LINE0上的中断标志位 } main.c /************************************************ 外部中断点亮LED ************************************************/ int main(void) { delay_init();//延时函数 LED_Init(); //KEY_Init(); EXIT_Init(); while(1) { } } 总结 注意: 1.要开启RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO,ENABLE); //使能复用功能时钟 2.将引脚链接到中断
上一篇:STM32笔记——GPIO
下一篇:STM32学习笔记--------时钟体系
推荐阅读最新更新时间:2024-11-13 17:18
设计资源 培训 开发板 精华推荐
- OP213FSZ-REEL精密称重传感器秤放大器的典型应用
- 【ART-Pi】NFC识别扩展板
- LTC1798CS8-5、2.5V 电池供电电压基准的典型应用电路
- 具有故障安全备用电源的 LTC4420CDD 优先级的典型应用电路
- A1321烙铁控制板
- LTC6263HMS 低功率、低失真 ADC 驱动器、运算放大器的典型应用
- 用于 CYPD5236-96BZXI USB Type-C 端口控制器的双端口坞站下游端口应用中的 CCG5
- SSM2380 用于 SSM2380 2X2 W、无滤波器、立体声、D 类音频放大器的典型 I2C 控制模式配置(MODE 引脚 = GND)电路
- 基于用于STM32 Nucleo的BLUENRG-M2SP模块的蓝牙低功耗扩展板
- LTC3624HMSE-3.3 3.3V 输出电压、2A 同步降压稳压器的典型应用,具有 800mA 突发钳位,fSW = 1MHz
- 科学家研发基于AI的身份验证工具 可保护车辆免受网络攻击威胁
- Microchip推出广泛的IGBT 7 功率器件组合,专为可持续发展、电动出行和数据中心应用而设计
- 面向未来驾驶体验 博世推出新型微电子技术
- 英飞凌与马瑞利合作 利用AURIX™ TC4x MCU系列推动区域控制单元创新
- 5C超充,该怎么卷?
- 《2025年度中国汽车十大技术趋势》正式揭晓!你最看好哪个?
- Microchip推出新型VelocityDRIVE™软件平台和车规级多千兆位以太网交换芯片,支持软件定义汽车
- 英特尔中国正式发布2023-2024企业社会责任报告
- can转485数据是如何对应的
- MCU今年的重点:NPU和64位
