STC15F2K60S2 16.384MHz
Keil uVision V5.29.0.0
PK51 Prof.Developers Kit Version:9.60.0.0
Python 3.8.11 (default, Aug 6 2021, 09:57:55) [MSC v.1916 64 bit (AMD64)] :: Anaconda, Inc. on win32
参考资料:
笔记:python读取串口数据并保到本地txt文件 —— 大头工程师笔记
最小二乘法拟合—基本原理 —— 铁头娃-wefly
硬知识
Python代码
if not 1: # 0为串口收集数据,1为椭球拟合
import serial
ser = serial.Serial(
port='COM8',
baudrate=1200,
parity=serial.PARITY_NONE, # 校验位
stopbits=serial.STOPBITS_ONE, # 停止位
bytesize=serial.EIGHTBITS # 数据位
First_Flag = 0
while True:
data = ser.readline()
if First_Flag: # 丢掉第一次的,避免写入半截数据
f = open('./Data.txt', 'a')
data = data.decode('utf-8')[:-1]
f.write(data)
f.close()
print(data)
First_Flag = 1
else:
Data_Path = r'./Data.txt'
f = open(Data_Path, 'r')
X = []
Y = []
Z = []
for _ in f:
List = _.replace(",", " ").split()
X.append(int(List[0]))
Y.append(int(List[1]))
Z.append(int(List[2]))
f.close()
from matplotlib.font_manager import FontProperties
from numpy.linalg import inv
from numpy import arange, zeros
from math import sqrt, sin, cos
from matplotlib import pyplot as plt
def dot_Mul(arr1, arr2):
return [a * b for a, b in zip(arr1, arr2)]
PI = 3.1415926535897932384626433832795
# 实测数据
x = []
y = []
z = []
for _ in f:
x.append(int(List[0]))
y.append(int(List[1]))
z.append(int(List[2]))
f.close()
# 数据总数
num_points = len(x)
# 一次项均值
x_avr = sum(x) / num_points
y_avr = sum(y) / num_points
z_avr = sum(z) / num_points
# 二次项均值
xx_avr = sum(dot_Mul(x, x)) / num_points
yy_avr = sum(dot_Mul(y, y)) / num_points
zz_avr = sum(dot_Mul(z, z)) / num_points
xy_avr = sum(dot_Mul(x, y)) / num_points
xz_avr = sum(dot_Mul(x, z)) / num_points
yz_avr = sum(dot_Mul(y, z)) / num_points
# 三次项均值
xxx_avr = sum(dot_Mul(dot_Mul(x, x), x)) / num_points
xxy_avr = sum(dot_Mul(dot_Mul(x, x), y)) / num_points
xxz_avr = sum(dot_Mul(dot_Mul(x, x), z)) / num_points
xyy_avr = sum(dot_Mul(dot_Mul(x, y), y)) / num_points
xzz_avr = sum(dot_Mul(dot_Mul(x, z), z)) / num_points
yyy_avr = sum(dot_Mul(dot_Mul(y, y), y)) / num_points
yyz_avr = sum(dot_Mul(dot_Mul(y, y), z)) / num_points
yzz_avr = sum(dot_Mul(dot_Mul(y, z), z)) / num_points
zzz_avr = sum(dot_Mul(dot_Mul(z, z), z)) / num_points
# 四次项均值
yyyy_avr = sum(dot_Mul(dot_Mul(dot_Mul(y, y), y), y)) / num_points
zzzz_avr = sum(dot_Mul(dot_Mul(dot_Mul(z, z), z), z)) / num_points
xxyy_avr = sum(dot_Mul(dot_Mul(dot_Mul(x, x), y), y)) / num_points
xxzz_avr = sum(dot_Mul(dot_Mul(dot_Mul(x, x), z), z)) / num_points
yyzz_avr = sum(dot_Mul(dot_Mul(dot_Mul(y, y), z), z)) / num_points
# 系数矩阵
A_Matrix = [[yyyy_avr, yyzz_avr, xyy_avr, yyy_avr, yyz_avr, yy_avr],
[yyzz_avr, zzzz_avr, xzz_avr, yzz_avr, zzz_avr, zz_avr],
[xyy_avr, xzz_avr, xx_avr, xy_avr, xz_avr, x_avr],
[yyy_avr, yzz_avr, xy_avr, yy_avr, yz_avr, y_avr],
[yyz_avr, zzz_avr, xz_avr, yz_avr, zz_avr, z_avr],
[yy_avr, zz_avr, x_avr, y_avr, z_avr, 1]]
# 等式右边的常数项矩阵
B_Matrix = [[-xxyy_avr], [-xxzz_avr], [-xxx_avr], [-xxy_avr], [-xxz_avr], [-xx_avr]]
result = inv(A_Matrix) @ B_Matrix
xo = -result[2] / 2 # 拟合出的x坐标
yo = -result[3] / (2 * result[0]) # 拟合出的y坐标
zo = -result[4] / (2 * result[1]) # 拟合出的z坐标
# 拟合出的x方向上的轴半径
A = sqrt(xo * xo + result[0] * yo * yo + result[1] * zo * zo - result[5])
# 拟合出的y方向上的轴半径
B = A / sqrt(result[0])
# 拟合出的z方向上的轴半径
C = A / sqrt(result[1])
ABC_avr = (A + B + C) / 3
kA = ABC_avr / A
kB = ABC_avr / B
kC = ABC_avr / C
xo = xo[0]
yo = yo[0]
zo = zo[0]
print("拟合结果: ")
print("xo = ", xo) # 椭球球心x坐标
print("yo = ", yo) # 椭球球心y坐标
print("zo = ", zo) # 椭球球心z坐标
print("A = ", A) # 拟合出的x方向上的轴半径
print("B = ", B) # 拟合出的y方向上的轴半径
print("C = ", C) # 拟合出的z方向上的轴半径
print("kA = ", kA)
print("kB = ", kB)
print("kC = ", kC)
num_alpha = 90
num_sita = 45
alfa = arange(0, num_alpha) * 1 * PI / num_alpha
sita = arange(0, num_sita) * 2 * PI / num_sita
X = zeros((num_alpha, num_sita))
Y = zeros((num_alpha, num_sita))
Z = zeros((num_alpha, num_sita))
for i in range(0, num_alpha):
for j in range(0, num_sita):
X[i, j] = xo + A * sin(alfa[i]) * cos(sita[j])
Y[i, j] = yo + B * sin(alfa[i]) * sin(sita[j])
Z[i, j] = zo + C * cos(alfa[i])
X = [i for arr in X for i in arr]
Y = [i for arr in Y for i in arr]
Z = [i for arr in Z for i in arr]
fig = plt.figure()
Font = FontProperties(fname=r"c:windowsfontssimsun.ttc", size=20)
ax1 = fig.add_subplot(221, projection='3d')
ax1.set_title('实测、拟合对比', fontproperties=Font)
ax1.scatter3D(X, Y, Z) # 拟合
ax1.scatter3D(x, y, z) # 实测
ax2 = fig.add_subplot(222)
ax2.set_title('x-y投影', fontproperties=Font)
ax2.scatter(X, Y)
ax2.scatter(x, y)
ax3 = fig.add_subplot(223)
ax3.set_title('x-z投影', fontproperties=Font)
ax3.scatter(X, Z)
ax3.scatter(x, z)
ax4 = fig.add_subplot(224)
ax4.set_title('y-z投影', fontproperties=Font)
ax4.scatter(Y, Z)
ax4.scatter(y, z)
plt.show()
使用方法
HMC5883L、QMC5883L的驱动程序见【51单片机快速入门指南】4.4:I2C 读取HMC5883L / QMC5883L 磁力计
串口收集数据
转动板子到各个角度
当觉得收集够时停止脚本
椭球拟合
开始椭球拟合
得到拟合结果:
验证
将计算结果用于矫正输出
清理掉旧数据后重新收集并拟合,得到如下结果,可见新的球心偏移较未矫正前小,且得到的椭球更接近正球。
上一篇:【51单片机快速入门指南】4.4.2:Mahony AHRS 九轴姿态融合获取四元数、欧拉角
下一篇:【51单片机快速入门指南】4.4:I2C 读取HMC5883L / QMC5883L 磁力计
推荐阅读最新更新时间:2024-11-12 10:47
设计资源 培训 开发板 精华推荐
- Si3000SSI-EVB,用于无线语音音频的 16 位音频编解码器评估套件
- 高速USB3.0共享器 四进四出选择 HUB+切换器
- ZXLD1374 60V 高精度 1.5A 降压-升压 LED 驱动器转换器的典型应用
- DC814A-G,使用 LTC6908-1 17MHz 至 170MHz 固定频率硅振荡器的演示板
- 使用 Cypress Semiconductor 的 CY8C27143-24PI 的参考设计
- 使用 Analog Devices 的 LTC1458LISW 的参考设计
- TM4C123G全面屏1.14寸核心板tiva
- LDK120M25R 2.5V低压降稳压器典型应用固定电路
- 磁吸开发板收纳塔
- 使用 Diodes Incorporated 的 PT8A 3519CPE 的参考设计
- 邀请小伙伴一起学AM437x,好礼有你!
- 【已结束】力源直播【安森美 25KW 充电桩模块方案】(9:30入场)
- 高性能手机设计如何实现?手机高校评估研讨会为您揭晓答案!
- 有奖直播:远近皆宜的无线连接方案 3月25日(周四)上午10:00 邀您观看!
- 【抢楼】正式开始!来抢TI LM3S811评估板吧!!!
- EEworld新春感恩回馈之ST新出道“高富帅”STM32F746G-DISCO 199元包邮
- 【MPS有奖评论】一起聊聊选型的那些过往
- 了解PI InnoSwitch-CE,答题赢好礼
- 富士通白皮书有奖下载|FRAM高性能存储器优化车载电子系统
- 提交WEBENCH设计,就能参与转盘抽奖!
